    4. Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      anno171986 last edited by
      Moin, ich habe seit ein paar tagen das problem, das mein iobroker fast gar nicht mehr läuft, wenn er denn kurz läuft ist er sehr träge.
      Hier die Infos:
      • Adaptername: iobroker Allgemein
      • Link zu Adapterrepository: n/a
      • Adapterversion: n/a
      • js-controller Version: 5.0.19
      • Admin Version: 6.13.16
      • Hardwaresystem: Pi4.
      • Arbeitsspeicher: 8 GB
      • Festplattenart: SSD
      • Betriebssystem: Raspbian GNU/Linux 11 (bullseye)
      • Nodejs-Version: v18.20.2
      • NPM-Version: 10.5.0
      • Installationsart: Skript
      • Image
      • Ort, Name der Imagedatei: Raspberry Pi imager
      iob diag Ausgabe:
      Skript v.2024-04-21
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 32 bit
      Systemuptime and Load:
       18:26:18 up 12:07,  2 users,  load average: 2.22, 2.45, 2.47
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-05-06 18:26:18 CEST
                 Universal time: Mon 2024-05-06 16:26:18 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin nordvpn gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth nordvpn gpio i2c
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        1.2G        5.2G        1.0M        1.4G        6.5G
      Swap:           999M          0B        999M
      Total:          8.8G        1.2G        6.2G
      Active iob-Instances:   1
               7811 M total memory
               1201 M used memory
               1506 M active memory
                873 M inactive memory
               5231 M free memory
                198 M buffer memory
               1179 M swap cache
                999 M total swap
                  0 M used swap
                999 M free swap
      top - 18:26:19 up 12:07,  2 users,  load average: 2.22, 2.45, 2.47
      Tasks: 175 total,   3 running, 163 sleeping,   9 stopped,   0 zombie
      %Cpu(s): 34.3 us, 15.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7811.3 total,   5232.4 free,   1200.9 used,   1377.9 buff/cache
      MiB Swap:   1000.0 total,   1000.0 free,      0.0 used.   6487.2 avail Mem
      *** FAILED SERVICES ***
        UNIT                        LOAD   ACTIVE SUB    DESCRIPTION
      * bthelper@hci0.service       loaded failed failed Raspberry Pi bluetooth helper
      * gpio-html-automatik.service loaded failed failed Rolladenautomatik
      2 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      117G   29G   82G  27% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G  4.0K  3.9G   1% /dev/shm
      tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
      /dev/sda1      vfat      476M   51M  425M  11% /boot
      tmpfs          tmpfs     782M   32K  782M   1% /run/user/1000
      Show mounted filesystems:
      TARGET                           SOURCE     FSTYPE     OPTIONS
      /                                /dev/sda2  ext4       rw,noatime
      |-/dev                           devtmpfs   devtmpfs   rw,relatime,size=3735168k,nr_inodes=933792,mode=755
      | |-/dev/shm                     tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/pts                     devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                  mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
      |-/proc                          proc       proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc     systemd-1  autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/sys                           sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security         securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup               cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore               pstore     pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                  bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug            debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing          tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections     fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config           configfs   configfs   rw,nosuid,nodev,noexec,relatime
      |-/run                           tmpfs      tmpfs      rw,nosuid,nodev,size=1599760k,nr_inodes=819200,mode=755
      | |-/run/lock                    tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs              sunrpc     rpc_pipefs rw,relatime
      | `-/run/user/1000               tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=799876k,nr_inodes=199969,mode=700,uid=1000,gid=1000
      |-/home/pi/MyCloudEx2_anno171986 systemd-1  autofs     rw,relatime,fd=46,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/home/pi/MyCloudEx2_claudia    systemd-1  autofs     rw,relatime,fd=47,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      `-/boot                          /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      12G     /var/
      5.7G    /var/log
      3.8G    /var/log/journal/1087cd60d21846fc8a373547c7447138
      3.4G    /var/cache/apt
      Archived and active journals take up 3.7G in the file system.
