    2. English
    3. Scripting / Logic
    5. problem during boot with schedule command in the script
      hschief last edited by
      Dear Forum,
      i face some problems during system boot. There are some scripts with time schedules. For testing I create the following:
      function Test1() {
          log('In Function','error');
          setState('0_userdata.0.Allgemein.TestBoot', 'test', false);
      log('Script Test1 aufgerufen','error');
      schedule("*/10 * * * * *", Test1 )
      During normal operation it logs every 10s: "In Function" - as expected.
      During boot-up the following happend - it wrote logs to the log file more than 1000 times in a minute.:
      2024-04-16 14:25:31.573 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
      2024-04-16 14:25:31.580 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
      2024-04-16 14:25:31.591 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
      2024-04-16 14:25:31.598 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
      2024-04-16 14:25:31.610 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
      2024-04-16 14:25:31.622 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
      2024-04-16 14:25:31.634 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
      2024-04-16 14:25:31.642 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
      This happens in my installation for any scripts which such a schedule.
      In case i go to the shell and i use the commands: iobroker stop and afterwards iobroker start .. the system runs as expected without scheduling this 1000 times.
      In case I do a fresh boot, without starting the iobroker and then starting the iobroker from the console, I have the same problem. After I do iobroker stop/start all is fine again.
      I run:
      js: 5.0.19
      node: v18.17.1
      javascript: v7.8.0
      Any ideas? Anybody able to reproduce this before I create a bug report?
      • DJMarc75
        DJMarc75 @hschief last edited by
        @hschief i don´t think that a double post in an other language is helpful to solve you´re Problem 😉
          why .....
          https://forum.iobroker.net/topic/74128/maximum-of-1000-setstate-during-boot?_=1713335509270
            hschief @DJMarc75 last edited by
            @djmarc75 easy to explain.... more english speaker the German speaker ... to reach a bigger audience. Thx. for the hint ... doesn't help anything for the question
              Homoran Global Moderator Administrators @hschief last edited by
              @hschief sagte in problem during boot with schedule command in the script:
              das sind die Installationen und im forum istcdie Luft noch viel dünner
