    4. iot Fehlermeldung
    iot Fehlermeldung
    • E
      emil70 last edited by emil70
      Hallo Zusammen,
      ich habe seit 2-3 Tagen folgene Fehlermeldung bei iot
      iot.0
      	2024-05-08 08:59:00.068	error	Cannot convert undefined or null to object
      iot.0
      	2024-05-08 08:59:00.067	error	TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at RemoteAccess.onCloudDisconnect (/opt/iobroker/node_modules/iobroker.iot/lib/remote.js:720:29) at DeviceClient.onDisconnect (/opt/iobroker/node_modules/iobroker.iot/main.js:564:22) at DeviceClient.emit (node:events:517:28) at MqttClient.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/device/index.js:797:12) at MqttClient.emit (node:events:529:35) at TLSSocket.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:360:10) at TLSSocket.emit (node:events:529:35) at node:net:350:12 at TCP.done (node:_tls_wrap:657:7)
      iot.0
      	2024-05-08 08:59:00.065	error	uncaught exception: Cannot convert undefined or null to object
      Habe mal auf debug gestellt und den Adapter neu gestartet
      2024-05-08 08:51:36.944 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132,20197,15905,15814,15403,16144,15126,15310,20041,19594","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213,11230,6733,7060,5764,7756,6593,7210,17200,14016","Newprio_realtime_bps":"1286,866,263,1275,2017,5081,188,619,339,662,1555,3434,538,487,507,1124,63,303,10382,1130","Newprio_high_bps":"6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801,6057,5650,5133,4879,5239,5847,5769,5633,5885","Newprio_default_bps":"721,1096,660,1374,482,2942,512,1182,909,1077,1857,1739,545,1440,378,1393,683,1138,1185,7001","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:51:42.048 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132,20197,15905,15814,15403,16144,15126,15310,20041","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213,11230,6733,7060,5764,7756,6593,7210,17200","Newprio_realtime_bps":"150,1286,866,263,1275,2017,5081,188,619,339,662,1555,3434,538,487,507,1124,63,303,10382","Newprio_high_bps":"5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801,6057,5650,5133,4879,5239,5847,5769,5633","Newprio_default_bps":"1119,721,1096,660,1374,482,2942,512,1182,909,1077,1857,1739,545,1440,378,1393,683,1138,1185","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:51:42.404 - info: host.f7c478effa45 "system.adapter.iot.0" enabled
      2024-05-08 08:51:43.123 - info: host.f7c478effa45 instance system.adapter.iot.0 started with pid 13031
      2024-05-08 08:51:44.690 - debug: iot.0 (13031) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-05-08 08:51:44.778 - debug: iot.0 (13031) Objects client ready ... initialize now
      2024-05-08 08:51:44.781 - debug: iot.0 (13031) Objects create System PubSub Client
      2024-05-08 08:51:44.782 - debug: iot.0 (13031) Objects create User PubSub Client
      2024-05-08 08:51:44.947 - debug: iot.0 (13031) Objects client initialize lua scripts
      2024-05-08 08:51:44.954 - debug: iot.0 (13031) Objects connected to redis: 127.0.0.1:9001
      2024-05-08 08:51:45.057 - debug: iot.0 (13031) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-05-08 08:51:45.159 - debug: iot.0 (13031) States create System PubSub Client
      2024-05-08 08:51:45.161 - debug: iot.0 (13031) States create User PubSub Client
      2024-05-08 08:51:45.335 - debug: iot.0 (13031) States connected to redis: 127.0.0.1:9000
      2024-05-08 08:51:45.443 - debug: iot.0 (13031) Plugin sentry Initialize Plugin (enabled=true)
      2024-05-08 08:51:45.449 - info: iot.0 (13031) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2024-05-08 08:51:45.800 - info: iot.0 (13031) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.19
      2024-05-08 08:51:45.847 - debug: iot.0 (13031) Schedule restart: * 8 * * *
      2024-05-08 08:51:46.039 - info: iot.0 (13031) Connecting with xxxxxxxxxxxxxxxxxx.iot.eu-west-1.amazonaws.com
      2024-05-08 08:51:47.269 - debug: iot.0 (13031) [ALEXA] Name "Fenster Badezimmer.STATE" cannot be written and will be ignored
      2024-05-08 08:51:47.274 - debug: iot.0 (13031) [ALEXA] Name "Fenster2 Wohnzimmer.STATE" cannot be written and will be ignored
      2024-05-08 08:51:47.274 - debug: iot.0 (13031) [ALEXA] Name "Garage-Geschlossen.STATE" cannot be written and will be ignored
      2024-05-08 08:51:47.276 - debug: iot.0 (13031) [ALEXA] Name "Wohnzimmerdeckenlampe.LEVEL_REAL" cannot be written and will be ignored
      2024-05-08 08:51:47.278 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: übersicht ["turnOn"]
      2024-05-08 08:51:47.278 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: z.d.f. info ["turnOn"]
      2024-05-08 08:51:47.279 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: z.d.f ["turnOn"]
      2024-05-08 08:51:47.279 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: welt ["turnOn"]
      2024-05-08 08:51:47.279 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: w.d.r ["turnOn"]
      2024-05-08 08:51:47.279 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: vox ["turnOn"]
      2024-05-08 08:51:47.280 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: ton ["turnOn"]
      2024-05-08 08:51:47.280 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: tele fünf ["turnOn"]
      2024-05-08 08:51:47.280 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: super r. t. l ["turnOn"]
      2024-05-08 08:51:47.280 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: sport eins ["turnOn"]
      2024-05-08 08:51:47.281 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: sixx ["turnOn"]
      2024-05-08 08:51:47.281 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: sat eins gold ["turnOn"]
      2024-05-08 08:51:47.281 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: sat eins ["turnOn"]
      2024-05-08 08:51:47.281 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: r.t.l zwei ["turnOn"]
      2024-05-08 08:51:47.281 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: r.t.l ["turnOn"]
      2024-05-08 08:51:47.282 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: pro sieben max ["turnOn"]
      2024-05-08 08:51:47.282 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: pro sieben ["turnOn"]
      2024-05-08 08:51:47.283 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: phoenix ["turnOn"]
      2024-05-08 08:51:47.283 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: okay ["turnOn"]
      2024-05-08 08:51:47.283 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: nächster kanal ["turnOn"]
      2024-05-08 08:51:47.283 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: nitro ["turnOn"]
      2024-05-08 08:51:47.283 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: nick ["turnOn"]
      2024-05-08 08:51:47.284 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: n.t.v ["turnOn"]
      2024-05-08 08:51:47.284 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: n. vier und zwanzig doku ["turnOn"]
      2024-05-08 08:51:47.285 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: mach leiser ["turnOn"]
      2024-05-08 08:51:47.285 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: mach lauter ["turnOn"]
      2024-05-08 08:51:47.285 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: kanal zurück ["turnOn"]
      2024-05-08 08:51:47.285 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: kabel eins doku ["turnOn"]
      2024-05-08 08:51:47.285 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: kabel eins ["turnOn"]
      2024-05-08 08:51:47.286 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: h.r ["turnOn"]
      2024-05-08 08:51:47.286 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: exit ["turnOn"]
      2024-05-08 08:51:47.286 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: eurosport eins deutschland ["turnOn"]
      2024-05-08 08:51:47.286 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: eurosport eins ["turnOn"]
      2024-05-08 08:51:47.286 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: eingangskamera ["turnOn"]
      2024-05-08 08:51:47.287 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: ecoMode ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:51:47.287 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: drei sat ["turnOn"]
      2024-05-08 08:51:47.287 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: d. max ["turnOn"]
      2024-05-08 08:51:47.287 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: aufnahme ["turnOn"]
      2024-05-08 08:51:47.287 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: arte ["turnOn"]
      2024-05-08 08:51:47.288 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: a.r.d ["turnOn"]
      2024-05-08 08:51:47.288 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Wohnzimmerstehlampe ["turnOn","turnOff"]
      2024-05-08 08:51:47.288 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Wohnzimmerschrank ["turnOn","turnOff"]
      2024-05-08 08:51:47.288 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Wohnzimmer Rollade rechts ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:51:47.288 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Wohnzimmer Rollade links ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:51:47.289 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Wohnzimmer Deckenlampe ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:51:47.289 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: WC Beleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.289 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Terrassenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.289 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Terrasse ["getTemperatureReading"]
      2024-05-08 08:51:47.289 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Strauchbewässerung ["turnOn","turnOff"]
      2024-05-08 08:51:47.290 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: SteckdoseJulia ["turnOn","turnOff"]