      /opt/iobroker/backups:
      557M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      876M    /opt/iobroker/iobroker-data/files
      463M    /opt/iobroker/iobroker-data/files/vis-2-beta
      428M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
      426M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
      277M    /opt/iobroker/iobroker-data/states.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
       States database error: connect ECONNREFUSED 127.0.0.1:9000
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      nodejs modules from github:     1
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
      Adapter State
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
        system.adapter.lupusec.0                : lupusec               : raspberrypi                              -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
        system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
        system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
        system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 192.168.178.12, run as: admin
        system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
        system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              - disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
        system.adapter.yamaha.0                 : yamaha                : raspberrypi                              -  enabled
        system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
       Connection is closed.
      Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
          at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Objects and States
      Objects:        9815
      States:         1
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://repo.nordvpn.com/deb/nordvpn/debian stable InRelease
      Reading package lists...
      Pending Updates: 4
      *** Listening Ports ***
      tcp        0      0 192.168.178.12:3306     0.0.0.0:*               LISTEN      111        16463      693/mariadbd
      tcp        0      0 0.0.0.0:52051           0.0.0.0:*               LISTEN      1000       16047      418/MyMediaForAlexa
      tcp        0      0 0.0.0.0:52050           0.0.0.0:*               LISTEN      1000       16051      418/MyMediaForAlexa
      tcp        0      0 100.120.141.7:49111     0.0.0.0:*               LISTEN      1001       19564      1144/nordfileshared
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          879        567/cupsd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          16957      768/python3
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15575      590/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          13944      406/connmand
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          878        567/cupsd
      tcp6       0      0 ::1:53                  :::*                    LISTEN      0          13948      406/connmand
      tcp6       0      0 :::3389                 :::*                    LISTEN      110        14098      648/xrdp
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15577      590/sshd: /usr/sbin
      tcp6       0      0 :::4369                 :::*                    LISTEN      0          673        1/init
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          15513      584/xrdp-sesman
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          13936      406/connmand
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15908      505/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16396      598/cups-browsed
      udp        0      0 0.0.0.0:58107           0.0.0.0:*                           0          16257      769/nordvpnd
      udp        0      0 0.0.0.0:49954           0.0.0.0:*                           0          18607      -
      udp        0      0 127.0.0.1:45893         0.0.0.0:*                           0          17184      769/nordvpnd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13665      403/avahi-daemon: r
      udp        0      0 0.0.0.0:42260           0.0.0.0:*                           0          16255      769/nordvpnd
      udp        0      0 0.0.0.0:38742           0.0.0.0:*                           0          14213      406/connmand
      udp        0      0 127.0.0.1:34900         0.0.0.0:*                           0          17183      769/nordvpnd
      udp        0      0 0.0.0.0:47682           0.0.0.0:*                           0          16256      769/nordvpnd
      udp        0      0 0.0.0.0:60348           0.0.0.0:*                           108        13667      403/avahi-daemon: r
      udp6       0      0 :::45020                :::*                                108        13668      403/avahi-daemon: r
      udp6       0      0 ::1:53                  :::*                                0          13940      406/connmand
      udp6       0      0 :::546                  :::*                                0          16042      505/dhcpcd
      udp6       0      0 :::49954                :::*                                0          18608      -
