    4. Microcontroller
    5. TuyaMCU per Tasmota Daten Identifizieren?
      Dieter_P last edited by Dieter_P
      Hi
      versuche mich gerade an einem Stromzähler von ZemiSmart dem ich statt der TuyaCPU CB2S einen ESP mit Tasmota verpasst habe.
      Gleicher Zähler nur mit Zigbee Ankopplung ist bereits per Zigbee2MqTT integriert insofern hatte ich mir erhofft die erwartbaren Datenpunkte dort etwas abzugucken. (https://github.com/zigpy/zha-device-handlers/commit/719490a2fda71ca790252e952224583cb090aa6e)
      Demnach hätte ich aktuelle Spannung, Strom und Leistung erwartet.
      Binde ich nun die TuyaMCU mit Tasmota an kommen da 8 Datenpunkte von der MCU:
      19:32:48.334 TYA: Send "55aa0008000007"
      19:32:48.337 RSL: RESULT = {"TuyaSend":"Done"}
      19:32:48.418 DMP: 55 AA 03 07 00 08 01 02 00 04 00 00 00 00 18
      19:32:48.421 {"TuyaReceived":{"Data":"55AA03070008010200040000000018","Cmnd":7,"CmndData":"0102000400000000","DpType2Id1":0,"1":{"DpId":1,"DpIdType":2,"DpIdData":"00000000"}}}
      19:32:48.424 TYA: fnId=11 is set for dpId=1
      19:32:48.426 TYA: RX value 0 from dpId 1
      19:32:48.429 DMP: 55 AA 03 07 00 08 02 02 00 04 00 00 00 00 19
      19:32:48.431 {"TuyaReceived":{"Data":"55AA03070008020200040000000019","Cmnd":7,"CmndData":"0202000400000000","DpType2Id2":0,"2":{"DpId":2,"DpIdType":2,"DpIdData":"00000000"}}}
      19:32:48.434 TYA: fnId=0 is set for dpId=2
      19:32:48.436 TYA: RX value 0 from dpId 2
      19:32:48.438 DMP: 55 AA 03 07 00 0C 06 00 00 08 09 20 00 00 2D 00 00 04 7D
      19:32:48.441 {"TuyaReceived":{"Data":"55AA0307000C06000008092000002D0000047D","Cmnd":7,"CmndData":"06000008092000002D000004","DpType0Id6":"0x092000002D000004","6":{"DpId":6,"DpIdType":0,"DpIdData":"092000002D000004"}}}
      19:32:48.444 TYA: fnId=33 is set for dpId=6
      19:32:48.446 DMP: 55 AA 03 07 00 05 09 05 00 01 00 1D
      19:32:48.449 {"TuyaReceived":{"Data":"55AA0307000509050001001D","Cmnd":7,"CmndData":"0905000100","DpType5Id9":"0x00","9":{"DpId":9,"DpIdType":5,"DpIdData":"00"}}}
      19:32:48.451 TYA: fnId=0 is set for dpId=9
      19:32:48.453 DMP: 55 AA 03 07 00 05 0C 01 00 01 00 1C
      19:32:48.456 {"TuyaReceived":{"Data":"55AA030700050C010001001C","Cmnd":7,"CmndData":"0C01000100","DpType1Id12":0,"12":{"DpId":12,"DpIdType":1,"DpIdData":"00"}}}
      19:32:48.459 TYA: fnId=0 is set for dpId=12
      19:32:48.460 DMP: 55 AA 03 07 00 08 0D 02 00 04 00 00 00 00 24
      19:32:48.463 {"TuyaReceived":{"Data":"55AA030700080D0200040000000024","Cmnd":7,"CmndData":"0D02000400000000","DpType2Id13":0,"13":{"DpId":13,"DpIdType":2,"DpIdData":"00000000"}}}
      19:32:48.466 TYA: fnId=0 is set for dpId=13
      19:32:48.468 TYA: RX value 0 from dpId 13
      19:32:48.470 DMP: 55 AA 03 07 00 0C 11 00 00 08 07 01 00 0D 08 00 00 00 4B
      19:32:48.473 {"TuyaReceived":{"Data":"55AA0307000C110000080701000D080000004B","Cmnd":7,"CmndData":"110000080701000D08000000","DpType0Id17":"0x0701000D08000000","17":{"DpId":17,"DpIdType":0,"DpIdData":"0701000D08000000"}}}
      19:32:48.476 TYA: fnId=32 is set for dpId=17
      19:32:48.485 DMP: 55 AA 03 07 00 1C 12 00 00 18 01 01 00 3C 03 01 00 FD 04 00 00 B4 07 01 00 00 08 00 00 1E 09 00 00 00 7D
      19:32:48.488 {"TuyaReceived":{"Data":"55AA0307001C120000180101003C030100FD040000B4070100000800001E090000007D","Cmnd":7,"CmndData":"120000180101003C030100FD040000B4070100000800001E09000000","DpType0Id18":"0x0101003C030100FD040000B4070100000800001E09000000","18":{"DpId":18,"DpIdType":0 "DpIdData":"0101003C030100FD040000B4070100000800001E09000000"}}}
      19:32:48.492 TYA: fnId=0 is set for dpId=18
      19:32:48.495 DMP: 55 AA 03 2D 00 00 2F
      Davon wiederum nur 3 (dpId: 6,17 & 18) mit irgendwelchen Daten ungleich 0.
