    4. keine Adapter mehr installieren /Updaten
      Farmer-cb last edited by
      Servus
      Kann seit kurzem keine Adapter mehr Updaten bzw Installieren.
      jedesmal kommt so eine Fehlermeldung:
      Update alexa2 from @3.26.4 to @3.26.5
      NPM version: 10.2.4
      Installing iobroker.alexa2@3.26.5... (System call)
      npm ERR! code 128
      npm ERR! An unknown git error occurred
      npm ERR! command git --no-replace-objects ls-remote ssh://git@github.com/TA2k/ioBroker.renault.git
      npm ERR! Warning: Permanently added the ECDSA host key for IP address '140.82.121.3' to the list of known hosts.
      npm ERR! git@github.com: Permission denied (publickey).
      npm ERR! fatal: Could not read from remote repository.
      npm ERR!
      npm ERR! Please make sure you have the correct access rights
      npm ERR! and the repository exists.
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-17T15_51_40_273Z-debug-0.log
      host.iobroker Cannot install iobroker.alexa2@3.26.5: 128
      erster Teil von iobroker diag kommt:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 5.15.131-2-pve
            Architecture: x86-64
      model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       18:06:05 up 24 min,  1 user,  load average: 1.26, 1.07, 0.91
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Wed 2024-04-17 18:06:05 CEST
                 Universal time: Wed 2024-04-17 16:06:05 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      Farmer
      /home/Farmer
      Farmer sudo
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:           6.0G        3.4G        1.9G        8.0M        630M        2.6G
      Swap:          1.0G          0B        1.0G
      Total:         7.0G        3.4G        3.0G
               6000 M total memory
               3431 M used memory
                320 M active memory
               3543 M inactive memory
               1937 M free memory
                  0 M buffer memory
                630 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * sys-kernel-debug.mount        loaded failed failed Kernel Debug File System
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      3 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4       24G  8.5G   14G  38% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     3.9G  8.1M  3.9G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     782M     0  782M   0% /run/user/0
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET                    SOURCE                           FSTYPE     OPTIONS
      /                         /dev/mapper/pve-vm--100--disk--0 ext4       rw,relatime,stripe=16
      |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      579M    /var/
      384M    /var/cache
      380M    /var/cache/apt
      318M    /var/cache/apt/archives
      187M    /var/lib
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      21M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      745M    /opt/iobroker/iobroker-data/
      444M    /opt/iobroker/iobroker-data/files
      197M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      50M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
           18.20.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
       *** 18.19.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u4 500
              500 http://security.debian.org buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://ftp.debian.org/debian buster/main amd64 Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
      npm ERR! invalid: iobroker.renault@0.0.21 /opt/iobroker/node_modules/iobroker.renault
      npm ERR! invalid: iobroker.vis-plumb@1.0.3 /opt/iobroker/node_modules/iobroker.vis-plumb
      npm ERR! extraneous: jsonata@2.0.4 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
      npm ERR! extraneous: typescript@5.3.3 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
      npm ERR! invalid: samsungtv@0.0.0 /opt/iobroker/node_modules/samsungtv
      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
      npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
      npm ERR! A complete log of this run can be found in: /home/Farmer/.npm/_logs/2024-04-17T16_06_07_268Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      npm ERR! A complete log of this run can be found in: /home/Farmer/.npm/_logs/2024-04-17T16_06_15_318Z-debug-0.log
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      + system.adapter.digitalstrom.0           : digitalstrom          : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.ekey.0                   : ekey                  : iobroker                                 -  enabled, port: 56000, bind: 0.0.0.0
        system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
        system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
        system.adapter.nut.0                    : nut                   : iobroker                                 - disabled
      + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
        system.adapter.pegelalarm.0             : pegelalarm            : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
      + system.adapter.renault.1                : renault               : iobroker                                 -  enabled
      + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
        system.adapter.sayit.1                  : sayit                 : iobroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonnen.0                 : sonnen                : iobroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
      + system.adapter.sql.1                    : sql                   : iobroker                                 -  enabled, port: 3306
      + system.adapter.sql.2                    : sql                   : iobroker                                 -  enabled, port: 3306
      + system.adapter.sql.3                    : sql                   : iobroker                                 -  enabled, port: 3306
        system.adapter.sql.4                    : sql                   : iobroker                                 - disabled, port: 3306
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.vr200.0                  : vr200                 : iobroker                                 - disabled
        system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 192.168.111.20, run as: admin
      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8080, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "digitalstrom" : 2.3.0    , installed 2.3.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "ekey"         : 1.2.3    , installed 1.2.3
      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
      Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.1  [Updatable]
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "parser"       : 2.1.0    , installed 2.1.0
      Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
      Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
      Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
      Adapter    "renault"      : 0.0.15   , installed 0.0.21
      Adapter    "s7"           : 1.4.3    , installed 1.4.2  [Updatable]
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.8.0    , installed 6.9.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "sonnen"       : 1.18.0   , installed 1.17.0 [Updatable]
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.3
      Adapter    "vr200"        : 1.0.0    , installed 1.0.0
      Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
      Adapter    "worx"         : 2.3.4    , installed 2.3.4
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Objects and States
      Objects:        37069
      States:         36368
      Hit:1 http://ftp.debian.org/debian buster InRelease
      Hit:2 http://security.debian.org buster/updates InRelease
      Hit:3 http://ftp.debian.org/debian buster-updates InRelease
      Reading package lists...
