    4. Installation
    5. iobroker influxdb1.x econnrefused 192.168.178.120:8086
      pepa last edited by pepa
      ich versuche ueber influxdb ein flot diagramm zu machen.ueber history oder sql responded der adapter.bei influxdb bekomme ich immer econnectrefused.
      was mache ich falsch ?
      • Adaptername: ... influxdb1.x
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: ... v4.0.2
      • js-controller Version: ... 5.0.19
      • Admin Version: ... 6.13.16iobdiag1.odt
      • Hardwaresystem: NUC, Pi4 ... esprimo q556/2
      • Arbeitsspeicher: ...xGB 8gb
      • Festplattenart: SD-Karte, SSD, HDD, ... M2 NVME 256Gb
      • Betriebssystem: ... linux mint 21.3 cinnamon
      • Nodejs-Version: ... 18.20.2
      • NPM-Version: ... 10.5.0
      • Installationsart: Skript oder Manuell ? manuell
      • Image, Docker genutzt: Ja - Nein nein
      • Ort, Name der Imagedatei: ...
      Linux User bitte hier den Output von iob diag einfügen.iobdiag1.odt```
      code_text
      Copy text starting here:
      			v.2024-04-21
       Static hostname: ppmint-ESPRIMO-Q556-2
             Icon name: computer-desktop
               Chassis: desktop
      Operating System: Linux Mint 21.3
                Kernel: Linux 5.15.0-106-generic
          Architecture: x86-64
       Hardware Vendor: FUJITSU
        Hardware Model: ESPRIMO Q556/2
      Installation: 		native
      Kernel: 		x86_64
      Userland: 		64 bit
      Timezone: 		Europe/Berlin (CEST, +0200)
      igured to read the RTC time in the local time zone.
      nges and daylight saving time adjustments. The RTC
      User-ID: 		1000
      Display-Server: 	true
      Boot Target: 		graphical.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/nodejs 	v18.20.2
      /usr/bin/node 		v18.20.2
      /usr/bin/npm 		10.5.0
      /usr/bin/npx 		10.5.0
      /usr/bin/corepack 	0.25.2
      Recommended versions are nodejs 18.20.2 and npm 10.5.0
      MEMORY:
      Mem:            7.8G        2.6G        1.1G        494M        4.1G        4.4G
      Swap:           2.0G        1.0M        2.0G
      Total:          9.8G        2.6G        3.1G
      Active iob-Instances: 	14
      Active repo(s): stable
      ioBroker Core: 		js-controller 		5.0.19
      			admin 			6.13.16
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		432
      States: 		339
      Size of iob-Database:
      14M	/opt/iobroker/iobroker-data/objects.jsonl
      6.7M	/opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      • DJMarc75
        DJMarc75 @pepa last edited by
        @pepa sagte in iobroker influxdb1.x econnrefused 192.168.178.120:8086:
        bitte das auch beachten und umsetzen 😉
          pepa @DJMarc75 last edited by
          @djmarc75
          habe ich eben getan,, ich wusste nicht, wie es geht.
          DJMarc75 2 Replies Last reply Reply Quote 0
          • DJMarc75
            jedenfalls nicht als Datei sondern in Codetags - siehe hier
            https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
            und keine Beiträge nachträglich editieren bitte 😉
            • DJMarc75
              @pepa Bitte die Langfassung von
              iob diag
              und nochmals:
              keinen vergangenen Post editieren sondern einen neuen mit den Infos reinsetzen
                Skript v.2024-04-21
                *** BASE SYSTEM ***
                         Chassis: desktop
                model name	: Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
                Docker          : false
                Virtualization  : none
                Kernel          : x86_64
                Userland        : 64 bit
                Systemuptime and Load:
                 16:23:19 up 1 day, 23:54,  2 users,  load average: 0.38, 0.37, 0.28
                CPU threads: 4
                *** Time and Time Zones ***
                               Local time: Sun 2024-05-12 16:23:19 CEST
                           Universal time: Sun 2024-05-12 14:23:19 UTC
                                 RTC time: Sun 2024-05-12 14:23:25
                              NTP service: active
                          RTC in local TZ: yes
                Warning: The system is configured to read the RTC time in the local time zone.
                         This mode cannot be fully supported. It will create various problems
                         with time zone changes and daylight saving time adjustments. The RTC
                         time is never updated, it relies on external facilities to maintain it.
                         If at all possible, use RTC in UTC by calling
                         'timedatectl set-local-rtc 0'.
