    4. vedirect keine Verbindung bei rasp 4
      mere13 last edited by
      Hallo
      nachdem vedirect von DrotmotiX am rasp 3b problemlos lief zusammen mit dem USB Kabel von victroenic (Bluesolar MPTT 100/50) bin ich auf rasp 4 umgestiegen und hab alles genauso installiert. iobroker und Adapter. Leider keine Verbindung zum USB. Hat jemand eine Idee, woran das liegt? Ein paar Details:
      Get error "Issue handling serial port connection : {}" and no connection to USB. power supply is no problem, because active usb hub. also tried without hub. same result. MPTT Bluesolar 100/50, ve.direct USB
      settings are /dev/ttyUSB0 , both times on 0sec
      is there an issue with rasp 4? any idea?
      These are my usb devices:
      usb-devices
      T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
      😧 Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
      P: Vendor=1d6b ProdID=0002 Rev=06.06
      S: Manufacturer=Linux 6.6.20+rpt-rpi-v8 xhci-hcd
      S: Product=xHCI Host Controller
      S: SerialNumber=0000:01:00.0
      😄 #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
      I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
      E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
      T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
      😧 Ver= 2.10 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
      P: Vendor=2109 ProdID=3431 Rev=04.21
      S: Product=USB2.0 Hub
      😄 #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
      E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
      T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=01 Dev#= 3 Spd=480 MxCh= 4
      😧 Ver= 2.00 Cls=09(hub ) Sub=00 Prot=02 MxPS=64 #Cfgs= 1
      P: Vendor=05e3 ProdID=0610 Rev=92.24
      S: Manufacturer=GenesysLogic
      I: If#= 0 Alt= 1 #EPs= 1 Cls=09(hub ) Sub=00 Prot=02 Driver=hub
      T: Bus=01 Lev=03 Prnt=03 Port=03 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
      😧 Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
      P: Vendor=0403 ProdID=6015 Rev=10.00
      S: Manufacturer=VictronEnergy BV
      S: Product=VE Direct cable
      S: SerialNumber=VE6WATIJ
      😄 #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=90mA
      I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
      E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
      E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
      T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 4
      😧 Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
      P: Vendor=1d6b ProdID=0003 Rev=06.06
      Versions:
      Adapter version: recent
      JS-Controller version: 5.0.19
      Node version: 18.20.2
      Operating system: rasp OS 64 bit
        Homoran Global Moderator Administrators @mere13 last edited by
        @mere13 sagte in vedirect keine Verbindung bei rasp 4:
        incl. des identischen USB Ports?
        wie sieht die config aus?
        was ergibt bei dir
        pi@tinkerboard:~$ ls /dev/serial/by-id/
        usb-FTDI_FT232R_USB_UART_A10NBMVW-if00-port0
        usb-FTDI_FT232R_USB_UART_AB0OH9QR-if00-port0
        usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01066523-if00-port0
        pi@tinkerboard:~$
          Thomas Braun Most Active @mere13 last edited by
          Setz da den Link aus /dev/serial/by-id rein, nicht die Gerätedatei direkt.
            mere13 @Thomas Braun last edited by
            @thomas-braun marcel@rasp:~ $ ls /dev/serial/by-id
            usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
            und was soll ich jetzt einsetzen?
              Homoran Global Moderator Administrators @mere13 last edited by Homoran
              genau das
              /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
              so wie hier
                leider nicht besser
                Bildschirmfoto 2024-04-14 um 10.37.40.png Bildschirmfoto 2024-04-14 um 10.37.53.png
                Thomas Braun M 2 Replies Last reply Reply Quote 0
                  @mere13
                  Zeig mal die Langfassung von
                  iob diag
                    mere13 @mere13 last edited by
                    @mere13 iobdiagsummary.txt
                      @mere13
                      Das ist nicht die Langfassung sondern die Zusammenfassung.
                        @thomas-braun sorry.
