Fehlermeldung bei Adapter installation.
Moin @foxriver76
Moin @apollon77
Moin @ AllWeiß jemand etwas mit diesen Fehlermeldungen etwas anzufangen?
Ist der deyeidc Adapter von raschy
Habe Issues angelegt, aber er weiß damit nichts anzufangen.2024-05-06 13:41:14.897 - info: host.rockpro64 iobroker url https://github.com/raschy/ioBroker.deyeidc --host rockpro64 --debug 2024-05-06 13:41:17.819 - info: host.rockpro64 iobroker install raschy/ioBroker.deyeidc#c8e6ee63f93e3bc8f6bef811e9dc77a6061b1dcb 2024-05-06 13:41:18.826 - info: host.rockpro64 iobroker NPM version: 10.5.0 2024-05-06 13:41:18.828 - info: host.rockpro64 iobroker Installing raschy/ioBroker.deyeidc#c8e6ee63f93e3bc8f6bef811e9dc77a6061b1dcb... (System call) 2024-05-06 13:41:30.679 - info: host.rockpro64 iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/raschy/ioBroker.deyeidc.git 2024-05-06 13:41:33.640 - info: host.rockpro64 iobroker npm ERR! code 1 2024-05-06 13:41:33.642 - info: host.rockpro64 iobroker npm ERR! path /opt/iobroker/node_modules/utf-8-validate 2024-05-06 13:41:33.650 - info: host.rockpro64 iobroker npm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! make: Entering directory '/opt/iobroker/node_modules/utf-8-validate/build'npm ERR! CC(target) Release/obj.target/validation/src/validation.onpm ERR! make: Leaving directory '/opt/iobroker/node_modules/utf-8-validate/build'npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@10.1.0npm ERR! gyp info using node@18.20.2 | linux | arm64npm ERR! gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/utf-8-validate/build/config.gypi', 2024-05-06 13:41:33.657 - info: host.rockpro64 iobroker npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/utf-8-validate',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! make: cc: No such file or directorynpm ERR! make: *** [validation.target.mk:111: Release/obj.target/validation/src/validation.o] Error 127npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/node-gyp/lib/build.js:209:23)npm ERR! gyp ERR! System Linux 5.15.93-rockchip64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validatenpm ERR! gyp ERR! node -v v18.20.2npm ERR! gyp ERR! node-gyp -v v10.1.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T11_41_19_591Z-debug-0.log 2024-05-06 13:41:33.708 - error: host.rockpro64 iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/raschy/ioBroker.deyeidc.git npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/utf-8-validatenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! make: Entering directory '/opt/iobroker/node_modules/utf-8-validate/build'npm ERR! CC(target) Release/obj.target/validation/src/validation.onpm ERR! make: Leaving directory '/opt/iobroker/node_modules/utf-8-validate/build'npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@10.1.0npm ERR! gyp info using node@18.20.2 | linux | arm64npm ERR! gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/utf-8-validate/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/utf-8-validate',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! make: cc: No such file or directorynpm ERR! make: *** [validation.target.mk:111: Release/obj.target/validation/src/validation.o] Error 127npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/node-gyp/lib/build.js:209:23)npm ERR! gyp ERR! System Linux 5.15.93-rockchip64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validatenpm ERR! gyp ERR! node -v v18.20.2npm ERR! gyp ERR! node-gyp -v v10.1.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T11_41_19_591Z-debug-0.log 2024-05-06 13:41:33.710 - error: host.rockpro64 iobroker host.rockpro64 Cannot install raschy/ioBroker.deyeidc#c8e6ee63f93e3bc8f6bef811e9dc77a6061b1dcb: 1 2024-05-06 13:41:34.773 - info: host.rockpro64 iobroker exit 25 -
@malleralle sagte in Fehlermeldung bei Adapter installation.:
Schau in das Log.
