    4. Node-Red
    5. Forecast Ergebnisse addieren
    • Nefetz
      Nefetz last edited by
      Hallo zusammen!
      Hat jemand eine Idee , wie ich die 3 forecast Ergebnisse in NodeRed addiert bekomme?
      • mickym
        mickym Most Active @Nefetz last edited by mickym
        @nefetz ah du hast schon alles richtig gemacht. Lass mal diese blöde function Node weg und rechne das Ganze mit einer Change Node aus.
        Hier zum Import
        [{"id":"2d9097cfea125152","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"solar","tot":"flow"},{"t":"set","p":"payload","pt":"msg","to":"$sum(payload.*)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":5480,"wires":[["1f803c8a56d7fd8a"]]},{"id":"56826b1da656a934","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Ost","payload":"3227","payloadType":"num","x":260,"y":5480,"wires":[["10f9a9866ebbf5cb"]]},{"id":"43fcc2624bea9df1","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"West","payload":"3851","payloadType":"num","x":260,"y":5560,"wires":[["8cba3160bd1d1888"]]},{"id":"e597068edcb68144","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Süd","payload":"3818","payloadType":"num","x":260,"y":5520,"wires":[["3c147ff6bf76f324"]]},{"id":"10f9a9866ebbf5cb","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"solar.Ost","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":5480,"wires":[["e32bb31d6a802a41"]]},{"id":"3c147ff6bf76f324","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"solar.Süd","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":5520,"wires":[["e32bb31d6a802a41"]]},{"id":"8cba3160bd1d1888","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"solar.West","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":5560,"wires":[["e32bb31d6a802a41"]]},{"id":"1f803c8a56d7fd8a","type":"debug","z":"289f539dcc33814e","name":"Summe","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":980,"y":5480,"wires":[]},{"id":"885d4a2cfe457563","type":"function","z":"289f539dcc33814e","name":"Wenn es unbedingt sein muss ...","func":"var solar= flow.get(\"solar\");\nmsg.payload = solar.Ost + solar.Süd + solar.West;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":5540,"wires":[["7db50b242637c8e3"]]},{"id":"7db50b242637c8e3","type":"debug","z":"289f539dcc33814e","name":"Summe Function Node","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1100,"y":5540,"wires":[]},{"id":"e32bb31d6a802a41","type":"junction","z":"289f539dcc33814e","x":620,"y":5520,"wires":[["2d9097cfea125152","885d4a2cfe457563"]]}]
        und wenn Du unbedingt JS Code schreiben willst - was ich persönlich ja überhaupt nicht verstehe, dann halt so:
        var solar= flow.get("solar");
        return msg;
        Nefetz 1 Reply Last reply Reply Quote 0
        • Nefetz
          Nefetz @mickym last edited by Nefetz
          @mickym
          Danke für deine Antwort!
          Ich habe jetzt einfach mal den change node von dir bei meinem flow eingefügt , aber dann kommt diese Fehlermeldung:
          Bildschirmfoto vom 2024-04-06 14-27-34.png Bildschirmfoto vom 2024-04-06 14-27-37.png
          • mickym
            @nefetz ich sehe keine - zeig mal deinen Kontext?
            • Nefetz
              @mickym
              Sorry, den wichtigsten screen vergessen.
              • mickym
                @nefetz Ja dann sind entweder noch nicht alle Felder belegt oder es ist keine Zahl drin (hast Du alle Inject Nodes betätigt?) - zeig mal deinen Kontext
                • Nefetz
                  @mickym Was meinste mit Kontext?
                  • mickym
                    @nefetz Na wo Deine Variablen drin stehen.
                    Falls Du den Kontext nicht findest - das Menü aufklappen:
                    Und immer auf aktualisieren klicken!
                    Prüfe, ob da auch Zahlen drin stehen und betätige alle Inject Nodes um Dir ALLE Solarwerte abzuholen - ggf. lösche Deine Solarvariable nochmal.
                    Ansonsten ist irgendwas anderes faul - dann importiere meinen gesamten Flow und hänge Deine Nodes vorne dran.
                    Wenn aus Deinen Forecast Nodes keine Zahl rauskommt, dann musst Du das ggf. abfangen.
                    • Nefetz
                      @mickym
                      Ich habe jetzt deinen Flow verwendet.
                      Habe alle inject nodes angestoßen.
                      Keine Werte.
                      Wenn ich einen funktion node da noch einbaue kann ich die Werte abfangen. allerdings sind die dann einzeln.
                      • mickym
                        na das sind ja objekte und keine Zahlen die du schreibst. zeig mal das objekt, das aus den nodes kommt. Alternativ schreibe die Ergebnisse der function node in solar.Ost etc.
                        Also setze die 3 function nodes 3 mal direkt hinter die solarforecast nodes.
                        • Nefetz
                          @mickym
                          Könntest du mit anydesk mal drüber schauen?
                          • mickym
                            @nefetz Nein VOR die Change NOdes - die function Nodes direkt hinter die solar forecast nodes!!!
                            • Nefetz
                              @mickym
                              Vielen Dank, es hat somit geklappt!
                              • mickym
                                @nefetz JA viel Spaß und ein schönes Wochenende.
                                • Nefetz
                                  @mickym Das wünsch ich dir auch 👍
                                  812