                *** Users and Groups ***
                User that called 'iob diag':
                ppmint
                HOME=/home/ppmint
                GROUPS=ppmint adm cdrom sudo dip plugdev lpadmin sambashare iobroker
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev bluetooth
                *** Display-Server-Setup ***
                Desktop: 	cinnamon
                Terminal: 	x11
                *** MEMORY ***
                Mem:            7.8G        2.6G        1.1G        521M        4.1G        4.3G
                Swap:           2.0G         47M        2.0G
                Total:          9.8G        2.7G        3.1G
                Active iob-Instances: 	13
                         7782 M total memory
                         2632 M used memory
                         2169 M active memory
                         3240 M inactive memory
                         1063 M free memory
                          895 M buffer memory
                         3191 M swap cache
                         2047 M total swap
                           47 M used swap
                         2000 M free swap
                top - 16:23:20 up 1 day, 23:54,  2 users,  load average: 0.38, 0.37, 0.28
                Tasks: 261 total,   1 running, 260 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   7783.0 total,   1061.3 free,   2632.6 used,   4089.1 buff/cache
                MiB Swap:   2048.0 total,   2001.0 free,     47.0 used.   4329.8 avail Mem
                *** FAILED SERVICES ***
                  UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                * casper-md5check.service loaded failed failed casper-md5check Verify Live ISO checksums
                1 loaded units listed.
                *** FILESYSTEM ***
                Filesystem     Type   Size  Used Avail Use% Mounted on
                tmpfs          tmpfs  779M  1.7M  777M   1% /run
                /dev/sda2      ext4   234G   31G  191G  15% /
                tmpfs          tmpfs  3.9G   23M  3.8G   1% /dev/shm
                tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
                /dev/nvme0n1p1 vfat   511M  6.1M  505M   2% /boot/efi
                tmpfs          tmpfs  779M  128K  779M   1% /run/user/1000
                [Fri May 10 16:28:54 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Fri May 10 16:28:55 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                [Fri May 10 17:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Fri May 10 18:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Fri May 10 19:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Fri May 10 20:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Fri May 10 21:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Fri May 10 22:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Fri May 10 23:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 00:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 01:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 02:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 03:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 04:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 05:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 06:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 07:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 08:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 09:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 10:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 11:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 12:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 13:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 14:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 15:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 16:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 17:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 18:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 19:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 20:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 21:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 22:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sat May 11 23:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 00:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 01:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 02:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 03:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 04:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 05:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 06:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 07:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 08:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 09:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 10:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 11:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 12:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 13:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 14:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 15:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun May 12 16:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                Show mounted filesystems:
                TARGET                                        SOURCE         FSTYPE          OPTIONS
                /                                             /dev/sda2      ext4            rw,relatime,errors=remount-ro
                |-/sys                                        sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/security                      securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/cgroup                            cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                | |-/sys/fs/pstore                            pstore         pstore          rw,nosuid,nodev,noexec,relatime
                | |-/sys/firmware/efi/efivars                 efivarfs       efivarfs        rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/bpf                               bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                | |-/sys/kernel/debug                         debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/tracing                       tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/fuse/connections                  fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
                | `-/sys/kernel/config                        configfs       configfs        rw,nosuid,nodev,noexec,relatime
                |-/proc                                       proc           proc            rw,nosuid,nodev,noexec,relatime
                | `-/proc/sys/fs/binfmt_misc                  systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=20386
                |   `-/proc/sys/fs/binfmt_misc                binfmt_misc    binfmt_misc     rw,nosuid,nodev,noexec,relatime
                |-/dev                                        udev           devtmpfs        rw,nosuid,relatime,size=3918988k,nr_inodes=979747,mode=755,inode64
                | |-/dev/pts                                  devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                | |-/dev/shm                                  tmpfs          tmpfs           rw,nosuid,nodev,inode64
                | |-/dev/hugepages                            hugetlbfs      hugetlbfs       rw,relatime,pagesize=2M
                | `-/dev/mqueue                               mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
                |-/run                                        tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=796980k,mode=755,inode64
                | |-/run/lock                                 tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                | |-/run/credentials/systemd-sysusers.service none           ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/rpc_pipefs                           sunrpc         rpc_pipefs      rw,relatime
                | `-/run/user/1000                            tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=796976k,nr_inodes=199244,mode=700,uid=1000,gid=1000,inode64
                |   |-/run/user/1000/gvfs                     gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                |   `-/run/user/1000/doc                      portal         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                `-/boot/efi                                   /dev/nvme0n1p1 vfat            rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                /var:
                2.2G	/var/
                1.4G	/var/cache
                1.3G	/var/cache/apt
                1.2G	/var/cache/apt/archives
                690M	/var/lib
                Archived and active journals take up 104.0M in the file system.
