    4. [gelöst] Sporadische Neustarts des iobroker
      m.schalk last edited by m.schalk
      Ich habe folgendes Problem, ich habe tägliche Reboots des Adminadapters, wie kann ich herausfinden was das verursacht.
      iob diag ausgabe.txt
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: BU02SMART02-iobroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 6.2.16-18-pve
          Architecture: x86-64
      model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       19:18:24 up 6 days, 12 min,  3 users,  load average: 2.46, 3.33, 3.33
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Tue 2024-04-16 19:18:24 CEST
                 Universal time: Tue 2024-04-16 17:18:24 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      mario
      /home/mario
      mario sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            5.1G        4.0G         40M        0.0K        1.1G        1.1G
      Swap:           5.1G        1.5G        3.6G
      Total:           10G        5.5G        3.6G
               5120 M total memory
               4007 M used memory
               1507 M active memory
               3250 M inactive memory
                 40 M free memory
                  0 M buffer memory
               1071 M swap cache
               5120 M total swap
               1535 M used swap
               3584 M free swap
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem     Type   Size  Used Avail Use% Mounted on
      /dev/loop0     ext4    26G   21G  4.5G  82% /
      none           tmpfs  492K  4.0K  488K   1% /dev
      tmpfs          tmpfs  7.8G     0  7.8G   0% /dev/shm
      tmpfs          tmpfs  3.1G  152K  3.1G   1% /run
      tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/1001
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE     FSTYPE OPTIONS
      /      /dev/loop0 ext4   rw,relatime
      /var:
      4.2G    /var/
      2.9G    /var/log
      2.8G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
      981M    /var/lib
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      713M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      7.9G    /opt/iobroker/iobroker-data/
      6.5G    /opt/iobroker/iobroker-data/history
      627M    /opt/iobroker/iobroker-data/files
      487M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
      49M     /opt/iobroker/iobroker-data/objects.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.ma        p
      28M     /opt/iobroker/iobroker-data/states.jsonl
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.ma        p
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade        6914f1d69213e-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.18.0
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.9~dfsg-1ubuntu3.5 500
              500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Package        s
              500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packag        es
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.17.3
      javascript:     8.0.3
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : BU02SMART02-i        obroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.daikin.0                 : daikin                : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.discovery.0              : discovery             : BU02SMART02-i        obroker                     -  enabled
        system.adapter.dwd.0                    : dwd                   : BU02SMART02-i        obroker                     -  enabled
        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-i        obroker                     - disabled
        system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-i        obroker                     - disabled
      + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-i        obroker                     -  enabled
        system.adapter.feiertage.0              : feiertage             : BU02SMART02-i        obroker                     -  enabled
        system.adapter.flot.0                   : flot                  : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.followthesun.0           : followthesun          : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.ford.0                   : ford                  : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.history.0                : history               : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-i        obroker                     -  enabled
        system.adapter.ical.0                   : ical                  : BU02SMART02-i        obroker                     -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02        SMART02-iobroker                     -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-i        obroker                     -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-i        obroker                     -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-i        obroker                     -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-i        obroker                     -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02        SMART02-iobroker                     -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.influxdb.0               : influxdb              : BU02SMART02-i        obroker                     -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.iot.0                    : iot                   : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.javascript.0             : javascript            : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-i        obroker                     -  enabled
        system.adapter.material.0               : material              : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-i        obroker                     -  enabled
        system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-i        obroker                     - disabled, port: 1892
      + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-i        obroker                     -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-i        obroker                     -  enabled, port: 1891, bind: 192.168.2.166
      + system.adapter.net-tools.0              : net-tools             : BU02SMART02-i        obroker                     -  enabled
