    4. xiaomi Staubsauger - Vacuum V1 iQontrol steuern?
      Beowolf last edited by Beowolf
      hat eventl. jemand schon eine Steuerung/Bedienung per iQontrol Vis mit passenden Blocklys erstellt?
      Es sind ja immer nur Buttons die der mihome-vacuum Adapter erzeugt.
      Er reagiert sehr verzögert. Ist das normal?
      Manfred
        Beowolf @Beowolf last edited by
        Ich habe diese Meldungen im Protokoll
        Ist das der falsche Adapter für den Sauger?
        host.raspberrypi
        	2024-05-13 10:08:45.906	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
        host.raspberrypi
        	2024-05-13 10:08:45.905	info	instance system.adapter.mihome-vacuum.0 terminated with code null ()
        host.raspberrypi
        	2024-05-13 10:08:45.905	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
        mihome-vacuum.0
        	2024-05-13 10:07:44.007	info	create state for carpet_mode
        mihome-vacuum.0
        	2024-05-13 10:07:43.018	info	settest next timer: not available
        mihome-vacuum.0
        	2024-05-13 10:07:42.467	info	select standard vacuum protocol....
        mihome-vacuum.0
        	2024-05-13 10:07:42.338	info	IOT enabled, create state
        mihome-vacuum.0
        	2024-05-13 10:07:42.274	info	starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v18.19.1, js-controller: 5.0.19
        host.raspberrypi
        	2024-05-13 10:07:40.716	info	instance system.adapter.mihome-vacuum.0 started with pid 3085
        host.raspberrypi
        	2024-05-13 10:07:10.394	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
        host.raspberrypi
        	2024-05-13 10:07:10.393	info	instance system.adapter.mihome-vacuum.0 terminated with code null ()
        host.raspberrypi
        	2024-05-13 10:07:10.393	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
        mihome-vacuum.0
        	2024-05-13 10:06:40.438	info	create state for carpet_mode
        admin.0
        	2024-05-13 10:05:56.253	info	==> Connected system.user.admin from ::ffff:192.168.49.12
        admin.0
        	2024-05-13 10:05:51.435	info	<== Disconnect system.user.admin from ::ffff:192.168.49.12 admin
        admin.0
        	2024-05-13 10:05:40.910	info	<== Disconnect system.user.admin from ::ffff:192.168.49.12
        mihome-vacuum.0
        	2024-05-13 10:05:37.493	info	settest next timer: not available
        mihome-vacuum.0
        	2024-05-13 10:05:36.946	info	select standard vacuum protocol....
        mihome-vacuum.0
        	2024-05-13 10:05:36.934	warn	No Answer for DeviceModel use model from Config
        mihome-vacuum.0
        	2024-05-13 10:05:36.933	warn	No Answer for DeviceModel use old one
        mihome-vacuum.0
        	2024-05-13 10:05:36.933	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
        mihome-vacuum.0
        	2024-05-13 10:05:26.911	info	IOT enabled, create state
        mihome-vacuum.0
        	2024-05-13 10:05:26.827	info	starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v18.19.1, js-controller: 5.0.19
          Thomas Braun Most Active @Beowolf last edited by
          @beowolf sagte in xiaomi Staubsauger - Vacuum V1 iQontrol steuern?:
          Eigentlich nicht. Aber wohl die falsche Version von nodejs.
          Bring das auf den aktuellen Stand.
          Per
          iob nodejs-update
          am besten.
            Beowolf @Thomas Braun last edited by
            Danke für den Hinweis. Mache ich sofort.
            Ist das denn normal, das nach dem Senden einen Befehls es eine kleine Weile dauert bis er den nächsten ausführt?
            Erst wenn das
            im LOG erscheint reagiert er wieder auf einen Befehl.
              @beowolf
              Ja, ist normal.
                Danke für die Info.
                  Noch eine kurze Frage.
                  Bei dem Update kamen diese Meldungen:
                  Installing the recommended nodejs version now!
                  Installing the recommended nodejs version!
                  W: GPG error: https://repos.influxdata.com/debian bookworm InRelease: The follow                                         ing signatures couldn't be verified because the public key is not available: NO_                                         PUBKEY D8FF8E1F7DF8B07E
                  E: The repository 'https://repos.influxdata.com/debian bookworm InRelease' is no                                         t signed.
                  W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is sto                                         red in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION se                                         ction in apt-key(8) for details.
                  Extracting templates from packages: 100%
                  Preconfiguring packages ...
                  Das Update ist soweit gut gelaufen.
