    4. NodeRed fkt. nicht nach Node.js Update auf 18.20.2
    • surfer09
      surfer09 last edited by
      nach dem Node.js Update auf 18.20.2 startet NodeRed nicht mehr bei mir. Kann jemand helfen?
      Mit 18.20.0 funktionierte noch alles.
      2024-04-11 15:28:36.531 - error: node-red.0 (3356) Node-RED: 11 Apr 15:28:36 - [error] Failed to start server:
      2024-04-11 15:28:36.531 - error: node-red.0 (3356) Node-RED: 11 Apr 15:28:36 - [error] Error: spawn EINVAL
      at ChildProcess.spawn (node:internal/child_process:414:11)
      at spawn (node:child_process:761:9)
      at Object.execFile (node:child_process:351:17)
      at I:\ioBroker\node_modules\@node-red\registry\lib\installer.js:581:27
      at new Promise ()
      at Object.checkPrereq (I:\ioBroker\node_modules\@node-red\registry\lib\installer.js:580:16)
      at Object.load (I:\ioBroker\node_modules\@node-red\registry\lib\index.js:59:22)
      at I:\ioBroker\node_modules\@node-red\runtime\lib\index.js:162:29
      2024-04-11 15:28:39.553 - info: host.IOBroker-Server "system.adapter.node-red.0" disabled
      2024-04-11 15:28:39.553 - info: host.IOBroker-Server stopInstance system.adapter.node-red.0 (force=false, process=true)
      2024-04-11 15:28:42.216 - error: node-red.0 (3356) Node-RED: 11 Apr 15:28:42 - [error] Failed to start server:
      2024-04-11 15:28:42.216 - error: node-red.0 (3356) Node-RED: 11 Apr 15:28:42 - [error] Error: spawn EINVAL
      at new Promise ()
      2024-04-11 15:28:44.556 - info: host.IOBroker-Server stopInstance timeout 5000 system.adapter.node-red.0 killing pid 3356
      2024-04-11 15:28:44.599 - warn: host.IOBroker-Server instance system.adapter.node-red.0 terminated due to SIGTERM
      2024-04-11 15:28:44.599 - info: host.IOBroker-Server instance system.adapter.node-red.0 terminated with code null ()
      • Adaptername: Node Red
      • Adapterversion: 5.2.0
      • js-controller Version: 5.0.19
      • Admin Version: 6.13.16
      • Hardwaresystem: NUC
      • Arbeitsspeicher: 12 GB
      • Festplattenart: SD-Karte, SSD, HDD, ...
      • Betriebssystem: Windows 10
      • Nodejs-Version: v18.20.2
      • NPM-Version: 10.5.0
      Gruß surfer 😉
      • haus-automatisierung
        haus-automatisierung Developer Most Active @surfer09 last edited by haus-automatisierung
        @surfer09 Spannend, weil 18.20.2 genau da eine "Sicherheitslücke" unter Windows geschlossen hat: https://nodejs.org/en/blog/vulnerability/april-2024-security-releases-2/
        Command injection via args parameter of child_process.spawn without shell option enabled on Windows (CVE-2024-27980) - (HIGH)
        Und genau diese Funktionen (process.spawn) werden genutzt um den Node-RED Prozess zu starten. Scheinbar muss man irgendwelche Flags setzen, um Prozesse starten zu dürfen (?). Müsste ich mir in Ruhe anschauen, aber mir fehlt dazu gerade etwas die Zeit.
        Am besten auf GitHub melden.
        Hier ist der Commit in node dazu: https://github.com/nodejs/node/commit/6627222409
        0 bnoordhuis committed to nodejs/node
        src: disallow direct .bat and .cmd file spawning
        An undocumented feature of the Win32 CreateProcess API allows spawning
        batch files directly but is potentially insecure because arguments are
        not escaped (and sometimes cannot be unambiguously escaped), hence why
        they are refused starting today.
        PR-URL: https://github.com/nodejs-private/node-private/pull/564
        Reviewed-By: Benjamin Gruenbaum <benjamingr@gmail.com>
        Reviewed-By: Rafael Gonzaga <rafael.nunu@hotmail.com>
        CVE-ID: CVE-2024-27980
        • surfer09
          surfer09 @haus-automatisierung last edited by
          @haus-automatisierung So ein Mist, und ich tappe da auch noch in die Falle... 😞 Hoffentlich gibt's da schnelle Hilfe zu.
            @surfer09 Ich bin momentan etwas ratlos, was da falsch sein könnte. Wie ich es verstanden habe, dürfen nur keine batch-Dateien direkt gestartet werden (?) Und das passiert hier ja nicht:
            https://github.com/ioBroker/ioBroker.node-red/blob/2da922e99894fa5e37da91d3169becacef95fcb4/main.js#L238-L251C41
            surfer09 1 Reply Last reply Reply Quote -1
            • surfer09
              @haus-automatisierung Ich habe auf Github mal ein Issue erstellt. Habe ich zwar noch nicht so oft gemacht, ich hoffe man kann damit etwas anfangen :-).
