    4. Node-Red startet nicht
    • Manuel Held 0
      Manuel Held 0 last edited by
      ich bekomme folgenden Fehler wenn die Instanz startet:
      2024-05-17 11:54:56.338 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/versioning.js:305
      2024-05-17 11:54:56.338 - error: host.raspberrypi Caught by controller[0]: libc: options.target_libc || detect_libc.familySync() || 'unknown',
      2024-05-17 11:54:56.339 - error: host.raspberrypi Caught by controller[0]: ^
      2024-05-17 11:54:56.339 - error: host.raspberrypi Caught by controller[0]: TypeError: detect_libc.familySync is not a function
      2024-05-17 11:54:56.339 - error: host.raspberrypi Caught by controller[0]: at module.exports.evaluate (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/versioning.js:305:46)
      2024-05-17 11:54:56.339 - error: host.raspberrypi Caught by controller[0]: at exports.find (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/pre-binding.js:32:27)
      2024-05-17 11:54:56.339 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/bcrypt/bcrypt.js:5:31)
      2024-05-17 11:54:56.339 - error: host.raspberrypi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-05-17 11:54:56.340 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-05-17 11:54:56.340 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-05-17 11:54:56.340 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-05-17 11:54:56.340 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
      2024-05-17 11:54:56.340 - error: host.raspberrypi Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      2024-05-17 11:54:56.340 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.node-red/main.js:8:16)
      2024-05-17 11:54:56.340 - error: host.raspberrypi Caught by controller[0]: Node.js v18.20.2
      2024-05-17 11:54:56.341 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-05-17 11:54:56.341 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
      Mein Diag schreibt folgendes:
      Temp directories causing npm8 problem: 8
      Some problems detected, please run iob fix
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
        system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
        system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      + system.adapter.kostal-piko-ba.0         : kostal-piko-ba        : raspberrypi                              -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
        system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "ble"          : 0.14.0   , installed 0.12.0 [Updatable]
      Adapter    "deconz"       : 1.4.0    , installed 1.3.23 [Updatable]
      Adapter    "discovery"    : 4.4.0    , installed 2.7.0  [Updatable]
      Adapter    "fritzdect"    : 2.5.9    , installed 2.1.15 [Updatable]
      Adapter    "hue"          : 3.11.0   , installed 3.5.31 [Updatable]
      Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
      Adapter    "jarvis"       : 3.1.8    , installed 2.2.1  [Updatable]
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "kostal-piko-ba": 4.0.0   , installed 3.0.8  [Updatable]
      Adapter    "mihome-vacuum": 4.2.0    , installed 3.9.5  [Updatable]
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "shelly"       : 6.9.0    , installed 6.3.1  [Updatable]
      Adapter    "smartcontrol" : 2.0.1    , installed 1.3.2  [Updatable]
      Adapter    "socketio"     : 6.7.0    , installed 6.6.1  [Updatable]
      Adapter    "sonoff"       : 3.0.3    , installed 2.5.1  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.14 [Updatable]
      Adapter    "tuya"         : 3.15.0   , installed 3.14.2 [Updatable]
      Adapter    "ws"           : 2.6.1    , installed 2.5.11 [Updatable]
      Adapter    "yahka"        : 1.0.3    , installed 0.17.0 [Updatable]
      Objects and States
      Objects:        1789
      States:         1396
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 http://phoscon.de/apt/deconz buster InRelease
      Hit:4 https://download.docker.com/linux/raspbian buster InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Get:7 https://packages.grafana.com/oss/deb stable InRelease [7661 B]
      Err:7 https://packages.grafana.com/oss/deb stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       361887331  18850/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       361887321  18850/iobroker.js-c
      tcp        0      0 0.0.0.0:9002            0.0.0.0:*               LISTEN      0          361878634  16007/docker-proxy
      tcp        0      0 0.0.0.0:35727           0.0.0.0:*               LISTEN      0          361876005  -
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2034604    1/systemd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       20594      377/deCONZ
      tcp        0      0 0.0.0.0:35697           0.0.0.0:*               LISTEN      1001       361892371  19692/io.yahka.0
      tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      1000       361877023  16658/Plex Media Se
      tcp        0      0 0.0.0.0:81              0.0.0.0:*               LISTEN      0          361878717  16161/docker-proxy
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          361876780  16253/docker-proxy
      tcp        0      0 0.0.0.0:853             0.0.0.0:*               LISTEN      0          361877586  16082/docker-proxy
      tcp        0      0 0.0.0.0:42869           0.0.0.0:*               LISTEN      106        2036217    3661/rpc.statd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          361882265  17592/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          362723042  11921/cupsd
      tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      1000       361880580  16962/Plex Tuner Se
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      0          361876683  16040/docker-proxy
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        20601      528/influxd
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       364215943  10064/sshd: pi@pts/
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       361887684  19250/io.sonoff.0
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       20613      377/deCONZ
