    4. Installation schlägt fehl
    • Merlin123
      Merlin123 last edited by
      Ich versuche gerade ioBroker auf nem Orange Pi Plus 2e zu installieren.
      Nutze dazu die Anleitung von Rainer. Die Installation von node war kein Problem.
      Leider spuckt die ioBroker Installation ne Menge Fehler und der Zugriff via Web geht auch nicht.
      Das meldet er bei mir.
      Vielleicht hat jemand ne Idee…
      root@orangepiplus2e:/opt/iobroker# sudo npm install iobroker --unsafe-perm
      > iobroker@1.0.1 install /opt/iobroker/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.discovery --production --prefix /opt/iobroker
      node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.2 (node-v48 ABI) (falling back to source compile with node-gyp)
      ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Local<v8::object>, std::string)’:
      ../src/serialport.cpp:90:52: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
         return getValueFromObject(options, key)->ToInt32()->Int32Value();
      ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Local<v8::object>, std::string)’:
      ../src/serialport.cpp:102:53: warning: ‘v8::Local <v8::number>v8::Value::ToNumber() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8173): Use maybe version [-Wdeprecated-declarations]
         return getValueFromObject(options, key)->ToNumber()->NumberValue();
      ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
      ../src/serialport.cpp:174:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
           int fd = argv[1]->ToInt32()->Int32Value();
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:193:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
         int fd = info[0]->ToInt32()->Int32Value();
      ../src/serialport.cpp:217:116: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
         baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:252:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:369:32: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
         baton->fd = info[0]->ToInt32()->Int32Value();
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:480:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:528:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:585:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
      ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatformOptions(const v8::Local<v8::object>&)’:
      ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
         result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
         result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      ../src/serialport_poller.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE SerialportPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
         obj->fd_ = info[0]->ToInt32()->Int32Value();
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      npm install iobroker.admin --production --prefix /opt/iobroker
      npm install iobroker.js-controller --production --prefix /opt/iobroker
      Write "./iobroker start" to start the ioBroker
      : No such file or directory
      Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
      iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
      /opt/iobroker
      └─┬ iobroker@1.0.1
        └─┬ yargs@7.1.0
          ├── camelcase@3.0.0
          ├─┬ cliui@3.2.0
          │ ├─┬ strip-ansi@3.0.1
          │ │ └── ansi-regex@2.1.1
          │ └── wrap-ansi@2.1.0
          ├── decamelize@1.2.0
          ├── get-caller-file@1.0.2
          ├─┬ os-locale@1.4.0
          │ └─┬ lcid@1.0.0
          │   └── invert-kv@1.0.0
          ├─┬ read-pkg-up@1.0.1
          │ ├─┬ find-up@1.1.2
          │ │ ├── path-exists@2.1.0
          │ │ └─┬ pinkie-promise@2.0.1
          │ │   └── pinkie@2.0.4
          │ └─┬ read-pkg@1.1.0
          │   ├─┬ load-json-file@1.1.0
          │   │ ├── graceful-fs@4.1.11
          │   │ ├─┬ parse-json@2.2.0
          │   │ │ └─┬ error-ex@1.3.1
          │   │ │   └── is-arrayish@0.2.1
          │   │ ├── pify@2.3.0
          │   │ └─┬ strip-bom@2.0.0
          │   │   └── is-utf8@0.2.1
          │   ├─┬ normalize-package-data@2.4.0
          │   │ ├── hosted-git-info@2.5.0
          │   │ ├─┬ is-builtin-module@1.0.0
          │   │ │ └── builtin-modules@1.1.1
          │   │ ├── semver@5.4.1
          │   │ └─┬ validate-npm-package-license@3.0.1
          │   │   ├─┬ spdx-correct@1.0.2
          │   │   │ └── spdx-license-ids@1.2.2
          │   │   └── spdx-expression-parse@1.0.4
          │   └── path-type@1.1.0
          ├── require-directory@2.1.1
          ├── require-main-filename@1.0.1
          ├── set-blocking@2.0.0
          ├─┬ string-width@1.0.2
          │ ├── code-point-at@1.1.0
          │ └─┬ is-fullwidth-code-point@1.0.0
          │   └── number-is-nan@1.0.1
          ├── which-module@1.0.0
          ├── y18n@3.2.1
          └── yargs-parser@5.0.0
      npm WARN iobroker No license field.</v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object>
        @Merlin123:
        Vielleicht hat jemand ne Idee… `
        Ja!
        alles ok!
        sudo iobroker stert
        und alles wird gut 😉
        • Merlin123
          Geht… Danke... Was mich nur wundert:
          Er meldet ja, dass autostart enabled wurde und iobroker gestartet wurde....
          Das ist dann "etwas" verwirrend... 😉
            @Merlin123:
            Er meldet ja, dass autostart enabled wurde und iobroker gestartet wurde…. `
            nein!
            er meldet:
            @Merlin123:
            Write "./iobroker start" to start the ioBroker `
            Das ist eine Aufforderung an dich! 😉
            • Merlin123
              Danach schreibt er aber:
              Also doch verwirrend 😉
                @Merlin123:
                Also doch verwirrend `
                Schon wieder: Jein! 😉
                ok, ioBroker sollte jetzt gestrtet sein (tut es im Moment nicht auf allen Installationen)
                Ansonsten informiert er dich, dass er den autostart von ioBroker aktiviert hat (also nach einem reboot ioBroker automatisch starten wird. Solltest du dies nicht wünschen musst du
                in die Konsole eingeben.
                Wo ist da die Verständnisschwierigkeit?
                • Merlin123
                  Mich hat nur das "ist gestartet" verwirrt. Ich dachte, das wäre das Ergebnis einer Prüfung und kein reiner Text.
                  Nachdem dann der Zugriff nicht ging und die Warnings kamen, dachte ich, es wäre was schief gegangen.
                  Wäre es sinnvoll, da eine Prüfung im Script einzubauen, das prüft, ob der Start geklappt hat?
                    Das muss sich @Bluefox mal ansehen, wenn er aus dem Urlaub zurück ist.
                    • Merlin123
                      ok 🙂