      Jeglicher Versuch das mit 230V und angeschlossener Last 5,5W oder 60W also 24mA oder 260mA in Hexadezimal zu identifizieren ist mir nicht geglückt.
      Klemme ich keine Last bleiben alle 3 dpIds mit gleichen Daten gefüllt.
      Alleinig dpId6 mit dem Inhalt ~0920.... könnte in Decimal konvertiert zu 2341 vielleicht die Spannung mit 233,6V Volt sein.
      Habt Ihr eine Idee dazu?
      Thx!
      0 agocsdaniel committed to zigpy/zha-device-handlers
      Add Zemismart SPM01 energy sensor
      • Ralla66
        Ralla66 Most Active @Dieter_P last edited by Ralla66
        @dieter_p
        Idee Raw Codes
        schau dir mal die Konvertierung an.
          Dieter_P @Ralla66 last edited by
          @ralla66
          Danke. Mittels der Anleitung bin ich auf die Idee zur Spannung für den dpID:6 gekommen.
          Demnach liegt dpId 17 &18 im Raw Format vor und und es gilt zu finden was das ist:
          eine Zuweisung dieser Werte auf bereits bekannte FnIds zeigt bisher kein Ergebnis:
          • Ralla66
            @dieter_p
            die Anfrage der Werte ist ja wichtig, welche Commands / Werte werden angefordert.
            07 scheint ja das Command zu sein.
            19:32:48.456
            {"TuyaReceived":
            "Cmnd":7,
            "DpType1Id12":0,
            {"TuyaReceived":
            gesendeter Befehl
            55AA ist Sync
            03 ??
            07 ist command
            "Cmnd":7,
            Command Data Register ?
            Type 12 ( Integer usw)
            "DpType1Id12":0,
            "12":
            "DpId":12,
            "DpIdType":1,
            "DpIdData":"00" ( Rohdata Wert)
            hier mehrere Werte ?
            "DpIdData":"01010
            03C030100FD040000B4
            070100000800001
            E09000000"
              @ralla66 said in TuyaMCU per Tasmota Daten Identifizieren?:
              @dieter_p
              Das ist ein Opfer meines "Ausschnitts". Ich fordere manuell mit tuyasend0 bei der MCU an alle Stati mitzuteilen.
              21:35:00.641 CMD: tuyasend0
              21:35:00.644 SRC: WebConsole from 192.168.0.2
              21:35:00.647 CMD: Grp 0, Cmd 'TUYASEND', Idx 0, Len 0, Pld -99, Data ''
              21:35:00.650 TYA: Read MCU state
              21:35:00.659 TYA: Send "55aa0008000007"
              21:35:00.663 RSL: RESULT = {"TuyaSend":"Done"}
              Was dann als Received folgt sind die 8 genannten dpIds. Von sich aus schickt die MCU bisher beobachtet nichts. Warum kann ich nicht sagen.
              • Ralla66
                @dieter_p
                was ist denn oben DMP ? Dump Commands ?
                soweit fast klar
                TYA: Send "
                55aa sync
                0008 command
                0000 command
                07 ? CRC ?
                  @dieter_p
                  Ein automatischer Dump. (Meine Selbsterklärung) In der Doku dazu bisher nichts gefunden.
                  Wie Du sagst:
                  55aa03 Frame Header Version Fixed value of 0x55aa
                  07 Command Word 0x06 - send commands 0x07 - report status
                  0005 data lenght
                  0C DpId ->12
                  01 data type boolean
                  00 01 function lenght
                  00 function command -> Off
                  1C Verification CRC
                  Hier also der Switch ID 12 ausgelesen mit dem Wert 0
                  Für die allgemeine MCU Statiabfrage das command 08 ist ebnfalls nicht dokumentiert.
                  • Ralla66
                    @dieter_p
                    dpId 17 ist ja
                    07 Command
                    01 ? je nach Zählweise , 0 und 1 wären 2 Werte ( 07 00 und 07 01 )
                    000D08 a 3 Byte
                    000000 a 3 Byte
                    Was ist denn 17 für ein Wert Volt, Watt ..........................