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-i        obroker                     -  enabled
        system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-i        obroker                     -  enabled
        system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-i        obroker                     - disabled
      + system.adapter.ping.0                   : ping                  : BU02SMART02-i        obroker                     -  enabled
        system.adapter.proxmox.0                : proxmox               : BU02SMART02-i        obroker                     - disabled, port: 8006
      + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.ring.0                   : ring                  : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.samsung.0                : samsung               : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.shelly.0                 : shelly                : BU02SMART02-i        obroker                     -  enabled, port: 1890, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : BU02SMART02-i        obroker                     -  enabled, port: 1890, bind: 192.168.2.166
        system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-i        obroker                     - disabled
      + system.adapter.slideshow.0              : slideshow             : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.smartthings.0            : smartthings           : BU02SMART02-i        obroker                     -  enabled
        system.adapter.snmp.0                   : snmp                  : BU02SMART02-i        obroker                     - disabled
        system.adapter.socketio.0               : socketio              : BU02SMART02-i        obroker                     - disabled, port: 8084, bind: 192.168.2.166, run as:        admin
      + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.telegram.0               : telegram              : BU02SMART02-i        obroker                     -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tuya.0                   : tuya                  : BU02SMART02-i        obroker                     -  enabled
        system.adapter.tuya.1                   : tuya                  : BU02SMART02-i        obroker                     - disabled
        system.adapter.unifi.0                  : unifi                 : BU02SMART02-i        obroker                     - disabled
      + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-i        obroker                     - disabled
        system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-history.0            : vis-history           : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-material.0           : vis-material          : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-i        obroker                     -  enabled
        system.adapter.vis.0                    : vis                   : BU02SMART02-i        obroker                     -  enabled
      + system.adapter.web.0                    : web                   : BU02SMART02-i        obroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.ws.0                     : ws                    : BU02SMART02-i        obroker                     - disabled, port: 8087, bind: 192.168.2.166, run as:        admin
      + system.adapter.yahka.0                  : yahka                 : BU02SMART02-i        obroker                     -  enabled
        system.adapter.yahka.1                  : yahka                 : BU02SMART02-i        obroker                     - disabled
      + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-i        obroker                     -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Beta (latest)
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 6.17.3   , installed 6.17.3
      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "apcups"       : 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 2.11.0   , installed 2.9.9  [Updatable]
      Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.0  , installed 2.12.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
      Adapter    "ems-esp"      : 3.1.1    , installed 3.1.1
      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
      Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "ford"         : 0.2.0    , installed 0.2.0
      Adapter    "hass-mqtt"    : 0.0.7    , installed 0.0.7
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "iot"          : 3.2.2    , installed 3.2.2
      Adapter    "javascript"   : 8.0.3    , installed 8.0.3
      Controller "js-controller": 5.0.19   , installed 5.0.17 [Updatable]
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
      Adapter    "mercedesme"   : 0.2.2    , installed 0.2.2
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
      Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "ring"         : 5.0.10   , installed 5.0.10
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "shelly"       : 6.9.0    , installed 6.9.0
      Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
      Adapter    "slideshow"    : 0.1.4    , installed 0.1.4
      Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.2.1    , installed 3.2.1
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis"          : 1.5.5    , installed 1.5.5
      Adapter    "vis-2"        : 2.9.49   , installed 2.9.49
      Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
      Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
      Adapter    "vis-2-widgets-material": 1.3.27, installed 1.3.27
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        49416
      States:         42924
      W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /        etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-all/Packages) is configured multiple times in /et        c/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Translations (main/i18n/Translation-en) is configured multiple times in        /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:        2
      W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/        sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/so        urces.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x jammy InRelease
      Reading package lists...
      Pending Updates: 98
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       U        ser       Inode      PID/Program name