/home/iobroker/.npm/_logs/2024-05-06T11_41_19_591Z-debug-0.log -
info run bufferutil@4.0.8 install node_modules/bufferutil node-gyp-build 63 info run bufferutil@4.0.8 install { code: 1, signal: null } 64 timing reify:rollback:createSparse Completed in 21ms 65 timing reify:rollback:retireShallow Completed in 0ms 66 timing command:i Completed in 11362ms 67 verbose stack Error: command failed 67 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27) 67 verbose stack at ChildProcess.emit (node:events:517:28) 67 verbose stack at maybeClose (node:internal/child_process:1098:16) 67 verbose stack at Socket.<anonymous> (node:internal/child_process:450:11) 67 verbose stack at Socket.emit (node:events:517:28) 67 verbose stack at Pipe.<anonymous> (node:net:350:12) 68 verbose pkgid bufferutil@4.0.8 69 verbose cwd /opt/iobroker/node_modules 70 verbose Linux 5.15.93-rockchip64 71 verbose node v18.20.2 72 verbose npm v10.5.0 73 error code 1 74 error path /opt/iobroker/node_modules/bufferutil 75 error command failed 76 error command sh -c node-gyp-build 77 error make: Entering directory '/opt/iobroker/node_modules/bufferutil/build' 77 error CC(target) Release/obj.target/bufferutil/src/bufferutil.o 77 error make: Leaving directory '/opt/iobroker/node_modules/bufferutil/build' 78 error gyp info it worked if it ends with ok 78 error gyp info using node-gyp@10.1.0 78 error gyp info using node@18.20.2 | linux | arm64 78 error gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3" 78 error gyp info spawn /usr/bin/python3 78 error gyp info spawn args [ 78 error gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', 78 error gyp info spawn args 'binding.gyp', 78 error gyp info spawn args '-f', 78 error gyp info spawn args 'make', 78 error gyp info spawn args '-I', 78 error gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi', 78 error gyp info spawn args '-I', 78 error gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', 78 error gyp info spawn args '-I', 78 error gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.2/include/node/common.gypi', 78 error gyp info spawn args '-Dlibrary=shared_library', 78 error gyp info spawn args '-Dvisibility=default', 78 error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.2', 78 error gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', 78 error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.2/<(target_arch)/node.lib', 78 error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil', 78 error gyp info spawn args '-Dnode_engine=v8', 78 error gyp info spawn args '--depth=.', 78 error gyp info spawn args '--no-parallel', 78 error gyp info spawn args '--generator-output', 78 error gyp info spawn args 'build', 78 error gyp info spawn args '-Goutput_dir=.' 78 error gyp info spawn args ] 78 error gyp info spawn make 78 error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ] 78 error make: cc: No such file or directory 78 error make: *** [bufferutil.target.mk:111: Release/obj.target/bufferutil/src/bufferutil.o] Error 127 78 error gyp ERR! build error 78 error gyp ERR! stack Error: `make` failed with exit code: 2 78 error gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-gyp/lib/build.js:209:23) 78 error gyp ERR! System Linux 5.15.93-rockchip64 78 error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild" 78 error gyp ERR! cwd /opt/iobroker/node_modules/bufferutil 78 error gyp ERR! node -v v18.20.2 78 error gyp ERR! node-gyp -v v10.1.0 78 error gyp ERR! not ok -
buildenvironment vollständig?