                    Typisch in Register sind eigentlich Längen von 2 bis 3 Byte
                    Nachtrag , 55aa03 , die 03 würde ich eher Read Register zuordnen.
                    Sync ( 55aa ) ist meist ein simples High / Low
                    0D08 == 3,336 A x 240 Volt == 800 Watt / 10 ungefähr 80 Watt
                      Dieter_P @Ralla66 last edited by Dieter_P
                      Thx. Versuche es gerade plausibel zu bekommen. GGf. fehlt noch der übliche Faktor 10 also 0,3336 A x 232V = 78W mmmh
                      Das seltsame die Werte bekomme ich übermittelt wenn keine Last angeschlossen ist.
                      dpID 6, 17, 18 sind nahezu gleich, egal ob mit oder ohne Last.
                      Ich prüfe das nochmal flott.
                      Ohne Last:
                      dpId 18: "55AA0307001C120000180101003C030100FD040000B4070100000800001E090000007D"
                      dpId 17: "55AA0307000C110000080701000D080000004B"
                      dpId 6: "55AA0307000C06000008091A00000000000046"
                      Mit Last (6W):
                      dpId 6: "55AA0307000C06000008091D00002E0000047B"
                      • Ralla66
                        @dieter_p sagte in TuyaMCU per Tasmota Daten Identifizieren?:
                        Zigbee halt, dauert und dauert .....................................................................
                          Welches Zigbee?
                          Edit: Und gerade nochmal mit 60W Last probiert.
                          Hier auch nur der Unterschied bei dpIx 6 zu sehen (17&18 gleich): 55AA0307000C06000008091D00010500003C
                          000C data length 12
                          06 dpIx 6
                          00 data type raw
                          0008 function length
                          091D0001050000 function command (Länge passt nicht) ergibt aus Hex in Dezimal 2565160644706304 mit einem Divisor von 10 könnten das 0,256A sein was bei ~233V die 60W wären.
                          Ralla66 2 Replies Last reply Reply Quote 0
                          • Ralla66
                            @dieter_p
                            habe mal die Ansicht anders gestaltet da sieht man mehr Auffälligkeiten und ist auch Übersichtlicher.
                            In Data können ja auch Wert und Text in Asci hex stehen, muß ja nicht nur Wert sein.
                            Bsp.: 60 W ist 60 als Wert, Leerzeichen und W als Ascii in Hex 0x57
                            Obwohl mit einer Ungenauigkeit von 20% würde ich bei 60 W rechnen ohne Abgleich.
                            55AA Sync
                            03 Command Read
                            07 00 Command x ( weitere 07 01 -> 07 cmnd 00 und 01 andere Data)
                            0C data length 12
                            06 dpIx 6
                            000000 data type raw ( ist was Integer / Ascii ? )
                            08 function length ( 08 )
                            09 1D Register Wert Volt dec 2.333 / 233 Volt ?
                            00 ?
                            01 function length ( 01 )
                            05 Register Watt Wert ?
                            00003C Raw Data ? hex 3C ist dec 60
                            oder
                            09 1D Register Wert Volt dec 2.333 == 233 Volt ?
                            000105 dec 261 macht 2,61 A ( 2,61 A x 233 Volt == 608,13 == 60,81 Watt )
                            00003C Raw Data ? hex 3C ist dec 60 Watt
                            zerlege mal dpId 18 so dann sieht man mehr, scheinen ja nur mehr Werte zu sein mit 07 01.
                            • Ralla66
                              @dieter_p
                              hast du 2 Zähler oder 3 Phasen wegen der 07 00 und 07 01.
                              Ab 03 01 eventuell Zählerstände ?
                              55AA Sync
                              03 Command Read
                              0700
                              1C // dec 28 data length dec 28 Gesamt ab hier
                              12 dpIx
                              00 function length ( 00 )
                              00
                              18 dec 24 ?
                              0101 2,57 Ampere Wert
                              003C 60 Watt Wert
                              0301
                              00FD04 // dec 64.772
                              0000B4 // dec 212
                              0701
                              00 data length
                              00 dpIx
                              0000
                              1E dec 30 ? hälfte der 60 Watt
                              0900 230,4 Volt
                              00007D dec 125 ? hälfte der A 1,25
                              003C 60 Watt Wert
                              03
                              0100 dec 256 Volt ?
                              00FD dec 253 Volt ?
                              04
                              0000 ?
                              00B4 dec 180 ?
                                @dieter_p
                                Danke! Versuche gerade Deine Analyse nachzuvollziehn und am WE leider nicht dazu gekommen.
