    4. [gelöst] Mehrfache gleiche Fehlermeldungen?
      Beowolf last edited by Beowolf
      ich bekomme immer mehrfach die gleichen Fehlermeldung/Hinweise hintereinander.
      Woran kann das liegen?
      host.raspberrypi
      	2024-05-22 10:30:12.333	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      ical.0
      	2024-05-22 10:30:11.815	info	Terminated (NO_ERROR): Without reason
      host.raspberrypi
      	2024-05-22 10:30:08.341	info	instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
      pegelalarm.0
      	2024-05-22 10:30:07.828	info	Terminated (NO_ERROR): Without reason
      ical.0
      	2024-05-22 10:30:06.339	info	processing URL: termine Einträge manuell gelöscht.
      ical.0
      	2024-05-22 10:30:05.932	info	processing URL: calendar1 Einträge manuell gelöscht.
      ical.0
      	2024-05-22 10:30:05.221	info	starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
      host.raspberrypi
      	2024-05-22 10:30:04.050	info	instance system.adapter.ical.0 started with pid 19149
      pegelalarm.0
      	2024-05-22 10:30:01.312	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.20.2, js-controller: 5.0.19
      host.raspberrypi
      	2024-05-22 10:30:00.033	info	instance system.adapter.pegelalarm.0 started with pid 19109
      host.raspberrypi
      	2024-05-22 10:45:08.106	info	instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
      pegelalarm.0
      	2024-05-22 10:45:07.593	info	Terminated (NO_ERROR): Without reason
      pegelalarm.0
      	2024-05-22 10:45:01.057	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.20.2, js-controller: 5.0.19
      host.raspberrypi
      	2024-05-22 10:45:00.027	info	instance system.adapter.pegelalarm.0 started with pid 19974
      admin.0
      	2024-05-22 10:41:42.936	info	==> Connected system.user.admin from ::ffff:192.168.49.12
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      admin.0
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      admin.0
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      admin.0
      admin.0
      	2024-05-22 10:41:14.907	info	<== Disconnect system.user.admin from ::ffff:192.168.49.12 admin
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      • sigi234
        sigi234 Forum Testing Most Active @Beowolf last edited by
        @beowolf
        Persönliche Daten rausnehmen!!!
          Danke. So ist es besser.
          • sigi234
            @beowolf sagte in Mehrfache gleiche Fehlermeldungen?:
            Gut, ich sehe da aber keine Fehler sind nur Info
              Nee, es geht nicht um die Fehler/Hinweise. Es geht um das, das die immer wieder hintereinander kommen. Also mehrfach die selbe Zeit.
              Die Meldungen hier gehen um
              los, bis
              Also die selben Meldungen ein paar mal hintereinander.
              • DJMarc75
                DJMarc75 @Beowolf last edited by
                @beowolf LOG löschen:
                Browserfenster neu laden.
                  Beowolf @DJMarc75 last edited by
                  @djmarc75 sagte in Mehrfache gleiche Fehlermeldungen?:
                  Das habe ich auch schon versucht. Hat aber nicht funktioniert. Hätte mich auch gewundert. Die Meldungen kommen ja vom ioBroker.
                    Thomas Braun Most Active @Beowolf last edited by
                    @beowolf
                    Schau dir das LogFile im Terminal an:
                    iob logs | uniq
                    Sind da auch doppelte Einträge drin?
                    Wenn nein, dann hat dich die GUI mal wieder angeschwindelt.
                      Habe jetzt mal dieses gemacht.
                      iob nodejs-update
                      Mal schauen ob jetzt Ruhe ist.
                        @beowolf
                        Abgesehen davon, dass ein aktuelles nodejs immer eine gute Idee ist:
                        Sollte mit der üblichen Systempflege via
                        sudo apt update
                        sudo apt full-upgrade
                        mitlaufen. Doppelte Einträge in Logs verhindert das allerdings auch nicht.
                          Ok. Habe ich jetzt auch gemacht. Jetzt scheint Ruhe zu sein. 👍
                          205
