    4. mal wieder node und npm update
      docsnyder7 @Jan1 last edited by docsnyder7
      Nabend zusammen.. ich hab heute mal wieder nodejs aktualisiert und dabei festgestellt, dass auch npm von 10.5.2 auf 10.7 angehoben werden kann.. allerdings bekomme ich
      npm ERR! code EACCES
      npm ERR! syscall rename
      npm ERR! path /usr/lib/node_modules/npm
      npm ERR! dest /usr/lib/node_modules/.npm-qUIFSsiV
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, rename '/usr/lib/node_modules/npm' -> '/usr/lib/node_modules/.npm-qUIFSsiV'
      npm ERR!     at async Object.rename (node:internal/fs/promises:779:10)
      npm ERR!     at async moveFile (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/move-file.js:30:5)
      npm ERR!     at async Promise.allSettled (index 0)
      npm ERR!     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:246:11)
      npm ERR!     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:165:5)
      npm ERR!     at async Update.exec (/usr/lib/node_modules/npm/lib/commands/update.js:65:5)
      npm ERR!     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5)
      npm ERR!     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5) {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'rename',
      npm ERR!   path: '/usr/lib/node_modules/npm',
      npm ERR!   dest: '/usr/lib/node_modules/.npm-qUIFSsiV'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR! A complete log of this run can be found in: /home/docsn/.npm/_logs/2024-05-22T17_57_32_781Z-debug-0.log
      jetzt hab ich schon einige Anleitungen gelesen, bin mir aber nicht sicher, ob das alles für mich so passt... gibts ein kurze interne Anleitung zu dieser Fehlerlage?
      Muss ich als root angemeldet sein?
      Erledigt... ein reboot und ein erneutes iob fix hats erledigt.
        Thomas Braun Most Active @docsnyder7 last edited by
        @docsnyder7 sagte in Wichtige Hinweise bei neueren npm-Versionen und sudo:
        Frage: Wie?
        Denn npm wird nicht separat angelangt. Das kommt immer schon passend mit nodejs daher...
        D 1 Reply Last reply Reply Quote 2
          docsnyder7 @Thomas Braun last edited by docsnyder7
          Recht du hast, war wohl etwas hibbelig und ungeduldig 😕
          nodejs über den Leitfaden hier aus dem Forum
          iob nodejs-update 20
            @docsnyder7
            Eigentlich wollte ich auch nicht wissen ob ich Recht habe sondern wie du nodejs aktualisierst...
                Jan1 @docsnyder7 last edited by
                npm bleibt so lange in der "alten" Version, bis es mit dem nächsten Node Update mit aktualisiert wird. Also jetzt einfach so lassen und Finger weg 😉
                  @docsnyder7
                  ich hab das mal von dem alten Thread abgetrennt.
                  Hat auch gar nichts mit sudo npm.... zu tun.
                  Bitte ggf. den provisorischen Threadtitel anpassen
                    @docsnyder7
                    Hier noch die derzeitig im Umlauf befindlichen nodejs/npm-Bundles:
                      danke dafür.. mit dem Update auf 20.13.1 hab ich die 10.8.0 npm bekommen
                        Thomas Braun Most Active @docsnyder7 last edited by Thomas Braun
                        @docsnyder7
                        Dann hast du da irgendwas anderes reingeknallt, denn wie du oben siehst wird npm 10.8.0 derzeitig mit gar keinem nodejs-Paket ausgeliefert.
                        Das 'irgendwas anderes' dürfte auch die Meldungen aus dem ersten Beitrag verursachen.
                          die Meldung kam vor dem reboot und dem iob fix, aber nach dem iob nodejs-update 20
                          macht es Sinn das 20er Update nochmals anzuwerfen
                          ich hatte mit
                          npm install -g npm@latest
                          versucht die Version anzupassen, dies führte dann zu den obigen Fehlermeldungen
                            @docsnyder7
                            Und genau DAS macht man halt nicht.
                            Nie per npm install -g 'irgendwas' global in das System klatschen.
                            Wie gesagt, das ist der Auslöser für die Meldung aus dem ersten Beitrag.
                            sudo apt update
                            sudo apt install --reinstall nodejs
                            sollte das richtige Paket aber jetzt auf die Kiste bügeln.
                            D Duffy 2 Replies Last reply Reply Quote 1
                              Danke für die Hilfe!
                              Werde ich umgehend erledigen... mir war bis dato nicht bewußt, dass npm mit dem nodejs Paket daherkommt
                              Update: alles erledigt.. npm wieder auf 10.5.2
                                @docsnyder7
                                Genau deshalb habe ich das auch oben geschrieben, dass es mit dem nächsten Node Update mitkommt und Du die Finger nun weglassen sollst 😉
                                  @jan1
                                  das hatte ich ja auch, aber das war das Kind schon Richtung Brunnen abgesprungen 😬
                                  • Duffy
                                    Duffy @Thomas Braun last edited by
                                    @thomas-braun sagte in mal wieder node und npm update:
                                    @docsnyder7
                                    sudo apt update
                                    Ohh weh ist das alles kompliziert (wenn man ahnungslos ist)
                                    Ich hatte mir vor ca. einem 1/2 Jahr
                                    folgendes zum node-js Update dokumentiert.
                                    Warum sieht der Befehl zum Update von Node-js nun so aus?
                                    sudo apt update
                                    Hängt es damit zusammen, dass es andere Voraussetzungen waren da bei docsnyder7 etwas verbogen war?
                                    Ich habe es an meinem Testpi, so wie von dir geschrieben gemacht, es hat auch funktioniert ich würde nur gerne die Hintergründe für die unterschiedlichen Befehle kennen.
                                    VG Duffy
                                      Thomas Braun Most Active @Duffy last edited by
                                      @duffy sagte in mal wieder node und npm update:
                                      Das hängt damit zusammen dass der Doktor die falsche Behandlungsmethoden gewählt hat und der Patient jetzt nochmal mit dem richtigen Besteck operiert werden musste.
                                      Duffy 1 Reply Last reply Reply Quote 1
                                      • Duffy
                                        🙂 anschaulich formuliert, danke dafür.
                                        D.h. so sollte es nach wie vor klappen?
                                        iob stop
                                        iob fix
                                        iob nodejs-update
                                        iob upload all
                                        Gruß Duffy
                                          @duffy
                                          Ja, so sollte das funktionieren.
                                          Bzw. bei Updates innerhalb des Major Releases läuft es natürlich über das ordentliche System-Update mit.
                                          iob nodejs-update ist eigentlich nur bei Wechsel des Releases oder notwendigen Reparaturen der Pfade erforderlich.
                                          • Duffy
                                            Major Release
                                            Heisst das für mich das ich node-js 20.xx wenn ich aktuell Bookworm habe im Rahmen eines:
                                            sudo apt update && sudo apt full-upgrade
                                            das automatisch bekomme?
                                            4774