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1        000       132599104  1264635/io.mqtt.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0        64314729   281/master
      tcp        0      0 0.0.0.0:42723           0.0.0.0:*               LISTEN      1        000       132605813  1264901/io.yahka.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      1        06        64316436   99/systemd-resolved
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0        64312195   1/init
      tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1        000       132598062  1264542/io.shelly.1
      tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1        000       132597639  1264558/io.mqtt.1
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1        001       133820253  1293171/sshd: mario
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      1        13        64314560   113/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0        64315524   1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0        64312197   1/init
      tcp6       0      0 :::3000                 :::*                    LISTEN      1        12        64315297   118/grafana
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0        64314730   281/master
      tcp6       0      0 ::1:6379                :::*                    LISTEN      1        13        64314561   113/redis-server 12
      tcp6       0      0 :::8082                 :::*                    LISTEN      1        000       132615242  1265507/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1        000       132594694  1264383/io.admin.0
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1        001       133820252  1293171/sshd: mario
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           1        06        64316435   99/systemd-resolved
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0        64312196   1/init
      udp        0      0 0.0.0.0:34136           0.0.0.0:*                           1        000       132602193  1264717/io.shelly.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1        000       132605810  1264901/io.yahka.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1        000       132602180  1264717/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1        000       132596964  1264462/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1        000       132596965  1264462/io.tuya.0
      udp6       0      0 :::111                  :::*                                0        64312198   1/init
      2024-04-16 18:43:26.914  - debug: ring.0 (1264817) Device 95880122 ("Haustür"): U        pdate Snapshot Object
      2024-04-16 18:43:26.914  - debug: ring.0 (1264817) Device 95880122 ("Haustür"): U        pdate HD Snapshot Object
      2024-04-16 18:43:27.252  - debug: ring.0 (1264817) Device 95880122 ("Haustür"): U        pdate Health Callback
      2024-04-16 18:45:05.389  - info: ring.0 (1264817) Got terminate signal TERMINATE_        YOURSELF
      2024-04-16 18:45:05.391  - info: ring.0 (1264817) terminating
      2024-04-16 18:45:05.392  - info: ring.0 (1264817) Terminated (ADAPTER_REQUESTED_T        ERMINATION): Without reason
      2024-04-16 18:45:05.896  - info: ring.0 (1264817) terminating
      2024-04-16 18:47:01.349  - warn: zigbee.0 (1264627) DeviceAvailability:Failed to        ping 0x8418260000cab6da Flex RGBW
      2024-04-16 18:52:28.297  - warn: javascript.0 (1264421) You are assigning a boole        an to the state "javascript.0.Taster_und_Schalter.Beschattung_West" which expects        a object. Please fix your code to use a object or change the state type to boole        an. This warning might become an error in future versions.
      2024-04-16 18:52:29.433  - warn: javascript.0 (1264421)     at setState (/opt/iob        roker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
      2024-04-16 18:52:29.434  - warn: javascript.0 (1264421)     at Object.<anonymous>        (script.js.07_Rollladen.Beschattung_West:41:3)
      2024-04-16 18:52:29.435  - warn: javascript.0 (1264421)     at Object.<anonymous>        (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1691:34)
      2024-04-16 18:52:29.439  - warn: javascript.0 (1264421)     at Timeout._onTimeout        (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3031:34)
      2024-04-16 18:52:29.440  - warn: javascript.0 (1264421)     at listOnTimeout (nod        e:internal/timers:569:17)
      2024-04-16 18:52:29.440  - warn: javascript.0 (1264421)     at processTimers (nod        e:internal/timers:512:7)
      2024-04-16 18:59:04.437  - info: feiertage.0 (1290817) starting. Version 1.2.0 in        /opt/iobroker/node_modules/iobroker.feiertage, node: v18.17.1, js-controller: 5.        0.17
      2024-04-16 18:59:04.524  - info: feiertage.0 (1290817) Next holiday: Tag der Arbe        it is in 15 days on 01.05.2024
      2024-04-16 18:59:04.534  - info: feiertage.0 (1290817) all objects written
      2024-04-16 18:59:04.539  - info: feiertage.0 (1290817) Terminated (NO_ERROR): Wit        hout reason
      2024-04-16 19:00:05.038  - info: feiertage.0 (1291015) starting. Version 1.2.0 in        /opt/iobroker/node_modules/iobroker.feiertage, node: v18.17.1, js-controller: 5.        0.17
      2024-04-16 19:00:05.314  - info: feiertage.0 (1291015) Next holiday: Tag der Arbe        it is in 15 days on 01.05.2024
      2024-04-16 19:00:05.340  - info: feiertage.0 (1291015) all objects written
      2024-04-16 19:00:05.355  - info: feiertage.0 (1291015) Terminated (NO_ERROR): Wit        hout reason
      2024-04-16 19:05:47.882  - warn: zigbee.0 (1264627) DeviceAvailability:Stopping t        o ping 0x84182600000daf7a Plug 01 after 4 ping attempts
      2024-04-16 19:17:25.311  - warn: zigbee.0 (1264627) DeviceAvailability:Failed to        ping 0x5c0272fffe6e55ea TRADFRI Signal Repeater
        Thomas Braun Most Active @m.schalk last edited by
        @m-schalk sagte in Sporadische Neustarts des iobroker:
        Deine grafana.list hat Doubletten.
        Schmeiß die doppelten Einträge dort raus.
        Dein nodejs ist veraltet. Per
        iob nodejs-update
        auf Stand bringen.
        Dann wird es wohl so sein, dass du für redis/redis zu wenig RAM hast. redis läuft ja komplett im RAM und deswegen braucht es da halt reichlich von.
