    4. zigbee / controller Fehler 'ERR_INVALID_ARG_VALUE'
      Matzeit last edited by
      ich habe zigbee geupdatet (bin eigentlich immer up to date also vorherige Version war 1.10.1 oder 1.10.2). Und seitdem erhalte ich folgende Fehler:
      host.iobroker-produktiv
      	2024-04-19 20:56:10.299	info	Restart adapter system.adapter.zigbee.0 because enabled
      	2024-04-19 20:56:10.299	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      	2024-04-19 20:56:10.298	error	Caught by controller[0]: Node.js v18.20.2
      	2024-04-19 20:56:10.298	error	Caught by controller[0]: }
      	2024-04-19 20:56:10.298	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
      	2024-04-19 20:56:10.297	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22) {
      	2024-04-19 20:56:10.297	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      	2024-04-19 20:56:10.296	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
      	2024-04-19 20:56:10.295	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      	2024-04-19 20:56:10.295	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      	2024-04-19 20:56:10.295	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      	2024-04-19 20:56:10.294	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      	2024-04-19 20:56:10.294	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
      	2024-04-19 20:56:10.294	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1501:13)
      	2024-04-19 20:56:10.293	error	Caught by controller[0]: at new NodeError (node:internal/errors:405:5)
      	2024-04-19 20:56:10.293	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
      	2024-04-19 20:56:10.292	error	Caught by controller[0]: ^
      	2024-04-19 20:56:10.292	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
      	2024-04-19 20:56:10.291	error	Caught by controller[0]: node:internal/modules/cjs/loader:1501
      	2024-04-19 20:56:09.606	info	instance system.adapter.zigbee.0 started with pid 1527
      	2024-04-19 20:55:39.405	info	Restart adapter system.adapter.zigbee.0 because enabled
      Habe Proxmox schon neu gestartet und iobroker VM aber der Adapter läuft nicht mehr. Mir ist aufgefallen, dass ich das Gerät bzw. den Port/ die Schnittstelle auch nicht mehr per Dropdown auswählen kann. Im Zwave Adapter hingegen kann ich die Schnittstelle auswählen.
      Jemand eine Idee/Lösung?
        Homoran Global Moderator Administrators @Matzeit last edited by
        @matzeit sagte in zigbee / controller Fehler 'ERR_INVALID_ARG_VALUE':
        https://forum.iobroker.net/post/1152332