apt policy build-essential -
$ apt policy build-essential build-essential: Installiert: 12.9ubuntu3 Installationskandidat: 12.9ubuntu3 Versionstabelle: *** 12.9ubuntu3 500 500 http://ports.ubuntu.com jammy/main arm64 Packages 100 /var/lib/dpkg/status -
Skript v.2024-04-21 *** BASE SYSTEM *** Static hostname: rockpro64 Icon name: computer Operating System: Ubuntu 22.04.4 LTS Kernel: Linux 5.15.93-rockchip64 Architecture: arm64 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 15:55:10 up 2:55, 1 user, load average: 1.30, 1.23, 1.08 CPU threads: 6 *** Time and Time Zones *** Local time: Mon 2024-05-06 15:55:10 CEST Universal time: Mon 2024-05-06 13:55:10 UTC RTC time: Mon 2024-05-06 13:55:10 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': rockpro64 HOME=/home/rockpro64 GROUPS=rockpro64 tty disk dialout sudo audio video plugdev games users systemd-journal input netdev _ssh lpadmin iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev i2c bluetooth *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.9G 3.0G 164M 10M 715M 781M Swap: 1.9G 1.1G 812M Total: 5.8G 4.1G 977M Active iob-Instances: 39 3863 M total memory 2983 M used memory 1544 M active memory 1337 M inactive memory 164 M free memory 81 M buffer memory 634 M swap cache 1931 M total swap 1119 M used swap 812 M free swap *** top - Table Of Processes *** top - 15:55:11 up 2:55, 1 user, load average: 1.30, 1.23, 1.08 Tasks: 260 total, 1 running, 259 sleeping, 0 stopped, 0 zombie %Cpu(s): 8.1 us, 4.8 sy, 0.0 ni, 87.1 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3863.0 total, 164.0 free, 2983.5 used, 715.5 buff/cache MiB Swap: 1931.5 total, 812.3 free, 1119.2 used. 781.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * rc-local.service loaded failed failed /etc/rc.local Compatibility LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 387M 21M 366M 6% /run /dev/sda1 ext4 59G 25G 33G 43% / tmpfs tmpfs 1.9G 4.0K 1.9G 1% /dev/shm tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 1.9G 920K 1.9G 1% /tmp /dev/zram1 ext4 47M 18M 26M 41% /var/log tmpfs tmpfs 387M 0 387M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon May 6 12:59:49 2024] Kernel command line: root=UUID=fbc89545-e72e-44f3-bbbc-44a3ff945d2a rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [Mon May 6 12:59:59 2024] EXT4-fs (sda1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none. [Mon May 6 13:00:03 2024] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [Mon May 6 13:00:08 2024] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,noatime,errors=remount-ro,commit=600 |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime | |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | | `-/sys/kernel/debug/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime | `-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,nosuid,nodev,noexec,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct | `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime |-/dev udev devtmpfs rw,nosuid,relatime,size=1902140k,nr_inodes=475535,mode=755 | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/hugepages hugetlbfs hugetlbfs rw,relatime,pagesize=2M | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=395576k,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/credentials/systemd-sysusers.service none ramfs ro,nosuid,nodev,noexec,relatime,mode=700 | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=395572k,nr_inodes=98893,mode=700,uid=1000,gid=1000 |-/tmp tmpfs tmpfs rw,nosuid,relatime |-/var/log.hdd /dev/sda1[/var/log] ext4 rw,noatime,errors=remount-ro,commit=600 `-/var/log /dev/zram1 ext4 rw,relatime,discard Files in neuralgic directories: /var: 4.7G /var/ 4.4G /var/lib 3.5G /var/lib/plexmediaserver/Library/Application Support/Plex Media