        Pending Updates: 98
        Updaten. Die iob-Adapter auch.
          m.schalk @Thomas Braun last edited by
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
          Operating System: Ubuntu 22.04.4 LTS
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
           21:19:03 up 26 min,  3 users,  load average: 3.10, 4.57, 4.47
          CPU threads: 4
                         Local time: Tue 2024-04-16 21:19:03 CEST
                     Universal time: Tue 2024-04-16 19:19:03 UTC
                           RTC time: n/a
                    RTC in local TZ: no
          mario
          /home/mario
          mario sudo iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.2G        3.6G        2.6G        0.0K        2.0G        4.6G
          Swap:           7.8G        0.0K        7.8G
          Total:           15G        3.6G         10G
                   8192 M total memory
                   3619 M used memory
                    565 M active memory
                   4778 M inactive memory
                   2612 M free memory
                      0 M buffer memory
                   1959 M swap cache
                   7759 M total swap
                      0 M used swap
                   7759 M free swap
          *** FILESYSTEM ***
          /dev/loop0     ext4    26G   20G  4.6G  82% /
          tmpfs          tmpfs  3.1G  172K  3.1G   1% /run
          tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/0
          /var:
          4.0G    /var/
          2.8G    /var/log
          2.7G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
          781M    /var/lib
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
          /usr/bin/nodejs         v18.20.2
          /usr/bin/node           v18.20.2
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.25.2
          nodejs:
            Installed: 18.20.2-1nodesource1
            Candidate: 18.20.2-1nodesource1
            Version table:
           *** 18.20.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
                  500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                  500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
          Errors in npm tree:
          ioBroker Status
          Objects type: redis
          States  type: redis
          js-controller:  5.0.19
          admin:          6.17.3
          javascript:     8.0.3
          Adapter State
          + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
          + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
          + system.adapter.backitup.0               : backitup              : BU02SMART02-iobroker                     -  enabled
          + system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     -  enabled
          + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
          + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
          + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
            system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
            system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
            system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     - disabled
          + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
          + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
            system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
            system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
          + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
          + system.adapter.ford.0                   : ford                  : BU02SMART02-iobroker                     -  enabled
          + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
          + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
            system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
          + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : BU02SMART02-iobroker                     -  enabled
          + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
          + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
          + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
            system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
          + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     -  enabled
            system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
          + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
          + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
          + system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
            system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
            system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-iobroker                     - disabled
          + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
            system.adapter.proxmox.0                : proxmox               : BU02SMART02-iobroker                     - disabled, port: 8006
          + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
          + system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     -  enabled
          + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
          + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
            system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-iobroker                     - disabled
          + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
          + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
            system.adapter.snmp.0                   : snmp                  : BU02SMART02-iobroker                     - disabled
            system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
          + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
          + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
            system.adapter.tuya.1                   : tuya                  : BU02SMART02-iobroker                     - disabled
            system.adapter.unifi.0                  : unifi                 : BU02SMART02-iobroker                     - disabled
          + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
            system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
            system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
          + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.ws.0                     : ws                    : BU02SMART02-iobroker                     - disabled, port: 8087, bind: 192.168.2.166, run as: admin
          + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
            system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
          + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
          + instance is alive
