    2. English
    4. Why are directories missing after Ubuntu installation?
      BobbyBraun last edited by
      What's the trick to get this running on Ubuntu without a container, just direct install? After I install, there's nothing in the browser on the localhost and there's a lot missing in the iobroker directory. iobroker.js is missing, as well as sub-directories leading to its location, etc.
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      Distributor ID: Ubuntu
      Description: Ubuntu 20.04.6 LTS
      Release: 20.04
      Codename: focal
      Thinkpad E14 i5 8gb 256gb
      node -v : v18.20.2
      npm version : 10.5.2
      I tried two different scripts. Same results.
        Homoran Global Moderator Administrators @BobbyBraun last edited by
        @bobbybraun sagte in Why are directories missing after Ubuntu installation?:
        no trick!
        it should work out of the Box.
        I don't use Ubuntu, just debian. But there should be no difference.
        which scripts?
        it's just one line!
          BobbyBraun @Homoran last edited by
          @homoran Of course, the solution comes to me after I post. I was colliding with Portainer. I shut down Portainer because i had errors during iobroker install that something was amiss with port 9001 and since Portainer is port 9000 I had my suspicions. I shut it down by closing docker, because signing out of it did not shut it off. Ran the oneline script for iobroker again and after that, it responded on port 8081. Now I will look into how to modify the docker command for change the port for portainer. Thank you for replying and have a great weekend.
            Homoran Global Moderator Administrators @BobbyBraun last edited by Homoran
            why that?
            you told
            so, what is your real environment?
            you didn't mention Docker at all