      udp6       0      0 :::5353                 :::*                                108        13666      403/avahi-daemon: r
      udp6       0      0 :::43390                :::*                                0          16056      769/nordvpnd
      2024-05-06 18:27:35.680  - info: telegram.0 (28112) Terminated (NO_ERROR): Without reason
      2024-05-06 18:27:36.678  - info: javascript.0 (28040) terminating with timeout
      2024-05-06 18:27:36.684  - info: admin.0 (28001) terminating with timeout
      2024-05-06 18:27:36.687  - info: admin.0 (28001) Terminated (NO_ERROR): Without reason
      2024-05-06 18:27:36.689  - info: javascript.0 (28040) Terminated (NO_ERROR): Without reason
      2024-05-06 18:27:40.162  - error: javascript.0 (28040) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-05-06 18:27:40.171  - warn: admin.0 (28001) get state error: DB closed
      2024-05-06 18:27:40.171  - warn: javascript.0 (28040) get state error: DB closed
      2024-05-06 18:27:40.178  - info: admin.0 (28001) terminating
      2024-05-06 18:27:40.179  - info: admin.0 (28001) terminating
      2024-05-06 18:27:40.191  - error: sql.0 (28075) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2024-05-06 18:27:40.194  - error: sql.0 (28075) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-05-06 18:27:45.204  - error: sql.0 (28075) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-05-06 18:27:45.206  - error: sql.0 (28075) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2024-05-06 18:27:46.189  - info: sql.0 (28075) terminating with timeout
      2024-05-06 18:27:46.191  - info: sql.0 (28075) Terminated (NO_ERROR): Without reason
      2024-05-06 18:27:50.216  - error: sql.0 (28075) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-05-06 18:27:56.833  - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
      2024-05-06 18:27:56.843  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2024-05-06 18:27:56.845  - info: host.raspberrypi hostname: raspberrypi, node: v18.20.2
      2024-05-06 18:27:56.846  - info: host.raspberrypi ip addresses: 192.168.178.12 2003:dd:bf3a:b100:7de:bd88:cf59:322e fe80::be23:e850:8020:5a50 100.120.141.7
      2024-05-06 18:27:59.928  - info: host.raspberrypi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
      2024-05-06 18:28:26.875  - error: host.raspberrypi No connection to databases possible, restart
      2024-05-06 18:28:26.884  - info: host.raspberrypi iobroker _restart
        Thomas Braun Most Active @anno171986 last edited by Thomas Braun
        @anno171986
        Installier das Betriebssystem neu, diesmal in der 64Bit-Lite-Version. Also 'bookworm' ohne Desktop.
        A 2 Replies Last reply Reply Quote 0
          anno171986 @Thomas Braun last edited by
          @thomas-braun also komplett die SSD platt machen? Über den Imager? Über den Backitup Adapter danach dann gleich alle Backups einspielen?
            @anno171986
            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            Und dann ein Backup wählen, das noch keinen Fehler hat.
              @thomas-braun Ich habe BAckups von iobroker, Javascripts, MySQl und Zigbee.
              Gibt es eine empfohlene Reihenfolge?
                @anno171986
                Im iobroker-Backup ist doch soweit alles drin.
                Bei mysql weiß ich es aber nicht genau, hab ich nicht im Einsatz.
                  @thomas-braun sagte in Objects database error: connect ECONNREFUSED 127.0.0.1:9001:
                  nur Javascript!
                  die anderen beiden müssen extra gesichert und wiederhergestellt werden.
                  @anno171986
                  aber die Reihenfolge kann ich dir bei SQL nicht sagen.
                    anno171986 @Homoran last edited by
                    @homoran Ok, bin dabei und nach und nach scheint alles wieder zu starten. EIne dumme Frage habe ich noch: hätte ich die SQl DB eigenständig backupen müssen?
                      Homoran Global Moderator Administrators @anno171986 last edited by
                      @anno171986 sagte in Objects database error: connect ECONNREFUSED 127.0.0.1:9001:
                      über backitup geht das
                        @homoran Ich versuche ja das MySQl Backup über den Adapter, das klappt nicht. Jetzt frage ich mich ob denn die DB selbst durch das Backup gesichert wird.
                        Started restore ...
                        [DEBUG] [mysql] - Start mysql Restore ...
                        [DEBUG] [mysql] - sql.0 is stopped
                        [ERROR] [mysql] - ERROR 2002 (HY000): Can't connect to server on '192.168.178.12' (115)
                        [DEBUG] [mysql] - mySql Restore completed successfully
                        [EXIT] mysql restore done
                        [DEBUG] [mysql] - sql.0 started
                        DIe Instanz bleibt gelb
                          genau die sollte in dem Backup drin sein.
                          Ich nutze SQL nicht
                            @thomas-braun Leider ist nach der Neuinstallation und einspielen des Backups alles viel schlimmer geworden. iobroker läuft jetzt gar nicht mehr.