          Objects and States
          Objects:        49449
          States:         43067
          Hit:1 https://repos.influxdata.com/debian stable InRelease
          Hit:2 https://apt.grafana.com stable InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          134632524  1/init
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       134767830  3724/io.mqtt.0
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          134635725  283/master
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        134631393  100/systemd-resolve
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        134635550  116/redis-server 12
          tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      0          134652904  935/sshd: root@pts/
          tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1001       134826590  5717/sshd: mario@pt
          tcp        0      0 0.0.0.0:39227           0.0.0.0:*               LISTEN      1000       134773301  4042/io.yahka.0
          tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       134769007  3803/io.shelly.1
          tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       134770223  3841/io.mqtt.1
          tcp6       0      0 :::111                  :::*                    LISTEN      0          134632526  1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          134632859  1/init
          tcp6       0      0 :::3000                 :::*                    LISTEN      112        134639723  339/grafana
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          134635726  283/master
          tcp6       0      0 ::1:6379                :::*                    LISTEN      113        134635551  116/redis-server 12
          tcp6       0      0 ::1:6010                :::*                    LISTEN      0          134652903  935/sshd: root@pts/
          tcp6       0      0 ::1:6011                :::*                    LISTEN      1001       134826589  5717/sshd: mario@pt
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       134762300  3585/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134782529  4319/io.web.0
          udp        0      0 0.0.0.0:50492           0.0.0.0:*                           1000       134778743  3917/io.shelly.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       134775091  4042/io.yahka.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       134773821  3917/io.shelly.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134765342  3672/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134765343  3672/io.tuya.0
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        134631392  100/systemd-resolve
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          134632525  1/init
          udp6       0      0 :::111                  :::*                                0          134632527  1/init
          2024-04-16 21:14:16.270  - info: sourceanalytix.0 (4060) Initialising (24 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay1.gesamt"
          2024-04-16 21:14:17.088  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay1.gesamt successfully
          2024-04-16 21:14:17.089  - info: sourceanalytix.0 (4060) Initialising (25 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay0.gesamt"
          2024-04-16 21:14:18.113  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay0.gesamt successfully
          2024-04-16 21:14:18.114  - info: sourceanalytix.0 (4060) Initialising (26 of 34) "javascript.0.ShellyVerbrauch.SHPLG-S#1D409A#1.Relay0.gesamt"
          2024-04-16 21:14:18.812  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#1D409A#1.Relay0.gesamt successfully
          2024-04-16 21:14:18.812  - info: sourceanalytix.0 (4060) Initialising (27 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E571#1.Relay1.gesamt"
          2024-04-16 21:14:19.828  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E571#1.Relay1.gesamt successfully
          2024-04-16 21:14:19.828  - info: sourceanalytix.0 (4060) Initialising (28 of 34) "linkeddevices.0.Solarleistung.Summe-Solar-kwh"
          2024-04-16 21:14:20.982  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Solarleistung.Summe-Solar-kwh successfully
          2024-04-16 21:14:20.982  - info: sourceanalytix.0 (4060) Initialising (29 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC49C48#1.Relay0.gesamt"
          2024-04-16 21:14:21.914  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC49C48#1.Relay0.gesamt successfully
          2024-04-16 21:14:21.914  - info: sourceanalytix.0 (4060) Initialising (30 of 34) "linkeddevices.0.Solarleistung.open-DTU-612W"
          2024-04-16 21:14:22.613  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Solarleistung.open-DTU-612W successfully
          2024-04-16 21:14:22.614  - info: sourceanalytix.0 (4060) Initialising (31 of 34) "javascript.0.ShellyVerbrauch.shellyplus1pm#4855199d4330#1.Relay0.gesamt"
          2024-04-16 21:14:23.863  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.shellyplus1pm#4855199d4330#1.Relay0.gesamt successfully
          2024-04-16 21:14:23.863  - info: sourceanalytix.0 (4060) Initialising (32 of 34) "javascript.0.ShellyVerbrauch.SHEM-3#C45BBE783E1A#1.Total.gesamt"
          2024-04-16 21:14:24.861  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHEM-3#C45BBE783E1A#1.Total.gesamt successfully
          2024-04-16 21:14:24.861  - info: sourceanalytix.0 (4060) Initialising (33 of 34) "linkeddevices.0.Gesamt"
          2024-04-16 21:14:25.916  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Gesamt successfully
          2024-04-16 21:14:25.916  - info: sourceanalytix.0 (4060) Initialising (34 of 34) "javascript.0.ShellyVerbrauch.SHPLG-S#E868E7C38CAD#1.Relay0.gesamt"
          2024-04-16 21:14:27.233  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#E868E7C38CAD#1.Relay0.gesamt successfully
          2024-04-16 21:14:27.245  - warn: sourceanalytix.0 (4060) Cannot handle calculations for 1 of 34 enabled states, check error messages
          2024-04-16 21:14:27.245  - info: sourceanalytix.0 (4060) Successfully activated SourceAnalytix for 33 of 34 states, will do my Job until you stop me!
          2024-04-16 21:14:58.300  - error: daikin.0 (3782) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
            CPU threads: 4
            Irgendwas haut dir da aber auch die Load in ungesunde Bereiche. Bei 4 ist die Kiste dicht.
            Ausschalten:
            Boot Target: graphical.target
            sudo systemctl set-default multi-user.target
            Das Dateisystem droht dir auch in absehbarer Zeit vollzulaufen:
            Trag im zigbee-Adapter statt /dev/ttyUSB0
            besser
            ein.
            Und meld dich NICHT als root an.