                /opt/iobroker/backups:
                7.6M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                168M	/opt/iobroker/iobroker-data/
                114M	/opt/iobroker/iobroker-data/files
                57M	/opt/iobroker/iobroker-data/files/javascript.admin
                38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                37M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                9.3M	/opt/iobroker/iobroker-data/objects.jsonl
                8.5M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                USB-Devices by-id:
                No Devices found 'by-id'
                *** NodeJS-Installation ***
                /usr/bin/npm 		10.5.0
                /usr/bin/npx 		10.5.0
                nodejs:
                  Installed: 18.20.2-1nodesource1
                  Candidate: 18.20.2-1nodesource1
                  Version table:
                 *** 18.20.2-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                        100 /var/lib/dpkg/status
                     18.20.1-1nodesource1 1001
                     18.20.0-1nodesource1 1001
                     18.19.1-1nodesource1 1001
                     18.19.0-1nodesource1 1001
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                     12.22.9~dfsg-1ubuntu3.5 500
                        500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                        500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                     12.22.9~dfsg-1ubuntu3 500
                        500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller: 	5.0.19
                admin: 		6.13.16
                javascript: 	7.8.0
                nodejs modules from github: 	0
                Adapter State
                + system.adapter.backitup.0               : backitup              : ppmint-ESPRIMO-Q556-2                    -  enabled
                + system.adapter.discovery.0              : discovery             : ppmint-ESPRIMO-Q556-2                    -  enabled
                  system.adapter.flot.0                   : flot                  : ppmint-ESPRIMO-Q556-2                    -  enabled
                + system.adapter.history.0                : history               : ppmint-ESPRIMO-Q556-2                    -  enabled
                + system.adapter.influxdb.0               : influxdb              : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 8086
                + system.adapter.influxdb.1               : influxdb              : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 8086
                + system.adapter.javascript.0             : javascript            : ppmint-ESPRIMO-Q556-2                    -  enabled
                + system.adapter.mqtt-client.0            : mqtt-client           : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 1883
                + system.adapter.mqtt.0                   : mqtt                  : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.ping.0                   : ping                  : ppmint-ESPRIMO-Q556-2                    -  enabled
                + system.adapter.sonoff.0                 : sonoff                : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.sql.0                    : sql                   : ppmint-ESPRIMO-Q556-2                    - disabled, port: 3306
                + instance is alive
                ioBroker-Repositories
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
                Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                Adapter    "ws"           : 2.6.1    , installed 2.6.1
                Objects and States
                Objects: 	432
                States: 	330
                Hit:1 https://apt.grafana.com stable InRelease
                Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
                Hit:4 https://linux.teamviewer.com/deb stable InRelease
                Hit:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                Hit:6 https://dl.google.com/linux/chrome/deb stable InRelease
                Hit:7 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
                Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:9 https://ppa.launchpadcontent.net/linuxgndu/sqlitebrowser/ubuntu jammy InRelease
                Ign:10 http://packages.linuxmint.com virginia InRelease
                Hit:11 http://packages.linuxmint.com virginia Release
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          26169      1393/teamviewerd
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          867753     88824/cupsd
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25820      795/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25827      795/iobroker.js-con
                tcp        0      0 0.0.0.0:5938            0.0.0.0:*               LISTEN      0          26167      1393/teamviewerd
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34864      2784/io.sonoff.0
                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        24960      634/systemd-resolve
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23842      821/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15646      1/init
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          867752     88824/cupsd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31152      2092/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       36958      3007/io.web.0
                tcp6       0      0 :::3000                 :::*                    LISTEN      131        27243      1363/grafana
                tcp6       0      0 :::5938                 :::*                    LISTEN      0          26165      1393/teamviewerd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          23844      821/sshd: /usr/sbin
                tcp6       0      0 :::111                  :::*                    LISTEN      0          15648      1/init
                udp        0      0 0.0.0.0:34510           0.0.0.0:*                           122        25687      694/avahi-daemon: r
                udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        24959      634/systemd-resolve
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15647      1/init
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          866892     88825/cups-browsed
                udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       1271758    79985/chrome --prof
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           122        25685      694/avahi-daemon: r
                udp6       0      0 :::60194                :::*                                122        25688      694/avahi-daemon: r
                udp6       0      0 :::111                  :::*                                0          15649      1/init
                udp6       0      0 fe80::84b2:a3b4:b84:546 :::*                                0          27085      698/NetworkManager
                udp6       0      0 :::5353                 :::*                                122        25686      694/avahi-daemon: r
                2024-05-12 16:23:15.778  - error: influxdb.1 (2592) Error: connect ECONNREFUSED 192.168.178.120:8086
                2024-05-12 16:23:16.374  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.Wifi_RSSI/sonoff.0.DVES_56CBA1.Wifi_RSSI:{"val":100,"ack":true,"ts":1715523796372,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715454457345}
                2024-05-12 16:23:16.390  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.DS18B20_Temperature/sonoff.0.DVES_56CBA1.DS18B20_Temperature:{"val":22.38,"ack":true,"ts":1715523796389,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715523746314}
                2024-05-12 16:23:22.310  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:22.313  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:25.779  - info: influxdb.1 (2592) Connecting http://192.168.178.120:8086/ ...