      2024-05-08 08:51:47.290 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Schuppenbewegungsbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.290 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Schuppenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.290 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Schlafzimmerbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.290 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Rasenbewässerung ["turnOn","turnOff"]
      2024-05-08 08:51:47.291 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Mower stoppen ["turnOn"]
      2024-05-08 08:51:47.291 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Mower starten ["turnOn"]
      2024-05-08 08:51:47.291 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Mower nach Hause schicken ["turnOn"]
      2024-05-08 08:51:47.291 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Mower Kantenschnitt ["turnOn"]
      2024-05-08 08:51:47.291 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Küchenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.292 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Kompressor ["turnOn","turnOff"]
      2024-05-08 08:51:47.292 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Wohnzimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:51:47.292 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Wohnzimmer Power ["turnOn","turnOff"]
      2024-05-08 08:51:47.292 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Wohnzimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:51:47.292 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Wohnzimmer ["turnOn","turnOff"]
      2024-05-08 08:51:47.293 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Schlafzimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:51:47.293 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Schlafzimmer Power ["turnOn","turnOff"]
      2024-05-08 08:51:47.293 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Schlafzimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:51:47.293 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Schlafzimmer ["turnOn","turnOff"]
      2024-05-08 08:51:47.293 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Juliazimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:51:47.294 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Juliazimmer Power ["turnOn","turnOff"]
      2024-05-08 08:51:47.294 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Juliazimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:51:47.294 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Klima Juliazimmer ["turnOn","turnOff"]
      2024-05-08 08:51:47.294 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Juliazimmerbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.295 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Hochbeetsteckdose ["turnOn"]
      2024-05-08 08:51:47.295 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Hochbeetbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.295 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Heizungsraumbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.295 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Heizung Wohnzimmer ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:51:47.295 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Heizung WC ["turnOn","turnOff"]
      2024-05-08 08:51:47.296 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Heizung Schlafzimmer ["getTemperatureReading","setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:51:47.296 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Heizung Julia ["getTemperatureReading","setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:51:47.296 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Heizung Flur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:51:47.296 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Heizung Büro ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:51:47.296 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Heizung Bad ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:51:47.297 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Hauswirtschaftsraumbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.297 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Gartentorbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.297 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Gartenpumpe ["turnOn","turnOff"]
      2024-05-08 08:51:47.297 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Gartenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.297 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Garagentortaster ["turnOn"]
      2024-05-08 08:51:47.298 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Garagenbeleuchtungvorne ["turnOn","turnOff"]
      2024-05-08 08:51:47.298 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Flurstehlampe ["turnOn","turnOff"]
      2024-05-08 08:51:47.298 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: FireTvStick ["turnOn","turnOff"]
      2024-05-08 08:51:47.298 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Fernseher ["turnOn","turnOff"]
      2024-05-08 08:51:47.298 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Esszimmerstehlampe ["turnOn","turnOff"]
      2024-05-08 08:51:47.299 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Esszimmersteckdose ["turnOn","turnOff"]
      2024-05-08 08:51:47.299 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Esszimmerschrank ["turnOn","turnOff"]
      2024-05-08 08:51:47.299 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Esszimmer Deckenlampe ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:51:47.299 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Eingangslampe ["turnOn","turnOff"]
      2024-05-08 08:51:47.299 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Dachboden ["getTemperatureReading"]
      2024-05-08 08:51:47.300 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Carportbewegungsbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.300 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Carportbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.300 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Box ["turnOn","turnOff"]
      2024-05-08 08:51:47.300 - debug: iot.0 (13031) [ALEXA] Created ALEXA device: Aussenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:51:47.456 - info: iot.0 (13031) Connection changed: connect "yyyyyyyyyyyyyy"
      2024-05-08 08:51:48.123 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132,20197,15905,15814,15403,16144,15126,15310","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213,11230,6733,7060,5764,7756,6593,7210","Newprio_realtime_bps":"1939,150,1286,866,263,1275,2017,5081,188,619,339,662,1555,3434,538,487,507,1124,63,303","Newprio_high_bps":"4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801,6057,5650,5133,4879,5239,5847,5769","Newprio_default_bps":"653,1119,721,1096,660,1374,482,2942,512,1182,909,1077,1857,1739,545,1440,378,1393,683,1138","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:51:54.106 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"17247,17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132,20197,15905,15814,15403,16144,15126","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"8029,7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213,11230,6733,7060,5764,7756,6593","Newprio_realtime_bps":"904,1939,150,1286,866,263,1275,2017,5081,188,619,339,662,1555,3434,538,487,507,1124,63","Newprio_high_bps":"5817,4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801,6057,5650,5133,4879,5239,5847","Newprio_default_bps":"1308,653,1119,721,1096,660,1374,482,2942,512,1182,909,1077,1857,1739,545,1440,378,1393,683","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:00.015 - info: iot.0 (13031) Scheduled restart.
      2024-05-08 08:52:00.042 - info: iot.0 (13031) terminating
      2024-05-08 08:52:00.043 - debug: iot.0 (13031) Plugin sentry destroyed
      2024-05-08 08:52:00.044 - info: iot.0 (13031) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2024-05-08 08:52:00.054 - info: iot.0 (13031) Connection changed: disconnect
      2024-05-08 08:52:00.055 - info: iot.0 (13031) Connection lost
      2024-05-08 08:52:00.056 - debug: iot.0 (13031) [REMOTE] Cloud disconnected
      2024-05-08 08:52:00.057 - error: iot.0 (13031) uncaught exception: Cannot convert undefined or null to object
      2024-05-08 08:52:00.059 - error: iot.0 (13031) TypeError: Cannot convert undefined or null to object
      at Function.keys ()
      at MqttClient. (/opt/iobroker/node_modules/aws-iot-device-sdk/device/index.js:797:12)
      at TLSSocket. (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:360:10)
      at node:net:350:12
      2024-05-08 08:52:00.060 - error: iot.0 (13031) Cannot convert undefined or null to object
      2024-05-08 08:52:00.108 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"13960,17247,17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132,20197,15905,15814,15403,16144","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"6084,8029,7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213,11230,6733,7060,5764,7756","Newprio_realtime_bps":"120,904,1939,150,1286,866,263,1275,2017,5081,188,619,339,662,1555,3434,538,487,507,1124","Newprio_high_bps":"5474,5817,4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801,6057,5650,5133,4879,5239","Newprio_default_bps":"490,1308,653,1119,721,1096,660,1374,482,2942,512,1182,909,1077,1857,1739,545,1440,378,1393","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:00.524 - info: iot.0 (13031) terminating
      2024-05-08 08:52:00.759 - info: mqtt.0 (28269) Client [] connection closed: disconnected
      2024-05-08 08:52:00.830 - info: host.f7c478effa45 instance system.adapter.iot.0 scheduled normal terminated and will be restarted on schedule.