Server 3.5G /var/lib/plexmediaserver/Library/Application Support 3.5G /var/lib/plexmediaserver/Library Archived and active journals take up 19.3M in the file system. /opt/iobroker/backups: 230M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 820M /opt/iobroker/iobroker-data/ 581M /opt/iobroker/iobroker-data/files 146M /opt/iobroker/iobroker-data/backup-objects 121M /opt/iobroker/iobroker-data/files/javascript.admin 101M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 43M /opt/iobroker/iobroker-data/states.jsonl 39M /opt/iobroker/iobroker-data/objects.jsonl 38M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_68a1518bde1aec11b17674e5f01c6278-if00-port0 HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/SONOFF *** NodeJS-Installation *** /usr/bin/nodejs v18.20.2 /usr/bin/node v18.20.2 /usr/bin/npm 10.5.0 /usr/bin/npx 10.5.0 /usr/bin/corepack 0.25.2 nodejs: Installed: 18.20.2-1nodesource1 Candidate: 18.20.2-1nodesource1 Version table: *** 18.20.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.20.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 12.22.9~dfsg-1ubuntu3.5 500 500 http://ports.ubuntu.com jammy-security/universe arm64 Packages 500 http://ports.ubuntu.com jammy-updates/universe arm64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://ports.ubuntu.com jammy/universe arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.19 admin: 6.17.6 javascript: 8.1.1 nodejs modules from github: 7 +-- iobroker.broadlink@0.1.5 (git+ssh://git@github.com/hieblmedia/ioBroker.broadlink.git#8ae2d84e3641e3dc98029d77d7072502e5e55346) +-- iobroker.epson_workforce@0.0.4 (git+ssh://git@github.com/rrov1/ioBroker.epson_workforce.git#429c9a158984e8e3e197bc05d965e6810dff551e) +-- iobroker.google-sharedlocations@2.1.6 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#387af5f4ecd91225484f996a291232d04c9745a8) +-- iobroker.hiob@0.1.4 (git+ssh://git@github.com/moba15/ioBroker.hiob.git#6c6affd82241bc6e6bcaae766cb498804e2b2413) +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946) +-- iobroker.rtl_433@1.1.6 (git+ssh://git@github.com/phillipssc/ioBroker.rtl_433.git#09e16f677bb29548939493c8c2aba6b5be75bc5e) +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92) Adapter State + system.adapter.admin.0 : admin : rockpro64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa-timer-vis.0 : alexa-timer-vis : rockpro64 - enabled system.adapter.alexa-timer-vis.1 : alexa-timer-vis : rockpro64 - disabled + system.adapter.alexa2.0 : alexa2 : rockpro64 - enabled system.adapter.alexa2.1 : alexa2 : rockpro64 - disabled + system.adapter.amazon-dash.0 : amazon-dash : rockpro64 - enabled + system.adapter.backitup.0 : backitup : rockpro64 - enabled + system.adapter.broadlink.0 : broadlink : rockpro64 - enabled + system.adapter.broadlink2.0 : broadlink2 : rockpro64 - enabled system.adapter.coronavirus-statistics.0 : coronavirus-statistics: rockpro64 - disabled system.adapter.daswetter.0 : daswetter : rockpro64 - enabled system.adapter.discovery.0 : discovery : rockpro64 - disabled system.adapter.dwd.0 : dwd : rockpro64 - enabled + system.adapter.email.0 : email : rockpro64 - enabled + system.adapter.enigma2.0 : enigma2 : rockpro64 - enabled + system.adapter.enigma2.1 : enigma2 : rockpro64 - enabled system.adapter.enigma2.2 : enigma2 : rockpro64 - disabled system.adapter.enigma2.3 : enigma2 : rockpro64 - disabled + system.adapter.epson_workforce.0 : epson_workforce : rockpro64 - enabled system.adapter.feiertage.0 : feiertage : rockpro64 - enabled system.adapter.firetv.0 : firetv : rockpro64 - disabled system.adapter.flot.0 : flot : rockpro64 - disabled + system.adapter.google-sharedlocations.0 : google-sharedlocations: rockpro64 - enabled + system.adapter.hiob.0 : hiob : rockpro64 - enabled, port: 7999 + system.adapter.history.0 : history : rockpro64 - enabled + system.adapter.hm-rega.0 : hm-rega : rockpro64 - enabled + system.adapter.hm-rpc.2 : hm-rpc : rockpro64 - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : rockpro64 - enabled, port: 12001 system.adapter.hs100.0 : hs100 : rockpro64 - disabled system.adapter.ical.0 : ical : rockpro64 - enabled system.adapter.ical.1 : ical : rockpro64 - enabled system.adapter.ical.2 : ical : rockpro64 - enabled system.adapter.ical.3 : ical : rockpro64 - enabled system.adapter.ical.4 : ical : rockpro64 - enabled system.adapter.ical.5 : ical : rockpro64 - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: rockpro64 - disabled system.adapter.icons-icons8.0 : icons-icons8 : rockpro64 - disabled system.adapter.icons-material-svg.0 : icons-material-svg : rockpro64 - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : rockpro64 - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : rockpro64 - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: rockpro64 - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : rockpro64 - disabled + system.adapter.info.0 : info : rockpro64 - enabled + system.adapter.iot.0 : iot : rockpro64 - enabled + system.adapter.javascript.0 : javascript : rockpro64 - enabled system.adapter.mobile.0 : mobile : rockpro64 - disabled system.adapter.mqtt.0 : mqtt : rockpro64 - disabled, port: 1883, bind: 192.168.123.248 + system.adapter.mytime.0 : mytime : rockpro64 - enabled + system.adapter.nut.0 : nut : rockpro64 - enabled + system.adapter.paw.0 : paw : rockpro64 - enabled, port: 9876 system.adapter.pollenflug.0 : pollenflug : rockpro64 - disabled + system.adapter.radar2.0 : radar2 : rockpro64 - enabled + system.adapter.rtl_433.0 : rtl_433 : rockpro64 - enabled system.adapter.schoolfree.0 : schoolfree : rockpro64 - enabled + system.adapter.shelly.0 : shelly : rockpro64 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : rockpro64 - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.socketio.0 : socketio : rockpro64 - disabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sourceanalytix.0 : sourceanalytix : rockpro64 - enabled system.adapter.statistics.0 : statistics : rockpro64 - disabled + system.adapter.tado.0 : tado : rockpro64 - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : rockpro64 - enabled + system.adapter.telegram.0 : telegram : rockpro64 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : rockpro64 - enabled + system.adapter.trashschedule.0 : trashschedule : rockpro64 - enabled + system.adapter.tuya.0 : tuya : rockpro64 - enabled system.adapter.tvspielfilm.0 : tvspielfilm : rockpro64 - disabled system.adapter.vis-bars.0 : vis-bars : rockpro64 - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : rockpro64 - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : rockpro64 - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : rockpro64 - disabled system.adapter.vis-history.0 : vis-history : rockpro64 - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : rockpro64 - disabled system.adapter.vis-icontwo.0 : vis-icontwo : rockpro64 - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : rockpro64 - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : rockpro64 - disabled system.adapter.vis-justgage.0 : vis-justgage : rockpro64 - disabled system.adapter.vis-keyboard.0 : vis-keyboard : rockpro64 - disabled system.adapter.vis-lcars.0 : vis-lcars : rockpro64 - disabled system.adapter.vis-map.0 : vis-map : rockpro64 - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : rockpro64 - disabled system.adapter.vis-material.0 : vis-material : rockpro64 - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : rockpro64 - disabled system.adapter.vis-metro.0 : vis-metro : rockpro64 - disabled system.adapter.vis-players.0 : vis-players : rockpro64 - disabled system.adapter.vis-rgraph.0 : vis-rgraph : rockpro64 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : rockpro64 - disabled system.adapter.vis-weather.0 : vis-weather : rockpro64 - disabled system.adapter.vis.0 : vis : rockpro64 - enabled system.adapter.weatherunderground.0 : weatherunderground : rockpro64 - enabled + system.adapter.web.0 : web : rockpro64 - enabled, port: 8082, bind: 192.168.123.248, run as: admin + system.adapter.ws.0 : ws : rockpro64 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : rockpro64 - enabled, port: /dev/SONOFF + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : rockpro64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hiob.0 : hiob : rockpro64 - enabled, port: 7999 + system.adapter.hm-rpc.2 : hm-rpc : rockpro64 - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : rockpro64 - enabled, port: 12001 + system.adapter.paw.0 : paw : rockpro64 - enabled, port: 9876 + system.adapter.shelly.0 : shelly : rockpro64 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : rockpro64 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : rockpro64 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : rockpro64 - enabled, port: 8082, bind: 192.168.123.248, run as: admin + system.adapter.ws.0 : ws : rockpro64 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : rockpro64 - enabled, port: /dev/SONOFF ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): beta Installed ioBroker-Instances Used repository: beta Adapter "admin" : 6.17.6 , installed 6.17.6 Adapter "alexa-timer-vis": 0.3.0 , installed 0.3.0 Adapter "alexa2" : 3.26.5 , installed 3.26.5 Adapter "amazon-dash" : 1.2.0 , installed 1.2.0 Adapter "backitup" : 2.11.0 , installed 2.11.0 Adapter "broadlink2" : 2.2.0 , installed 2.2.0 Adapter "coronavirus-statistics": 0.9.0, installed 0.9.0 Adapter "daswetter" : 3.1.13 , installed 3.1.13 Adapter "discovery" : 4.5.0 , installed 4.5.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "email" : 1.3.0 , installed 1.3.0 Adapter "enigma2" : 2.1.0 , installed 2.1.0 Adapter "feiertage" : 1.2.0 , installed 1.2.0 Adapter "firetv" : 2.1.0 , installed 2.1.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hm-rega" : 4.0.0 , installed 4.0.0 Adapter "hm-rpc" : 1.17.0 , installed 1.17.0 Adapter "hs100" : 2.2.0 , installed 2.2.0 Adapter "ical" : 1.15.0 , installed 1.15.0 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "iot" : 3.2.2 , installed 3.2.2 Adapter "javascript" : 8.1.1 , installed 8.1.1 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "mytime" : 0.7.12 , installed 0.7.12 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "paw" : 0.3.2 , installed 0.3.2 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "radar2" : 2.2.0 , installed 2.2.0 Adapter "schoolfree" : 1.1.4 , installed 1.1.4 Adapter "shelly" : 7.0.0 , installed 7.0.0 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.7.0 , installed 6.7.0 Adapter "sourceanalytix": 0.4.14 , installed 0.4.14 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "tado" : 0.5.4 , installed 0.5.4 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 3.2.1 , installed 3.2.1 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "tvspielfilm" : 2.1.0 , installed 2.