      tcp        0      0 0.0.0.0:60              0.0.0.0:*               LISTEN      0          361878802  16210/docker-proxy
      tcp        0      0 0.0.0.0:444             0.0.0.0:*               LISTEN      0          361878698  16126/docker-proxy
      tcp        0      0 127.0.0.1:35431         0.0.0.0:*               LISTEN      1000       361878156  16695/Plex Plug-in
      tcp6       0      0 :::36457                :::*                    LISTEN      0          361876009  -
      tcp6       0      0 :::9002                 :::*                    LISTEN      0          361876643  16016/docker-proxy
      tcp6       0      0 :::111                  :::*                    LISTEN      0          2034610    1/systemd
      tcp6       0      0 :::32400                :::*                    LISTEN      1000       361877021  16658/Plex Media Se
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       361887451  18978/io.admin.0
      tcp6       0      0 :::81                   :::*                    LISTEN      0          361877712  16168/docker-proxy
      tcp6       0      0 :::47025                :::*                    LISTEN      106        2036221    3661/rpc.statd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       361891027  19406/io.web.0
      tcp6       0      0 :::53                   :::*                    LISTEN      0          361876024  16265/docker-proxy
      tcp6       0      0 :::853                  :::*                    LISTEN      0          361877591  16091/docker-proxy
      tcp6       0      0 :::22                   :::*                    LISTEN      0          361882267  17592/sshd
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        21295      528/influxd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          362723041  11921/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      0          361875851  16050/docker-proxy
      tcp6       0      0 :::3001                 :::*                    LISTEN      115        21619      515/grafana-server
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       364215942  10064/sshd: pi@pts/
      tcp6       0      0 :::60                   :::*                    LISTEN      0          361877760  16218/docker-proxy
      tcp6       0      0 :::444                  :::*                    LISTEN      0          361875941  16136/docker-proxy
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       361892903  19289/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       361891928  19289/io.tuya.0
      udp        0      0 10.168.178.124:49675    0.0.0.0:*                           1000       361877324  16658/Plex Media Se
      udp        0      0 0.0.0.0:52755           0.0.0.0:*                           0          361876004  -
      udp        0      0 169.254.93.136:58396    0.0.0.0:*                           1000       361877325  16658/Plex Media Se
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       361887562  19136/io.shelly.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          361876818  16298/docker-proxy
      udp        0      0 169.254.16.8:60992      0.0.0.0:*                           1000       361877330  16658/Plex Media Se
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          361877735  16184/docker-proxy
      udp        0      0 169.254.93.136:46148    0.0.0.0:*                           1000       361877333  16658/Plex Media Se
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19700      407/dhcpcd
      udp        0      0 0.0.0.0:44108           0.0.0.0:*                           106        2036215    3661/rpc.statd
      udp        0      0 127.0.0.1:50765         0.0.0.0:*                           1000       361877323  16658/Plex Media Se
      udp        0      0 169.254.16.8:47712      0.0.0.0:*                           1000       361877326  16658/Plex Media Se
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2034606    1/systemd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          362724904  11922/cups-browsed
      udp        0      0 0.0.0.0:32410           0.0.0.0:*                           1000       361877198  16658/Plex Media Se
      udp        0      0 0.0.0.0:32412           0.0.0.0:*                           1000       361877199  16658/Plex Media Se
      udp        0      0 0.0.0.0:32413           0.0.0.0:*                           1000       361877322  16658/Plex Media Se
      udp        0      0 0.0.0.0:32414           0.0.0.0:*                           1000       361877197  16658/Plex Media Se
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        361883407  18055/avahi-daemon:
      udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        361883409  18055/avahi-daemon:
      udp        0      0 169.254.93.136:42736    0.0.0.0:*                           1000       361877329  16658/Plex Media Se
      udp        0      0 10.168.178.124:44317    0.0.0.0:*                           1000       361877332  16658/Plex Media Se
      udp        0      0 127.0.0.1:46915         0.0.0.0:*                           1000       361877327  16658/Plex Media Se
      udp        0      0 0.0.0.0:50515           0.0.0.0:*                           1000       361879698  16962/Plex Tuner Se
      udp        0      0 127.0.0.1:869           0.0.0.0:*                           0          2036211    3661/rpc.statd
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       361893074  19532/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       361893072  19532/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       361893070  19532/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       361893066  19532/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18722      377/deCONZ
      udp        0      0 0.0.0.0:1901            0.0.0.0:*                           1000       361877331  16658/Plex Media Se
      udp        0      0 169.254.16.8:50574      0.0.0.0:*                           1000       361877334  16658/Plex Media Se
      udp        0      0 10.168.178.124:35266    0.0.0.0:*                           1000       361877328  16658/Plex Media Se
      udp6       0      0 :::59423                :::*                                108        361883410  18055/avahi-daemon:
