    4. Adapter lassen sich nicht mehr aktualisieren
      t1m0 last edited by
      Grüße,
      seit ein paar Tagen bin ich nicht in der Lage irgendwelche updates durchzuführen. Ich habe, zumindest nicht wissentlich, irgendetwas geändert.
      Ich bekomme immer, egal welchen Adapter ich Updaten will, folgende Fehlermeldung:
      $ iobroker upgrade hm-rpc@1.17.0 --debug
      Update hm-rpc from @1.16.0 to @1.17.0
      NPM version: 10.5.0
      Installing iobroker.hm-rpc@1.17.0... (System call)
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
      npm ERR! code 127
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.npm WARN deprecated har-validator@5.1.5: this library is no longer supportednpm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.loghost.iobroker Cannot install iobroker.hm-rpc@1.17.0: 127
      ERROR: Process exited with code 25
      Mein System:
      pi@iobroker:~$ uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      /usr/bin/corepack
      v18.20.2
      v18.20.2
      10.5.0
      10.5.0
      0.25.2
      5.0.19
      pi
      pi cdrom floppy sudo audio dip video plugdev netdev iobroker
      tty
      /home/pi
      OK:1 http://security.debian.org/debian-security buster/updates InRelease
      OK:2 http://deb.debian.org/debian buster InRelease
      OK:3 http://deb.debian.org/debian buster-updates InRelease
      OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Abhängigkeitsbaum wird aufgebaut.
      Statusinformationen werden eingelesen.... Fertig
      Aktualisierung für 7 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      nodejs:
        Installiert:           18.20.2-1nodesource1
        Installationskandidat: 18.20.2-1nodesource1
        Versionstabelle:
       *** 18.20.2-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 500
           18.20.0-1nodesource1 500
           18.19.1-1nodesource1 500
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           10.24.0~dfsg-1~deb10u4 500
              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://deb.debian.org/debian buster/main amd64 Packages
      Über eure Hilfe wäre ich sehr Dankbar!
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      timemachine3030 created this issue in axios/axios
      closed Hotfix: Prevent SSRF #3410
      DJMarc75 Thomas Braun T 4 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @t1m0 last edited by
        @t1m0 BUSTER ist auch schon sehr, sehr lange tot 😉
        Wir sind mittlerweile bei BOOKWORM.
        Bring das auf Stand.
        • amg_666
          amg_666 last edited by
          @t1m0 sagte in Adapter lassen sich nicht mehr aktualisieren:
          Kannst du diesen Log mal posten? und ich würde auch mal iobroker fix über das System laufen lassen.
            Thomas Braun Most Active @t1m0 last edited by
            Joh, aber dein Betriebssystem hättest du ganz wissentlich aktualisieren dürfen. Buster ist seit September 2022 abgekündigt. Höchste Zeit von dem toten Gaul herunterzusteigen.