      2024-05-08 08:52:00.831 - info: host.f7c478effa45 Restart adapter system.adapter.iot.0 because enabled
      2024-05-08 08:52:01.006 - info: mqtt.0 (28269) Client [] connected with secret 1715151121006_817
      2024-05-08 08:52:02.131 - info: host.f7c478effa45 instance system.adapter.iot.0 started with pid 13071
      2024-05-08 08:52:03.567 - debug: iot.0 (13071) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-05-08 08:52:03.654 - debug: iot.0 (13071) Objects client ready ... initialize now
      2024-05-08 08:52:03.657 - debug: iot.0 (13071) Objects create System PubSub Client
      2024-05-08 08:52:03.658 - debug: iot.0 (13071) Objects create User PubSub Client
      2024-05-08 08:52:03.828 - debug: iot.0 (13071) Objects client initialize lua scripts
      2024-05-08 08:52:03.835 - debug: iot.0 (13071) Objects connected to redis: 127.0.0.1:9001
      2024-05-08 08:52:03.929 - debug: iot.0 (13071) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-05-08 08:52:03.999 - debug: iot.0 (13071) States create System PubSub Client
      2024-05-08 08:52:04.000 - debug: iot.0 (13071) States create User PubSub Client
      2024-05-08 08:52:04.175 - debug: iot.0 (13071) States connected to redis: 127.0.0.1:9000
      2024-05-08 08:52:04.286 - debug: iot.0 (13071) Plugin sentry Initialize Plugin (enabled=true)
      2024-05-08 08:52:04.293 - info: iot.0 (13071) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2024-05-08 08:52:04.687 - info: iot.0 (13071) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.19
      2024-05-08 08:52:04.744 - debug: iot.0 (13071) Schedule restart: * 8 * * *
      2024-05-08 08:52:05.019 - info: iot.0 (13071) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2024-05-08 08:52:06.256 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"16023,13960,17247,17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132,20197,15905,15814,15403","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"7521,6084,8029,7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213,11230,6733,7060,5764","Newprio_realtime_bps":"114,120,904,1939,150,1286,866,263,1275,2017,5081,188,619,339,662,1555,3434,538,487,507","Newprio_high_bps":"6015,5474,5817,4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801,6057,5650,5133,4879","Newprio_default_bps":"1392,490,1308,653,1119,721,1096,660,1374,482,2942,512,1182,909,1077,1857,1739,545,1440,378","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:06.419 - debug: iot.0 (13071) [ALEXA] Name "Fenster Badezimmer.STATE" cannot be written and will be ignored
      2024-05-08 08:52:06.424 - debug: iot.0 (13071) [ALEXA] Name "Fenster2 Wohnzimmer.STATE" cannot be written and will be ignored
      2024-05-08 08:52:06.424 - debug: iot.0 (13071) [ALEXA] Name "Garage-Geschlossen.STATE" cannot be written and will be ignored
      2024-05-08 08:52:06.426 - debug: iot.0 (13071) [ALEXA] Name "Wohnzimmerdeckenlampe.LEVEL_REAL" cannot be written and will be ignored
      2024-05-08 08:52:06.428 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: übersicht ["turnOn"]
      2024-05-08 08:52:06.428 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: z.d.f. info ["turnOn"]
      2024-05-08 08:52:06.429 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: z.d.f ["turnOn"]
      2024-05-08 08:52:06.429 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: welt ["turnOn"]
      2024-05-08 08:52:06.429 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: w.d.r ["turnOn"]
      2024-05-08 08:52:06.429 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: vox ["turnOn"]
      2024-05-08 08:52:06.430 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: ton ["turnOn"]
      2024-05-08 08:52:06.430 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: tele fünf ["turnOn"]
      2024-05-08 08:52:06.430 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: super r. t. l ["turnOn"]
      2024-05-08 08:52:06.430 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: sport eins ["turnOn"]
      2024-05-08 08:52:06.430 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: sixx ["turnOn"]
      2024-05-08 08:52:06.431 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: sat eins gold ["turnOn"]
      2024-05-08 08:52:06.431 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: sat eins ["turnOn"]
      2024-05-08 08:52:06.431 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: r.t.l zwei ["turnOn"]
      2024-05-08 08:52:06.431 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: r.t.l ["turnOn"]
      2024-05-08 08:52:06.432 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: pro sieben max ["turnOn"]
      2024-05-08 08:52:06.432 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: pro sieben ["turnOn"]
      2024-05-08 08:52:06.432 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: phoenix ["turnOn"]
      2024-05-08 08:52:06.433 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: okay ["turnOn"]
      2024-05-08 08:52:06.433 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: nächster kanal ["turnOn"]
      2024-05-08 08:52:06.433 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: nitro ["turnOn"]
      2024-05-08 08:52:06.433 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: nick ["turnOn"]
      2024-05-08 08:52:06.433 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: n.t.v ["turnOn"]
      2024-05-08 08:52:06.434 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: n. vier und zwanzig doku ["turnOn"]
      2024-05-08 08:52:06.434 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: mach leiser ["turnOn"]
      2024-05-08 08:52:06.434 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: mach lauter ["turnOn"]
      2024-05-08 08:52:06.434 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: kanal zurück ["turnOn"]
      2024-05-08 08:52:06.434 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: kabel eins doku ["turnOn"]
      2024-05-08 08:52:06.435 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: kabel eins ["turnOn"]
      2024-05-08 08:52:06.435 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: h.r ["turnOn"]
      2024-05-08 08:52:06.435 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: exit ["turnOn"]
      2024-05-08 08:52:06.435 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: eurosport eins deutschland ["turnOn"]
      2024-05-08 08:52:06.436 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: eurosport eins ["turnOn"]
      2024-05-08 08:52:06.436 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: eingangskamera ["turnOn"]
      2024-05-08 08:52:06.436 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: ecoMode ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:52:06.436 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: drei sat ["turnOn"]
      2024-05-08 08:52:06.436 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: d. max ["turnOn"]
      2024-05-08 08:52:06.437 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: aufnahme ["turnOn"]
      2024-05-08 08:52:06.437 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: arte ["turnOn"]
      2024-05-08 08:52:06.437 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: a.r.d ["turnOn"]
      2024-05-08 08:52:06.437 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Wohnzimmerstehlampe ["turnOn","turnOff"]
      2024-05-08 08:52:06.438 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Wohnzimmerschrank ["turnOn","turnOff"]
      2024-05-08 08:52:06.438 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Wohnzimmer Rollade rechts ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:52:06.438 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Wohnzimmer Rollade links ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:52:06.438 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Wohnzimmer Deckenlampe ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:52:06.438 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: WC Beleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.439 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Terrassenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.439 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Terrasse ["getTemperatureReading"]
      2024-05-08 08:52:06.439 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Strauchbewässerung ["turnOn","turnOff"]
      2024-05-08 08:52:06.439 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: SteckdoseJulia ["turnOn","turnOff"]
      2024-05-08 08:52:06.439 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Schuppenbewegungsbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.440 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Schuppenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.440 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Schlafzimmerbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.440 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Rasenbewässerung ["turnOn","turnOff"]
      2024-05-08 08:52:06.440 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Mower stoppen ["turnOn"]
      2024-05-08 08:52:06.440 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Mower starten ["turnOn"]
      2024-05-08 08:52:06.441 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Mower nach Hause schicken ["turnOn"]
      2024-05-08 08:52:06.441 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Mower Kantenschnitt ["turnOn"]
      2024-05-08 08:52:06.441 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Küchenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.441 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Kompressor ["turnOn","turnOff"]
      2024-05-08 08:52:06.441 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Wohnzimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:52:06.442 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Wohnzimmer Power ["turnOn","turnOff"]
      2024-05-08 08:52:06.442 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Wohnzimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:52:06.442 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Wohnzimmer ["turnOn","turnOff"]
      2024-05-08 08:52:06.442 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Schlafzimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:52:06.442 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Schlafzimmer Power ["turnOn","turnOff"]
      2024-05-08 08:52:06.443 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Schlafzimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:52:06.443 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Schlafzimmer ["turnOn","turnOff"]
      2024-05-08 08:52:06.443 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Juliazimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:52:06.443 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Juliazimmer Power ["turnOn","turnOff"]