      Pending Updates: 30
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          621956498  114/sshd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       621960050  527/io.sonoff.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       621963415  602/io.shelly.0
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        621957189  117/redis-server 12
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          621956646  272/master
      tcp        0      0 192.168.111.20:9292     0.0.0.0:*               LISTEN      1000       621964589  677/io.hm-rpc.2
      tcp        0      0 192.168.111.20:2001     0.0.0.0:*               LISTEN      1000       621961489  557/io.hm-rpc.0
      tcp        0      0 192.168.111.20:2010     0.0.0.0:*               LISTEN      1000       621961914  662/io.hm-rpc.1
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       621957432  128/iobroker.js-con
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          621956647  272/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          621956500  114/sshd
      tcp6       0      0 :::3000                 :::*                    LISTEN      1000       621966717  798/io.fullybrowser
      tcp6       0      0 ::1:6379                :::*                    LISTEN      107        621957190  117/redis-server 12
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       621957604  309/io.admin.0
      tcp6       0      0 :::8080                 :::*                    LISTEN      1000       621967294  861/io.web.1
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       621967111  845/io.simple-api.0
      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       621964977  738/io.sonos.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       621963260  722/io.mihome-vacuu
      udp        0      0 192.168.111.20:5353     0.0.0.0:*                           1000       621963619  647/io.tr-064.0
      udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1000       621970782  921/io.ekey.0
      2024-04-17 17:46:58.438  - info: admin.0 (309) ==> Connected system.user.admin from ::ffff:192.168.108.21
      2024-04-17 17:47:08.911  - info: admin.0 (309) <== Disconnect system.user.admin from ::ffff:192.168.108.21
      2024-04-17 17:47:43.275  - error: proxmox.0 (813) Check storage -- Problem found.. maybe offline
      2024-04-17 17:48:00.028  - info: host.iobroker instance system.adapter.ical.0 started with pid 2164
      2024-04-17 17:48:12.168  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-04-17 17:51:00.022  - info: host.iobroker instance system.adapter.ical.2 started with pid 3139
      2024-04-17 17:51:09.505  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
      2024-04-17 17:51:23.387  - info: host.iobroker "system.adapter.alexa2.0" disabled
      2024-04-17 17:51:23.387  - info: host.iobroker stopInstance system.adapter.alexa2.0 (force=false, process=true)
      2024-04-17 17:51:23.524  - info: host.iobroker stopInstance system.adapter.alexa2.0 send kill signal
      2024-04-17 17:51:24.046  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-04-17 18:00:00.045  - info: host.iobroker instance system.adapter.ical.2 started with pid 3326
      2024-04-17 18:00:00.083  - info: javascript.0 (336) script.js.common.Wetterdaten.Regenmengenmesser: daten in letzte Stunde schreiben
      2024-04-17 18:00:04.082  - info: host.iobroker instance system.adapter.ical.0 started with pid 3341
      2024-04-17 18:00:08.095  - info: host.iobroker instance system.adapter.ical.1 started with pid 3356
      2024-04-17 18:00:10.553  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
      2024-04-17 18:00:15.972  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-04-17 18:00:16.441  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
      2024-04-17 18:01:00.042  - info: host.iobroker instance system.adapter.pegelalarm.0 started with pid 3372
      2024-04-17 18:01:01.133  - info: host.iobroker instance system.adapter.parser.0 scheduled normal terminated and will be restarted on schedule.