              t1m0 @amg_666 last edited by
              @amg_666 said in Adapter lassen sich nicht mehr aktualisieren:
              schon probiert, bringt nix 😕
              pi@iobroker:~$ nano /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
                GNU nano 3.2        /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
              0 verbose cli /usr/bin/node /usr/bin/npm
              1 info using npm@10.5.0
              2 info using node@v18.20.2
              3 timing npm:load:whichnode Completed in 2ms
              4 timing config:load:defaults Completed in 2ms
              5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
              6 timing config:load:builtin Completed in 0ms
              7 timing config:load:cli Completed in 3ms
              8 timing config:load:env Completed in 0ms
              9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
              10 timing config:load:project Completed in 7ms
              11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
              12 timing config:load:user Completed in 0ms
              13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
              14 timing config:load:global Completed in 0ms
              15 timing config:load:setEnvs Completed in 1ms
              16 timing config:load Completed in 13ms
              17 timing npm:load:configload Completed in 13ms
              18 timing config:load:flatten Completed in 2ms
              19 timing npm:load:mkdirpcache Completed in 0ms
              20 timing npm:load:mkdirplogs Completed in 0ms
              21 verbose title npm install iobroker.hm-rpc@1.17.0
              22 verbose argv "install" "--save-exact" "iobroker.hm-rpc@1.17.0"
              23 timing npm:load:setTitle Completed in 0ms
              24 timing npm:load:display Completed in 1ms
              25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-
              26 verbose logfile /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
              27 timing npm:load:logFile Completed in 6ms
              28 timing npm:load:timers Completed in 0ms
              29 timing npm:load:configScope Completed in 0ms
              30 timing npm:load Completed in 34ms
              31 timing arborist:ctor Completed in 0ms
              32 silly logfile start cleaning logs, removing 3 files
              33 timing idealTree:init Completed in 7ms
              34 timing idealTree:userRequests Completed in 3ms
              35 silly idealTree buildDeps
              36 silly fetch manifest colors@^1.3.2
              37 silly logfile done cleaning log files
              38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
              39 http fetch GET 200 https://registry.npmjs.org/colors 575ms (cache revalidated)
              40 silly fetch manifest fs-extra@^7.0.0
              41 http fetch GET 200 https://registry.npmjs.org/fs-extra 160ms (cache revalidated)
              42 silly fetch manifest iobroker.acme@0.1.2
              43 http fetch GET 200 https://registry.npmjs.org/iobroker.acme 567ms (cache revalidated)
              44 silly fetch manifest iobroker.admin@6.13.16
              45 http fetch GET 200 https://registry.npmjs.org/iobroker.admin 592ms (cache revalidated)
              46 silly fetch manifest iobroker.alexa2@3.26.4
              47 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 591ms (cache revalidated)
              48 silly fetch manifest iobroker.alias-manager@1.2.6
              49 http fetch GET 200 https://registry.npmjs.org/iobroker.alias-manager 561ms (cache revalidated)
              50 silly fetch manifest iobroker.amazon-dash@1.2.0
              51 http fetch GET 200 https://registry.npmjs.org/iobroker.amazon-dash 581ms (cache revalidated)
              52 silly fetch manifest iobroker.backitup@2.9.8
              53 http fetch GET 200 https://registry.npmjs.org/iobroker.backitup 568ms (cache revalidated)
              54 silly fetch manifest iobroker.ble@0.13.4
              55 http fetch GET 200 https://registry.npmjs.org/iobroker.ble 225ms (cache revalidated)
              56 silly fetch manifest iobroker.broadlink2@2.1.5
              57 http fetch GET 200 https://registry.npmjs.org/iobroker.broadlink2 591ms (cache revalidated)
                t1m0 @Thomas Braun last edited by
                @thomas-braun okay, danke! War da nie dran. Werde das dann mal probieren 😵
                  t1m0 @DJMarc75 last edited by
                  @djmarc75 ich werde es mal versuchen und berichten
                    Thomas Braun Most Active @t1m0 last edited by Thomas Braun
                    War da nie dran.
                    Das sieht man...
                    Das Log ist nicht vollständig.
                    • Meister Mopper
                      Meister Mopper @t1m0 last edited by
                      Ja, da gibt es hier im Forum gefühlt zehntausend Beiträge für Systemupgrades. Einfach suchen und das Problem selbst lösen.
                        t1m0 @t1m0 last edited by t1m0
                        So ich habe nun alles auf den neuesten Stand gebracht (hoffe ich zumindest).
                        Trotzdem bekomme ich weiterhin diese Fehlermeldung...
                        $ iobroker upgrade alexa2@3.26.5
                        Update alexa2 from @3.26.4 to @3.26.5
                        NPM version: 10.5.0Installing iobroker.alexa2@3.26.5... (System call)
                        npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T20_53_59_908Z-debug-0.loghost.iobroker Cannot install iobroker.alexa2@3.26.5: 127
                        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        pi@iobroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        x86_64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v18.20.2
                        v18.20.2
                        10.5.0
                        5.0.19
                        pi
                        /home/pi
                        OK:1 http://deb.debian.org/debian bookworm InRelease
                        OK:2 http://security.debian.org/debian-security bookworm-security InRelease
                        OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                        Paketlisten werden gelesen… Fertig
                        Abhängigkeitsbaum wird aufgebaut… Fertig
                        Statusinformationen werden eingelesen… Fertig
                        Alle Pakete sind aktuell.