      2024-05-08 08:52:06.443 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Juliazimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:52:06.444 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Klima Juliazimmer ["turnOn","turnOff"]
      2024-05-08 08:52:06.444 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Juliazimmerbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.444 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Hochbeetsteckdose ["turnOn"]
      2024-05-08 08:52:06.444 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Hochbeetbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.444 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Heizungsraumbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.445 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Heizung Wohnzimmer ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:52:06.445 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Heizung WC ["turnOn","turnOff"]
      2024-05-08 08:52:06.445 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Heizung Schlafzimmer ["getTemperatureReading","setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:52:06.445 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Heizung Julia ["getTemperatureReading","setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:52:06.445 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Heizung Flur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:52:06.446 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Heizung Büro ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:52:06.446 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Heizung Bad ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:52:06.446 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Hauswirtschaftsraumbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.446 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Gartentorbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.446 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Gartenpumpe ["turnOn","turnOff"]
      2024-05-08 08:52:06.447 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Gartenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.447 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Garagentortaster ["turnOn"]
      2024-05-08 08:52:06.447 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Garagenbeleuchtungvorne ["turnOn","turnOff"]
      2024-05-08 08:52:06.447 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Flurstehlampe ["turnOn","turnOff"]
      2024-05-08 08:52:06.447 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: FireTvStick ["turnOn","turnOff"]
      2024-05-08 08:52:06.448 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Fernseher ["turnOn","turnOff"]
      2024-05-08 08:52:06.448 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Esszimmerstehlampe ["turnOn","turnOff"]
      2024-05-08 08:52:06.448 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Esszimmersteckdose ["turnOn","turnOff"]
      2024-05-08 08:52:06.448 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Esszimmerschrank ["turnOn","turnOff"]
      2024-05-08 08:52:06.448 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Esszimmer Deckenlampe ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:52:06.449 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Eingangslampe ["turnOn","turnOff"]
      2024-05-08 08:52:06.449 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Dachboden ["getTemperatureReading"]
      2024-05-08 08:52:06.449 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Carportbewegungsbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.449 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Carportbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.449 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Box ["turnOn","turnOff"]
      2024-05-08 08:52:06.450 - debug: iot.0 (13071) [ALEXA] Created ALEXA device: Aussenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:52:06.613 - info: iot.0 (13071) Connection changed: connect "yyyyyyyyyyyyyy"
      2024-05-08 08:52:12.113 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132,20197,15905","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213,11230,6733","Newprio_realtime_bps":"385,2764,114,120,904,1939,150,1286,866,263,1275,2017,5081,188,619,339,662,1555,3434,538","Newprio_high_bps":"5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801,6057,5650","Newprio_default_bps":"1101,543,1392,490,1308,653,1119,721,1096,660,1374,482,2942,512,1182,909,1077,1857,1739,545","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:18.074 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132,20197","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213,11230","Newprio_realtime_bps":"4735,385,2764,114,120,904,1939,150,1286,866,263,1275,2017,5081,188,619,339,662,1555,3434","Newprio_high_bps":"5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801,6057","Newprio_default_bps":"715,1101,543,1392,490,1308,653,1119,721,1096,660,1374,482,2942,512,1182,909,1077,1857,1739","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:24.048 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"14764,17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505,23132","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"6785,11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513,9213","Newprio_realtime_bps":"226,4735,385,2764,114,120,904,1939,150,1286,866,263,1275,2017,5081,188,619,339,662,1555","Newprio_high_bps":"5395,5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774,5801","Newprio_default_bps":"1164,715,1101,543,1392,490,1308,653,1119,721,1096,660,1374,482,2942,512,1182,909,1077,1857","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:30.081 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"17744,14764,17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836,15505","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"11256,6785,11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076,7513","Newprio_realtime_bps":"5146,226,4735,385,2764,114,120,904,1939,150,1286,866,263,1275,2017,5081,188,619,339,662","Newprio_high_bps":"5360,5395,5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828,5774","Newprio_default_bps":"750,1164,715,1101,543,1392,490,1308,653,1119,721,1096,660,1374,482,2942,512,1182,909,1077","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:36.175 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"17982,17744,14764,17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267,17481,35794,15179,15063,15836","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"9787,11256,6785,11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681,8308,14069,4798,7366,7076","Newprio_realtime_bps":"2817,5146,226,4735,385,2764,114,120,904,1939,150,1286,866,263,1275,2017,5081,188,619,339","Newprio_high_bps":"5461,5360,5395,5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032,5809,6046,4098,5565,5828","Newprio_default_bps":"1509,750,1164,715,1101,543,1392,490,1308,653,1119,721,1096,660,1374,482,2942,512,1182,909","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:42.131 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267,17481,35794,15179","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681,8308,14069,4798","Newprio_realtime_bps":"2272,1037,2817,5146,226,4735,385,2764,114,120,904,1939,150,1286,866,263,1275,2017,5081,188","Newprio_high_bps":"6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032,5809,6046,4098","Newprio_default_bps":"1419,1259,1509,750,1164,715,1101,543,1392,490,1308,653,1119,721,1096,660,1374,482,2942,512","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:42.615 - info: panasonic-comfort-cloud.0 (5465) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
      2024-05-08 08:52:48.094 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267,17481,35794","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681,8308,14069","Newprio_realtime_bps":"2601,2272,1037,2817,5146,226,4735,385,2764,114,120,904,1939,150,1286,866,263,1275,2017,5081","Newprio_high_bps":"5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032,5809,6046","Newprio_default_bps":"878,1419,1259,1509,750,1164,715,1101,543,1392,490,1308,653,1119,721,1096,660,1374,482,2942","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:52:54.220 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"17303,18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267,17481","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"10312,9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681,8308","Newprio_realtime_bps":"1261,2601,2272,1037,2817,5146,226,4735,385,2764,114,120,904,1939,150,1286,866,263,1275,2017","Newprio_high_bps":"6896,5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032,5809","Newprio_default_bps":"2155,878,1419,1259,1509,750,1164,715,1101,543,1392,490,1308,653,1119,721,1096,660,1374,482","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:53:00.014 - info: iot.0 (13071) Scheduled restart.
      2024-05-08 08:53:00.055 - info: iot.0 (13071) Connection changed: disconnect
      2024-05-08 08:53:00.055 - info: iot.0 (13071) Connection lost
      2024-05-08 08:53:00.056 - debug: iot.0 (13071) [REMOTE] Cloud disconnected
      2024-05-08 08:53:00.057 - error: iot.0 (13071) uncaught exception: Cannot convert undefined or null to object
      2024-05-08 08:53:00.060 - error: iot.0 (13071) TypeError: Cannot convert undefined or null to object
      at Function.keys ()
      at node:net:350:12
      2024-05-08 08:53:00.060 - error: iot.0 (13071) Cannot convert undefined or null to object
      2024-05-08 08:53:00.064 - info: iot.0 (13071) terminating
      2024-05-08 08:53:00.066 - debug: iot.0 (13071) Plugin sentry destroyed
      2024-05-08 08:53:00.067 - info: iot.0 (13071) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2024-05-08 08:53:00.089 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"14861,17303,18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276,16267","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"6103,10312,9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923,8681","Newprio_realtime_bps":"97,1261,2601,2272,1037,2817,5146,226,4735,385,2764,114,120,904,1939,150,1286,866,263,1275","Newprio_high_bps":"5564,6896,5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000,6032","Newprio_default_bps":"442,2155,878,1419,1259,1509,750,1164,715,1101,543,1392,490,1308,653,1119,721,1096,660,1374","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:53:00.272 - info: mqtt.0 (28269) Client [] connection closed: disconnected
      2024-05-08 08:53:00.521 - info: mqtt.0 (28269) Client [] connected with secret 1715151180521_6251
      2024-05-08 08:53:00.525 - info: iot.0 (13071) terminating
      2024-05-08 08:53:00.850 - info: host.f7c478effa45 instance system.adapter.iot.0 scheduled normal terminated and will be restarted on schedule.
