    5. Kann mit diesen Logs noch nix anfangen...
      docsnyder7 last edited by
      javascript.0
      	2024-05-07 21:51:23.350	warn	at processImmediate (node:internal/timers:476:21)
      javascript.0
      	2024-05-07 21:51:23.350	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
      javascript.0
      	2024-05-07 21:51:23.349	warn	at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11154:36)
      javascript.0
      	2024-05-07 21:51:23.349	warn	at Array.forEach (<anonymous>)
      javascript.0
      	2024-05-07 21:51:23.349	warn	at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11172:47
      javascript.0
      	2024-05-07 21:51:23.349	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
      javascript.0
      	2024-05-07 21:51:23.348	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1269:38)
      javascript.0
      	2024-05-07 21:51:23.348	warn	at Object.<anonymous> (script.js.common.Hausstatus.Status_setzen_überwachen:40:14)
      javascript.0
      	2024-05-07 21:51:23.346	warn	getState "[object Object]" not found (3)
      javascript.0
      	2024-05-07 21:51:23.346	warn	at processImmediate (node:internal/timers:476:21)
      javascript.0
      	2024-05-07 21:51:23.345	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
      javascript.0
      	2024-05-07 21:51:23.345	warn	at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11154:36)
      javascript.0
      	2024-05-07 21:51:23.345	warn	at Array.forEach (<anonymous>)
      javascript.0
      	2024-05-07 21:51:23.345	warn	at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11172:47
      javascript.0
      	2024-05-07 21:51:23.344	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
      javascript.0
      	2024-05-07 21:51:23.344	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1269:38)
      javascript.0
      	2024-05-07 21:51:23.344	warn	at Object.<anonymous> (script.js.common.Hausstatus.Status_setzen_überwachen:33:7)
      iob fix hab ich schon durchlaufen lassen...
      die Meldung kommt von nachstehenden Blockly, mit welchem der Hausstatus gesetzt wird...
      die Meldungen im LOG sind mir erst jetzt aufgefallen... kann jemand dazu etwas sagen, worauf ich achten muss, um zu sehen, aus welcher Ecke des Blocklys hier Ärger kommt?
      • BananaJoe
        BananaJoe Most Active @docsnyder7 last edited by
        @docsnyder7 sagte in Kann mit diesen Logs noch nix anfangen...:
        Vermutlich geht das mit deiner Liste nicht?
        Und falls doch: Irgend ein objekt kann nicht abgefragt werden. Wenn du oben rechts auf die Ansicht mit dem Quellcode umschaltest wäre dann Zeile 40 die mit dem Problem
          docsnyder7 @BananaJoe last edited by
          @bananajoe
          ich hab grad herausgefunden, dass ich beim Öffnen der Fenster dies im LOg erhalte
          22:24:21.764	warn	javascript.0 (390534) at Object.<anonymous> (script.js.common.Hausstatus.Status_setzen_überwachen:33:7)
          22:24:21.770	warn	javascript.0 (390534) at Object.<anonymous> (script.js.common.Hausstatus.Status_setzen_überwachen:40:14)
          BananaJoe Codierknecht 2 Replies Last reply Reply Quote 0
          • BananaJoe
            @docsnyder7 und, was steht in den beiden Zeilen?
            • Codierknecht
              Codierknecht Developer Most Active @docsnyder7 last edited by Codierknecht
              @docsnyder7
              Dazu müsste man - wie @BananaJoe bereits erwähnt hat - den Quellcode sehen.
              Zeile 33 und 40 sind hier von Interesse.
              Aber mir fallen noch weitere Sachen auf:
              • Ein Zeitplan mit dem Wizard funktioniert nach meiner Erfahrung nicht immer so wie man es sich wünscht. Besser wäre CRON.
              • Scriptnamen sollten keine Umlaute enthalten.
              • Warum baust Du so umständlich eine Liste zusammen? Das geht über "Aufzählungen" wesentlich eleganter.
                docsnyder7 @Codierknecht last edited by
                @codierknecht
                Zeile 33
                if (getState(getObject('0_userdata.0.Hausstatus.Abwesend')).val == 1) {
                und
                zeile 40
                } else if (getState(getObject('0_userdata.0.Hausstatus.Schlafen')).val == 1) {
                Aufzählung statt Liste.. naja ich bin immernoch am lernen und tüfteln, bis dato funktionierte das Blockly... wenn Du nen Wink hast mit Aufzählung, dann gerne her damit
                • Codierknecht
                  @docsnyder7
                  Sowas geht nicht
                  Das sollte so aussehen
                  Da wird eine Objekt-ID erwartet - kein komplettes Objekt!
                  D 1 Reply Last reply Reply Quote 2
                  • BananaJoe
                    kannst auch einfach das Objekt als Pfad nehmen: 2846cf55-3866-4a1b-a87d-58987ee90af7-image.png
                    Dazu ein Textfeld hineinziehen - so mache ich das gerne, finde ich etwas lesbarer
                    • Codierknecht
                        @codierknecht
                        ich fass es nicht... das war der Fehler!?! Blöder Anfänger-Nicht-Hingeschaut-Fehler 🤦‍♂️
                        @BananaJoe verstehe, würde hier auch die realtiv neuen grünen bausteine aus dem SYSTEM reiter funktionieren?
                        Mal wieder herzlichen Dank Euch beiden
                        @BananaJoe +
                        @Codierknecht
                          @codierknecht Danke, dass guck ich mir an 😎
                          • BananaJoe
                            Ja. Aber dann hast du immer noch nicht den Pfad sondern nur den Namen, da würde ich jetzt keinen Vorteil sehen.
                              @bananajoe
                              Ok…jetzt hab ich es verstanden 👍
                                @codierknecht
                                kurze Frage dazu... anlegen von functions im Reiter Aufzählungen und dann ziehe ich nur die zb door DP oder open DP der Fenstersensoren in die passende function?
                                und dann den ID Selector functions=window zb? für die Liste der Sensoren?
                                • Codierknecht
                                  @docsnyder7
                                  Genau so 😉
                                    @codierknecht
                                    Sänkju 😁
                                    495