                        nodejs:
                          Versionstabelle:
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                             18.13.0+dfsg1-1 500
                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                        pi@iobroker:~$
                          @t1m0
                          Gib mal die Langfassung von
                          iob diag
                          bekannt.
                            node-waf
                            Das Ding macht seit einiger Zeit Trouble. Siehe auch hier:
                            https://forum.iobroker.net/topic/73800/iobroker-exit-25-bei-adapter-update
                              Skript v.2024-04-21
                              *** BASE SYSTEM ***
                               Static hostname: iobroker
                                     Icon name: computer-vm
                                       Chassis: vm 🖴
                                Virtualization: kvm
                                        Kernel: Linux 6.1.0-21-amd64
                                  Architecture: x86-64
                               Hardware Vendor: QEMU
                                Hardware Model: Standard PC _i440FX + PIIX, 1996_
                              Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
                              model name      : Common KVM processor
                              Docker          : false
                              Virtualization  : kvm
                              Kernel          : x86_64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               23:42:01 up 10 min,  2 users,  load average: 0.15, 0.30, 0.20
                              CPU threads: 4
                              *** Time and Time Zones ***
                                             Local time: Thu 2024-05-16 23:42:01 CEST
                                         Universal time: Thu 2024-05-16 21:42:01 UTC
                                               RTC time: Thu 2024-05-16 21:42:01
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              pi
                              HOME=/home/pi
                              GROUPS=pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev bluetooth
                              *** Display-Server-Setup ***
                              pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                              Try `pgrep -f' option to match against the complete command line.
                              Display-Server: false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            6.2G        2.6G        2.7G        544K        1.1G        3.6G
                              Swap:           5.4G          0B        5.4G
                              Total:           11G        2.6G        8.1G
                              Active iob-Instances:   31
                                       5925 M total memory
                                       2523 M used memory
                                        374 M active memory
                                       2621 M inactive memory
                                       2583 M free memory
                                        156 M buffer memory
                                        938 M swap cache
                                       5117 M total swap
                                          0 M used swap
                                       5117 M free swap
                              top - 23:42:01 up 10 min,  2 users,  load average: 0.15, 0.30, 0.20
                              Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   5925.2 total,   2583.4 free,   2523.1 used,   1094.5 buff/cache
                              MiB Swap:   5118.0 total,   5118.0 free,      0.0 used.   3402.1 avail Mem
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** FILESYSTEM ***
                              udev           devtmpfs  2.9G     0  2.9G   0% /dev
                              tmpfs          tmpfs     593M  536K  592M   1% /run
                              /dev/vda1      ext4       27G   19G  6.6G  74% /
                              tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
                              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
                              [Thu May 16 23:31:21 2024] EXT4-fs (vda1): mounted filesystem with ordered data mode. Quota mode: none.
                              [Thu May 16 23:31:22 2024] EXT4-fs (vda1): re-mounted. Quota mode: none.
                              Show mounted filesystems:
                              TARGET                                                  SOURCE      FSTYPE      OPTIONS
                              /                                                       /dev/vda1   ext4        rw,relatime,errors=remount-ro
                              |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                              | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                              | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                              | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                              |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
                              | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13012
                              |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                              |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=3014624k,nr_inodes=753656,mode=755,inode64
                              | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                              | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
                              | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                              | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                              `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=606744k,mode=755,inode64
                                |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                                |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                                `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=606740k,nr_inodes=151685,mode=700,uid=1000,gid=1000,inode64
                              /var:
                              1.3G    /var/
                              1020M   /var/cache
                              1011M   /var/cache/apt
                              935M    /var/cache/apt/archives
                              179M    /var/lib
                              Archived and active journals take up 15.3M in the file system.