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                      Kernel: Linux 6.6.28+rpt-rpi-v8
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             20:13:46 up 8 days, 7 min,  4 users,  load average: 6.78, 3.30, 3.07
                            CPU threads: 4
                            Current issues:
                                           Local time: Tue 2024-06-04 20:13:47 CEST
                                       Universal time: Tue 2024-06-04 18:13:47 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            anno171986
                            HOME=/home/anno171986
                            GROUPS=anno171986 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.2G        3.5G        2.4G        1.3M        2.5G        4.7G
                            Swap:           209M          0B        209M
                            Total:          8.4G        3.5G        2.6G
                            Active iob-Instances:   2
                                     7809 M total memory
                                     3346 M used memory
                                     3572 M active memory
                                     1697 M inactive memory
                                     2269 M free memory
                                      159 M buffer memory
                                     2204 M swap cache
                                      199 M total swap
                                        0 M used swap
                                      199 M free swap
                            top - 20:13:47 up 8 days, 7 min,  4 users,  load average: 6.78, 3.30, 3.07
                            Tasks: 215 total,   7 running, 208 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 62.5 us, 37.5 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   7809.0 total,   2265.8 free,   3350.6 used,   2363.7 buff/cache
                            MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4458.5 avail Mem
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            Filesystem                                  Type      Size  Used Avail Use% Mounted on
                            udev                                        devtmpfs  3.6G     0  3.6G   0% /dev
                            tmpfs                                       tmpfs     781M  1.3M  780M   1% /run
                            /dev/sda2                                   ext4      117G  7.3G  104G   7% /
                            tmpfs                                       tmpfs     3.9G     0  3.9G   0% /dev/shm
                            tmpfs                                       tmpfs     5.0M   16K  5.0M   1% /run/lock
                            /dev/sda1                                   vfat      510M   64M  447M  13% /boot/firmware
                            //192.168.178.11/raspberrypi/ioBrokerBackup cifs      7.3T  1.3T  6.0T  18% /opt/iobroker/backups
                            tmpfs                                       tmpfs     781M     0  781M   0% /run/user/1000
                            | `-/proc/sys/fs/binfmt_misc                            systemd-1                                   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2262
                            |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc                                 binfmt_misc rw,nosuid,nodev,noexec,relatime
                            |-/dev                                                  udev                                        devtmpfs    rw,nosuid,relatime,size=3728000k,nr_inodes=932000,mode=755
                            |-/run                                                  tmpfs                                       tmpfs       rw,nosuid,nodev,noexec,relatime,size=799648k,mode=755
                            | |-/run/credentials/systemd-sysctl.service             ramfs                                       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                            | |-/run/credentials/systemd-sysusers.service           ramfs                                       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                            | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                                       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                            | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                                       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                            | `-/run/user/1000                                      tmpfs                                       tmpfs       rw,nosuid,nodev,relatime,size=799644k,nr_inodes=199911,mode=700,uid=1000,gid=1000
                            |-/boot/firmware                                        /dev/sda1                                   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            `-/opt/iobroker/backups                                 //192.168.178.11/raspberrypi/ioBrokerBackup cifs        rw,relatime,vers=3.1.1,cache=strict,username=raspberrypi,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.11,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
                            /var:
                            1.6G    /var/
                            912M    /var/log/journal/9735987036244807bbcd08440a9098fe
                            912M    /var/log
                            291M    /var/lib
                            Archived and active journals take up 911.5M in the file system.