      2024-05-08 08:53:00.851 - info: host.f7c478effa45 Restart adapter system.adapter.iot.0 because enabled
      2024-05-08 08:53:02.152 - info: host.f7c478effa45 instance system.adapter.iot.0 started with pid 13135
      2024-05-08 08:53:03.636 - debug: iot.0 (13135) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-05-08 08:53:03.748 - debug: iot.0 (13135) Objects client ready ... initialize now
      2024-05-08 08:53:03.751 - debug: iot.0 (13135) Objects create System PubSub Client
      2024-05-08 08:53:03.752 - debug: iot.0 (13135) Objects create User PubSub Client
      2024-05-08 08:53:03.930 - debug: iot.0 (13135) Objects client initialize lua scripts
      2024-05-08 08:53:03.937 - debug: iot.0 (13135) Objects connected to redis: 127.0.0.1:9001
      2024-05-08 08:53:04.040 - debug: iot.0 (13135) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-05-08 08:53:04.117 - debug: iot.0 (13135) States create System PubSub Client
      2024-05-08 08:53:04.118 - debug: iot.0 (13135) States create User PubSub Client
      2024-05-08 08:53:04.295 - debug: iot.0 (13135) States connected to redis: 127.0.0.1:9000
      2024-05-08 08:53:04.424 - debug: iot.0 (13135) Plugin sentry Initialize Plugin (enabled=true)
      2024-05-08 08:53:04.431 - info: iot.0 (13135) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2024-05-08 08:53:04.856 - info: iot.0 (13135) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.19
      2024-05-08 08:53:04.911 - debug: iot.0 (13135) Schedule restart: * 8 * * *
      2024-05-08 08:53:05.261 - info: iot.0 (13135) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2024-05-08 08:53:06.265 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"15074,14861,17303,18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247,17830,15827,18050,16273,16276","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"6677,6103,10312,9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029,7046,6849,8114,7631,6923","Newprio_realtime_bps":"222,97,1261,2601,2272,1037,2817,5146,226,4735,385,2764,114,120,904,1939,150,1286,866,263","Newprio_high_bps":"5284,5564,6896,5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817,4454,5580,6107,5669,6000","Newprio_default_bps":"1171,442,2155,878,1419,1259,1509,750,1164,715,1101,543,1392,490,1308,653,1119,721,1096,660","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:53:06.670 - debug: iot.0 (13135) [ALEXA] Name "Fenster Badezimmer.STATE" cannot be written and will be ignored
      2024-05-08 08:53:06.674 - debug: iot.0 (13135) [ALEXA] Name "Fenster2 Wohnzimmer.STATE" cannot be written and will be ignored
      2024-05-08 08:53:06.675 - debug: iot.0 (13135) [ALEXA] Name "Garage-Geschlossen.STATE" cannot be written and will be ignored
      2024-05-08 08:53:06.677 - debug: iot.0 (13135) [ALEXA] Name "Wohnzimmerdeckenlampe.LEVEL_REAL" cannot be written and will be ignored
      2024-05-08 08:53:06.679 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: übersicht ["turnOn"]
      2024-05-08 08:53:06.679 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: z.d.f. info ["turnOn"]
      2024-05-08 08:53:06.680 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: z.d.f ["turnOn"]
      2024-05-08 08:53:06.680 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: welt ["turnOn"]
      2024-05-08 08:53:06.680 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: w.d.r ["turnOn"]
      2024-05-08 08:53:06.680 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: vox ["turnOn"]
      2024-05-08 08:53:06.681 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: ton ["turnOn"]
      2024-05-08 08:53:06.681 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: tele fünf ["turnOn"]
      2024-05-08 08:53:06.681 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: super r. t. l ["turnOn"]
      2024-05-08 08:53:06.681 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: sport eins ["turnOn"]
      2024-05-08 08:53:06.681 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: sixx ["turnOn"]
      2024-05-08 08:53:06.682 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: sat eins gold ["turnOn"]
      2024-05-08 08:53:06.682 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: sat eins ["turnOn"]
      2024-05-08 08:53:06.682 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: r.t.l zwei ["turnOn"]
      2024-05-08 08:53:06.682 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: r.t.l ["turnOn"]
      2024-05-08 08:53:06.682 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: pro sieben max ["turnOn"]
      2024-05-08 08:53:06.683 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: pro sieben ["turnOn"]
      2024-05-08 08:53:06.683 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: phoenix ["turnOn"]
      2024-05-08 08:53:06.684 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: okay ["turnOn"]
      2024-05-08 08:53:06.684 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: nächster kanal ["turnOn"]
      2024-05-08 08:53:06.684 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: nitro ["turnOn"]
      2024-05-08 08:53:06.684 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: nick ["turnOn"]
      2024-05-08 08:53:06.684 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: n.t.v ["turnOn"]
      2024-05-08 08:53:06.685 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: n. vier und zwanzig doku ["turnOn"]
      2024-05-08 08:53:06.685 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: mach leiser ["turnOn"]
      2024-05-08 08:53:06.685 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: mach lauter ["turnOn"]
      2024-05-08 08:53:06.685 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: kanal zurück ["turnOn"]
      2024-05-08 08:53:06.685 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: kabel eins doku ["turnOn"]
      2024-05-08 08:53:06.686 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: kabel eins ["turnOn"]
      2024-05-08 08:53:06.686 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: h.r ["turnOn"]
      2024-05-08 08:53:06.686 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: exit ["turnOn"]
      2024-05-08 08:53:06.686 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: eurosport eins deutschland ["turnOn"]
      2024-05-08 08:53:06.687 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: eurosport eins ["turnOn"]
      2024-05-08 08:53:06.687 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: eingangskamera ["turnOn"]
      2024-05-08 08:53:06.687 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: ecoMode ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:53:06.687 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: drei sat ["turnOn"]
      2024-05-08 08:53:06.687 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: d. max ["turnOn"]
      2024-05-08 08:53:06.687 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: aufnahme ["turnOn"]
      2024-05-08 08:53:06.688 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: arte ["turnOn"]
      2024-05-08 08:53:06.688 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: a.r.d ["turnOn"]
      2024-05-08 08:53:06.688 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Wohnzimmerstehlampe ["turnOn","turnOff"]
      2024-05-08 08:53:06.688 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Wohnzimmerschrank ["turnOn","turnOff"]
      2024-05-08 08:53:06.689 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Wohnzimmer Rollade rechts ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:53:06.689 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Wohnzimmer Rollade links ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:53:06.689 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Wohnzimmer Deckenlampe ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:53:06.689 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: WC Beleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.689 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Terrassenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.690 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Terrasse ["getTemperatureReading"]
      2024-05-08 08:53:06.690 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Strauchbewässerung ["turnOn","turnOff"]
      2024-05-08 08:53:06.690 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: SteckdoseJulia ["turnOn","turnOff"]
      2024-05-08 08:53:06.690 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Schuppenbewegungsbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.690 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Schuppenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.690 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Schlafzimmerbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.691 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Rasenbewässerung ["turnOn","turnOff"]
      2024-05-08 08:53:06.691 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Mower stoppen ["turnOn"]
      2024-05-08 08:53:06.691 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Mower starten ["turnOn"]
      2024-05-08 08:53:06.691 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Mower nach Hause schicken ["turnOn"]
      2024-05-08 08:53:06.691 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Mower Kantenschnitt ["turnOn"]
      2024-05-08 08:53:06.692 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Küchenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.692 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Kompressor ["turnOn","turnOff"]
      2024-05-08 08:53:06.692 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Wohnzimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:53:06.692 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Wohnzimmer Power ["turnOn","turnOff"]
      2024-05-08 08:53:06.692 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Wohnzimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:53:06.693 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Wohnzimmer ["turnOn","turnOff"]
      2024-05-08 08:53:06.693 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Schlafzimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:53:06.693 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Schlafzimmer Power ["turnOn","turnOff"]
      2024-05-08 08:53:06.693 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Schlafzimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:53:06.693 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Schlafzimmer ["turnOn","turnOff"]
      2024-05-08 08:53:06.694 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Juliazimmer Temperatur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:53:06.694 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Juliazimmer Power ["turnOn","turnOff"]
      2024-05-08 08:53:06.694 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Juliazimmer Leise ["turnOn","turnOff"]
      2024-05-08 08:53:06.694 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Klima Juliazimmer ["turnOn","turnOff"]
      2024-05-08 08:53:06.694 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Juliazimmerbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.694 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Hochbeetsteckdose ["turnOn"]
      2024-05-08 08:53:06.695 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Hochbeetbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.695 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Heizungsraumbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.695 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Heizung Wohnzimmer ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:53:06.695 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Heizung WC ["turnOn","turnOff"]
      2024-05-08 08:53:06.696 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Heizung Schlafzimmer ["getTemperatureReading","setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:53:06.696 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Heizung Julia ["getTemperatureReading","setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:53:06.696 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Heizung Flur ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:53:06.696 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Heizung Büro ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature"]