      2024-04-17 18:01:01.133  - info: host.iobroker Restart adapter system.adapter.parser.0 because enabled
      2024-04-17 18:01:01.172  - info: pegelalarm.0 (3372) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.19.1, js-controller: 5.0.19
      2024-04-17 18:01:02.230  - info: host.iobroker instance system.adapter.parser.0 started with pid 3387
      2024-04-17 18:01:09.924  - info: pegelalarm.0 (3372) Terminated (NO_ERROR): Without reason
      2024-04-17 18:01:10.434  - info: host.iobroker instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
      iob diag has finished.
      zweiter Teil:
                              v.2023-10-10
                 Chassis: container
          Virtualization: lxc
      Installation:           lxc
      Userland:               amd64
      User-ID:                1001
      X-Server:               false
      Pending OS-Updates:     30
      Pending iob updates:    7
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                              /usr/bin/npm            10.2.4
                              /usr/bin/npx            10.2.4
      Recommended versions are nodejs 18.20.2 and npm 10.5.0
      MEMORY:
      Mem:           6.0G        3.5G        1.9G        8.0M        630M        2.5G
      Swap:          1.0G          0B        1.0G
      Total:         7.0G        3.5G        2.9G
      Active iob-Instances:   36
                              admin                   6.13.16
      Objects type: jsonl
      States  type: redis
      Objects:                37069
      States:                 36368
      Size of iob-Database:
      18M     /opt/iobroker/iobroker-data/objects.json.migrated
      18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      80K     /opt/iobroker/iobroker-data/states.json
      76K     /opt/iobroker/iobroker-data/states.json.bak
      Thomas Braun 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Farmer-cb last edited by
        @farmer-cb sagte in keine Adapter mehr installieren /Updaten:
        ECDSA
        Wird wohl damit in Verbindung stehen.
        https://www.golem.de/news/sicherheitsluecke-in-putty-rekonstruktion-privater-ecdsa-schluessel-moeglich-2404-184208.html
        Da müssen die Schlüssel aktualisiert werden.
          Thomas Braun Most Active @Farmer-cb last edited by Thomas Braun
          Pending OS-Updates: 30 Pending iob updates: 7
          Und neben den Schlüsseln musst du dein System auch auf Stand bringen...
          Leute, Leute, Leute...
          Dabei ist das ein nur Zweizeiler für das OS.
          sudo apt update
          sudo apt full-upgrade
            Seh ich ja jetzt erst...
            Buster ist abgekündigt. Installier da was lebendes.
            Debian 12 'Bookworm' z. B. Im Container ja kein Ding.
              Farmer-cb @Thomas Braun last edited by Farmer-cb
              Servus
              wollte jetzt den iobroker komplett neu aufziehen und ein Backup einspielen. aber leider
              bekomme ich beim Backuperstellen einen Fehler
              Parsing error on getStates("io.undefined"), returning "null" for "undefined": Unexpected token u in JSON at position 0
              host.iobroker 36380 states saved
              host.iobroker 37080 objects saved
              Backup created: /opt/iobroker/backups/2024_04_18-17_08_05_backupiobroker.tar.gz
              This backup can only be restored with js-controller version up from 4.1
              beim wiedereinspielen kommt dann:
              root@iobroker:/opt/iobroker# iobroker  restore 2024_04_18-17_08_05_backupiobroker.tar.gz
              iobroker controller daemon is not running
              host.iobroker OK.
              Removing current installation of iobroker.admin
              removed 43 packages in 1s
              56 packages are looking for funding
                run `npm fund` for details
              Removing current installation of iobroker.backitup
              removed 170 packages in 914ms
              29 packages are looking for funding
              Removing current installation of iobroker.discovery
              removed 44 packages in 2s
              15 packages are looking for funding
              host.iobroker Connecting to new DB "redis/jsonl" (can take up to 20s) ...