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-lcars" : 1.1.1 , installed 1.1.1 Adapter "vis-map" : 1.1.0 , installed 1.1.0 Adapter "vis-material" : 0.1.3 , installed 0.1.3 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.94 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.1 , installed 2.6.1 Adapter "zigbee" : 1.10.3 , installed 1.10.3 Objects and States Please stand by - This may take a while Objects: 26986 States: 27627 *** OS-Repositories and Updates *** Hit:1 https://downloads.plex.tv/repo/deb public InRelease Hit:2 http://ports.ubuntu.com jammy InRelease Hit:3 http://ports.ubuntu.com jammy-security InRelease Hit:4 http://ports.ubuntu.com jammy-updates InRelease Hit:5 https://apt.pivccu.de/piVCCU stable InRelease Hit:6 http://ports.ubuntu.com jammy-backports InRelease Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 24751 2995/sendmail: MTA: tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 17698 1/init tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 20108 1810/apache2 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 19970 1401/sshd: /usr/sbi tcp 0 0 127.0.0.1:587 0.0.0.0:* LISTEN 0 24752 2995/sendmail: MTA: tcp 0 0 10.0.3.1:53 0.0.0.0:* LISTEN 0 20094 1792/dnsmasq tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 22056 1247/iobroker.js-co tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 22051 1247/iobroker.js-co tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN 0 22981 1242/cupsd tcp 0 0 192.168.123.248:12001 0.0.0.0:* LISTEN 1001 24823 3167/io.hm-rpc.3 tcp 0 0 0.0.0.0:7575 0.0.0.0:* LISTEN 0 21685 1402/vhusbdarm64 tcp 0 0 127.0.0.1:33979 0.0.0.0:* LISTEN 998 20123 1841/Plex Plug-in [ tcp 0 0 192.168.123.248:8082 0.0.0.0:* LISTEN 1001 31879 4065/io.web.0 tcp 0 0 192.168.123.248:2010 0.0.0.0:* LISTEN 1001 31208 3774/io.hm-rpc.2 tcp 0 0 127.0.0.1:3493 0.0.0.0:* LISTEN 0 21727 1512/upsd tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 25165 3607/io.shelly.0 tcp 0 0 127.0.0.1:32401 0.0.0.0:* LISTEN 998 21833 1329/Plex Media Ser tcp 0 0 127.0.0.1:32600 0.0.0.0:* LISTEN 998 11083 2212/Plex Tuner Ser tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 101 19765 759/systemd-resolve tcp6 0 0 :::111 :::* LISTEN 0 17700 1/init tcp6 0 0 :::22 :::* LISTEN 0 19972 1401/sshd: /usr/sbi tcp6 0 0 :::631 :::* LISTEN 0 22982 1242/cupsd tcp6 0 0 :::8084 :::* LISTEN 1001 32777 4076/io.ws.0 tcp6 0 0 :::8087 :::* LISTEN 1001 30467 3944/io.simple-api. tcp6 0 0 :::8081 :::* LISTEN 1001 22181 2270/io.admin.0 tcp6 0 0 :::7999 :::* LISTEN 1001 22446 3058/io.hiob.0 tcp6 0 0 :::9876 :::* LISTEN 1001 29182 3914/io.paw.0 tcp6 0 0 :::32400 :::* LISTEN 998 21831 1329/Plex Media Ser udp 0 0 127.0.0.1:56223 0.0.0.0:* 998 23095 1329/Plex Media Ser udp 0 0 192.168.123.248:33835 0.0.0.0:* 998 23103 1329/Plex Media Ser udp 0 0 10.0.3.1:40080 0.0.0.0:* 998 23096 1329/Plex Media Ser udp 0 0 0.0.0.0:46472 0.0.0.0:* 1001 27181 3753/io.broadlink.0 udp 0 0 192.168.123.248:60817 0.0.0.0:* 998 23100 1329/Plex Media Ser udp 0 0 0.0.0.0:52857 0.0.0.0:* 1001 31151 3753/io.broadlink.0 udp 0 0 0.0.0.0:32410 0.0.0.0:* 998 20131 1329/Plex Media Ser udp 0 0 0.0.0.0:32412 0.0.0.0:* 998 23093 1329/Plex Media Ser udp 0 0 0.0.0.0:32413 0.0.0.0:* 998 23094 1329/Plex Media Ser udp 0 0 0.0.0.0:32414 0.0.0.0:* 998 20130 1329/Plex Media Ser udp 0 0 0.0.0.0:1901 0.0.0.0:* 998 23101 1329/Plex Media Ser udp 0 0 0.0.0.0:49102 0.0.0.0:* 1001 24742 2646/io.broadlink2. udp 0 0 192.168.123.248:43060 0.0.0.0:* 998 23097 1329/Plex Media Ser udp 0 0 10.0.3.1:53 0.0.0.0:* 0 20093 1792/dnsmasq udp 0 0 127.0.0.53:53 0.0.0.0:* 101 19764 759/systemd-resolve udp 0 0 0.0.0.0:67 0.0.0.0:* 1001 27917 3525/io.radar2.0 udp 0 0 0.0.0.0:67 0.0.0.0:* 0 20090 1792/dnsmasq udp 0 0 127.0.0.1:39015 0.0.0.0:* 998 23098 1329/Plex Media Ser udp 0 0 0.0.0.0:111 0.0.0.0:* 0 17699 1/init udp 0 0 10.0.3.1:39124 0.0.0.0:* 998 23099 1329/Plex Media Ser udp 0 0 127.0.0.1:323 0.0.0.0:* 0 10767 1323/chronyd udp 0 0 0.0.0.0:39302 0.0.0.0:* 1001 164134 2646/io.broadlink2. udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 29023 3644/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 29024 3644/io.tuya.0 udp 0 0 10.0.3.1:45595 0.0.0.0:* 998 23102 1329/Plex Media Ser udp 0 0 0.0.0.0:15001 0.0.0.0:* 1001 22289 2646/io.broadlink2. udp 0 