      2024-05-08 08:53:06.696 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Heizung Bad ["setTargetTemperature","incrementTargetTemperature","decrementTargetTemperature","getTargetTemperature","getTemperatureReading"]
      2024-05-08 08:53:06.697 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Hauswirtschaftsraumbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.697 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Gartentorbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.697 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Gartenpumpe ["turnOn","turnOff"]
      2024-05-08 08:53:06.697 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Gartenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.697 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Garagentortaster ["turnOn"]
      2024-05-08 08:53:06.697 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Garagenbeleuchtungvorne ["turnOn","turnOff"]
      2024-05-08 08:53:06.698 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Flurstehlampe ["turnOn","turnOff"]
      2024-05-08 08:53:06.698 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: FireTvStick ["turnOn","turnOff"]
      2024-05-08 08:53:06.698 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Fernseher ["turnOn","turnOff"]
      2024-05-08 08:53:06.698 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Esszimmerstehlampe ["turnOn","turnOff"]
      2024-05-08 08:53:06.698 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Esszimmersteckdose ["turnOn","turnOff"]
      2024-05-08 08:53:06.699 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Esszimmerschrank ["turnOn","turnOff"]
      2024-05-08 08:53:06.699 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Esszimmer Deckenlampe ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      2024-05-08 08:53:06.699 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Eingangslampe ["turnOn","turnOff"]
      2024-05-08 08:53:06.699 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Dachboden ["getTemperatureReading"]
      2024-05-08 08:53:06.700 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Carportbewegungsbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.700 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Carportbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.700 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Box ["turnOn","turnOff"]
      2024-05-08 08:53:06.700 - debug: iot.0 (13135) [ALEXA] Created ALEXA device: Aussenbeleuchtung ["turnOn","turnOff"]
      2024-05-08 08:53:06.858 - info: iot.0 (13135) Connection changed: connect "yyyyyyyyyyyyyy"
      2024-05-08 08:53:12.046 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"16310,17460,15074,14861,17303,18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247,17830,15827,18050","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"7733,7096,6677,6103,10312,9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029,7046,6849,8114","Newprio_realtime_bps":"998,2622,222,97,1261,2601,2272,1037,2817,5146,226,4735,385,2764,114,120,904,1939,150,1286","Newprio_high_bps":"5567,3694,5284,5564,6896,5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817,4454,5580,6107","Newprio_default_bps":"1168,780,1171,442,2155,878,1419,1259,1509,750,1164,715,1101,543,1392,490,1308,653,1119,721","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:53:18.119 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"15607,16310,17460,15074,14861,17303,18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247,17830,15827","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"7127,7733,7096,6677,6103,10312,9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029,7046,6849","Newprio_realtime_bps":"538,998,2622,222,97,1261,2601,2272,1037,2817,5146,226,4735,385,2764,114,120,904,1939,150","Newprio_high_bps":"5950,5567,3694,5284,5564,6896,5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817,4454,5580","Newprio_default_bps":"639,1168,780,1171,442,2155,878,1419,1259,1509,750,1164,715,1101,543,1392,490,1308,653,1119","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:53:24.075 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"14953,15607,16310,17460,15074,14861,17303,18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247,17830","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"7038,7127,7733,7096,6677,6103,10312,9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029,7046","Newprio_realtime_bps":"115,538,998,2622,222,97,1261,2601,2272,1037,2817,5146,226,4735,385,2764,114,120,904,1939","Newprio_high_bps":"5550,5950,5567,3694,5284,5564,6896,5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817,4454","Newprio_default_bps":"1373,639,1168,780,1171,442,2155,878,1419,1259,1509,750,1164,715,1101,543,1392,490,1308,653","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:53:30.145 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"15652,14953,15607,16310,17460,15074,14861,17303,18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960,17247","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"6295,7038,7127,7733,7096,6677,6103,10312,9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084,8029","Newprio_realtime_bps":"88,115,538,998,2622,222,97,1261,2601,2272,1037,2817,5146,226,4735,385,2764,114,120,904","Newprio_high_bps":"5769,5550,5950,5567,3694,5284,5564,6896,5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474,5817","Newprio_default_bps":"438,1373,639,1168,780,1171,442,2155,878,1419,1259,1509,750,1164,715,1101,543,1392,490,1308","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      2024-05-08 08:53:36.133 - info: tr-064.0 (27358) {"NewTotalNumberSyncGroups":"1","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13302000","Newmax_us":"4872625","Newds_current_bps":"15866,15652,14953,15607,16310,17460,15074,14861,17303,18756,17256,16893,17982,17744,14764,17047,15552,17391,16023,13960","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"7662,6295,7038,7127,7733,7096,6677,6103,10312,9117,9721,8255,9787,11256,6785,11281,7326,8785,7521,6084","Newprio_realtime_bps":"630,88,115,538,998,2622,222,97,1261,2601,2272,1037,2817,5146,226,4735,385,2764,114,120","Newprio_high_bps":"5666,5769,5550,5950,5567,3694,5284,5564,6896,5638,6030,5959,5461,5360,5395,5831,5840,5478,6015,5474","Newprio_default_bps":"1366,438,1373,639,1168,780,1171,442,2155,878,1419,1259,1509,750,1164,715,1101,543,1392,490","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
      Mein System
          Plattform: docker (official image - v9.1.1)
          Betriebssystem: linux
          Architektur: x64
          CPUs: 4
          Geschwindigkeit: 1501 MHz
          Modell: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
          RAM: 11.5 GB
          System-Betriebszeit: 43 T. 17:39:52
          Node.js: v18.19.0
          time: 1715153126234
          timeOffset: -120
          NPM: 10.2.3
          Adapter-Anzahl: 539
          Datenträgergröße: 3572.6 GB
          Freier Festplattenspeicher: 2111.0 GB
          Aktive Instanzen: 29
          Pfad: /opt/iobroker/
          Betriebszeit: 43 T. 17:29:22
          aktiv:
      iot Version ist die v3.2.1
      Weiß jemand was da schief läuft??
      Edit: So wie es aussieht, kommt der Fehlereintrag nur nach einem Neustart des Adapters
        arteck Developer Most Active @emil70 last edited by
        @emil70 sagte in iot Fehlermeldung:
        klar hier
        https://github.com/ioBroker/ioBroker.iot/issues/758
        vaaarg created this issue in ioBroker/ioBroker.iot
        open Caught by controller[0]: TypeError: Cannot convert undefined or null to object #758
        • E
          emil70 @arteck last edited by
          @arteck
          Danke dir
          Da habe ich natürlich nicht nachgesehen 😞
            klaris last edited by klaris
            hallo
            habe auch ein problem ,mit dem iot adapter ,Verbunden mit Gerät oder Dienst ist gelb
            was könnte das sein...
            Plattform
                linux
            Betriebssystem
                linux
            Architektur
                arm
            CPUs
            Geschwindigkeit
                2400 MHz
            Modell
                unknown
            RAM
                3.9 GB
            System-Betriebszeit
                00:54:10
            Node.js
                v20.17.0 (Empfohlene Version v18.20.4)
            time
                1725926959144
            timeOffset
                -120
            NPM
                10.8.2
            Anzahl der Adapter
                0
            iot.0iot.0
            	2024-09-10 01:51:12.369	error	Error by device connection: {"code":"ECONNREFUSED"}
            iot.0
              Thomas Braun Most Active @klaris last edited by
              @klaris sagte in iot Fehlermeldung:
              Deine alten Softwarestände. Bring die Kiste auf den aktuellen Stand.
                ich war mir sicher ist alles auf den neusten stand!!
                frisch installiert und dann den befehl sudo apt update +sudo apt upgrade eingetippt ....
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.17.0
                /usr/bin/node           v20.17.0
                /usr/bin/corepack       0.29.3
                  @klaris
                  Die Meldung
                  dürfte aber nur bei einem alten Admin erscheinen. In aktuellen Versionen sollte auch ein nodejs@20 empfohlen werden.
                  Die Langfassung von
                  iob diag
                  schaut wie aus?
                    klaris @Thomas Braun last edited by
                    @thomas-braun ```
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                     Static hostname: raspberrypidi
                           Icon name: computer
                    Operating System: Raspbian GNU/Linux 12 (bookworm)
                              Kernel: Linux 6.6.31+rpt-rpi-v8
                        Architecture: arm64
                    Model           : Raspberry Pi 5 Model B Rev 1.0
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 32 bit
                    Systemuptime and Load:
                     10:52:32 up 48 min,  2 users,  load average: 0.39, 0.59, 0.72
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Tue 2024-09-10 10:52:32 CEST
                               Universal time: Tue 2024-09-10 08:52:32 UTC
                                     RTC time: Tue 2024-09-10 08:52:32
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    pi
                    HOME=/home/pi
                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    *** Display-Server-Setup ***
                    Display-Server: false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.2G        619M        2.8G        1.3M        855M        3.6G
                    Swap:           209M          0B        209M
                    Total:          4.4G        619M        3.0G
                    Active iob-Instances:   8
                             3991 M total memory
                              590 M used memory
                              583 M active memory
                              597 M inactive memory
                             2650 M free memory
                               71 M buffer memory
                              744 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    top - 10:52:32 up 48 min,  2 users,  load average: 0.39, 0.59, 0.72
                    Tasks: 168 total,   1 running, 167 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3991.9 total,   2649.6 free,    591.7 used,    816.2 buff/cache
                    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3400.2 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    udev           devtmpfs  1.8G     0  1.8G   0% /dev
                    tmpfs          tmpfs     400M  1.3M  398M   1% /run
                    /dev/mmcblk0p2 ext4       29G  4.3G   23G  16% /
                    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                    /dev/mmcblk0p1 vfat      510M   96M  415M  19% /boot/firmware
                    tmpfs          tmpfs     400M     0  400M   0% /run/user/1000
                    [Tue Sep 10 10:04:27 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:62:1C:7C vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=24dd4293-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Tue Sep 10 10:04:30 2024] EXT4-fs (mmcblk0p2): mounted filesystem 4d48c72f-b919-4823-96cc-04d8e6dcc211 ro with ordered data mode. Quota mode: none.