                  Was hat das mit den Hinweisen bezüglich "influxdata.com" aufsich?
                  Die Influx und Grafana Geschichten laufen ohne Probleme.
                    Thomas Braun Most Active @Beowolf last edited by Thomas Braun
                    Das bedeutet, dass du da noch das alte Repo mit dem alten Key drin hast.
                    Korrektur via:
                    sudo rm /etc/apt/sources.list.d/influ*
                    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                    rm influxdata-archive_compat.key
                      Vielen Dank.
                      Habe die Befehle ausgeführt. Sonst muß nichts gemacht werden, oder?
                        @beowolf
                        Zeig mal das große Ganze.
                        iob diag
                        in der Langfassung.
                          @thomas-braun sagte in xiaomi Staubsauger - Vacuum V1 iQontrol steuern?:
                          iob diag
                                                  v.2024-04-21
                           Static hostname: raspberrypi
                                 Icon name: computer
                          Operating System: Raspbian GNU/Linux 12 (bookworm)
                                    Kernel: Linux 6.1.0-rpi8-rpi-v8
                              Architecture: arm64
                          Userland:               32 bit
                          User-ID:                1000
                          Display-Server:         false
                          Pending OS-Updates:     1
                          Pending iob updates:    1
                          Nodejs-Installation:
                          /usr/bin/nodejs         v18.20.2
                          /usr/bin/node           v18.20.2
                          /usr/bin/npm            10.5.0
                          /usr/bin/npx            10.5.0
                          /usr/bin/corepack       0.25.2
                          Recommended versions are nodejs 18.20.2 and npm 10.5.0
                          MEMORY:
                          Mem:            8.3G        1.7G        1.7G        1.3M        5.0G        6.6G
                          Total:          8.4G        1.7G        1.8G
                          Active iob-Instances:   30
                          Active repo(s): stable
                                                  admin                   6.13.16
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                11696
                          States:                 10883
                          Size of iob-Database:
                          48M     /opt/iobroker/iobroker-data/objects.jsonl
                          8.2M    /opt/iobroker/iobroker-data/states.jsonl
                            @beowolf
                            Summary ist die Zusammenfassung, nicht die Langversion.
                              Dieses ist besser.
                              Skript v.2024-04-21
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Model           : Raspberry Pi 5 Model B Rev 1.0
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : 32 bit
                              Systemuptime and Load:
                               11:34:07 up 59 days, 16:32,  2 users,  load average: 0.31, 0.27, 0.38
                              CPU threads: 4
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              ~ Under-voltage has occurred
                              ~ Arm frequency capping has occurred
                              *** Time and Time Zones ***
                                             Local time: Mon 2024-05-13 11:34:07 CEST
                                         Universal time: Mon 2024-05-13 09:34:07 UTC
                                               RTC time: Mon 2024-05-13 09:34:07
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              pi
                              HOME=/home/pi
                              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
                              *** Display-Server-Setup ***
                              pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                              Try `pgrep -f' option to match against the complete command line.
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            8.3G        1.7G        1.8G        1.3M        4.9G        6.6G
                              Total:          8.4G        1.7G        1.9G
                                       7946 M total memory
                                       1622 M used memory
                                       1854 M active memory
                                       3009 M inactive memory
                                       1704 M free memory
                                        351 M buffer memory
                                       4364 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              top - 11:34:07 up 59 days, 16:32,  2 users,  load average: 0.31, 0.27, 0.38
                              Tasks: 185 total,   1 running, 184 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   7946.4 total,   1703.3 free,   1623.5 used,   4716.0 buff/cache
                              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6322.8 avail Mem
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** FILESYSTEM ***
                              udev           devtmpfs  3.8G     0  3.8G   0% /dev
                              tmpfs          tmpfs     795M  1.3M  794M   1% /run
                              /dev/sda2      ext4       29G  6.8G   21G  26% /
                              tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                              /dev/sda1      vfat      510M   93M  418M  19% /boot/firmware
                              tmpfs          tmpfs     795M  4.0K  795M   1% /run/user/1000
                              [Thu Mar 14 18:01:31 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:DE:AA:50 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=b0716aca-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                              [Thu Mar 14 18:01:34 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Thu Mar 14 18:01:35 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                              Show mounted filesystems:
                              TARGET                                                  SOURCE      FSTYPE      OPTIONS
                              /                                                       /dev/sda2   ext4        rw,noatime
                              |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                              | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                              | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                              | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                              |-/proc                                                 proc        proc        rw,relatime
                              | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5800
                              |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                              |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=3897388k,nr_inodes=974347,mode=755
                              | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                              | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
                              | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                              |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=813712k,mode=755
                              | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                              | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                              | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=813708k,nr_inodes=203427,mode=700,uid=1000,gid=1000
                              `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              799M    /var/
                              495M    /var/cache
                              489M    /var/cache/apt
                              414M    /var/cache/apt/archives
                              123M    /var/lib
                              Archived and active journals take up 79.3M in the file system.