                2024-05-12 16:23:25.780  - info: influxdb.1 (2592) Influx DB Version used: 1.x
                2024-05-12 16:23:25.780  - debug: influxdb.1 (2592) Connect InfluxDB1: http://192.168.178.120:8086 [iobroker]
                2024-05-12 16:23:25.784  - error: influxdb.1 (2592) Error: connect ECONNREFUSED 192.168.178.120:8086
                2024-05-12 16:23:26.352  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.Wifi_RSSI/sonoff.0.DVES_56CBA1.Wifi_RSSI:{"val":100,"ack":true,"ts":1715523806352,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715454457345}
                2024-05-12 16:23:26.358  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.DS18B20_Temperature/sonoff.0.DVES_56CBA1.DS18B20_Temperature:{"val":22.38,"ack":true,"ts":1715523806357,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715523746314}
                2024-05-12 16:23:28.039  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:28.041  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:29.732  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:29.735  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:32.654  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:32.656  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:34.381  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:34.382  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                2024-05-12 16:23:35.783  - info: influxdb.1 (2592) Connecting http://192.168.178.120:8086/ ...
                2024-05-12 16:23:35.784  - info: influxdb.1 (2592) Influx DB Version used: 1.x
                2024-05-12 16:23:35.784  - debug: influxdb.1 (2592) Connect InfluxDB1: http://192.168.178.120:8086 [iobroker]
                2024-05-12 16:23:35.786  - error: influxdb.1 (2592) Error: connect ECONNREFUSED 192.168.178.120:8086
                2024-05-12 16:23:36.334  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.Wifi_RSSI/sonoff.0.DVES_56CBA1.Wifi_RSSI:{"val":100,"ack":true,"ts":1715523816333,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715454457345}
                2024-05-12 16:23:36.339  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.DS18B20_Temperature/sonoff.0.DVES_56CBA1.DS18B20_Temperature:{"val":22.38,"ack":true,"ts":1715523816339,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715523746314}
                • Meister Mopper
                  Meister Mopper @pepa last edited by
                  Skript v.2024-04-21
                  *** BASE SYSTEM ***
                           Chassis: desktop
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 4
                                NTP service: active
                  ppmint
                  HOME=/home/ppmint
                  iobroker
                  HOME=/home/iobroker
                  Desktop: 	cinnamon
                  Terminal: 	x11
                  *** MEMORY ***
                  Swap:           2.0G         47M        2.0G
                           7782 M total memory
                           2632 M used memory
                           1063 M free memory
                            895 M buffer memory
                           3191 M swap cache
                           2047 M total swap
                             47 M used swap
                           2000 M free swap
                  *** FILESYSTEM ***
                  /var:
                  2.2G	/var/
                  1.4G	/var/cache
                  1.3G	/var/cache/apt
                  690M	/var/lib
                  USB-Devices by-id:
                  /usr/bin/npm 		10.5.0
                  /usr/bin/npx 		10.5.0
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.13.16
                  javascript: 	7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	432
                  States: 	330
                  Pending Updates: 0
                  Ist nicht komplett.
                  • DJMarc75
                    DJMarc75 @Meister Mopper last edited by DJMarc75
                    @meister-mopper sagte in iobroker influxdb1.x econnrefused 192.168.178.120:8086:
                    Ist nicht komplett
                    Denke schon aber da läuft einiges krumm:
                    Desktop: cinnamon
                    Terminal: x11
                    • system.adapter.influxdb.0 : influxdb : ppmint-ESPRIMO-Q556-2 - enabled, port: 8086
                    • system.adapter.influxdb.1 : influxdb : ppmint-ESPRIMO-Q556-2 - enabled, port: 8086
                    • system.adapter.javascript.0 : javascript : ppmint-ESPRIMO-Q556-2 - enabled
                    • system.adapter.mqtt-client.0 : mqtt-client : ppmint-ESPRIMO-Q556-2 - enabled, port: 1883
                    • system.adapter.mqtt.0 : mqtt : ppmint-ESPRIMO-Q556-2 - enabled, port: 1883, bind: 0.0.0.0
                    • system.adapter.ping.0 : ping : ppmint-ESPRIMO-Q556-2 - enabled
                    • system.adapter.sonoff.0 : sonoff : ppmint-ESPRIMO-Q556-2 - enabled, port: 1883, bind: 0.0.0.0
                    edit:
                    zusätzlich bitte das LOGLevel der Instanzen nicht auf SILLY stellen 🙂
                      ronk last edited by ronk
                      nun auch hier nach Adapterupdate javascript keine Verbindung mehr zu influxdb.
                      Error: connect ECONNREFUSED 192.168.178.58:8086
                      iob diag:
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.1.21-v8+
                          Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.5
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       17:27:50 up 26 min,  2 users,  load average: 4.50, 3.25, 2.51
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                                     Local time: Sun 2024-05-26 17:27:50 CEST
                                 Universal time: Sun 2024-05-26 15:27:50 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      ronny
                      HOME=/home/ronny
                      GROUPS=ronny adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            4.0G        1.6G        551M         56M        2.0G        2.4G
                      Total:          4.1G        1.6G        656M
                      Active iob-Instances:   15
                               3794 M total memory
                               1516 M used memory
                               2045 M active memory
                                684 M inactive memory
                                526 M free memory
                                227 M buffer memory
                               1653 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      top - 17:27:51 up 26 min,  2 users,  load average: 4.50, 3.25, 2.51
                      Tasks: 238 total,   1 running, 237 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3794.3 total,    525.2 free,   1517.6 used,   1881.1 buff/cache
                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2276.7 avail Mem
                      * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                      * rc-local.service loaded failed failed /etc/rc.local Compatibility
                      2 loaded units listed.
