    5. Script mit "request" umbauen
    • Merlin123
      Merlin123 last edited by
      Ein ähnliches Problem gab es hier schon, aber ich kann mit der Lösung dort nichts anfangen 😞 Kann kein JS (bis jetzt)
      Hab folgendes Script
      const printerName = 'K1'; // Replace with your actual printer name
      const printerBaseUrl = 'http://192.168.0.252:7125'; // Replace with your actual moonraker ip
      const updateInterval = 20000; // 20 seconds
      // Function to make an HTTP request and return a promise
      function getPrinterStatus(url) {
          return new Promise((resolve, reject) => {
              const request = require('request');
              request(url, { json: true }, (err, res, body) => {
                  if (err) {
                      reject(err);
                  } else {
                      resolve(body);
      // Function to get metadata for the given filename
      function getFileMetadata(filename) {
          const metadataUrl = printerBaseUrl + `/server/files/metadata?filename=${encodeURIComponent(filename)}`;
          return getPrinterStatus(metadataUrl); // Reusing the HTTP request function
      // Function to convert seconds to HH:MM:SS
      function toHHMMSS(seconds) {
          const hours = Math.floor(seconds / 3600);
          const minutes = Math.floor((seconds % 3600) / 60);
          const sec = Math.floor(seconds % 60);
          return [hours, minutes, sec]
              .map(v => v < 10 ? "0" + v : v)
              .join(":");
      // Function to update the online status of the printer
      function updatePrinterOnlineStatus(isOnline) {
          const onlineStateName = `${printerName}.onlineStatus`;
          createOrUpdateState(onlineStateName, isOnline);
      // Function to create or update ioBroker states
      function createOrUpdateState(fullStateName, value, key='') {
          // Check if the key contains 'duration' and format it if it does
          if (key.includes('duration')) {
              value = toHHMMSS(value);
          // Check if the key contains 'progress' and multiply by 100 and round it if it does
          if (key.includes('progress')) {
              value = Math.round(value * 100); // Converts to percentage and rounds to the nearest integer
          if (!existsState(fullStateName)) {
              createState(fullStateName, {
                  type: typeof value,
                  read: true,
                  write: false,
                  desc: 'Printer status value'
                  setState(fullStateName, value, true);
          } else {
      // Function to process the printer status and update the ioBroker states
      function processPrinterStatus(printerData, parentKey = '') {
          Object.keys(printerData).forEach(key => {
              const value = printerData[key];
              let fullStateName = `${printerName}`;
              if (parentKey) {
                  fullStateName += `.${parentKey}`;
              fullStateName += `.${key}`;
              if (value !== null && typeof value === 'object' && !(value instanceof Array)) {
                  // It's a nested object, so we need to recurse
                  processPrinterStatus(value, key);
              } else {
                  // It's a value, so we create or update the state
                  createOrUpdateState(fullStateName, value, key);
      // Function to nullify file metadata states in ioBroker
      function nullifyFileMetadataStates() {
          var states = $(`*.${printerName}.file_metadata.*`/*Printer file metadata*/);
          states.each(function(id, i){
              setState(id, {val: null, ack: true});
      // Polling function
      function startPolling() {
          setInterval(() => {
              if (getState('sonoff.0.DVES_C38B13.POWER').val == true) getPrinterStatus(printerBaseUrl + '/printer/objects/query?display_status&print_stats&extruder&heater_bed&system_stats')
                  .then(response => {
                      if (response && response.result) {
                          const printStats = response.result.status.print_stats || {};
                          const filename = printStats.filename;
                          // Update printer status
                          processPrinterStatus(response.result);
                          // If there is a filename, get and process the file metadata
                          if (filename) {
                              getFileMetadata(filename).then(metadataResponse => {
                                  if (metadataResponse && metadataResponse.result) {
                                      processPrinterStatus(metadataResponse.result, 'file_metadata');
                              }).catch(error => {
                                  console.error('Error fetching file metadata:', error);
                          } else {
                              // If filename is empty, nullify all file_metadata states
                              nullifyFileMetadataStates();
                          updatePrinterOnlineStatus(true); // Printer is online
                  .catch(error => {
                      console.log('Error fetching printer status... setting Printer offline');
                      updatePrinterOnlineStatus(false); // Printer is offline
          }, updateInterval);
      // Start the polling process
      startPolling();
      Da soll das request raus.