                            277M    /opt/iobroker/backups/
                            1.6G    /opt/iobroker/iobroker-data/
                            409M    /opt/iobroker/iobroker-data/files
                            128M    /opt/iobroker/iobroker-data/backup-objects
                            89M     /opt/iobroker/iobroker-data/files/echarts.admin
                            57M     /opt/iobroker/iobroker-data/files/javascript.admin
                            994M    /opt/iobroker/iobroker-data/states.jsonl
                            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                            USB-Devices by-id:
                            /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
                            HINT:
                            /dev/ttyACM0
                            /usr/bin/nodejs         v18.20.3
                            /usr/bin/node           v18.20.3
                            /usr/bin/npm            10.7.0
                            /usr/bin/npx            10.7.0
                            /usr/bin/corepack       0.28.0
                            nodejs:
                              Installed: 18.20.3-1nodesource1
                              Candidate: 18.20.3-1nodesource1
                              Version table:
                             *** 18.20.3-1nodesource1 1001
                                 18.19.0+dfsg-6~deb12u1 500
                                 18.13.0+dfsg1-1 500
                            Temp directories causing npm8 problem: 108
                            Some problems detected, please run iob fix
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.13.16
                            javascript:     7.8.0
                            Adapter State
                              system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                              system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                              system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                              system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
                              system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              - disabled
                              system.adapter.sql.0                    : sql                   : raspberrypi                              - disabled, port: 3306
                              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              - disabled
                              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
                              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                              system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                              system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                            + instance is alive
                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                            Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                            Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                            Adapter    "ems-esp"      : 3.5.0    , installed 3.0.3  [Updatable]
                            Adapter    "harmony"      : 1.4.0    , installed 1.4.0
                            Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
                            Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
                            Adapter    "iot"          : 3.2.2    , installed 2.0.11 [Updatable]
                            Adapter    "javascript"   : 8.3.1    , installed 7.8.0  [Updatable]
                            Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                            Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
                            Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.1  [Updatable]
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                            Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                            Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
                            Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                            Adapter    "sql"          : 2.2.0    , installed 2.2.0
                            Adapter    "tankerkoenig" : 3.4.0    , installed 3.3.7  [Updatable]
                            Adapter    "telegram"     : 3.3.2    , installed 3.2.1  [Updatable]
                            Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
                            Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
                            Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.25 [Updatable]
                            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                            Adapter    "worx"         : 3.0.2    , installed 2.3.4  [Updatable]
                            Adapter    "ws"           : 2.6.1    , installed 2.6.1
                            Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                            Objects and States
                            Objects:        9805
                            States:         7152
                            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                            Pending Updates: 4
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1736       729/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6995707    2389797/iobroker.js
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6997486    2389797/iobroker.js
                            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       7005258    2389957/io.mqtt.0
                            tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        1769       803/mariadbd
                            tcp        0      0 192.168.178.12:8087     0.0.0.0:*               LISTEN      1001       7002408    2391110/io.simple-a
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          1738       729/sshd: /usr/sbin
                            tcp6       0      0 :::61991                :::*                    LISTEN      1001       6998550    2389928/io.harmony.
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6998490    2389840/io.admin.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1533       554/avahi-daemon: r
                            udp        0      0 0.0.0.0:47870           0.0.0.0:*                           104        1535       554/avahi-daemon: r
                            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       6998551    2389928/io.harmony.
                            udp6       0      0 :::5353                 :::*                                104        1534       554/avahi-daemon: r
                            udp6       0      0 :::52854                :::*                                104        1536       554/avahi-daemon: r
                            udp6       0      0 fe80::378e:5998:7a1:546 :::*                                0          2974       601/NetworkManager
                            2024-06-04 20:14:46.279  - error: daswetter.0 (2390543) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4.clouds_value": Connection is closed.]
                            2024-06-04 20:14:46.282  - error: daswetter.0 (2390543) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4.snowline_value": Connection is closed.
                            2024-06-04 20:14:46.284  - error: daswetter.0 (2390543) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4.snowline_value": Connection is closed.]
                            2024-06-04 20:14:46.291  - error: daswetter.0 (2390543) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4.windchill_value": Connection is closed.
                            2024-06-04 20:14:46.294  - error: daswetter.0 (2390543) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4.windchill_value": Connection is closed.]
                            2024-06-04 20:14:46.558  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                            2024-06-04 20:14:47.983  - info: heatingcontrol.0 (2391035) start statemachine
                            2024-06-04 20:14:50.125  - info: sourceanalytix.0 (2391160) Initialization of mqtt.0.Gaszaehler.main.value successfully
                            2024-06-04 20:14:50.204  - info: sourceanalytix.0 (2391160) Successfully activated SourceAnalytix for 3 of 3 states, will do my Job until you stop me!
