    2. English
    3. ioBroker general
    4. Sonoff Zigbee 3.0 Dongle E
      ap2017 last edited by ap2017
      Do I need to flash Sonoff Zigbee 3.0 Dongle E with any specific firmware to work with iobroker? I tried non-flashed dongle and it seems to be working after I set proper communication port and type to Silicon Labs.
      • David G.
        David G. @ap2017 last edited by David G.
        @ap2017
        The stick usually comes with the correct firmware. If everything works, then it's good.
        The P is more common here in the forum, you can also find some instructions for flashing here.
          ap2017 @David G. last edited by
          @david-g Thanks. I've noticed that on Silabs Firmware Flasher sire https://darkxst.github.io/silabs-firmware-builder/ there are few versions of firmware for -E adapter in addition to latest Sonoff version, Is there any advantage using one of these?
          David G. arteck 2 Replies Last reply Reply Quote 0
          • David G.
            @ap2017
            Ezsp is the normal firmware. This is required for zigbee. I don't know if it works with Multipan, Thread is not yet supported by iobroker. If it comes soon, I don't know if zigbee and Thread can run on one stick.
              arteck Developer Most Active @ap2017 last edited by arteck
              @ap2017 you can follow the project zigbee2mqtt..
              if it works there..then we look here if is it possible
              FYI : the dongle E does not support nvbackup function..
              sonoff zigbee dongle