      udp6       0      0 :::546                  :::*                                0          28375      407/dhcpcd
      udp6       0      0 :::53                   :::*                                0          361876824  16307/docker-proxy
      udp6       0      0 :::67                   :::*                                0          361878773  16190/docker-proxy
      udp6       0      0 :::111                  :::*                                0          2035454    1/systemd
      udp6       0      0 :::36486                :::*                                0          361876008  -
      udp6       0      0 :::51926                :::*                                106        2036219    3661/rpc.statd
      udp6       0      0 :::5353                 :::*                                108        361883408  18055/avahi-daemon:
      udp6       0      0 :::1900                 :::*                                1001       361893076  19532/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       361893075  19532/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       361893073  19532/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       361893071  19532/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       361893069  19532/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       361893068  19532/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       361893067  19532/io.deconz.0
      2024-05-17 11:59:46.922  - warn: shelly.0 (19136) [authEnabled] 10.168.178.87 (shellydimmer2 / shellydimmer2-C8C9A325A0FE / SHDM-2#C8C9A325A0FE#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-05-17 11:59:52.190  - warn: shelly.0 (19136) [authEnabled] 10.168.178.87 (shellydimmer2 / shellydimmer2-C8C9A325A0FE / SHDM-2#C8C9A325A0FE#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-05-17 11:59:57.748  - warn: shelly.0 (19136) [authEnabled] 10.168.178.87 (shellydimmer2 / shellydimmer2-C8C9A325A0FE / SHDM-2#C8C9A325A0FE#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-05-17 12:00:03.040  - warn: shelly.0 (19136) [authEnabled] 10.168.178.87 (shellydimmer2 / shellydimmer2-C8C9A325A0FE / SHDM-2#C8C9A325A0FE#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-05-17 12:00:08.321  - warn: shelly.0 (19136) [authEnabled] 10.168.178.87 (shellydimmer2 / shellydimmer2-C8C9A325A0FE / SHDM-2#C8C9A325A0FE#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-05-17 12:00:10.810  - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 11731
      2024-05-17 12:00:12.467  - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/versioning.js:305
      2024-05-17 12:00:12.467  - error: host.raspberrypi Caught by controller[0]:     libc: options.target_libc || detect_libc.familySync() || 'unknown',
      2024-05-17 12:00:12.468  - error: host.raspberrypi Caught by controller[0]:                                              ^
      2024-05-17 12:00:12.468  - error: host.raspberrypi Caught by controller[0]: TypeError: detect_libc.familySync is not a function
      2024-05-17 12:00:12.468  - error: host.raspberrypi Caught by controller[0]:     at module.exports.evaluate (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/versioning.js:305:46)
      2024-05-17 12:00:12.468  - error: host.raspberrypi Caught by controller[0]:     at exports.find (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/pre-binding.js:32:27)
      2024-05-17 12:00:12.468  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/bcrypt/bcrypt.js:5:31)
      2024-05-17 12:00:12.468  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-05-17 12:00:12.469  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-05-17 12:00:12.469  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-05-17 12:00:12.469  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-05-17 12:00:12.469  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
      2024-05-17 12:00:12.469  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-05-17 12:00:12.469  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.node-red/main.js:8:16)
      2024-05-17 12:00:12.469  - error: host.raspberrypi Caught by controller[0]: Node.js v18.20.2
      2024-05-17 12:00:12.470  - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-05-17 12:00:12.470  - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
      2024-05-17 12:00:13.628  - warn: shelly.0 (19136) [authEnabled] 10.168.178.87 (shellydimmer2 / shellydimmer2-C8C9A325A0FE / SHDM-2#C8C9A325A0FE#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-05-17 12:00:18.926  - warn: shelly.0 (19136) [authEnabled] 10.168.178.87 (shellydimmer2 / shellydimmer2-C8C9A325A0FE / SHDM-2#C8C9A325A0FE#1): This device is not protected via restricted login (see adapter documentation for details)
      Kann mir jemand helfen ?
      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @Manuel Held 0 last edited by
        @manuel-held-0 Bitte iob diag komplett zeigen.
        Aber ich sehe schon, Du bist da noch mit Buster unterwegs.
          Thomas Braun Most Active @Manuel Held 0 last edited by Thomas Braun
          @manuel-held-0
          Dein Betriebssystem ZU ALT.
          Buster ist vor geraumer Zeit ABGEKÜNDIGT und hätte schon vor geraumer ZEIT NEUINSTALLIERT werden müssen.
          NEIN, 'never tatsch your running süstäm' funktioniert NICHT.
          Gilt auch für die ganzen ioBroker-Adapter.
          Zum technischen Hintergrund: Hier ist die Library 'glibc' wohl veraltet und aktueller Code baut nicht mehr dagegen. Und da Buster tot ist baut auch niemand eine aktuelle glibc ein.
          Manuel Held 0 1 Reply Last reply Reply Quote 0
          • Manuel Held 0
            Manuel Held 0 @Thomas Braun last edited by
            @thomas-braun Dankeschön. Mach ich gleich nachm Urlaub ein Update.
              @manuel-held-0 sagte in Node-Red startet nicht:
              Installier es NEU. Updates von so einer versumpften Version gehen meist in die Hose. Insbesondere, wenn dann auch auch Versionen übersprungen werden.
              • Manuel Held 0
                @thomas-braun Oha, damit hab ich nicht gerechnet
                  Ist mir klar. Deswegen schreib ich es nochmal.