            Hier läuft eine root shell:
            Mach es einfach nicht.
            Und bring die Adapter auf Stand.
              @thomas-braun said in Sporadische Neustarts des iobroker:
              also Zigbee läuft nicht mehr, habe zurückgestellt.
              Starting zigbee-herdsman problem : "Error: Permission denied, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0"
                Thomas Braun Most Active @m.schalk last edited by Thomas Braun
                Und welche Rechte wären erforderlich?
                ls -la /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
                Kann aber auch mit dem Container zusammenhängen. Die Dinger ticken ja anders.
                  @thomas-braun root 🙂
                  1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
                    @m-schalk
                    Und den wichtigsten Part hast unterschlagen. Die Rechte stehen ganz am Anfang.
                    So soll das aussehen:
                    echad@chet:/opt/iobroker $ ls -la /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
                    lrwxrwxrwx 1 root root 13 Apr  8 17:19 /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                      ---------- 1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
                        @m-schalk
                        Ja, das hat mit dem Durchreichen in den Container zu tun. Hab ich aber keine Ahnung von.
                          @thomas-braun ok, trotzdem Danke, ich schau mal wie es läuft.
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                           22:13:26 up  1:20,  2 users,  load average: 5.88, 4.78, 4.63
                          CPU threads: 4
                                         Local time: Tue 2024-04-16 22:13:26 CEST
                                     Universal time: Tue 2024-04-16 20:13:26 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          mario
                          /home/mario
                          mario sudo iobroker
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            8.2G        4.0G        1.9G        0.0K        2.3G        4.2G
                          Total:           15G        4.0G        9.6G
                                   8192 M total memory
                                   4020 M used memory
                                    844 M active memory
                                   5138 M inactive memory
                                   1879 M free memory
                                      0 M buffer memory
                                   2292 M swap cache
                                   7759 M total swap
                                      0 M used swap
                                   7759 M free swap
                          *** FILESYSTEM ***
                          /dev/loop0     ext4    26G   21G  4.6G  82% /
                          /var:
                          4.0G    /var/
                          2.8G    /var/log
                          781M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.5.0
                          /usr/bin/npx            10.5.0
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: redis
                          States  type: redis
                          admin:          6.17.3
                          javascript:     8.0.3
                          Adapter State
                          + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
                          + instance is alive
                          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                          Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                          Objects and States
                          Objects:        49451
                          States:         42960
                          Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                          Hit:3 https://apt.grafana.com stable InRelease
                          Pending Updates: 0
                          udp        0      0 0.0.0.0:55014           0.0.0.0:*                           1000       135249274  3917/io.shelly.0
                          2024-04-16 21:49:27.283  - info: zigbee.0 (13050) 0x84182600000d798a (addr 50622): AB3257001NJ - OSRAM Smart+ plug (Router)
                          2024-04-16 21:49:27.285  - info: zigbee.0 (13050) 0x7cb03eaa00ad4adf (addr 48445): AB3257001NJ - OSRAM Smart+ plug (Router)
                          2024-04-16 21:49:27.287  - info: zigbee.0 (13050) 0x7cb03eaa00ad1661 (addr 64742): AB3257001NJ - OSRAM Smart+ plug (Router)
                          2024-04-16 21:49:27.289  - info: zigbee.0 (13050) 0x8418260000cab6da (addr 26679): 4052899926110 - OSRAM Flex RGBW (Router)
                          2024-04-16 21:49:27.291  - info: zigbee.0 (13050) 0x5c0272fffe6e55ea (addr 38364): E1746 - IKEA TRADFRI signal repeater (Router)
                          2024-04-16 21:49:27.294  - info: zigbee.0 (13050) 0x54ef4410005b43d3 (addr 45208): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
                          2024-04-16 21:49:27.297  - info: zigbee.0 (13050) 0x5c0272fffe5b723b (addr 27218): E1746 - IKEA TRADFRI signal repeater (Router)
                          2024-04-16 21:49:27.298  - info: zigbee.0 (13050) 0x7cb03eaa0a068fec (addr 16021): AB3257001NJ - OSRAM Smart+ plug (Router)
                          2024-04-16 21:49:27.306  - info: zigbee.0 (13050) 0x00158d0008a6bd14 (addr 37504): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                          2024-04-16 21:49:27.308  - info: zigbee.0 (13050) 0x00158d0008834af4 (addr 53958): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                          2024-04-16 21:49:27.309  - info: zigbee.0 (13050) Zigbee started
                          2024-04-16 21:49:27.379  - info: zigbee.0 (13050) debug devices set to []
                          2024-04-16 21:49:35.454  - info: admin.0 (3585) ==> Connected system.user.admin from ::ffff:192.168.2.160
                          2024-04-16 21:49:35.812  - info: zigbee.0 (13050) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}]
                          2024-04-16 21:50:03.153  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa0a068fec Plug 01
                          2024-04-16 21:59:03.751  - info: feiertage.0 (14906) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
                          2024-04-16 21:59:03.864  - info: feiertage.0 (14906) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
                          2024-04-16 21:59:03.874  - info: feiertage.0 (14906) all objects written
                          2024-04-16 21:59:03.883  - info: feiertage.0 (14906) Terminated (NO_ERROR): Without reason