      Hatte mit ChatGPT mein Glück versucht und den request block so ersetzt:
      const axios = require('axios');
          return axios.get(url)
              .then(response => response.data)
              .catch(error => {
                  throw error;
      Reicht aber anscheinend nicht...
      Was muss ich da noch umbauen?
      Merlin123 crunchip haus-automatisierung 3 Replies Last reply Reply Quote 0
      • Merlin123
        Merlin123 @Merlin123 last edited by
        @merlin123 Hab es jetzt mal anders umbauen lassen:
        const http = require('http');
                const req = http.get(url, (res) => {
                    let data = '';
                    // A chunk of data has been received
                    res.on('data', (chunk) => {
                        data += chunk;
                    // The whole response has been received
                    res.on('end', () => {
                        try {
                            const parsedData = JSON.parse(data);
                            resolve(parsedData);
                        } catch (error) {
                            reject(error);
                // Error handling for the request
                req.on('error', (error) => {
                    reject(error);
        Wirft zumindest nicht gleich nen Fehler. Mal testen, wenn ich das nächste Mal was drucke
        Merlin123 1 Reply Last reply Reply Quote 0
        • Merlin123
          War leider nix.... Wirft keinen Fehler, aber es geht leider nicht mehr 😞
          • crunchip
            crunchip Forum Testing Most Active @Merlin123 last edited by
            @merlin123 sagte in Script mit "request" umbauen:
            Kann kein JS
            ich auch nicht, aber denke das sollte so in etwas passen
            https://forum.iobroker.net/post/1159470
            • haus-automatisierung
              haus-automatisierung Developer Most Active @Merlin123 last edited by
              @merlin123 Ungetestet, aber das wäre die Grundlage. Ginge auch mit httpGetAsync.
              async function getPrinterStatus(url) {
                      httpGet(url, { timeout: 2000 }, (err, response) => {
                          if (err) {
                              reject(err);
                          } else {
                              resolve(JSON.parse(response.data));
              async function getFileMetadata(filename) {
                  return getPrinterStatus(`${printerBaseUrl}/server/files/metadata?filename=${encodeURIComponent(filename)}`); // Reusing the HTTP request function
                      .map(v => v < 10 ? '0' + v : v)
                      .join(':');
                  createOrUpdateState(`${printerName}.onlineStatus`, isOnline);
                          type: typeof value,
                          read: true,
                          write: false,
                  } else {
                      if (parentKey) {
                      } else {
                  const states = $(`*.${printerName}.file_metadata.*`);
                  states.each((id, i) => {
                      setState(id, { val: null, ack: true });
              // Polling function
                  setInterval(() => {
                      if (getState('sonoff.0.DVES_C38B13.POWER').val) {
                          getPrinterStatus(`${printerBaseUrl}/printer/objects/query?display_status&print_stats&extruder&heater_bed&system_stats`)
                              .then(data => {
                                  const printStats = data.status.print_stats || {};
                                  processPrinterStatus(data);
                                  if (filename) {
                                          .then(data => {
                                              processPrinterStatus(data, 'file_metadata');
                                          }).catch(error => {
                                  } else {
                              .catch(error => {
                  }, updateInterval);
              startPolling();
              Merlin123 2 Replies Last reply Reply Quote 2
              • Merlin123
                Merlin123 @haus-automatisierung last edited by
                @haus-automatisierung Dank Dir! Werde es testen 🙂
                • Merlin123
                  @haus-automatisierung Auf den ersten Blick sieht es gut aus. Riesigen Dank! Ich schau mir das mal in Ruhe an und versuche es zu verstehen 🙂