                      *** FILESYSTEM ***
                      /dev/root                                ext4       29G   23G  4.2G  85% /
                      devtmpfs                                 devtmpfs  1.7G     0  1.7G   0% /dev
                      tmpfs                                    tmpfs     1.9G     0  1.9G   0% /dev/shm
                      tmpfs                                    tmpfs     759M  3.3M  756M   1% /run
                      tmpfs                                    tmpfs     5.0M   16K  5.0M   1% /run/lock
                      /dev/mmcblk0p1                           vfat      255M   31M  225M  13% /boot
                      tmpfs                                    tmpfs     380M   36K  380M   1% /run/user/1000
                      //192.168.178.1/fritz.nas/FRITZ_1/Backup cifs      118G  4.9G  113G   5% /opt/iobroker/backups
                      [Sun May 26 17:01:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Sun May 26 17:01:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                      [Sun May 26 17:01:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                      [Sun May 26 17:01:37 2024] EXT4-fs (mmcblk0p2): recovery complete
                      [Sun May 26 17:01:37 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun May 26 17:01:37 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Sun May 26 17:01:40 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #324609: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #324609: comm du: Directory block failed checksum
                      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325045: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325045: comm du: Directory block failed checksum
                      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325090: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325090: comm du: Directory block failed checksum
                      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325078: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325078: comm du: Directory block failed checksum
                      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325086: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325086: comm du: Directory block failed checksum
                      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325082: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325082: comm du: Directory block failed checksum
                      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325088: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325088: comm du: Directory block failed checksum
                      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325084: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325084: comm du: Directory block failed checksum
                      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325080: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325080: comm du: Directory block failed checksum
                      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #324539: comm du: No space for directory leaf checksum. Please run e2fsck -D.
                      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #324539: comm du: Directory block failed checksum
                      /        /dev/mmcblk0p2                           ext4        rw,noatime
                      |-/dev        devtmpfs                                 devtmpfs    rw,relatime,size=1678472k,nr_inodes=419618,mode=755
                      |-/proc        proc                                     proc        rw,relatime
                      |-/run        tmpfs                                    tmpfs       rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
                      | |-/run/credentials/systemd-sysctl.service                                                        ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-sysusers.service                                                      ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-tmpfiles-setup-dev.service                                            ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-tmpfiles-setup.service                                                ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/user/1000        tmpfs                                    tmpfs       rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
                      | |-/run/docker/netns/baec15910bef        nsfs[net:[4026532852]]                   nsfs        rw
                      | |-/run/docker/netns/9ccad93d5340        nsfs[net:[4026532933]]                   nsfs        rw
                      | |-/run/docker/netns/5c56e1cacff4        nsfs[net:[4026532609]]                   nsfs        rw
                      | |-/run/docker/netns/84f9adbecec1        nsfs[net:[4026532422]]                   nsfs        rw
                      | `-/run/docker/netns/cdf8b87c3a2e        nsfs[net:[4026533013]]                   nsfs        rw