                                Das Ding hat nur 1 Phase, schaue ich aber in den Zigbee2Mqtt-Code des ähnlichen Models finde ich dort 2 Zähler zusätzlich zu den 3 Measurements (Spannung, Strom, Leistung):
                                ""Zemismart Power Meter Attributes"""
                                ZEMISMART_TOTAL_ENERGY_ATTR = 0x0201
                                ZEMISMART_TOTAL_REVERSE_ENERGY_ATTR = 0x0202
                                ZEMISMART_VCP_ATTR = 0x0006
                                VCP sagt mir noch nichts.
                                Edit: Einen neuen Benefit sehe ich aus dem Tool bisher nicht, aber möchte es hier nicht vorenthalten:
                                und in der Anleitung wird eindeutig Dein Ansatz bestätigt:
                                "What does the program not help with?
                                Basically, there is one situation where this program cannot help. Some of the more advanced Tuya electricity meters (higher-end, already DIN rail, in the price range of PLN 100 or more) use TuyaMCU to report measurements, but often report a group of measurements in one dpID. Then such a dpID is of the Raw type (no longer Value) and contains several bytes in which (depending on the device) data such as the current value of voltage, current, power, sometimes frequency are stored. Such a raw package has a device-dependent format and it is difficult to decode it more universally.
                                Cheaper products with energy measurement, in turn, do not use TuyaMCU, rather BL0937 or BL0942 are directly connected to the WiFI module there."
                                  @ralla66
                                  Hab mir mal ein Excel gebaut um zu vergleichen. Das jetzt mit 60W Glühlampe und 5,5W LED.
                                  dpIx 6 macht durchaus Sinn:
                                  dpIx 18: auch wenn Ich Deinen gezeigten Ansatz nicht verstanden hab, hab ihn dennoch auch ins Excel überführt aber ein Vergleich 60W Last zu 5,5W macht kaum Sinn, da in beiden Fällen alles identisch bleibt:
                                  • Ralla66
                                    @dieter_p
                                    Systeme sind ja alle ähnlich, dann würde ich Zählerstände suchen in dpIx 18 ab 03 01.
                                    Mögliche Werte wären dann in etwa :
                                    Zum testen könnte man mal versuchen Werte zu nullen wenn es das Gerät hergibt.
                                      @ralla66
                                      Zum Nullen habe ich bisher in Anleitungen und App nichts finden können.
                                      In der App ist noch ein "Balance"-Zähler drin. Wenn ich es aber richtig verstehe ist das aber die Summe der beiden Zählerrichtungen mit einem Preis je kWh aus der App verrechnet. Denke das passiert in der App und kommt nicht von der MCU.
                                      Muß mir mal eine größere Last suchen. In der Auflösung kWh werde ich mit 60W nicht so schnell etwas sehen.
                                      • Ralla66
                                        @dieter_p
                                        -> die Summe der beiden Zählerrichtungen , also 2 Werte
                                        wenn die App ja verrechnet braucht die ja Zählerwerte und die können ja nur von der MCU kommen.
                                        Mal angenommen Teiler ist 100 oder 1000, gibt es ein Bezug zu 647,72 / 64,77 Kw/h oder
                                        1,8 / 0.18 Kw/h ?
                                        3 Stunden 60 Watt Test kommt das hin ?
                                        Das riecht nach Energy Total und Today 🙂
                                        D 3 Replies Last reply Reply Quote 0
                                          @ralla66
                                          Denke das ist gerade mein Hauptproblem. Ich habe den Zähler nie im Orginalzustand betrieben sondern direkt mit ESP umgebaut. Von daher weiß ich A) nicht wie der aktuelle Zählerstand ist und kann nur vermuten, dass er bei 0 gestartet ist.
                                          Mit 60W und 5,5W ist das Ding allerhöchstens 30 Minuten in Betrieb gewesen und davon bestimmt nur 5 Minuten mit der 60W Birne -> der Zähler kann sich nicht groß bewegt haben.
                                          Der Zähler in Speiserichtung kann noch weniger gezählt haben da ich ihn höchsten 2 Minuten am Anfang falschrum in Betrieb hatte mit 5,5W.
                                          Aber mein Problem B) habe im Moment keine sichere Referenz um mir ein Delta im Zählerstand ableiten zu können. Muß mir mal ein Kabel bauen und denke daran meinen Fön mit 1800W mal 10 Minuten laufen zu lassen was ja zu mindest 0,3kWh sichtbar machen sollte.
                                            @ralla66
                                            Sieht nicht gut aus und irgendwas erscheint mir inaktiv auch durch die blinkende LED des Geräts signalisiert.
                                            Hab jetzt einen Test gefahren mit dem Fön 2,2kW für 2 Min und dpIx 17 & 18 bleiben völlig unverändert. dpIx 6 macht Sinn:
                                            81.0k
                                            1760