                              /opt/iobroker/backups:
                              14M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              334M    /opt/iobroker/iobroker-data/
                              212M    /opt/iobroker/iobroker-data/files
                              94M     /opt/iobroker/iobroker-data/backup-objects
                              57M     /opt/iobroker/iobroker-data/files/javascript.admin
                              43M     /opt/iobroker/iobroker-data/files/iot.admin
                              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                              19M     /opt/iobroker/iobroker-data/objects.jsonl
                              9.4M    /opt/iobroker/iobroker-data/states.jsonl
                              8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
                              USB-Devices by-id:
                              No Devices found 'by-id'
                              *** NodeJS-Installation ***
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              nodejs:
                                Installed: 18.20.2-1nodesource1
                                Candidate: 18.20.2-1nodesource1
                                Version table:
                               *** 18.20.2-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                      100 /var/lib/dpkg/status
                                   18.20.1-1nodesource1 1001
                                   18.20.0-1nodesource1 1001
                                   18.19.1-1nodesource1 1001
                                   18.19.0+dfsg-6~deb12u1+rpi1 500
                                      500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
                                   18.19.0-1nodesource1 1001
                                   18.18.2-1nodesource1 1001
                                   18.18.1-1nodesource1 1001
                                   18.18.0-1nodesource1 1001
                                   18.17.1-1nodesource1 1001
                                   18.17.0-1nodesource1 1001
                                   18.16.1-1nodesource1 1001
                                   18.16.0-1nodesource1 1001
                                   18.15.0-1nodesource1 1001
                                   18.14.2-1nodesource1 1001
                                   18.14.1-1nodesource1 1001
                                   18.14.0-1nodesource1 1001
                                   18.13.0-1nodesource1 1001
                                   18.12.0-1nodesource1 1001
                                   18.11.0-1nodesource1 1001
                                   18.10.0-1nodesource1 1001
                                   18.9.1-1nodesource1 1001
                                   18.9.0-1nodesource1 1001
                                   18.8.0-1nodesource1 1001
                                   18.7.0-1nodesource1 1001
                                   18.6.0-1nodesource1 1001
                                   18.5.0-1nodesource1 1001
                                   18.4.0-1nodesource1 1001
                                   18.3.0-1nodesource1 1001
                                   18.2.0-1nodesource1 1001
                                   18.1.0-1nodesource1 1001
                                   18.0.0-1nodesource1 1001
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              admin:          6.13.16
                              javascript:     7.8.0
                              nodejs modules from github:     2
                              +-- iobroker.open-epaper-link@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.open-epaper-link.git#08b686b15fece44f0ecd00314243bc22d5a15b9c)
                              +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
                              Adapter State
                              + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                              + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                              + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                              + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                                system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              - disabled
                              + system.adapter.mihome-cloud.0           : mihome-cloud          : raspberrypi                              -  enabled
                              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                              + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
                              + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
                                system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
                              + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                              + system.adapter.puppeteer.0              : puppeteer             : raspberrypi                              -  enabled
                              + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                              + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 192.168.49.38, run as: admin
                              + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                              + system.adapter.tradfri.0                : tradfri               : raspberrypi                              -  enabled
                              + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                              + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              ioBroker-Repositories
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "alarm"        : 3.6.0    , installed 3.6.0
                              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                              Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                              Adapter    "email"        : 1.2.2    , installed 1.2.2
                              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                              Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                              Adapter    "ical"         : 1.14.3   , installed 1.14.3
                              Adapter    "iot"          : 2.0.11   , installed 2.0.11
                              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                              Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
                              Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
                              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                              Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                              Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
                              Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
                              Adapter    "puppeteer"    : 0.2.8    , installed 0.2.7  [Updatable]
                              Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                              Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                              Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                              Adapter    "wled"         : 0.7.2    , installed 0.7.2
                              Adapter    "ws"           : 2.6.1    , installed 2.6.1
                              Objects and States
                              Objects:        11696
                              States:         10883
                              W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                              Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                              Hit:3 https://repos.influxdata.com/debian stable InRelease
                              Reading package lists...