                    [Tue Sep 10 10:04:31 2024] EXT4-fs (mmcblk0p2): re-mounted 4d48c72f-b919-4823-96cc-04d8e6dcc211 r/w. Quota mode: none.
                    Show mounted filesystems:
                    TARGET                                                  SOURCE         FSTYPE      OPTIONS
                    /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                    |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
                    | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
                    | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                    | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
                    | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                    | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
                    | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
                    | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                    | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
                    |-/proc                                                 proc           proc        rw,relatime
                    | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4211
                    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                    |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1872200k,nr_inodes=468050,mode=755
                    | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                    | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
                    | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
                    |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=408776k,mode=755
                    | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
                    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=408772k,nr_inodes=102193,mode=700,uid=1000,gid=1000
                    `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    544M    /var/
                    168M    /var/cache
                    162M    /var/cache/apt
                    112M    /var/lib
                    86M     /var/cache/apt/archives
                    Archived and active journals take up 63.7M in the file system.
                    /opt/iobroker/backups:
                    39M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    683M    /opt/iobroker/iobroker-data/
                    656M    /opt/iobroker/iobroker-data/files
                    441M    /opt/iobroker/iobroker-data/files/javascript.admin
                    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                    25M     /opt/iobroker/iobroker-data/objects.jsonl
                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                    14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                    USB-Devices by-id:
                    No Devices found 'by-id'
                    HINT:
                    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                    /dev/ttyACM0
                    nodejs:
                      Installed: 20.17.0-1nodesource1
                      Candidate: 20.17.0-1nodesource1
                      Version table:
                     *** 20.17.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                            100 /var/lib/dpkg/status
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         18.19.0+dfsg-6~deb12u2+rpi1 500
                            500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  6.0.11
                    admin:          7.0.23
                    javascript:     "javascript" not found
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : raspberrypidi                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : raspberrypidi                            -  enabled
                    + system.adapter.backitup.0               : backitup              : raspberrypidi                            -  enabled
                      system.adapter.countdown.0              : countdown             : raspberrypidi                            - disabled
                      system.adapter.daswetter.0              : daswetter             : raspberrypidi                            - disabled
                      system.adapter.deconz.0                 : deconz                : raspberrypidi                            - disabled, port: 80
                      system.adapter.discovery.0              : discovery             : raspberrypidi                            - disabled
                      system.adapter.govee-app.1              : govee-app             : raspberrypidi                            - disabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypidi                            -  enabled
                    + system.adapter.info.0                   : info                  : raspberrypidi                            -  enabled
                      system.adapter.iot.1                    : iot                   : raspberrypidi                            - disabled
                    + system.adapter.iot.2                    : iot                   : raspberrypidi                            -  enabled
                    + system.adapter.javascript.0             : javascript            : raspberrypidi                            -  enabled
                      system.adapter.meross.1                 : meross                : raspberrypidi                            - disabled
                      system.adapter.ping.0                   : ping                  : raspberrypidi                            - disabled
                      system.adapter.shelly.0                 : shelly                : raspberrypidi                            - disabled, port: 1882, bind: 0.0.0.0
                      system.adapter.sonoff.1                 : sonoff                : raspberrypidi                            - disabled, port: 1883, bind: 0.0.0.0
                      system.adapter.telegram.1               : telegram              : raspberrypidi                            - disabled, port: 8443, bind: 0.0.0.0
                      system.adapter.tr-064.0                 : tr-064                : raspberrypidi                            - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypidi                            - disabled
                      system.adapter.vis-metro.0              : vis-metro             : raspberrypidi                            - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypidi                            - disabled
                      system.adapter.vis.0                    : vis                   : raspberrypidi                            -  enabled
                    + system.adapter.web.0                    : web                   : raspberrypidi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : raspberrypidi                            - disabled
                      system.adapter.whatsapp-cmb.3           : whatsapp-cmb          : raspberrypidi                            - disabled
                      system.adapter.wifilight.0              : wifilight             : raspberrypidi                            - disabled
                      system.adapter.wled.0                   : wled                  : raspberrypidi                            - disabled
                      system.adapter.yahka.0                  : yahka                 : raspberrypidi                            - disabled
                      system.adapter.zigbee.0                 : zigbee                : raspberrypidi                            - disabled, port: /dev/ttyACM0
                    + instance is alive
                    ioBroker-Repositories
                    │ (index) │ name     │ url                                              │ auto upgrade │
                    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
                    │ 1       │ 'beta'   │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
                    │ 2       │ '__test' │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
                    Active repo(s): stable
                    Upgrade policy: none
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "admin"        : 7.0.23   , installed 7.0.23
                    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                    Adapter    "iot"          : 3.3.0    , installed 3.3.0
                    Controller "js-controller": 6.0.11   , installed 6.0.11
                    Objects and States
                    Objects:        10954
                    States:         9440
                    W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6016       776/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18308      3187/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18313      3187/iobroker.js-co
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          6018       776/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18360      3205/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25142      3535/io.web.0
                    udp        0      0 0.0.0.0:43716           0.0.0.0:*                           104        7272       648/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7270       648/avahi-daemon: r
                    udp6       0      0 fe80::355f:3c17:f08:546 :::*                                0          5065       748/NetworkManager
                    udp6       0      0 :::38088                :::*                                104        7273       648/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                104        7271       648/avahi-daemon: r
                    2024-09-10 10:43:35.189  - info: iot.2 (7033) Connection changed: disconnect
                    2024-09-10 10:43:55.210  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:43:55.211  - info: iot.2 (7033) Connection changed: disconnect
                    2024-09-10 10:44:14.084  - info: alexa2.0 (3290) Alexa-Push-Connection disconnected - retry: Retry Connection in 35s
                    2024-09-10 10:44:35.254  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:44:35.255  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:44:35.255  - info: iot.2 (7033) Connection changed: disconnect
                    2024-09-10 10:44:49.226  - info: alexa2.0 (3290) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2024-09-10 10:45:55.317  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:45:55.318  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:45:55.318  - info: iot.2 (7033) Connection changed: disconnect
                    2024-09-10 10:47:29.386  - info: alexa2.0 (3290) Alexa-Push-Connection disconnected - retry: Retry Connection in 40s
                    2024-09-10 10:48:03.364  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:48:03.365  - info: iot.2 (7033) Connection changed: disconnect
                    2024-09-10 10:48:09.521  - info: alexa2.0 (3290) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2024-09-10 10:50:11.420  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:50:11.421  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:50:11.421  - info: iot.2 (7033) Connection changed: disconnect
                    2024-09-10 10:50:54.676  - info: alexa2.0 (3290) Alexa-Push-Connection disconnected - retry: Retry Connection in 45s
                    2024-09-10 10:51:39.825  - info: alexa2.0 (3290) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2024-09-10 10:52:20.657  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:52:20.658  - error: iot.2 (7033) Error by device connection: {"code":"ECONNREFUSED"}
                    2024-09-10 10:52:20.658  - info: iot.2 (7033) Connection changed: disconnect
                    iob diag has finished.
                    Press any key for a summary
                      @klaris
                      Userland : 32 bit
                      Warum hast du keine reine 64Bit-Version installiert?
                      sind falsch/missverständlich. Das 'beta'-Repo hat den falschen Inhalt und __test ist überflüssig/falsch.
                      Bei den Schlüsseln zum raspbian-Repo stimmt auch was nicht:
                      Hast du da irgendwie was hin und her geclont? Bei einer sauberen Neuinstallation dürfte das so eigentlich nicht vorkommen.
                        klaris @Thomas Braun last edited by klaris
                        stimmt habe von anfang auf repo installiert wegen vis und vis metro sind nicht in stable zu finden!!
                        64bit hast recht hätte es auch machen können!! habe keinen vorteil gesehen ...