                        iobdiag.txt
                          iobdiag.txt
                          bitte in code-tags gesetzt posten
                            mere13 @Homoran last edited by
                            @homoran verstehe ich leider nicht. wie bekomme ich die code-tags? Hab alles per copy-paste übertragen. So?
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                             Static hostname: rasp
                                   Icon name: computer
                                      Kernel: Linux 6.6.20+rpt-rpi-v8
                                Architecture: arm64
                            Model		: Raspberry Pi 4 Model B Rev 1.5
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : arm64
                            Systemuptime and Load:
                             11:15:46 up 1 day,  1:06,  3 users,  load average: 0.14, 0.26, 0.34
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            *** Time and Time Zones ***
                                           Local time: Sun 2024-04-14 11:15:47 CEST
                                       Universal time: Sun 2024-04-14 09:15:47 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            marcel
                            /home/marcel
                            marcel adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                            *** X-Server-Setup ***
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            Boot Target: 	graphical.target
                            *** MEMORY ***
                            Mem:            8.2G        1.2G        5.7G        1.4M        1.4G        6.9G
                            Total:          8.3G        1.2G        5.8G
                                     7810 M total memory
                                     1184 M used memory
                                     1421 M active memory
                                      775 M inactive memory
                                     5445 M free memory
                                      122 M buffer memory
                                     1181 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FAILED SERVICES ***
                              UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                            * lightdm.service loaded failed failed Light Display Manager
                            1 loaded units listed.
                            *** FILESYSTEM ***
                            udev           devtmpfs  3.6G     0  3.6G   0% /dev
                            tmpfs          tmpfs     782M  1.3M  780M   1% /run
                            /dev/mmcblk0p2 ext4       58G  6.4G   48G  12% /
                            tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
                            /dev/mmcblk0p1 vfat      510M   82M  429M  17% /boot/firmware
                            tmpfs          tmpfs     782M   28K  781M   1% /run/user/1000
                            [Sat Apr 13 10:09:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:B1:D2:3A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8a167c7b-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                            [Sat Apr 13 10:09:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
                            [Sat Apr 13 10:09:09 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
                            TARGET           SOURCE         FSTYPE OPTIONS
                            /                /dev/mmcblk0p2 ext4   rw,noatime
                            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            870M	/var/
                            341M	/var/cache
                            334M	/var/cache/apt
                            322M	/var/lib
                            221M	/var/cache/apt/archives
                            Archived and active journals take up 104.0M in the file system.
                            /opt/iobroker/backups:
                            2.9M	/opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            62M	/opt/iobroker/iobroker-data/
                            31M	/opt/iobroker/iobroker-data/backup-objects
                            19M	/opt/iobroker/iobroker-data/files
                            13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                            8.8M	/opt/iobroker/iobroker-data/objects.jsonl
                            6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                            4.6M	/opt/iobroker/iobroker-data/states.jsonl
                            2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                            2.6M	/opt/iobroker/iobroker-data/files/ble.admin/build/index.js.map
                            USB-Devices by-id:
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs 	v18.20.2
                            /usr/bin/node 		v18.20.2
                            /usr/bin/npm 		10.5.0
                            /usr/bin/npx 		10.5.0
                            /usr/bin/corepack 	0.25.2
                            nodejs:
                              Installed: 18.20.2-1nodesource1
                              Candidate: 18.20.2-1nodesource1
                              Version table:
                             *** 18.20.2-1nodesource1 600
                                    100 /var/lib/dpkg/status
                                 18.20.1-1nodesource1 600
                                 18.20.0-1nodesource1 600
                                 18.19.1-1nodesource1 600
                                 18.19.0+dfsg-6~deb12u1 500
                                 18.19.0-1nodesource1 600
                                 18.18.2-1nodesource1 600
                                 18.18.1-1nodesource1 600
                                 18.18.0-1nodesource1 600