                          2024-04-16 22:00:09.226  - info: feiertage.0 (15092) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
                          2024-04-16 22:00:09.729  - info: feiertage.0 (15092) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
                          2024-04-16 22:00:09.875  - info: feiertage.0 (15092) all objects written
                          2024-04-16 22:00:09.889  - info: feiertage.0 (15092) Terminated (NO_ERROR): Without reason
                          2024-04-16 22:00:21.817  - warn: netatmo-crawler.0 (15192) slow connection to objects DB. Still waiting ...
                          2024-04-16 22:06:45.998  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa00ad1661 Plug 01
                            Wenn die Kiste jetzt nicht stabiler läuft:
                            Ich vermute hier ein Skript, das ungünstig angelegt wurde.
                              @thomas-braun Hallo Thomas, die Restarts sind weniger geworden, aber leider sind es immer noch 2 am Tag. Was kann ich noch prüfen? Skripte?
                              Thomas Braun ? 2 Replies Last reply Reply Quote 0
                                @m-schalk
                                Ja, i.d.R. ist dann ein Skript falsch/ungünstig angelegt.
                                  @thomas-braun leider weiß ich nicht, wie ich das überprüfen kann.
                                    @m-schalk
                                    Ich auch nicht.
                                      A Former User @m.schalk last edited by
                                      oder Backup? Backups fressen Speicher und Ressourcen.. nicht, dass hier die Luft aus geht..?
                                      Bei den Skripten bleibt nur eins, der Reihe nach ausschalten oder alle Aus, und dann der Reihe nach ein..
                                      Es hilft auch, die Uhrzeiten zu protokollieren, und dann im Log zu sehen, was vorher passiert ist.. auch Skripte, die kurz vorher starten, mal anschauen..
                                        @thomas-braun was kannst du dazu sagen? Das habe ich ca 1000
                                        2024-04-19 21:30:47.475  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2024-04-19 21:30:47.475  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.475  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                           at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                                           at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                        2024-04-19 21:30:47.823  - error: shelly.0 (470312) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.829  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.833  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.835  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.841  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.843  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.846  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.850  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.851  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.855  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.859  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.861  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.862  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.864  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.866  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.869  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.870  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.872  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.875  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.876  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.877  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.879  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.881  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.884  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.886  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.887  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.888  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.889  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.892  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.893  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.894  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.897  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.899  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.901  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.831  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2024-04-19 21:30:47.831  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        2024-04-19 21:30:47.831  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                          m.schalk @Thomas Braun last edited by m.schalk
                                          @thomas-braun das ist als letztes im log vor dem Restart, mindestens 10.000 mal
                                          der Logfile ist 35Mb groß
                                          2024-04-19 21:31:36.745  - error: javascript.0 (499664) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                                          2024-04-19 21:31:36.745  - error: javascript.0 (499664) Error: write EPIPE
                                              at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                                              at writeGeneric (node:internal/stream_base_commons:151:3)
                                              at Socket._writeGeneric (node:net:962:11)
                                              at Socket._write (node:net:974:8)
                                              at writeOrBuffer (node:internal/streams/writable:392:12)
                                              at _write (node:internal/streams/writable:333:10)
                                              at Socket.Writable.write (node:internal/streams/writable:337:10)
                                              at console.value (node:internal/console/constructor:305:16)
                                              at console.warn (node:internal/console/constructor:385:26)
                                              at /opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:15:13
                                            A Former User last edited by
                                            @m-schalk
                                            Dann schau mal in das Redis log, da stimmt was nicht..
                                            902