              No connection to states 127.0.0.1:6379[redis]
                root@iobroker
                Nicht als root herumhampeln...
                  hab ich verschlafen... jetzt umgestellt
                  iob diag sagt:
                  iob diag (neues system) sagt folgendes:
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Chassis: container ☐
                    Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                   17:33:28 up 31 min,  2 users,  load average: 0.41, 0.53, 0.70
                  CPU threads: 4
                                 Local time: Thu 2024-04-18 17:33:28 CEST
                             Universal time: Thu 2024-04-18 15:33:28 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  Farmer
                  /home/Farmer
                  Farmer sudo users
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            4.3G        105M        3.5G        139K        733M        4.2G
                  Swap:           4.3G        106K        4.3G
                  Total:          8.6G        105M        7.8G
                           4096 M total memory
                            100 M used memory
                            266 M active memory
                            458 M inactive memory
                           3295 M free memory
                              0 M buffer memory
                            699 M swap cache
                           4096 M total swap
                              0 M used swap
                           4095 M free swap
                  * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                  * iobroker.service        loaded failed failed ioBroker Server
                  *** FILESYSTEM ***
                  /dev/mapper/pve-vm--101--disk--0 ext4       16G  2.1G   13G  14% /
                  tmpfs                            tmpfs     1.6G  136K  1.6G   1% /run
                  /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                  /var:
                  479M    /var/
                  250M    /var/cache
                  246M    /var/cache/apt
                  197M    /var/lib
                  170M    /var/cache/apt/archives
                  Archived and active journals take up 8.0M in the file system.
                  22M     /opt/iobroker/backups/
                  15M     /opt/iobroker/iobroker-data/files
                  13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                  1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                  652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                  384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                  USB-Devices by-id:
                  /usr/bin/nodejs         v18.20.2
                  /usr/bin/node           v18.20.2
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  /usr/bin/corepack       0.25.2
                  nodejs:
                    Installed: 18.20.2-1nodesource1
                    Version table:
                   *** 18.20.2-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://security.debian.org/debian-security stable-security/main amd64 Packages
                       18.13.0+dfsg1-1 500
                          500 http://deb.debian.org/debian stable/main amd64 Packages
                  Errors in npm tree:
                  ioBroker Status
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          "admin" not found
                  javascript:     "javascript" not found
                  Adapters from github:   0
                  Adapter State
                    system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + instance is alive
                  Active repo(s): stable
                  Used repository: stable
                  Objects and States
                  Objects:        142
                  States:         76
                  Hit:1 http://security.debian.org/debian-security stable-security InRelease
                  Hit:2 http://deb.debian.org/debian stable InRelease
                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          626469319  300/master
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          626541046  1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          626541048  1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          626467646  1/init
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          626469320  300/master
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          626466679  92/dhclient
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          626541047  1/init
                  udp6       0      0 :::111                  :::*                                0          626541049  1/init
                  2024-04-18 17:14:10.977  - info: host.iobroker received SIGTERM
                  2024-04-18 17:14:10.977  - info: admin.0 (8788) terminating http server on port 8081
                  2024-04-18 17:14:10.978  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                  2024-04-18 17:14:10.979  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                  2024-04-18 17:14:10.979  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                  2024-04-18 17:14:10.982  - info: backitup.0 (8815) Got terminate signal TERMINATE_YOURSELF
                  2024-04-18 17:14:10.981  - info: admin.0 (8788) Got terminate signal TERMINATE_YOURSELF
                  2024-04-18 17:14:10.982  - info: discovery.0 (8830) Got terminate signal TERMINATE_YOURSELF
                  2024-04-18 17:14:10.983  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                  2024-04-18 17:14:10.983  - info: discovery.0 (8830) terminating
                  2024-04-18 17:14:10.983  - info: admin.0 (8788) terminating
                  2024-04-18 17:14:10.983  - info: backitup.0 (8815) terminating
                  2024-04-18 17:14:10.984  - info: admin.0 (8788) Terminated (NO_ERROR): Without reason
                  2024-04-18 17:14:10.983  - info: discovery.0 (8830) Terminated (NO_ERROR): Without reason
                  2024-04-18 17:14:10.984  - info: backitup.0 (8815) Terminated (NO_ERROR): Without reason
                  2024-04-18 17:14:11.029  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
                  2024-04-18 17:14:11.029  - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
                  2024-04-18 17:14:11.479  - info: discovery.0 (8830) terminating
                  2024-04-18 17:14:11.481  - info: backitup.0 (8815) terminating
                  2024-04-18 17:14:11.481  - info: admin.0 (8788) terminating
                  2024-04-18 17:14:11.528  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2024-04-18 17:14:11.533  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2024-04-18 17:14:11.537  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                  2024-04-18 17:14:11.537  - info: host.iobroker All instances are stopped.