                      |-/home/iobroker_backup/fritzNAS        systemd-1                                autofs      rw,relatime,fd=47,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                      |-/boot        /dev/mmcblk0p1                           vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      |-/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/ZXOIITVSJWC2J45LRYORORNTX6:/var/lib/docker/overlay2/l/3LB5VQVUZLTIWLHCXYXYVTBYTP:/var/lib/docker/overlay2/l/WDJFTTDVG4RVBG7KEKKW23TPFC:/var/lib/docker/overlay2/l/IWAVT44WFCJBLPUYNWZRDBA2XF,upperdir=/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/diff,workdir=/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/work
                      |-/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/Y4KIDLIINUL4F2DXESC4O5KRBJ:/var/lib/docker/overlay2/l/LXPEYR7VBFQ6BZETH37VPMGFLQ:/var/lib/docker/overlay2/l/RG5KXMBTXWGWYY4H3ISX2NQ2AT:/var/lib/docker/overlay2/l/7SZ7C77PC5ONRYST6QJB4BZYRA:/var/lib/docker/overlay2/l/OJZY7YGXRVAA7QCVIKVEOXJEX3:/var/lib/docker/overlay2/l/JNSS5BO3UKLABDPSVWBUP4DWQ7:/var/lib/docker/overlay2/l/NLDOZSC7FVQY6O25WPNZSDPDTW:/var/lib/docker/overlay2/l/DVOKLYVEJGXBDOGHGVWHIIRT2I:/var/lib/docker/overlay2/l/T54RJWMX2RGJNSLQHKWZ4IYHMN:/var/lib/docker/overlay2/l/KD3VFV5TWC6CQHAQX4GW2EQORH:/var/lib/docker/overlay2/l/63AK5PBC3MFBRJYMHDH6HUWU5P:/var/lib/docker/overlay2/l/SFPY6ZYRB4L6MTPU3TXMK5NCNR:/var/lib/docker/overlay2/l/CK7PHP4NVYM4RC5L5FPXQJOGCN:/var/lib/docker/overlay2/l/5EHULSCTZM6FKKP5MCMB2V63YH:/var/lib/docker/overlay2/l/RKNTNECVBYMERRMUZRRGIISS7C:/var/lib/docker/overlay2/l/5OG5USPEL6SAIDNEUNVQBPKJSM:/var/lib/docker/overlay2/l/3H2TFNRJ7VIFMSWBPRH5JS5MHJ:/var/lib/docker/overlay2/l/GO6JHZDVILQZG57AZ4EG3RAJVI:/var/lib/docker/overlay2/l/PC5SBE6QGP4IZVQQZZLYB54GXX,upperdir=/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/diff,workdir=/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/work
                      |-/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/WBOYRJN6BCIHKCZJ6BPHZ37L3Y:/var/lib/docker/overlay2/l/7PMBGDN3W4JVMZFHEA4VVFEWOA:/var/lib/docker/overlay2/l/L4X52U3RRFPAUV6A2FH5HVKUJU:/var/lib/docker/overlay2/l/REZGUYYZ3US7PQUZWSAPSH326P:/var/lib/docker/overlay2/l/3WLQHIHKHYSMWBKJXM6LJYXP3T,upperdir=/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/diff,workdir=/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/work
                      |-/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/B7R4UXH2SL2EH2RNJS5S2DU4KQ:/var/lib/docker/overlay2/l/AV3C4K3WX3M2KALWG55MT5CEGZ:/var/lib/docker/overlay2/l/5TZELNBRLQV34FU25JYNQPIU6I:/var/lib/docker/overlay2/l/3ZA2SRHIKDVMBT7HIARZ432R5G:/var/lib/docker/overlay2/l/TDGWKQ4LZHZN66QG672TOA5EVG:/var/lib/docker/overlay2/l/5FLAUAG6OTPPCO7LNPBV4YJRHO:/var/lib/docker/overlay2/l/M4XKCWRYMA3ULE6ASYZ5M7GI53,upperdir=/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/diff,workdir=/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/work
                      |-/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/AEAXG5LKPHDFV3ECO2R7VI55WT:/var/lib/docker/overlay2/l/TOYFTJO536Y2CEFDKOGOPZWU6I:/var/lib/docker/overlay2/l/IRTVWCUYRMJT6673HFMWQV5SWX:/var/lib/docker/overlay2/l/HK4YRXKD6HZIFOKUXWK4I2LMLN:/var/lib/docker/overlay2/l/LEVA2AJAJNZIDJL5K4U4Y7AVHX:/var/lib/docker/overlay2/l/VJK7DLUJQVJH2KPMWPQ2ESYY7P:/var/lib/docker/overlay2/l/RKVLUAOKNZUX35Z6ENMAS7F2GI:/var/lib/docker/overlay2/l/LZT6TFXGCTFOXPCIYZCS3KCCI4:/var/lib/docker/overlay2/l/KGKN7LZBUMSQMYVY2L2IZNTOTV:/var/lib/docker/overlay2/l/SNUQZSIGTJ2HAYRJ4SSNSDIMUD:/var/lib/docker/overlay2/l/7EQICGQIM32XJQZRP76XAMWXJE:/var/lib/docker/overlay2/l/XP5HQXJAX2NKBCZNUZMK3YVFOM:/var/lib/docker/overlay2/l/R24LNBXO44TBEBMVZV6X7NSZZE:/var/lib/docker/overlay2/l/SW5OMAT4IVAQMBOWNHBVMPJPVP:/var/lib/docker/overlay2/l/LAZI6DH7DOFEEOWHEUB7YTXMAQ,upperdir=/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/diff,workdir=/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/work
                      `-/opt/iobroker/backups        //192.168.178.1/fritz.nas/FRITZ_1/Backup cifs        rw,relatime,vers=3.1.1,cache=loose,username=iobroker_backup,uid=1002,noforceuid,gid=1002,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                      /var:
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/Test2': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Gc': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/IDS': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/GrBase': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hyphen': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hex': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/IDC': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hst': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/GrExt': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Harness': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Parser/Scheduler': Bad message
                      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Parser/Result': Bad message
                      16G     /var/
                      13G     /var/lib/docker
                      13G     /var/lib
                      11G     /var/lib/docker/overlay2
                      1.8G    /var/log
                      Archived and active journals take up 1.6G in the file system.
