    2. English
    4. Rest-Api adapter error
    • Macrisu
      Macrisu last edited by
      Hello!
      I've reinstalled my NAS and I use iobroker on Docker latest. - v.9.1.2
      After installing the Rest-Api 1.1 adapter, it does not start.
      Error log:
      2024-05-22 08:26:54.002 - error: rest-api.0 (2520) Cannot create webserver: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
      2024-05-22 08:26:54.003 - warn: rest-api.0 (2520) Terminated (JS_CONTROLLER_STOPPED): Without reason
      2024-05-22 08:26:54.510 - info: rest-api.0 (2520) terminating http server on port 8093
      2024-05-22 08:26:54.528 - error: host.796b7a0bc948 instance system.adapter.rest-api.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-05-22 08:26:54.528 - info: host.796b7a0bc948 Restart adapter system.adapter.rest-api.0 because enabled
      haselchen Macrisu 2 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @Macrisu last edited by
        @macrisu
        Host Modus or Bridge Modus?
        Is there another Application on Port 8093 running?
        Macrisu 1 Reply Last reply Reply Quote 0
        • Macrisu
          Macrisu @haselchen last edited by
          @haselchen
          1. I've change the port to test, but same error.
          2. Bridge mode
          • Macrisu
            Macrisu @Macrisu last edited by
            I've tried now on another machine/arhotecture - rpi 3b
            Same error
            haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
            • haselchen
              @macrisu
              Which JS Controller Version?
                Thomas Braun Most Active @Macrisu last edited by
                @macrisu
                Should be fixed with latest beta of the adapter.
                • Macrisu
                  Macrisu @Thomas Braun last edited by
                  @thomas-braun There is nothing new in the beta repository of the adapter - latest version still 1.1
                  I see here the new one, but how can I use it in docker?
                    @macrisu sagte in Rest-Api adapter error:
                    Adapter is still 'incoming'. Please check later today or tomorrow if the repository had been synced.