0 0.0.0.0:54028 0.0.0.0:* 1001 24743 2646/io.broadlink2. udp6 0 0 :::111 :::* 0 10337 1/init udp6 0 0 ::1:323 :::* 0 10768 1323/chronyd *** Log File - Last 25 Lines *** 2024-05-06 15:33:10.390 - info: ical.3 (36291) Terminated (NO_ERROR): Without reason 2024-05-06 15:33:10.954 - info: host.rockpro64 instance system.adapter.ical.3 terminated with code 0 (NO_ERROR) 2024-05-06 15:34:00.041 - info: host.rockpro64 instance system.adapter.ical.4 started with pid 36380 2024-05-06 15:34:03.404 - info: ical.4 (36380) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19 2024-05-06 15:34:10.379 - info: ical.4 (36380) Terminated (NO_ERROR): Without reason 2024-05-06 15:34:10.949 - info: host.rockpro64 instance system.adapter.ical.4 terminated with code 0 (NO_ERROR) 2024-05-06 15:35:00.121 - info: host.rockpro64 instance system.adapter.ical.5 started with pid 36734 2024-05-06 15:35:00.285 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200 2024-05-06 15:35:00.368 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200 2024-05-06 15:35:03.821 - info: ical.5 (36734) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19 2024-05-06 15:35:10.644 - info: ical.5 (36734) Terminated (NO_ERROR): Without reason 2024-05-06 15:35:11.210 - info: host.rockpro64 instance system.adapter.ical.5 terminated with code 0 (NO_ERROR) 2024-05-06 15:40:00.225 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200 2024-05-06 15:40:00.336 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200 2024-05-06 15:45:00.240 - info: javascript.0 (2559) script.js.Datenpunkte.TPLinkVerbrauch: hs100 Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 6 2024-05-06 15:45:00.242 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200 2024-05-06 15:45:00.289 - info: javascript.0 (2559) script.js.Datenpunkte.ShellyVerbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 13 | Reboots korrigiert: 0 | Unveränderte Werte: 18 2024-05-06 15:45:00.330 - info: javascript.0 (2559) script.js.Datenpunkte.HomematicVerbrauch: Homematic Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0 2024-05-06 15:45:00.371 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200 2024-05-06 15:50:00.336 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200 2024-05-06 15:50:00.445 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200 2024-05-06 15:55:00.286 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200 2024-05-06 15:55:00.394 - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200======================= SUMMARY ======================= v.2024-04-21 Static hostname: rockpro64 Icon name: computer Operating System: Ubuntu 22.04.4 LTS Kernel: Linux 5.15.93-rockchip64 Architecture: arm64 Installation: native Kernel: aarch64 Userland: 64 bit Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 Display-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.20.2 /usr/bin/node v18.20.2 /usr/bin/npm 10.5.0 /usr/bin/npx 10.5.0 /usr/bin/corepack 0.25.2 Recommended versions are nodejs 18.20.2 and npm 10.5.0 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.9G 2.8G 217M 7.0M 882M 988M Swap: 1.9G 1.4G 496M Total: 5.8G 4.2G 713M Active iob-Instances: 39 Active repo(s): beta ioBroker Core: js-controller 5.0.19 admin 6.17.6 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : rockpro64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : rockpro64 - enabled, port: 8082, bind: 192.168.123.248, run as: admin Objects: 26986 States: 27627 Size of iob-Database: 39M /opt/iobroker/iobroker-data/objects.jsonl 46M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ==================== -
Nimm mal die Links zu Reginas Kalendern aus dem Log (letzte Zeilen) raus.
Danke, ist raus. Shit übersehen... -
r$ npm ls bufferutil iobroker.inst@3.0.0 /opt/iobroker └── (empty)