                                 18.17.1-1nodesource1 600
                                 18.17.0-1nodesource1 600
                                 18.16.1-1nodesource1 600
                                 18.16.0-1nodesource1 600
                                 18.15.0-1nodesource1 600
                                 18.14.2-1nodesource1 600
                                 18.14.1-1nodesource1 600
                                 18.14.0-1nodesource1 600
                                 18.13.0+dfsg1-1 500
                                 18.13.0-1nodesource1 600
                                 18.12.0-1nodesource1 600
                                 18.11.0-1nodesource1 600
                                 18.10.0-1nodesource1 600
                                 18.9.1-1nodesource1 600
                                 18.9.0-1nodesource1 600
                                 18.8.0-1nodesource1 600
                                 18.7.0-1nodesource1 600
                                 18.6.0-1nodesource1 600
                                 18.5.0-1nodesource1 600
                                 18.4.0-1nodesource1 600
                                 18.3.0-1nodesource1 600
                                 18.2.0-1nodesource1 600
                                 18.1.0-1nodesource1 600
                                 18.0.0-1nodesource1 600
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller: 	5.0.19
                            admin: 		6.13.16
                            javascript: 	"javascript" not found
                            Adapters from github: 	1
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : rasp                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.0               : backitup              : rasp                                     -  enabled
                            + system.adapter.ble.0                    : ble                   : rasp                                     -  enabled
                            + system.adapter.discovery.0              : discovery             : rasp                                     -  enabled
                            + system.adapter.influxdb.0               : influxdb              : rasp                                     -  enabled, port: 8086
                            + system.adapter.mqtt.0                   : mqtt                  : rasp                                     -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.mystrom.0                : mystrom               : rasp                                     -  enabled
                            + system.adapter.vedirect.0               : vedirect              : rasp                                     -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): stable
                            Installed ioBroker-Instances
                            Used repository: stable
                            Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                            Adapter    "ble"          : 0.14.0   , installed 0.14.0
                            Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "mystrom"      : 0.0.14   , installed 0.0.14
                            Objects and States
                            Objects: 	385
                            States: 	287
                            Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:5 https://repos.influxdata.com/debian stable InRelease
                            Hit:6 https://apt.grafana.com stable InRelease
                            Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2106529    42615/cupsd
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       42475      11730/io.mqtt.0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8479       1072/iobroker.js-co
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8472       1072/iobroker.js-co
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9234       778/sshd: /usr/sbin
                            tcp6       0      0 :::8086                 :::*                    LISTEN      999        6022       896/influxd
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7635       1122/io.admin.0
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2106528    42615/cupsd
                            tcp6       0      0 :::3000                 :::*                    LISTEN      113        6061       1071/grafana
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          9236       778/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1857       626/dhcpcd: [networ
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2107407    42643/cups-browsed
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7074       570/avahi-daemon: r
                            udp        0      0 0.0.0.0:38954           0.0.0.0:*                           104        7076       570/avahi-daemon: r
                            udp6       0      0 :::36418                :::*                                104        7077       570/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          1859       626/dhcpcd: [networ
                            udp6       0      0 :::5353                 :::*                                104        7075       570/avahi-daemon: r
                            2024-04-14 10:37:15.420  - debug: vedirect.0 (70677) Objects client ready ... initialize now
                            2024-04-14 10:37:15.423  - debug: vedirect.0 (70677) Objects create System PubSub Client
                            2024-04-14 10:37:15.425  - debug: vedirect.0 (70677) Objects create User PubSub Client
                            2024-04-14 10:37:15.461  - debug: vedirect.0 (70677) Objects client initialize lua scripts
                            2024-04-14 10:37:15.470  - debug: vedirect.0 (70677) Objects connected to redis: 127.0.0.1:9001
