    4. SONOS Adapter Abstürze (wegen Move2?)
    • NinjaTurtle85
      NinjaTurtle85 last edited by
      Mein Sonos Adapter stürtzt ständig ab:
      2024-04-08 16:10:11.550 - warn: admin.0 (825) sonos has an invalid jsonConfig: [{"instancePath":"/items/devicesTab/items/_sendto","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"timeout"},"message":"must NOT have additional properties"},{"instancePath":"/items/devicesTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      2024-04-08 16:10:11.747 - info: sonos.0 (180242) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v20.12.1, js-controller: 5.0.19
      2024-04-08 16:10:12.871 - error: sonos.0 (180242) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-04-08 16:10:12.872 - error: sonos.0 (180242) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
      2024-04-08 16:10:12.873 - error: sonos.0 (180242) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
      at NotificationListener.notificationHandler (/opt/iobroker/node_modules/sonos-discovery/lib/models/Player.js:370:25)
      at NotificationListener.emit (node:events:530:35)
      at /opt/iobroker/node_modules/sonos-discovery/lib/NotificationListener.js:125:17
      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      2024-04-08 16:10:12.873 - error: sonos.0 (180242) Cannot read properties of undefined (reading 'recalculateGroupVolume')
      2024-04-08 16:10:12.879 - info: sonos.0 (180242) terminating
      2024-04-08 16:10:12.883 - info: sonos.0 (180242) terminating
      2024-04-08 16:10:12.884 - warn: sonos.0 (180242) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-04-08 16:10:12.889 - error: sonos.0 (180242) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-04-08 16:10:12.889 - error: sonos.0 (180242) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
      2024-04-08 16:10:12.890 - error: sonos.0 (180242) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
      2024-04-08 16:10:12.890 - error: sonos.0 (180242) Cannot read properties of undefined (reading 'recalculateGroupVolume')
      2024-04-08 16:10:12.894 - error: sonos.0 (180242) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-04-08 16:10:12.894 - error: sonos.0 (180242) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
      2024-04-08 16:10:12.894 - error: sonos.0 (180242) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
      2024-04-08 16:10:12.895 - error: sonos.0 (180242) Cannot read properties of undefined (reading 'recalculateGroupVolume')
      2024-04-08 16:10:13.386 - info: sonos.0 (180242) terminating
      2024-04-08 16:10:13.518 - error: host.IoBroker instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-04-08 16:10:13.519 - info: host.IoBroker Restart adapter system.adapter.sonos.0 because enabled
      Ich würde behaupten das dass Problem erst mit dem Sonos Move 2 anfing.
      Hat jemad eine Idee woran es liegen kann?
      • DJMarc75
        DJMarc75 @NinjaTurtle85 last edited by
        @ninjaturtle85 sagte in SONOS Adapter Abstürze (wegen Move2?):
        node: v20.12.1
        warum zu aktuell ?
        Geh da mal auf was aktuell Empfohlenes zurück und dann schau mal 😉
        NinjaTurtle85 1 Reply Last reply Reply Quote 0
        • NinjaTurtle85
          NinjaTurtle85 @DJMarc75 last edited by
          @djmarc75 nope, leider keine Besserung:
          2024-04-08 16:36:22.883 - info: host.IoBroker "system.adapter.sonos.0" enabled
          2024-04-08 16:36:23.188 - info: host.IoBroker instance system.adapter.sonos.0 started with pid 2283
          2024-04-08 16:36:24.436 - info: sonos.0 (2283) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.20.1, js-controller: 5.0.19
          2024-04-08 16:37:18.542 - info: host.IoBroker stopInstance system.adapter.sonos.0 (force=false, process=true)
          2024-04-08 16:37:18.545 - info: sonos.0 (2283) Got terminate signal TERMINATE_YOURSELF
          2024-04-08 16:37:18.546 - info: sonos.0 (2283) terminating
          2024-04-08 16:37:18.548 - info: sonos.0 (2283) terminating
          2024-04-08 16:37:18.550 - info: sonos.0 (2283) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-04-08 16:37:18.775 - info: host.IoBroker stopInstance system.adapter.sonos.0 send kill signal
          2024-04-08 16:37:19.051 - info: sonos.0 (2283) terminating
          2024-04-08 16:37:19.178 - info: host.IoBroker instance system.adapter.sonos.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-04-08 16:37:22.082 - info: host.IoBroker instance system.adapter.sonos.0 started with pid 2315
          2024-04-08 16:37:24.787 - info: sonos.0 (2315) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.20.1, js-controller: 5.0.19
          2024-04-08 16:37:26.430 - error: sonos.0 (2315) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-04-08 16:37:26.430 - error: sonos.0 (2315) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
          2024-04-08 16:37:26.431 - error: sonos.0 (2315) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
          at NotificationListener.emit (node:events:529:35)
          2024-04-08 16:37:26.431 - error: sonos.0 (2315) Cannot read properties of undefined (reading 'recalculateGroupVolume')
          2024-04-08 16:37:26.440 - info: sonos.0 (2315) terminating
          2024-04-08 16:37:26.443 - info: sonos.0 (2315) terminating
          2024-04-08 16:37:26.444 - warn: sonos.0 (2315) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-04-08 16:37:26.453 - error: sonos.0 (2315) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-04-08 16:37:26.453 - error: sonos.0 (2315) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
          2024-04-08 16:37:26.453 - error: sonos.0 (2315) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
          2024-04-08 16:37:26.453 - error: sonos.0 (2315) Cannot read properties of undefined (reading 'recalculateGroupVolume')
          2024-04-08 16:37:26.945 - info: sonos.0 (2315) terminating
          2024-04-08 16:37:27.069 - error: host.IoBroker instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2024-04-08 16:37:27.069 - info: host.IoBroker Restart adapter system.adapter.sonos.0 because enabled
          • NinjaTurtle85
            bei neuinstallation des Sonos Adapters warnt der Admin Adapter:
            	2024-04-08 17:04:19.609	warn	sonos has an invalid jsonConfig: [{"instancePath":"/items/devicesTab/items/_sendto","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"timeout"},"message":"must NOT have additional properties"},{"instancePath":"/items/devicesTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
              Wildbill @NinjaTurtle85 last edited by
              @ninjaturtle85 Das warning kommt momentan bei so gut wie jedem Adapter (bei vielen) und hat keine Auswirkungen auf die Funktion. Ist nur kosmetischer Natur und hat mit eventuellen Fehlern nichts zu tun.
              Gruss, Jürgen