                @surfer09 Wo denn? Gehört hier hin: https://github.com/ioBroker/ioBroker.node-red/issues
                Aber eventuell ist das auch ein Bug von Node-Red. Laut Stack crasht das hier:
                https://github.com/node-red/node-red/blob/9a3cb0b2b55fc018d7bc450081332b5180a2c7c5/packages/node_modules/%40node-red/registry/lib/installer.js#L581-L594
                Das Problem ist, dass der Befehl hier unter Windows mit .cmd endet:
                https://github.com/node-red/node-red/blob/9a3cb0b2b55fc018d7bc450081332b5180a2c7c5/packages/node_modules/%40node-red/registry/lib/installer.js#L28
                  haus-automatisierung Developer Most Active last edited by
                  Liegt also nicht an ioBroker, sondern an Node-RED. Habe hier reported:
                  https://github.com/node-red/node-red/issues/4653
                  klein0r created this issue in node-red/node-red
                  closed Unable to start with latest node version on Windows (tested with 18.20.2) - CVE-2024-27980 #4653
                  • surfer09
                    Ob wohl heute noch ein Update kommt? Scheinbar wird ja schon dran gearbeitet..
                      @surfer09 Ja. Fixed in Node-RED 3.1.9
                      • surfer09
                        @haus-automatisierung Nochmal eine blöde Frage... Der Adapter für den IOBroker bekommt jetzt auch noch ein Update? Da bin ich auf Version 5.2.0. Wie bekomme ich denn da jetzt die aktuellste Version?
                        ? Thomas Braun haus-automatisierung 4 Replies Last reply Reply Quote 0
                          A Former User @surfer09 last edited by
                          @surfer09 Hallo, besteht das Problem noch? Oder läuft wieder alles?
                            @surfer09 Bei mir kam das Problem auf durch den Wechsel von node 18.20.1 nach 18.20.2. Habe einfach wieder nach 18.19.0 gewechselt - weil da alles noch bestens lief - und gut wars. Wenn eine Umgebung 365x24 laufen muss, ist einfach wichtig, was hilft, nicht wer Schuld war - das kommt, wenn wieder alles läuft 🙂
                              Homoran Global Moderator Administrators @Guest last edited by
                              @hk30 sagte in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
                              und gut wars
                              nicht unbedingt!
                              18.20.2 enthält einen Sicherheitspatch
                                Thomas Braun Most Active @Guest last edited by Thomas Braun
                                @hk30 Und damit reißt du dir die mit den Versionen 18.20.x beseitigten Sicherheitslücken wieder auf.
                                Also keine clevere Idee.
                                node-red 3.1.9 ist ja wohl wieder kompatibel mit aktuellem nodejs. Also musst du das UPDATEN und nicht nodejs kaputt machen.
                                Kommt ganz easy auf ein aktuelles System:
                                echad@chet:/opt/iobroker $ npm ls node-red
                                iobroker.inst@3.0.0 /opt/iobroker
                                `-- iobroker.node-red@5.2.0
                                  `-- node-red@3.1.9
                                ? 2 Replies Last reply Reply Quote 1
                                  A Former User @Thomas Braun last edited by
                                  @thomas-braun schon klar. Ein patch hilft (fast) immer. Und was war vor oder bis zum patch? Stillstand tut eben mehr weh. Weiss man vielleicht nicht auf Bastellösungen.
                                    @thomas-braun ich bin in letzter Zeit seh vorsichtig geworden mit der patcherei. Diesmal hab ich ziemlich sicher gewusst, welcher "patch" es wieder mal war. Jetzt gilt: Solange es läuft - alles gut. Man kennt ja den Spruch: Never touch a running system. Und wenn man seine Umgebung in Richtung Inet nicht zu offen oder sogar geschlossen hat, gibt es wenig Sicherheitslücken.
                                    Samson71 Thomas Braun 2 Replies Last reply Reply Quote 0
                                      Du meinst deine verbastelte, mit Sicherheitslücken versehene Frickelbude? Dann weißt du ja jetzt wie es besser geht.
                                      Downgrades sind nie eine gute Idee, aktuelle stabile Versionen sind für ein stabiles System zu verwenden.
                                      • Samson71
                                        Samson71 Global Moderator @Guest last edited by
                                        Eine der schlimmsten und dümmsten Aussagen ever und gerade aktuell hier in der letzten Zeit immer wieder aufs Neue sinnlos proklamiert und vorgelebt. Geheult wird dann aber immer und um Hilfe gebettelt, wenn das System zu alt und völlig versumpft ist für weitere Updates.
                                          Und genau der Spruch ist der Oberschwachsinn schlechthin.
                                          ? 1 Reply Last reply Reply Quote 1
                                            @thomas-braun also hilfe gibts hier scheinbar nicht, nur dumme sprüche - ich wollte surfer09 helfen - mit meiner Lösung. Von den schlauen Leuten hier gab es keine Hilfe - ausser starken Sprüchen - kann man sich also schenken. Viel Spass ihr sicheren Bastler 🙂
                                            1.1k
                                            49
                                            3972
