    4. Radar 2 nach update auf v2.2.0 bleibt rot
    • Walter.O.
      Walter.O. last edited by
      Radar 2 nach update auf v2.2.0 bleibt rot obwohl er vorher sauber lief.
      Läuft auf raspi 3 als slave.
      Update, Ubgrade, iob FIX wurde gemacht
      pi@pi:~ $ iob start
      pi@pi:~ $ node -v
      v18.20.2
      pi@pi:~ $ nodejs -v
      v18.20.2
      Js Controler : 5.0.19
      Log ausgabe:
      host.Raspberry-1
      2024-05-18 20:18:16.296 info Restart adapter system.adapter.radar2.0 because enabled
      host.Raspberry-1
      2024-05-18 20:18:16.296 error instance system.adapter.radar2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Raspberry-1
      2024-05-18 20:18:16.296 error Caught by controller[0]: Node.js v18.20.2
      host.Raspberry-1
      2024-05-18 20:18:16.295 error Caught by controller[0]: }
      host.Raspberry-1
      2024-05-18 20:18:16.295 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.radar2/package.json'
      host.Raspberry-1
      2024-05-18 20:18:16.295 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
      host.Raspberry-1
      2024-05-18 20:18:16.294 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:122:24)
      host.Raspberry-1
      2024-05-18 20:18:16.294 error Caught by controller[0]: at shouldUseESMLoader (node:internal/modules/run_main:77:15)
      host.Raspberry-1
      2024-05-18 20:18:16.294 error Caught by controller[0]: at readPackageScope (node:internal/modules/package_json_reader:157:19)
      host.Raspberry-1
      2024-05-18 20:18:16.293 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
      host.Raspberry-1
      2024-05-18 20:18:16.293 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
      host.Raspberry-1
      2024-05-18 20:18:16.293 error Caught by controller[0]: at parse (<anonymous>)
      host.Raspberry-1
      2024-05-18 20:18:16.292 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.radar2/package.json: Unexpected end of JSON input
      host.Raspberry-1
      2024-05-18 20:18:16.292 error Caught by controller[0]: ^
      host.Raspberry-1
      2024-05-18 20:18:16.291 error Caught by controller[0]: throw error;
      host.Raspberry-1
      2024-05-18 20:18:16.290 error Caught by controller[0]: node:internal/modules/package_json_reader:92
      host.Raspberry-1
      2024-05-18 20:18:15.574 info instance system.adapter.radar2.0 started with pid 2136
      host.Raspberry-1
      2024-05-18 20:18:15.514 error startInstance radar2.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.radar2/package.json"
      Also ich bin gerade mal völlig ratlos und hoffe hier auf hilfe.
        Thomas Braun Most Active @Walter.O. last edited by
        @walter-o sagte in Radar 2 nach update auf v2.2.0 bleibt rot:
        Wie sieht die Datei denn aus?
        Installier den Adapter vielleicht nochmal neu.
        Walter.O. 1 Reply Last reply Reply Quote 0
        • Walter.O.
          Walter.O. @Thomas Braun last edited by Walter.O.
          @thomas-braun sagte in Radar 2 nach update auf v2.2.0 bleibt rot:
          "name": "iobroker.radar2",
          "version": "2.2.0",
          "description": "Radar2 to find status of IP, Bluetooth, UWZ, ECB and HP-Printers-devices",
          "author": {
          "name": "iobroker-community-adapters",
          "email": "mcm57@gmx.at"
          "contributors": [
          "frankjoke frankjoke@hotmail.com"
          "homepage": "https://github.com/frankjoke/ioBroker.radar2",
          "license": "MIT",
          "keywords": [
          "iobroker",
          "adapter",
          "home automation",
          "ping",
          "bluetooth",
          "radar",
          "UWZ",
          "ECB",
          "printer",
          "HP",
          "Ink"
          "repository": {
          "type": "git",
          "url": "https://github.com/iobroker-community-adapters/ioBroker.radar2.git"
          "engines": {
          "node": ">=18"
          "dependencies": {
          "@iobroker/adapter-core": "^3.0.6",
          "axios": "^1.6.8",
          "node-arp": "^1.0.6",
          "node-ble": "^1.10.0",
          "ping": "^0.4.4",
          "xml2js": "^0.6.2"
          "devDependencies": {
          "@alcalzone/release-script": "^3.7.0",
          "@alcalzone/release-script-plugin-iobroker": "^3.7.0",
          "@alcalzone/release-script-plugin-license": "^3.7.0",
          "@alcalzone/release-script-plugin-manual-review": "^3.7.0",
          "@iobroker/adapter-dev": "^1.3.0",
          "@iobroker/testing": "^4.1.1",
          "@tsconfig/node14": "^14.1.2",
          "@types/chai": "^4.3.11",
          "@types/chai-as-promised": "^7.1.8",
          "@types/mocha": "^10.0.6",
          "@types/node": "^20.12.7",
          "@types/proxyquire": "^1.3.31",
          "@types/sinon": "^17.0.3",
          "@types/sinon-chai": "^3.2.12",
          "chai": "^4.4.1",
          "chai-as-promised": "^7.1.1",
          "eslint": "^8.57.0",
          "eslint-config-prettier": "^9.1.0",
          "eslint-plugin-prettier": "^5.1.3",
          "eslint-plugin-vue": "^9.24.1",
          "mocha": "^10.4.0",
          "prettier": "^3.2.5",
          "proxyquire": "^2.1.3",
          "sinon": "^17.0.1",
          "sinon-chai": "^3.7.0",
          "typescript": "~5.4.5"
          "optionalDependencies": {
          "@abandonware/noble": "1.9.2-24",
          "net-ping": "^1.2.4"
          "main": "radar2.js",
          "scripts": {
          "postbuild": "cpy --cwd=admin --rename=index_m.html index.html .",
          "test:js": "mocha --config test/mocharc.custom.json "{!(node_modules|test)//.test.js,.test.js,test//test!(PackageFiles|Startup).js}"",
          "test:package": "mocha test/package --exit",
          "test:integration": "mocha test/integration --exit",
          "test": "npm run test:js && npm run test:package",
          "check": "tsc --noEmit -p tsconfig.check.json",
          "lint": "eslint .",
          "translate": "translate-adapter",
          "release": "release-script"
          "bugs": {
          "url": "https://github.com/frankjoke/ioBroker.radar2/issues"
          "readmeFilename": "README.md"
          Inhalt der Datei
          Adapter wurde gelöscht und neu instaliert
          Rechte sind ; rw-rw-r--
            Und läuft das nun? Wenn nein, mit welchen Meldungen?
            Welche Rechte?
            • Walter.O.
              Welche Rechte?
              Die datei rechte ( schreib lese zugriff) der json
                Sagt nur nix aus. Die Ausgabe von
                ls -lah /pfad/zur/datei
                wäre sinnvoller. Ist aber auch meist nicht das Problem, wenn man nicht als root durch das System hampelt.
                Du hast aber immer noch nicht verraten, ob das Ding jetzt läuft und wenn nicht, mit welchen Meldungen.
                • Walter.O.
                  @thomas-braun Läuft auf dem Host aber nicht auf dem Slave.
                  Ich muss mich da jetzt noch mal mit beschäftigen
                    @walter-o
                    Irgendwie kann ich mit deinen Antworten nix anfangen...
                    Funktioniert der Adapter nun?
