    4. Microcontroller
    5. TX RealTimeRunData > Interrupt received
      wolfmensch last edited by
      Hallo zusammen, ich bekomme folgende Fehlermeldung, kann leider nichts damit anfangen, Produktion läuft unauffällig:
      16:03:41.488 > [DPL::loop] ******************* ENTER **********************
      16:03:41.538 > [DPL::calcPowerLimit] battery use prevented, solar power (DC): 10000 W
      16:03:41.704 > [DPL::calcPowerLimit] target consumption: -100 W, base load: 200 W, power meter does include inverter output
      16:03:41.760 > [DPL::calcPowerLimit] power meter value: -103 W, power meter valid: yes, inverter output: 428 W, solar power (AC): 9215 W
      16:03:41.906 > [DPL::calcPowerLimit] limited to solar power: 425 W
      16:03:41.962 > [DPL::setNewPowerLimit] input limit: 425 W, min limit: 10 W, max limit: 2000 W, hysteresis: 30 W
      16:03:42.111 > [DPL::setNewPowerLimit] inverter max: 2000 W, inverter is producing, requesting: 425 W, reported: 420 W, diff: 5 W
      16:03:42.159 > Fetch inverter: 116492232791
      16:03:42.315 > TX RealTimeRunData 868.00 MHz --> 15 92 23 27 91 80 17 13 44 80 0B 00 66 3F 7A BD 00 00 00 00 00 00 00 00 0A A9 64
      16:03:42.418 > Interrupt received
      16:03:42.470 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 01 00 01 01 59 01 58 01 46 01 47 04 67 04 67 00 00 52 | -53 dBm
      16:03:42.532 > Interrupt received
      16:03:42.597 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 02 B5 F1 00 00 BC C7 02 4B 02 49 01 58 01 57 01 47 24 | -54 dBm
      16:03:42.653 > Interrupt received
      16:03:42.721 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 03 01 48 04 67 04 67 00 00 85 40 00 00 B4 94 02 42 BD | -53 dBm
      16:03:42.840 > Interrupt received
      16:03:42.931 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 04 02 41 09 35 13 87 10 BB 00 00 00 B5 03 E8 02 0D 47 | -53 dBm
      16:03:42.981 > Interrupt received
      16:03:43.046 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 85 00 01 74 FE 5C | -53 dBm
      16:03:43.135 > RX Period End
      16:03:43.239 > Success
      16:03:43.293 > [DPL::loop] ******************* ENTER **********************
      16:03:43.442 > [DPL::calcPowerLimit] battery use prevented, solar power (DC): 10000 W
      16:03:43.495 > [DPL::calcPowerLimit] target consumption: -100 W, base load: 200 W, power meter does include inverter output
      16:03:43.648 > [DPL::calcPowerLimit] power meter value: -103 W, power meter valid: yes, inverter output: 428 W, solar power (AC): 9215 W
      16:03:43.694 > [DPL::calcPowerLimit] limited to solar power: 425 W
      16:03:43.763 > [DPL::setNewPowerLimit] input limit: 425 W, min limit: 10 W, max limit: 2000 W, hysteresis: 30 W
      16:03:43.817 > [DPL::setNewPowerLimit] inverter max: 2000 W, inverter is producing, requesting: 425 W, reported: 420 W, diff: 5 W
      16:03:43.955 > Fetch inverter: 116492232791
      16:03:44.004 > TX RealTimeRunData 868.00 MHz --> 15 92 23 27 91 80 17 13 44 80 0B 00 66 3F 7A BE 00 00 00 00 00 00 00 00 FA BD 83
      16:03:44.166 > Interrupt received
      16:03:44.225 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 01 00 01 01 59 01 58 01 46 01 47 04 67 04 67 00 00 52 | -53 dBm
      16:03:44.367 > Interrupt received
      16:03:44.425 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 02 B5 F1 00 00 BC C7 02 4B 02 49 01 58 01 57 01 47 24 | -53 dBm
      16:03:44.570 > Interrupt received
      16:03:44.626 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 03 01 48 04 67 04 67 00 00 85 40 00 00 B4 94 02 42 BD | -53 dBm
      16:03:44.773 > Interrupt received
      16:03:44.825 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 04 02 41 09 35 13 87 10 BB 00 00 00 B5 03 E8 02 0D 47 | -53 dBm
      16:03:44.906 > Interrupt received
      16:03:44.967 > RX 868.00 MHz --> 95 92 23 27 91 80 17 13 44 85 00 01 74 FE 5C | -54 dBm
      16:03:45.027 > RX Period End
      16:03:45.077 > Success
      16:03:45.186 > Fetch inverter: 116492232791
        Homoran Global Moderator Administrators @wolfmensch last edited by
        @wolfmensch sagte in TX RealTimeRunData > Interrupt received:
        ich auch nicht!
        Wo?
        wann?
        von wem?
        warum?
        Das sieht nicht nach iob log aus
          wolfmensch @Homoran last edited by
          @homoran ist OpenDTU on battery wenn ich die Konsole öffne
            Homoran Global Moderator Administrators @wolfmensch last edited by Homoran
            welche Konsole?
            also nix iobroker!?
            Bitte Threadtitel entsprechend anpassen.
            81.0k
