    4. Probleme nach Update Telegramm und Alexa Adapter
      Henny112 last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       16:38:39 up  1:00,  2 users,  load average: 3.84, 3.09, 2.93
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-04-19 16:38:39 CEST
                 Universal time: Fri 2024-04-19 14:38:39 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        1.6G        1.7G         56M        513M        2.0G
      Swap:           99M          0B         99M
      Total:         3.9G        1.6G        1.8G
               3838 M total memory
               1638 M used memory
                271 M active memory
               1779 M inactive memory
               1686 M free memory
                 77 M buffer memory
                436 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  9.4G   19G  34% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     1.9G   57M  1.9G   3% /run
      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      [Fri Apr 19 15:37:50 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:18:E5:11 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bcdf1e39-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Fri Apr 19 15:37:51 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Apr 19 15:37:51 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Apr 19 15:37:53 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.6G    /var/
      1.4G    /var/cache/apt
      1.4G    /var/cache
      1.3G    /var/cache/apt/archives
      97M     /var/lib
      Archived and active journals take up 55.9M in the file system.
      /opt/iobroker/backups:
      1.9G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      982M    /opt/iobroker/iobroker-data/
      552M    /opt/iobroker/iobroker-data/files
      183M    /opt/iobroker/iobroker-data/backup-objects
      176M    /opt/iobroker/iobroker-data/iobroker-data
      158M    /opt/iobroker/iobroker-data/files/vis-2
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2437483-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 600
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 600
           18.20.0-1nodesource1 600
           18.19.1-1nodesource1 600
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: node-mihome@^0.0.32, required by iobroker.javascript@7.8.0
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-19T14_38_53_961Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
        system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : raspberrypi                              - disabled
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled
      + system.adapter.backitup.2               : backitup              : raspberrypi                              -  enabled
      + system.adapter.backitup.3               : backitup              : raspberrypi                              -  enabled
        system.adapter.blockly-plus.0           : blockly-plus          : raspberrypi                              - disabled
      + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
        system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
      + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "deconz"       : 1.4.0    , installed 1.4.0
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "radar2"       : 2.1.0    , installed 2.1.0
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.2.1    , installed 3.2.1
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Objects and States
      Objects:        11993
      States:         10982
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 http://phoscon.de/apt/deconz buster InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        1      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       17848      342/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18463      651/sshd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       78421      17652/io.shelly.1
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17851      342/deCONZ
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       69596      16229/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       69589      16229/iobroker.js-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       71835      16283/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       77717      18505/io.web.0
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       78642      18135/io.nuki-exten
      tcp6       0      0 :::22                   :::*                    LISTEN      0          18465      651/sshd
      tcp6       0      0 :::8089                 :::*                    LISTEN      1001       71098      16372/io.admin.1
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       76103      17513/io.shelly.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       75955      17428/io.radar2.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15160      643/dhcpcd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       73682      17239/io.mihome-vac
      udp        0      0 0.0.0.0:46820           0.0.0.0:*                           108        15917      387/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15915      387/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       75482      17797/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17854      342/deCONZ
      udp6       0      0 :::46482                :::*                                108        15918      387/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15175      643/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        15916      387/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       75484      17797/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       75483      17797/io.deconz.0
      2024-04-19 16:41:25.994  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
      2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
      2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
      2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
      2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/index.js:35:30)
      2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19) {
      2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_INVALID_ARG_VALUE'
      2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]: }
      2024-04-19 16:41:26.002  - error: host.raspberrypi Caught by controller[0]: Node.js v18.20.2
      2024-04-19 16:41:26.002  - error: host.raspberrypi instance system.adapter.telegram.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-04-19 16:41:26.003  - info: host.raspberrypi Restart adapter system.adapter.telegram.1 because enabled
      iob diag has finished.
      Press any key for a summary
        Jaksa @Henny112 last edited by
        @henny112
        Was für Probleme hast du genau? Die Adapter selber laufen habe die selben Versionen im Einsatz.