                              /opt/iobroker/backups:
                              7.2G    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              2.0G    /opt/iobroker/iobroker-data/
                              1.4G    /opt/iobroker/iobroker-data/sonosCache
                              289M    /opt/iobroker/iobroker-data/files
                              159M    /opt/iobroker/iobroker-data/backup-objects
                              57M     /opt/iobroker/iobroker-data/files/javascript.admin
                              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                              22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                              20M     /opt/iobroker/iobroker-data/objects.jsonl
                              18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                              16M     /opt/iobroker/iobroker-data/objects.json.migrated
                              USB-Devices by-id:
                              No Devices found 'by-id'
                              HINT:
                              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f6cab8486cd9eb11a420178e6fe9f4d9-if00-port0
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.20.2
                              /usr/bin/node           v18.20.2
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              /usr/bin/corepack       0.25.2
                              nodejs:
                                Installed: 18.20.2-1nodesource1
                                Candidate: 18.20.2-1nodesource1
                                Version table:
                                   18.13.0+dfsg1-1 500
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  5.0.19
                              admin:          6.13.16
                              javascript:     7.8.0
                              nodejs modules from github:     1
                              |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                              + system.adapter.amazon-dash.0            : amazon-dash           : iobroker                                 -  enabled
                                system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
                                system.adapter.ble.0                    : ble                   : iobroker                                 - disabled
                                system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
                                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                              + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
                                system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                              + system.adapter.history.0                : history               : iobroker                                 -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
                              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12002
                              + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                              + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 443
                                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                system.adapter.info.0                   : info                  : iobroker                                 - disabled
                              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                              + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                              + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
                              + system.adapter.milight-smart-light.1    : milight-smart-light   : iobroker                                 -  enabled
                                system.adapter.milight.0                : milight               : iobroker                                 - disabled, port: 5987
                                system.adapter.milight.1                : milight               : iobroker                                 - disabled, port: 5987
                              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: iobroker                                 - disabled
                                system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
                              + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                              + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                              + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1337, bind: 10.0.0.9
                              + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                                system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                                system.adapter.tankerkoenig.1           : tankerkoenig          : iobroker                                 - disabled
                              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                              + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : iobroker                                 -  enabled
                                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                                system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                                system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
                                system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                                system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
                                system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f6cab8486cd9eb11a420178e6fe9f4d9-if00-port0
                              + instance is alive
                              ioBroker-Repositories
                              Stable (default): http://download.iobroker.net/sources-dist.json
                              Installed ioBroker-Instances
                              Adapter    "acme"         : 0.1.2    , installed 0.1.2
                              Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
                              Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                              Adapter    "backitup"     : 2.11.0   , installed 2.9.8  [Updatable]
                              Adapter    "ble"          : 0.14.0   , installed 0.13.4 [Updatable]
                              Adapter    "broadlink2"   : 2.2.0    , installed 2.1.5  [Updatable]
                              Adapter    "daswetter"    : 3.1.13   , installed 3.1.10 [Updatable]