                            2024-06-04 20:14:51.759  - info: heatingcontrol.0 (2391035) check all active sensors
                            2024-06-04 20:14:51.915  - info: heatingcontrol.0 (2391035) checking external states
                            2024-06-04 20:14:55.769  - info: tankerkoenig.0 (2391259) Start first request
                            2024-06-04 20:15:07.932  - info: heatingcontrol.0 (2391035) checking external states done
                            2024-06-04 20:15:07.936  - info: heatingcontrol.0 (2391035) calculate current profile point for all rooms
                            2024-06-04 20:15:07.944  - info: heatingcontrol.0 (2391035) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                            2024-06-04 20:15:08.248  - info: heatingcontrol.0 (2391035) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                            2024-06-04 20:15:08.545  - info: heatingcontrol.0 (2391035) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                            2024-06-04 20:15:08.700  - info: heatingcontrol.0 (2391035) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                            2024-06-04 20:15:08.844  - info: heatingcontrol.0 (2391035) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                            2024-06-04 20:15:09.027  - info: heatingcontrol.0 (2391035) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                            2024-06-04 20:15:09.174  - info: heatingcontrol.0 (2391035) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                            2024-06-04 20:15:09.311  - info: heatingcontrol.0 (2391035) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                            2024-06-04 20:15:09.800  - info: heatingcontrol.0 (2391035) Wohnzimmer: WZ Thermostatwert eingestellt auf 23.5°C
                            2024-06-04 20:15:10.864  - info: heatingcontrol.0 (2391035) Bad: Bad Thermostatwert eingestellt auf 22°C
                            2024-06-04 20:15:11.480  - info: heatingcontrol.0 (2391035) statemachine started
                              ioBroker Status
                              Der läuft.
                              Genauso wie ein Display-Server...
                              iob stop
                              sudo reboot
                                Das dann auch machen.
                                Und nodejs auf die Empfehlung v20 bringen.
                                iob nodejs-update
                                Die ganzen Adapter auch auf Stand bringen...
                                  @thomas-braun Ok, jetzt scheint er tatsächlich mal wieder zu laufen, hatte es 2 Wochen nicht mehr probiert weil ich frustriert war. Hauptproblem war der SQL Adapter bzw wohl die Datenbank. Kann man irgendwo im Dateisystem nachgucken ob die Datenbank richtig wiederhergestellt wurde?
                                    @anno171986
                                    Dein Hauptproblem ist der total inkonsistente Update-Stand auf der Kiste.
                                    A 3 Replies Last reply Reply Quote 0
                                      @thomas-braun Ich bin gerade dabei es upzudaten. Als ich es vor 3 Wochen neuaufgesetzt hatte, war alles auf den aktuellen Stand. So war jedenfalls meine Auffassung. Hatte alle Adapter und auch das Betriebsystem geupdated.
                                      cd /opt/iobroker
                                      iobroker backup
                                      iobroker stop
                                      iobroker update | grep Updatable
                                      iobroker upgrade -yes
                                      iobroker fix
                                      iobroker upgrade self
                                      iobroker start
                                      sudo apt update
                                      sudo apt dist-upgrade --fix-missing
                                      sudo reboot now
                                        cd /opt/iobroker
                                        iobroker backup
                                        iobroker stop
                                        iobroker fix
                                        iobroker start
                                        sudo apt update
                                        sudo reboot now
                                          anno171986 @Thomas Braun last edited by anno171986
                                          @thomas-braun Jetzt kommt der Fehler, der mich letztens auch so geärgert hat:
                                          anno171986@raspberrypi:/opt/iobroker $ iobroker update
                                          No connection to databases possible ...
                                           Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
                                          Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                                              at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:459:23)
                                          anno171986@raspberrypi:/opt/iobroker $ iobroker start
                                          anno171986@raspberrypi:/opt/iobroker $ iobroker status
                                          Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                            @anno171986
                                            Das ist insofern verwunderlich, weil deine Kiste auf jsonl läuft:
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            3475