                              Pending Updates: 1
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.1:38727         0.0.0.0:*               LISTEN      1001       67634520   31622/chromium
                              tcp        0      0 192.168.49.38:8087      0.0.0.0:*               LISTEN      1001       67634635   31721/io.simple-api
                              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      106        940        803/influxd
                              tcp        0      0 192.168.49.38:2001      0.0.0.0:*               LISTEN      1001       67631513   31356/io.hm-rpc.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       67634201   31422/io.sonoff.0
                              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       67631565   31387/io.mqtt.0
                              tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       67631566   31387/io.mqtt.0
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14244      830/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       67629812   31162/iobroker.js-c
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       67631232   31162/iobroker.js-c
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       67635373   31809/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       67629888   31183/io.admin.0
                              tcp6       0      0 :::8086                 :::*                    LISTEN      106        962        803/influxd
                              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       67634775   31843/io.ws.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          14246      830/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       67635379   31828/io.wled.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16481      676/avahi-daemon: r
                              udp        0      0 0.0.0.0:38794           0.0.0.0:*                           1001       67635288   31756/io.tradfri.0
                              udp        0      0 0.0.0.0:56261           0.0.0.0:*                           104        16483      676/avahi-daemon: r
                              udp        0      0 0.0.0.0:36849           0.0.0.0:*                           1001       67632359   31240/io.javascript
                              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       67638378   32049/io.mihome-vac
                              udp6       0      0 :::5353                 :::*                                104        16482      676/avahi-daemon: r
                              udp6       0      0 :::60000                :::*                                104        16484      676/avahi-daemon: r
                              udp6       0      0 fe80::5fdd:1c0f:15b:546 :::*                                0          16644      759/NetworkManager
                              2024-05-13 11:30:00.024  - info: host.raspberrypi instance system.adapter.pegelalarm.0 started with pid 2378
                              2024-05-13 11:30:01.104  - info: pegelalarm.0 (2378) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.20.2, js-controller: 5.0.19
                              2024-05-13 11:30:04.034  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 2408
                              2024-05-13 11:30:05.184  - info: ical.0 (2408) starting. Version 1.14.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
                              2024-05-13 11:30:05.939  - info: ical.0 (2408) processing URL: calendar1 https://calendar.google.com/calendar/ical/3h0jvvkghbe00dgfipllfi28qg%40group.calendar.google.com/private-954892fad41c2a41c3734599d28c7535/basic.ics
                              2024-05-13 11:30:06.325  - info: ical.0 (2408) processing URL: termine https://calendar.google.com/calendar/ical/manfredglanemann%40gmail.com/private-5c14c5fc0fea0bf96cc88aab7b87674c/basic.ics
                              2024-05-13 11:30:07.615  - info: pegelalarm.0 (2378) Terminated (NO_ERROR): Without reason
                              2024-05-13 11:30:08.116  - warn: pegelalarm.0 (2378) get state error: Connection is closed.
                              2024-05-13 11:30:08.132  - info: host.raspberrypi instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
                              2024-05-13 11:30:11.819  - info: ical.0 (2408) Terminated (NO_ERROR): Without reason
                              2024-05-13 11:30:12.337  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                              iob diag has finished.
                                Kernel : aarch64
                                Userland : 32 bit
                                Stell das mal bei Gelegenheit auf ein reines 64Bit-System um. Geht aber nur per Neuinstallation.
                                Deutet auf eine unzureichende Spannungsversorgung hin.
                                Pending Updates: 1
                                Da ist noch ein Update des Betriebssystems anhängig. Ebenso für den pupeteer-Adapter.
                                Beide auf dem gleichen Port ist auch eher nicht richtig.
                                  Kernel : aarch64
                                  Userland : 32 bit
                                  Ok, kann danach die Backup-Datei wieder eingespielt werden?
                                  Da ist schon ein anderes Netzteil vorhanden. Muß noch getauscht werden.
                                  Pending Updates: 1
                                  pupetter Update geht im Moment nicht. Dann laufen die OpenE-Papertags nicht mehr.
                                  Wo wird das geändert? Ich kann die Adapter nur installieren. Einstellungen habe die nicht, oder?
                                    Ja, das ist das übliche Vorgehen.
                                    avahi-daemon ist kein ioBroker-Adapter. Den wled kenn ich nicht.
                                      Ich dachte wegen 32 und 64 Bit. Das es da dann Probleme gibt.
                                      Vielen Dank für die vielen Hinweise.
                                      Manfred
                                        Ist den Nutzdaten wurscht. Die liegen ja nicht in binärer Form vor.
                                        368