                              Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                              Adapter    "doorbird"     : 1.5.0    , installed 1.3.1  [Updatable]
                              Adapter    "hm-rpc"       : 1.17.0   , installed 1.16.0 [Updatable]
                              Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                              Adapter    "hue"          : 3.11.0   , installed 3.10.2 [Updatable]
                              Adapter    "ical"         : 1.14.3   , installed 1.13.3 [Updatable]
                              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                              Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.0  [Updatable]
                              Adapter    "milight"      : 0.4.0    , installed 0.4.0
                              Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                              Adapter    "nut"          : 1.6.0    , installed 1.6.0
                              Adapter    "openweathermap": 1.0.4   , installed 0.4.5  [Updatable]
                              Adapter    "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
                              Adapter    "parser"       : 2.1.0    , installed 2.1.0
                              Adapter    "proxmox"      : 2.3.0    , installed 2.2.1  [Updatable]
                              Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
                              Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
                              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                              Adapter    "tankerkoenig" : 3.4.0    , installed 3.3.7  [Updatable]
                              Adapter    "telegram"     : 3.2.1    , installed 3.0.1  [Updatable]
                              Adapter    "text2command" : 3.0.3    , installed 3.0.2  [Updatable]
                              Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                              Adapter    "unifi"        : 0.7.0    , installed 0.6.6  [Updatable]
                              Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
                              Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                              Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
                              Adapter    "vis-justgage" : 2.1.7    , installed 2.0.2  [Updatable]
                              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                              Adapter    "vis-map"      : 1.0.5    , installed 1.0.4  [Updatable]
                              Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
                              Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
                              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                              Adapter    "zigbee"       : 1.10.3   , installed 1.8.24 [Updatable]
                              Objects and States
                              Objects:        23842
                              States:         20725
                              Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15559      471/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1864       1/init
                              tcp        0      0 0.0.0.0:42629           0.0.0.0:*               LISTEN      1001       19144      1127/io.yahka.1
                              tcp        0      0 10.0.0.9:12002          0.0.0.0:*               LISTEN      1001       17198      758/io.hm-rpc.1
                              tcp        0      0 10.0.0.9:12001          0.0.0.0:*               LISTEN      1001       16893      671/io.hm-rpc.0
                              tcp        0      0 10.0.0.9:8100           0.0.0.0:*               LISTEN      1001       18938      1021/io.doorbird.0
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15608      448/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15601      448/iobroker.js-con
                              tcp        0      0 10.0.0.9:1337           0.0.0.0:*               LISTEN      1001       17663      824/io.sonoff.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          15561      471/sshd: /usr/sbin
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          1866       1/init
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15679      497/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18589      898/io.web.0
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18105      985/io.simple-api.0
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14120      411/dhclient
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1865       1/init
                              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16278      741/io.mihome-vacuu
                              udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       17893      882/io.mihome-vacuu
                              udp        0      0 0.0.0.0:57980           0.0.0.0:*                           1001       19514      1178/io.milight-sma
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        15520      432/avahi-daemon: r
                              udp        0      0 0.0.0.0:38379           0.0.0.0:*                           106        15522      432/avahi-daemon: r
                              udp        0      0 0.0.0.0:1905            0.0.0.0:*                           1001       32778      706/io.sonos.0
                              udp        0      0 0.0.0.0:38880           0.0.0.0:*                           1001       19228      1161/io.milight-sma
                              udp6       0      0 :::111                  :::*                                0          1867       1/init
                              udp6       0      0 :::5353                 :::*                                106        15521      432/avahi-daemon: r
                              udp6       0      0 :::59121                :::*                                106        15523      432/avahi-daemon: r
                              2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) Got terminate signal TERMINATE_YOURSELF
                              2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) cleaned everything up...
                              2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) terminating
                              2024-05-16 23:34:01.581  - info: panasonic-comfort-cloud.0 (1145) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-05-16 23:34:01.623  - info: host.iobroker stopInstance system.adapter.panasonic-comfort-cloud.0 send kill signal
                              2024-05-16 23:34:02.081  - info: panasonic-comfort-cloud.0 (1145) terminating