        Dein System basiert auf Debian 10. Ein sehr guter Anfang wäre das Museum zu schließen und das ganze mal auf Debian 12 anzuheben.
        Erstell dir ein Backup von deinem IOB, installier Debian 12 frisch und spiel dann dein Backup ein und prüfe ob die Adapter dann nicht doch laufen.
          Henny112 @Jaksa last edited by
          @jaksa sagte in Probleme nach Update Telegramm und Alexa Adapter:
          @henny112
          Danke für deine Antwort aber da ja mehrere das Problem haben ist es damit ja nicht aus der Welt geschafft. Sondern nur der einfachste Ausweg. Habe ich dann da ein Problem mit einem Adapter wechsel ich wieder zurück ist ja auch nicht die Lösung des Problems. Alles andere und auch diese Adapter liefen ja bis dahin. Und ich denke da soll man eher schauen was das Problem ist als alles andere. Bisher hatte ich nie Probleme.
          Thomas Braun ? 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Henny112 last edited by Thomas Braun
            @henny112 sagte in Probleme nach Update Telegramm und Alexa Adapter:
            Eines deiner Grundprobleme ist die abgesoffene Version deines Betriebssystems.
            Wenn die Basis sauber ist schaut man sich den Rest an.
            Neuinstallation als reines 64Bit-System.
              A Former User @Henny112 last edited by
              @henny112
              Wenn dein Debian veraltet ist, wirst du bald noch mehr Probleme mit updates bekommen..
                Henny112 @Guest last edited by
                @ilovegym Wird Raspian denn nicht mehr weiter geführt das es veraltet ist ? Debian kenne ich mich gar nicht mit aus . Wo sind da Unterschiede ? LG
                  Raspbian basiert auf Debian. Für den Raspberry werden (insbesondere in der 32Bit-Version) da diverse Dinge noch an den Raspberry angepasst.
                  Die Unterschiede bestehen im wesentlichen aus diesen Gerätespezifischen Anpassungen.
                  Und die Basis Debian 10 'Buster' ist aufgegeben worden. Aktuell ist Debian 12 'Bookworm' die Basis.
                    Henny112 @Thomas Braun last edited by
                    @thomas-braun sagte in Probleme nach Update Telegramm und Alexa Adapter:
                    Das bedeutet ich würde mir die neue Raspian Version laden sehe ich das richtig? Das ja Debian 12 oder welche Version wird empfohlen? Der rest müsste ja so sein wie aktuell oder?
                      @henny112
                      Mach es per RaspiImager.
                      Ich hab mal irgendwo eine Anleitung 'Einfacher geht's nicht' im Forum hinterlassen. Such mal danach.
                        @henny112
                        Ja schaue gleich mal eben neue Karte besorgen. 😂
                        mcm1957 H 2 Replies Last reply Reply Quote 0
                        • mcm1957
                          mcm1957 @Henny112 last edited by
                          Es gab heute kurze Zeit (ca 30 Minuten) ein fehlerhaftes Downloadpaket. Durch eine Neuinstallation bzw ein Update eines Adapters sollte der Fehler automatisch behoben werden.
                          Bitte diesbezügliche Diskussion primär in diesem Topic führen um Parallelitäten zu minimieren.
                            Henny112 @Henny112 last edited by
                            @henny112
                            Danke habe alles neu Installiert läuft wieder aber der Fehler der da war wurde ja genannt. Naja nun ist de SD mal neu. 🙂 Aber danke trotzdem.
                              Henny112 @mcm1957 last edited by
                              @mcm57 sagte in Probleme nach Update Telegramm und Alexa Adapter:
                              Danke Dir aber nun ist alles neu.
                                Danke allen für die Tipps. Habe eine Neuinstallation gemacht nun rennt der Hobel wieder. Vielen Dank an alle. MFG
                                • mcm1957
                                  Für das zugrundeliegende Problem gibts nun einen eigenen Topic mit Erläuterung. Falls noch wer Hilfe braucht bitte dort melden:
                                  https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
                                  657