                            2024-04-14 10:37:15.488  - debug: vedirect.0 (70677) Redis States: Use Redis connection: 127.0.0.1:9000
                            2024-04-14 10:37:15.496  - debug: vedirect.0 (70677) States create System PubSub Client
                            2024-04-14 10:37:15.497  - debug: vedirect.0 (70677) States create User PubSub Client
                            2024-04-14 10:37:15.511  - debug: vedirect.0 (70677) States connected to redis: 127.0.0.1:9000
                            2024-04-14 10:37:15.541  - debug: vedirect.0 (70677) Plugin sentry Initialize Plugin (enabled=true)
                            2024-04-14 10:37:15.965  - info: vedirect.0 (70677) starting. Version 0.3.3 (non-npm: DrozmotiX/ioBroker.vedirect#8435302add9dc410535180c6c0d5ebbaef2eeb1e) in /opt/iobroker/node_modules/iobroker.vedirect, node: v18.20.2, js-controller: 5.0.19
                            2024-04-14 10:37:15.987  - info: vedirect.0 (70677) Starting VE.Direct with Protocol Version 3.33 and configurable expiring state capability
                            2024-04-14 10:37:15.998  - error: vedirect.0 (70677) Issue handling serial port connection : {}
                            2024-04-14 10:37:45.453  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                            2024-04-14 10:37:55.638  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201
                            2024-04-14 10:39:42.298  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
                            2024-04-14 10:40:09.177  - info: mystrom.0 (1240) Set update interval for 9C9C1FE323DC to 60
                            2024-04-14 10:43:51.983  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                            2024-04-14 10:44:41.987  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
                            2024-04-14 10:57:05.970  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                            2024-04-14 11:01:56.002  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
                            2024-04-14 11:06:49.715  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                            2024-04-14 11:08:09.723  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
                            2024-04-14 11:10:09.427  - info: mystrom.0 (1240) Set update interval for 9C9C1FE323DC to 60
                            2024-04-14 11:14:58.222  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
                            iob diag has finished.
                            Press any key for a summary
                              da steht er.
                              in deinem Screenshot leider nicht zu lesen.
                              Aber da sind anscheinend Leerzeichen verwendet und der abschließende Slash fehlt
                                Setz das auf
                                sudo systemctl set-default multi-user.target
                                Nach einem Neustart:
                                ls -la /dev/serial/by-id
                                  @thomas-braun said in vedirect keine Verbindung bei rasp 4:
                                  Bekomme das:
                                  total 0
                                  drwxr-xr-x 2 root root 60 Apr 14 12:29 .
                                  drwxr-xr-x 4 root root 80 Apr 14 12:29 ..
                                  lrwxrwxrwx 1 root root 13 Apr 14 12:29 usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0 -> ../../ttyUSB0
                                  und im Adapter ist das eingetragen, keine Leerzeichen
                                  /dev/serial/by-id usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
                                  DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                                  • DJMarc75
                                    DJMarc75 @mere13 last edited by
                                    keine Leerzeichen
                                    doch, zwischen id und usb
                                      mere13 @DJMarc75 last edited by
                                      @djmarc75 ok. sorry, war blind. habs jetzt korrigiert und mit / ersetzt. Was meintest Du mit abschließendem Slash? Jetzt steht das da, aber leider noch keine Verbindung:
                                        @mere13
                                        Es muss exakt das eingetragen werden:
                                        Rechte sind vorhanden?
                                        ls -la /dev/ttyUSB0
                                        sudo -u iobroker groups
                                          mit copy-paste übertragen. leider nix.
                                          marcel@rasp:~ $ ls -la /dev/ttyUSB0
                                          crw-rw----+ 1 root plugdev 188, 0 Apr 14 12:29 /dev/ttyUSB0
                                          iobroker tty dialout audio video bluetooth gpio i2c
                                            leider nix.
                                            Wie nix? Da sind doch die Ausgaben. Würde man besser sehen, wenn du freundlicherweise für solche Ausgaben aus der Konsole die CodeTags verwenden würdest.
                                            Der user 'iobroker' ist nicht in der Gruppe 'plugdev' drin. Deswegen darf der mit dem Gerät nix anfangen.
                                            Setz den da rein:
                                            sudo usermod -a -G plugdev iobroker
                                            iob stop
                                            sudo reboot
                                            Sollte danach funktionieren.
                                            625