                              2024-05-16 23:34:02.135  - info: host.iobroker instance system.adapter.panasonic-comfort-cloud.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-05-16 23:34:37.708  - info: sonoff.0 (824) Client [zwischensteckernous2] connected with secret 1715895277708_8747
                              2024-05-16 23:34:38.721  - info: sonoff.0 (824) Client [zwischensteckernous5] connected with secret 1715895278721_6036
                              2024-05-16 23:34:59.544  - info: mihome-vacuum.0 (741) create state for carpet_mode
                              2024-05-16 23:35:00.010  - info: host.iobroker instance system.adapter.dwd.0 started with pid 1332
                              2024-05-16 23:35:00.820  - info: dwd.0 (1332) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                              2024-05-16 23:35:01.346  - info: dwd.0 (1332) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-05-16 23:35:01.857  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-05-16 23:35:19.650  - info: mihome-vacuum.0 (741) change states from State control.fan_power
                              2024-05-16 23:35:19.650  - info: mihome-vacuum.0 (741) create states for water box
                              2024-05-16 23:36:01.350  - info: host.iobroker iobroker upgrade doorbird@1.5.0
                              2024-05-16 23:36:02.157  - info: host.iobroker iobroker Update doorbird from @1.3.1 to @1.5.0
                              2024-05-16 23:36:02.448  - info: host.iobroker iobroker NPM version: 10.5.0Installing iobroker.doorbird@1.5.0... (System call)
                              2024-05-16 23:39:32.894  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-16T21_36_02_664Z-debug-0.loghost.iobroker Cannot install iobroker.doorbird@1.5.0: 127
                              2024-05-16 23:39:33.904  - info: host.iobroker iobroker exit 25
                              2024-05-16 23:40:00.012  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2663
                              2024-05-16 23:40:00.853  - info: dwd.0 (2663) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                              2024-05-16 23:40:01.511  - info: dwd.0 (2663) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-05-16 23:40:02.022  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                                      v.2024-04-21
                                       Chassis: vm 🖴
                                Virtualization: kvm
                              Installation:           kvm
                              User-ID:                1000
                              Pending OS-Updates:     0
                              Pending iob updates:    26
                              Nodejs-Installation:
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              Recommended versions are nodejs 18.20.2 and npm 10.5.0
                              MEMORY:
                              Mem:            6.2G        2.7G        2.7G        548K        1.1G        3.6G
                              Swap:           5.4G          0B        5.4G
                              Total:           11G        2.7G        8.1G
                                                      admin                   6.13.16
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                23842
                              States:                 20725
                              Size of iob-Database:
                              16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              6.4M    /opt/iobroker/iobroker-data/states.jsonl
                              4.6M    /opt/iobroker/iobroker-data/states.json.migrated
                              4.6M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              0       /opt/iobroker/iobroker-data/states.json.broken
                                @t1m0
                                Da klemmt es:
                                Installier den homematic-Adapter nochmal.
                                  t1m0 @Thomas Braun last edited by t1m0
                                  Wie soll ich denn etwas neu installieren? Kann ich doch nicht. Oder meinst du es ändert sich, wenn ich die Adapter vorher lösche?
                                  Habe 3Stk
                                    @t1m0
                                    Versuch es mal über die Kommandozeile
                                    iobroker upgrade ADAPTERNAME@VERSIONSNUMMER
                                    €dit: Falschen Fehler korrigiert.
                                    Homoran T 2 Replies Last reply Reply Quote 0
                                      @thomas-braun sagte in Adapter lassen sich nicht mehr aktualisieren:
                                      @t1m0
                                      iobroker update ADAPTERNAME@VERSIONSNUMMER
                                      @t1m0 am besten mit `--debug`` hinten dran. Und dann die Ausgabe posten
                                        oder meinst du "upgrade"?
                                        pi@iobroker:~$ iobroker update zigbee@1.10.3 --debug
                                        Used repository: zigbee@1.10.3
                                        Error: unknown repository is active - "zigbee@1.10.3". Known: Stable (default)
                                        pi@iobroker:~$
                                          @t1m0
                                          Ja, sorry, hab aus dem Gedächtnis geschrieben.
                                          upgrade muss das heißen.
                                          Ich würde auch die homematic-Adapter ins Auge fassen, nicht den zigbee.
                                            pi@iobroker:~$ iobroker upgrade hm-rpc@1.17.0 --debug
                                            This upgrade of "hm-rpc" will introduce the following changes:
                                            -> 1.17.0:
                                            Fixed encrypted configuration
                                            -> 1.16.1:
                                            Improved the configuration layout
                                            Would you like to upgrade hm-rpc from @1.16.0 to @1.17.0 now? [(y)es, (n)o]: y
                                            NPM version: 10.5.0
                                            npm ERR! code 127
                                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-17T09_55_38_815Z-debug-0.log
                                            npm ERR! code 127
                                            pi@iobroker:~$
                                            1104
