    4. [Gelöst] Installation Logitech Harmony Adapter
    • E
      eurohulos last edited by
      Guten Abend,
      Die Installation von ioBroker 1.1.3 auf win32 hat funktioniert und auch der HUE Adapter funktioniert. Leider schlug aber die Installation des Logitech Harmony Adapter fehl. Dem Log verstehe ich so, dass gewisse Komponenten fehlen, komme da aber nicht weiter:
      $ ./iobroker add harmony
      npm install iobroker.harmony --production --prefix "C:/ioBroker" (System call)
      npm
       WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
      npm
      WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)
      npm WARN addRemoteGit     at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:69:19)
      npm WARN addRemoteGit     at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:81:29)
      npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16
      npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\index.js:44:5
      npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\windows.js:29:5
      npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:264:29
      npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
      npm WARN
      addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)
      npm WARN
      addRemoteGit
           at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:81:29)npm
      WARN addRemoteGit
           at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16npm WARN
      npm
      WARN
      addRemoteGit
           at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
      npm
       ERR! git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefinednpm ERR!
      npm
       ERR! Windows_NT 10.0.15063
      npm
      ERR! argv
       "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      npm ERR! node
       v6.11.2
      npm
      ERR! npm  v3.10.10
      npm
      ERR! code ENOGIT
      npm
       ERR! not found: gitnpm ERR!
      npm ERR! Failed using git.
      npm ERR! This is most likely not a problem with npm itself.
      npm ERR! Please check if you have git installed and in your PATH.
      npm ERR! Please include the following file with any support request:npm ERR!     C:\ioBroker\node_modules\iobroker\npm-debug.log
      host.TV-BOX install adapter harmony
      npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
      npm
      npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)npm
      WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)
      npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
      npm
      ERR!
      npm
      npm
       ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      npm ERR! node v6.11.2npm ERR! npm  v3.10.10
      npm
      ERR! code ENOGIT
      npm ERR! not found: gitnpm ERR!
      npm
      npm
      npm
      WARN addRemoteGit     at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:69:19)npm WARN addRemoteGit     at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:81:29)
      npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
      npm
      WARN addRemoteGit
      npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\index.js:44:5
      npm
       WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\windows.js:29:5npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:264:29
      npm
      npm
       ERR! Windows_NT 10.0.15063npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      npm
      ERR! node
      npm ERR! code ENOGIT
      npm
      npm ERR!
      npm
      ERROR: host.TV-BOX Cannot install harmony
      ERROR: process exited with code 13</https:></https:></https:>
      3415_npm-debug.log
      Danke für die Hilfe!
        Hallo und Willkommen im Forum!
        @eurohulos:
        Dem Log verstehe ich so, dass gewisse Komponenten fehlen `
        Wie recht du hast.
        @eurohulos:
        ERR! code ENOGIT `
        Ich kenne mich bei Windows nicht aus, aber irgendwo im Forum steht wie.
        (Git nicht github!)
        http://forum.iobroker.net/viewtopic.php … ren#p50835
        • E
          Und schon funktionierts.
          Danke!