                      1.3G    /opt/iobroker/backups/
                      47M     /opt/iobroker/backups/influxDBtmp
                      288M    /opt/iobroker/iobroker-data/
                      231M    /opt/iobroker/iobroker-data/files
                      138M    /opt/iobroker/iobroker-data/files/javascript.admin
                      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      13M     /opt/iobroker/iobroker-data/objects.jsonl
                      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
                      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/61.54b23816.chunk.js.map
                      USB-Devices by-id:
                      /usr/bin/nodejs         v18.20.3
                      /usr/bin/node           v18.20.3
                      /usr/bin/npm            10.7.0
                      /usr/bin/npx            10.7.0
                      /usr/bin/corepack       0.28.0
                      nodejs:
                        Installed: 18.20.3-1nodesource1
                        Candidate: 18.20.3-1nodesource1
                        Version table:
                       *** 18.20.3-1nodesource1 1001
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                           18.13.0+dfsg1-1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.16
                      javascript:     8.3.1
                      Adapter State
                      + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
                      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
                      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                      + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
                      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.58
                      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                      + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
                      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                      + instance is alive
                      Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
                      Adapter    "go-e"         : 1.0.29   , installed 1.0.29
                      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                      Adapter    "solax"        : 0.9.6    , installed 0.9.6
                      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                      Objects and States
                      Objects:        3373
                      States:         3335
                      Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:5 https://apt.grafana.com stable InRelease
                      Hit:6 https://download.docker.com/linux/debian bookworm InRelease
                      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14112      703/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          1936       1043/smbd
                      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          1935       1043/smbd
                      tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       26464      5190/io.mqtt.0
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15934      651/cupsd
                      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14143      687/vncserver-x11-c
                      tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          19734      1711/docker-proxy
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       18504      747/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       16695      747/iobroker.js-con
                      tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          18936      1678/docker-proxy
                      tcp6       0      0 :::3000                 :::*                    LISTEN      116        18497      746/grafana
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14114      703/sshd: /usr/sbin
                      tcp6       0      0 :::139                  :::*                    LISTEN      0          1934       1043/smbd
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15933      651/cupsd
                      tcp6       0      0 :::445                  :::*                    LISTEN      0          1933       1043/smbd
                      tcp6       0      0 :::5900                 :::*                    LISTEN      0          14142      687/vncserver-x11-c
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       27689      3966/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       29906      5833/io.web.0
                      tcp6       0      0 :::4000                 :::*                    LISTEN      0          18136      1719/docker-proxy
                      tcp6       0      0 :::3100                 :::*                    LISTEN      0          18116      1685/docker-proxy
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1650       435/avahi-daemon: r
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13248      512/dhcpcd
                      udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          26075      737/nmbd
                      udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          26074      737/nmbd
                      udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          26071      737/nmbd
                      udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          26070      737/nmbd
                      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26067      737/nmbd
                      udp        0      0 169.254.248.216:137     0.0.0.0:*                           0          26066      737/nmbd
                      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26063      737/nmbd
                      udp        0      0 169.254.225.2:137       0.0.0.0:*                           0          26062      737/nmbd
                      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26059      737/nmbd
                      udp        0      0 169.254.210.46:137      0.0.0.0:*                           0          26058      737/nmbd
                      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26055      737/nmbd
                      udp        0      0 169.254.141.55:137      0.0.0.0:*                           0          26054      737/nmbd
                      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26051      737/nmbd
                      udp        0      0 169.254.113.152:137     0.0.0.0:*                           0          26050      737/nmbd
                      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14306      737/nmbd
                      udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          14305      737/nmbd
                      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          15970      737/nmbd
                      udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          26077      737/nmbd
                      udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          26076      737/nmbd
                      udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          26073      737/nmbd
                      udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          26072      737/nmbd
                      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26069      737/nmbd
                      udp        0      0 169.254.248.216:138     0.0.0.0:*                           0          26068      737/nmbd
                      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26065      737/nmbd
                      udp        0      0 169.254.225.2:138       0.0.0.0:*                           0          26064      737/nmbd
                      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26061      737/nmbd
                      udp        0      0 169.254.210.46:138      0.0.0.0:*                           0          26060      737/nmbd
                      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26057      737/nmbd
                      udp        0      0 169.254.141.55:138      0.0.0.0:*                           0          26056      737/nmbd
                      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26053      737/nmbd