                  2024-04-18 17:14:11.650  - info: host.iobroker terminated
                                          v.2023-10-10
                    Virtualization: lxc
                  Installation:           lxc
                  Userland:               amd64
                  User-ID:                1001
                  X-Server:               false
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:    /usr/bin/nodejs         v18.20.2
                                          /usr/bin/npm            10.5.0
                                          /usr/bin/npx            10.5.0
                  MEMORY:
                  Mem:            4.3G        107M        3.4G        139K        740M        4.2G
                  Total:          8.6G        107M        7.7G
                  Active iob-Instances:   1
                                          admin                   "admin" not found
                  ioBroker Status:        iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                142
                  States:                 76
                  4.5M    /opt/iobroker/iobroker-data/objects.jsonl
                  28K     /opt/iobroker/iobroker-data/states.jsonl
                    • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                    • sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                    • iobroker.service loaded failed failed ioBroker Server
                    Eher ungünstig, wenn der Service nicht gestartet ist.
                    sudo systemctl start iobroker.service
                    sagt?
                      als normaler user darf ich das nicht, muss ich den user in einer besonderen gruppe eintrage
                      meldung:
                      Farmer@iobroker:/opt/iobroker$ sudo systemctl start iobroker.service
                      [sudo] password for Farmer:
                      Sorry, user Farmer is not allowed to execute '/usr/bin/systemctl start iobroker.service' as root on iobroker
                        @farmer-cb
                        Das muss der Farmer (am Rande: Besser usernames in Kleinschreibung) aber können:
                        Farmer
                        /home/Farmer
                        Farmer sudo users
                        Hast du den Farmer mal aus- und wieder eingeloggt? Gruppenrechte werden nur beim einloggen neugelesen.
                          habs hinbekommen.
                          sudo systemctl start iobroker.service erzeugt keine Meldung.
                          Aber:
                          Farmer@iobroker:~$ sudo systemctl status iobroker.service
                          * iobroker.service - ioBroker Server
                               Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
                               Active: active (running) since Thu 2024-04-18 18:02:51 CEST; 31s ago
                                 Docs: http://iobroker.net
                             Main PID: 1117 (iobroker.js-con)
                                Tasks: 18 (limit: 9301)
                               Memory: 67.8M
                                  CPU: 1.134s
                               CGroup: /system.slice/iobroker.service
                                       |-1117 iobroker.js-controller
                                       `-1130 /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js _restart
                          Apr 18 18:02:51 iobroker systemd[1]: Started iobroker.service - ioBroker Server.
                          Farmer@iobroker:~$ iobroker status
                          Farmer@iobroker:~$
                            @farmer-cb
                            Ist redis installiert?
                            sudo apt update
                            apt policy redis
                              installiert sich das nicht automatisch bei einer iobroker neuinstallation
                              Farmer@iobroker:/opt/iobroker$ sudo apt update
                              Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Hit:3 http://deb.debian.org/debian stable InRelease
                              Reading package lists... Done
                              Building dependency tree... Done
                              All packages are up to date.
                              Farmer@iobroker:/opt/iobroker$ apt policy redis
                              redis:
                                Installed: (none)
                                Candidate: 5:7.0.15-1~deb12u1
                                Version table:
                                   5:7.0.15-1~deb12u1 500
                                Nein. Wie du siehst nicht. Ist ein Ding vom Betriebssystem und muss vom Administrator manuell hinzugefügt werden. Der ioBroker läuft ja auch in der Voreinstellung nicht mittels redis.
                                Also jetzt
                                sudo apt install redis
                                  was ist eigentlich besser, json/redis.....
                                  hab redis installiert und restore läuft gerade
                                    Hängt von deinem Setup ab.
                                    redis braucht viel RAM, ist aber bei einer großen Zahl von States/Objects schneller als jsonl oder file.
                                      Guten Morgen
                                      Erst einmal vielen vielen Dank für die Unterstützung, jetzt 🏃‍♂️ der iobroker wieder wie 🐖
                                      nun zu:
                                      @Thomas-Braun
                                      sollte ich hier Objects auch auf redis umstellen???
                                      errror npm fehler update
                                      708