                        danke für den Tip ich instaliere alles neu und sehe mal weiter
                        und "__test" ist überflüssig/falsch. habe ich einfach so hinzugefügt habe von der quelle nichts installiert
                          Thomas Braun Most Active @klaris last edited by Thomas Braun
                          Keine Ahnung was du damit sagen willst...
                          Dann schmeiß es raus und stell 'beta' richtig.
                          Dafür haste jetzt den kruden Mix aus 32Bit-Userland und 64Bit-Kernel-Space. Ist halt ungünstig und bereitet in gewissen Konstellationen Probleme. Deswegen vermeidet man sowas.
                            @thomas-braun said in iot Fehlermeldung:
                            ich installiere alles neu nach deinen anweisungen !!! DANKE !!!
                              iob diag
                              alles frisch installiert leider gleicher fehler
                              iot.0
                              	2024-09-11 00:26:35.356	error	Error by device connection: {"code":"ECONNREFUSED"}
                              iot.0
                                code_text
                                Skript v.2024-05-22
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                          Kernel: Linux 6.6.31+rpt-rpi-2712
                                    Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                 00:34:51 up  1:12,  4 users,  load average: 0.06, 0.25, 1.00
                                CPU threads: 4
                                Current issues:
                                               Local time: Wed 2024-09-11 00:34:51 CEST
                                           Universal time: Tue 2024-09-10 22:34:51 UTC
                                                 RTC time: Tue 2024-09-10 22:34:51
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi
                                iobroker
                                HOME=/home/iobroker
                                Display-Server: true
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            4.2G        1.2G        422M         21M        2.7G        3.0G
                                Swap:           209M          0B        209M
                                Total:          4.5G        1.2G        632M
                                Active iob-Instances:   7
                                         4045 M total memory
                                         1144 M used memory
                                         1760 M active memory
                                         1596 M inactive memory
                                          403 M free memory
                                           92 M buffer memory
                                         2490 M swap cache
                                          199 M total swap
                                            0 M used swap
                                          199 M free swap
                                top - 00:34:52 up  1:12,  4 users,  load average: 0.06, 0.25, 1.00
                                Tasks: 203 total,   1 running, 202 sleeping,   0 stopped,   0 zombie
                                %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   4045.1 total,    402.6 free,   1145.1 used,   2583.6 buff/cache
                                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2900.0 avail Mem
                                *** FILESYSTEM ***
                                udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                tmpfs          tmpfs     405M  5.8M  399M   2% /run
                                /dev/mmcblk0p2 ext4       29G  6.8G   21G  25% /
                                tmpfs          tmpfs     2.0G  288K  2.0G   1% /dev/shm
                                tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
                                tmpfs          tmpfs     405M  176K  405M   1% /run/user/1000
                                [Tue Sep 10 23:22:21 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:62:1C:7C vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=57002be6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                [Tue Sep 10 23:22:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
                                [Tue Sep 10 23:22:23 2024] EXT4-fs (mmcblk0p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
                                | `-/sys/fs/fuse/connections                            fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
                                | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=6189
                                |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=1896160k,nr_inodes=118510,mode=755
                                |-/run                                                  tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=414224k,mode=755
                                | `-/run/user/1000                                      tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=414208k,nr_inodes=103552,mode=700,uid=1000,gid=1000
                                |   |-/run/user/1000/gvfs                               gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                |   `-/run/user/1000/doc                                portal         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                /var:
                                625M    /var/
                                193M    /var/lib
                                190M    /var/cache
                                183M    /var/cache/apt
                                133M    /var/lib/apt/lists
                                Archived and active journals take up 39.9M in the file system.
                                559M    /opt/iobroker/iobroker-data/
                                553M    /opt/iobroker/iobroker-data/files
                                8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                                USB-Devices by-id:
                                nodejs:
                                  Version table:
                                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                     18.19.0+dfsg-6~deb12u2 500
                                     18.19.0+dfsg-6~deb12u1 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          7.0.23
                                javascript:     8.7.6
                                Adapter State
                                + system.adapter.discovery.0              : discovery             : raspberrypidi                            -  enabled
                                + system.adapter.iot.0                    : iot                   : raspberrypidi                            -  enabled
                                  system.adapter.telegram.0               : telegram              : raspberrypidi                            - disabled, port: 8443, bind: 0.0.0.0
                                + instance is alive
                                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                Objects and States
                                Objects:        1184
                                States:         953
                                Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Pending Updates: 134
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6032       875/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       49440      17432/iobroker.js-c
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       49445      17432/iobroker.js-c
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          50495      17647/cupsd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          6034       875/sshd: /usr/sbin
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47830      17475/io.admin.0
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          50494      17647/cupsd
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          48773      17676/cups-browsed
                                udp        0      0 0.0.0.0:39645           0.0.0.0:*                           104        5923       661/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5921       661/avahi-daemon: r
                                udp6       0      0 fe80::a47f:2be5:db8:546 :::*                                0          987        812/NetworkManager
                                udp6       0      0 :::50321                :::*                                104        5924       661/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                104        5922       661/avahi-daemon: r
                                2024-09-11 00:31:14.313  - info: host.raspberrypidi instance system.adapter.iot.0 in version "3.3.0" started with pid 18536
                                2024-09-11 00:31:15.105  - info: iot.0 (18536) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.17.0, js-controller: 6.0.11
                                2024-09-11 00:31:15.130  - info: iot.0 (18536) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                2024-09-11 00:31:16.318  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:31:16.319  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:31:16.320  - info: iot.0 (18536) Connection changed: disconnect
                                2024-09-11 00:31:21.338  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:31:21.339  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:31:21.340  - info: iot.0 (18536) Connection changed: disconnect
                                2024-09-11 00:31:31.356  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:31:31.357  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:31:31.358  - info: iot.0 (18536) Connection changed: disconnect
                                2024-09-11 00:31:51.377  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:31:51.378  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:31:51.379  - info: iot.0 (18536) Connection changed: disconnect
                                2024-09-11 00:32:04.716  - info: admin.0 (17475) <== Disconnect system.user.admin from ::ffff:192.168.178.91 admin
                                2024-09-11 00:32:04.737  - info: admin.0 (17475) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                2024-09-11 00:32:04.741  - info: admin.0 (17475) <== Disconnect system.user.admin from ::ffff:192.168.178.91 admin
                                2024-09-11 00:32:05.299  - info: admin.0 (17475) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                2024-09-11 00:32:31.412  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:32:31.413  - info: iot.0 (18536) Connection changed: disconnect
                                2024-09-11 00:33:51.451  - error: iot.0 (18536) Error by device connection: {"code":"ECONNREFUSED"}
                                2024-09-11 00:33:51.452  - info: iot.0 (18536) Connection changed: disconnect
                                  Und
                                  Wie sehen die Einstellungen im iot-Adapter aus?
                                    @thomas-braun im iot habe ich nichts verstellt , nur mein Passwort eingegeben für den Iobroker pro … denke mal das Problem liegt bei dem Adapter der ist sehr empfindlich in Verbindung mit der Node js. Ich hoffe und warte auf eine neue Version
                                    Display Server true wollte es so
                                      ??? Der läuft hier mit allen aktuellen nodejs-Versionen.
                                      Hau die 134 Updates auf die Kiste.
                                        Alles gemacht !!! Alle Updates installiert Neustart und leider immer noch der gleiche Fehler !!
                                        Schade !!
                                        Ich habe zum Glück den Raspberry Pi 3 der parallel läuft und alle Adapter Iobroker, Alexa2 und IOT sind grün!!! Ich glaube nicht, dass das genau das Problem ist, dass ich mich hier beim Raspberry Pi 5 nicht einloggen kann
                                          Doch. Es kann zur iot-Cloud nur EINE Verbindung aufgebaut werden. Du hast ja auch nur EINE Lizenz dafür.
                                            @thomas-braun komischerweise habe ich das auch versucht. Ich habe den IoT Adapter vom Raspberry Pi 3 deaktiviert und auch sonst alle Aktionen gestoppt… hat aber trotzdem auf den raspberry 5 nicht funktioniert.
                                            Ich werde mal beim iobroker mich neu anmelden und eine neue Lizenz erstellen ob das dann hilft schauen wir mal..aber die Fehler Meldung „ ECONNREFUSED “ deutet aus meiner Sicht auf eine andere unbekannte Ursache hin …
                                            1136