                      udp        0      0 169.254.113.152:138     0.0.0.0:*                           0          26052      737/nmbd
                      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14308      737/nmbd
                      udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          14307      737/nmbd
                      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          15971      737/nmbd
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15945      735/cups-browsed
                      udp        0      0 0.0.0.0:49917           0.0.0.0:*                           108        1652       435/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        1651       435/avahi-daemon: r
                      udp6       0      0 :::47428                :::*                                108        1653       435/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          14259      512/dhcpcd
                      2024-05-26 17:27:44.862  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
                      2024-05-26 17:27:44.863  - info: influxdb.0 (14866) Influx DB Version used: 2.x
                      2024-05-26 17:27:44.868  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
                      2024-05-26 17:27:54.870  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
                      2024-05-26 17:27:54.870  - info: influxdb.0 (14866) Influx DB Version used: 2.x
                      2024-05-26 17:27:54.873  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
                      2024-05-26 17:28:04.875  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
                      2024-05-26 17:28:04.876  - info: influxdb.0 (14866) Influx DB Version used: 2.x
                      2024-05-26 17:28:04.883  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
                      2024-05-26 17:28:14.884  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
                      2024-05-26 17:28:14.885  - info: influxdb.0 (14866) Influx DB Version used: 2.x
                      2024-05-26 17:28:14.888  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
                      2024-05-26 17:28:24.890  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
                      2024-05-26 17:28:24.891  - info: influxdb.0 (14866) Influx DB Version used: 2.x
                      2024-05-26 17:28:24.894  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
                      2024-05-26 17:28:34.896  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
                      2024-05-26 17:28:34.896  - info: influxdb.0 (14866) Influx DB Version used: 2.x
                      2024-05-26 17:28:34.900  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
                      2024-05-26 17:28:44.901  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
                      2024-05-26 17:28:44.902  - info: influxdb.0 (14866) Influx DB Version used: 2.x
                      2024-05-26 17:28:44.905  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
                      2024-05-26 17:28:45.236  - info: solax.0 (4715) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                      2024-05-26 17:28:54.906  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
                      2024-05-26 17:28:54.907  - info: influxdb.0 (14866) Influx DB Version used: 2.x
                      2024-05-26 17:28:54.911  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
                      Lief einwandfrei, nach javascript-Adapter-update keine Verbindung. Danke.
                        Thomas Braun Most Active @ronk last edited by
                        @ronk
                        Dein Raspberry OS 'Bookworm' ist nicht richtig installiert. War ein 'inline upgrade' von einer Vorversion aus, vermute ich...
                          ronk @Thomas Braun last edited by ronk
                          ja, stimmt. hat aber bis jetzt funktioniert... Ich komme auch nicht mehr auf die Webseite der influxdb-Installation merke ich gerade.
                            @ronk sagte in iobroker influxdb1.x econnrefused 192.168.178.120:8086:
                            Aber nicht richtig...
                            Die Kiste dreht im roten Bereich und der influxdb.service startet nicht.
                            systemctl status influxdb.service
                              Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarc        h64
                              The programs included with the Debian GNU/Linux system are free software;
                              the exact distribution terms for each program are described in the
                              individual files in /usr/share/doc/*/copyright.
                              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                              permitted by applicable law.
                              Last login: Sun May 26 17:42:47 2024 from 192.168.178.20
                              ronny@raspberrypi:~ $ systemctl status influxdb.service
                              × influxdb.service - InfluxDB is an open-source, distributed, time series database
                                   Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enabled)
                                   Active: failed (Result: exit-code) since Sun 2024-05-26 17:34:08 CEST; 9min ago
                                     Docs: https://docs.influxdata.com/influxdb/
                                  Process: 792 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=2)
                                      CPU: 208ms
                              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/mgc.go:1407 +0x398 fp=0x4000072fd0 sp=0x4000072f40 pc=0x7f89bfaa58
                              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]: runtime.goexit()
                              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/asm_arm64.s:1172 +0x4 fp=0x4000072fd0 sp=0x4000072fd0 pc=0x7f89c4af04
                              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]: created by runtime.gcBgMarkStartWorkers
                              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/mgc.go:1199 +0x28
                              Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                              Mai 26 17:34:08 raspberrypi systemd[1]: Stopped influxdb.service - InfluxDB is an open-source, distributed, time series database.
                              Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                              Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                              Mai 26 17:34:08 raspberrypi systemd[1]: Failed to start influxdb.service - InfluxDB is an open-source, distributed, time series database.
                                @ronk
                                Dein Dateisystem läuft voll und der Kernel hat ein fscheck durchführen müssen.
                                Dann spukt da noch irgendwas von einem Docker herum.
                                  ja, da läuft eine Dockerinstallation mit TeslaSolarCharger.
                                    @ronk
                                    Bei dem Thema bin ich dann auch raus.
                                    Schau das du deine Basis sauber hinbekommst. Wirst du aber nur per Neuinstallation das OS richtig hinbekommen, sage ich voraus.
                                      nuja, das lief alles einträchtig nebeneinander. Also von grundauf neuinstallieren?
                                        Thomas Braun Most Active @ronk last edited by Thomas Braun
                                        @ronk
                                        Nuja, nicht wirklich. Wie du siehst.
                                        Die Empfehlung Raspberry OS 'Bookworm' komplett neuzuinstallieren gab es nicht ohne Grund.
                                          okay. danke dir.
                                          Läuft wieder.
                                            @ronk
                                            Das ging aber schnell... Eine ordentliche Neuinstallation kann das nicht gewesen sein und da ist immer noch das Flickwerk am Start.
                                            1.1k
                                            econnectrefused influxdb iobroker instanzen
                                            1746
