    3. Tester
    4. iobroker Shutdown/Start unter Windows
    • Gaspode
      Gaspode last edited by Gaspode
      Ich habe jetzt mal ein Minimal System unter Windows auf den neuesten JS-Controller aktualisiert. Grundsätzlich läuft alles, aber das Log sieht etwas merkwürdig aus, oder sind diese "Already Running" meldungen normal?
      Sorry, wenn das schon Thema gewesen sein sollte, dann hab ich es übersehen.
      2024-05-24 08:42:58.450  - info: host.SmartHome5 iobroker.js-controller version 6.0.1 js-controller starting
      2024-05-24 08:42:58.451  - info: host.SmartHome5 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2024-05-24 08:42:58.452  - info: host.SmartHome5 hostname: SmartHome5, node: v18.20.3
      2024-05-24 08:42:58.452  - info: host.SmartHome5 ip addresses: XXXXXXXXXXXXXXXXXXXXXXXXXXXX
      2024-05-24 08:42:58.570  - info: host.SmartHome5 connected to Objects and States
      2024-05-24 08:42:58.575  - info: host.SmartHome5 added notifications configuration of host
      2024-05-24 08:42:58.735  - info: host.SmartHome5 4 instances found
      2024-05-24 08:42:58.738  - info: host.SmartHome5 starting 3 instances
      2024-05-24 08:42:58.811  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeCurrent"
      2024-05-24 08:42:58.818  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeNewest"
      2024-05-24 08:42:58.828  - info: host.SmartHome5 instance system.adapter.admin.0 started with pid 3656
      2024-05-24 08:42:58.829  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeNewestNext"
      2024-05-24 08:42:58.831  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmCurrent"
      2024-05-24 08:42:58.831  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmNewest"
      2024-05-24 08:42:58.833  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmNewestNext"
      2024-05-24 08:42:58.834  - info: host.SmartHome5 Some obsolete host states deleted.
      2024-05-24 08:42:59.582  - error: admin.0 (3656) admin.0 already running
      2024-05-24 08:42:59.583  - warn: admin.0 (3656) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-05-24 08:43:00.121  - error: host.SmartHome5 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-05-24 08:43:00.121  - info: host.SmartHome5 Restart adapter system.adapter.admin.0 because enabled
      2024-05-24 08:43:02.835  - info: host.SmartHome5 instance system.adapter.backitup.0 started with pid 11512
      2024-05-24 08:43:03.342  - error: backitup.0 (11512) backitup.0 already running
      2024-05-24 08:43:03.343  - warn: backitup.0 (11512) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-05-24 08:43:03.872  - error: host.SmartHome5 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-05-24 08:43:03.872  - info: host.SmartHome5 Restart adapter system.adapter.backitup.0 because enabled
      2024-05-24 08:43:06.826  - info: host.SmartHome5 instance system.adapter.discovery.0 started with pid 40380
      2024-05-24 08:43:07.322  - error: discovery.0 (40380) discovery.0 already running
      2024-05-24 08:43:07.323  - warn: discovery.0 (40380) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-05-24 08:43:07.852  - error: host.SmartHome5 instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-05-24 08:43:07.853  - info: host.SmartHome5 Restart adapter system.adapter.discovery.0 because enabled
      2024-05-24 08:43:30.223  - info: host.SmartHome5 instance system.adapter.admin.0 started with pid 26844
      2024-05-24 08:43:31.051  - info: admin.0 (26844) starting. Version 6.13.16 in C:/ioBroker/SmartHome5/node_modules/iobroker.admin, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
      2024-05-24 08:43:31.062  - info: admin.0 (26844) requesting all objects
      2024-05-24 08:43:31.204  - info: admin.0 (26844) received all objects
      2024-05-24 08:43:31.248  - info: admin.0 (26844) socket.io server listening on port 8191
      2024-05-24 08:43:31.249  - info: admin.0 (26844) http server listening on port 8191
      2024-05-24 08:43:31.249  - info: admin.0 (26844) Use link "http://127.0.0.1:8191" to configure.
      2024-05-24 08:43:33.966  - info: host.SmartHome5 instance system.adapter.backitup.0 started with pid 2380
      2024-05-24 08:43:34.465  - info: admin.0 (26844) ==> Connected system.user.admin from ::1
      2024-05-24 08:43:34.657  - info: backitup.0 (2380) starting. Version 2.11.0 in C:/ioBroker/SmartHome5/node_modules/iobroker.backitup, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
      2024-05-24 08:43:34.680  - info: backitup.0 (2380) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2024-05-24 08:43:37.946  - info: host.SmartHome5 instance system.adapter.discovery.0 started with pid 39616
      2024-05-24 08:43:38.571  - info: discovery.0 (39616) starting. Version 4.4.0 in C:/ioBroker/SmartHome5/node_modules/iobroker.discovery, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
      sigi234 mcm1957 2 Replies Last reply Reply Quote 0
      • sigi234
        sigi234 Forum Testing Most Active @Gaspode last edited by
        @gaspode sagte in Alpha Test js-controller Kiera (v6.0):
        Diese Meldungen habe ich schon ewig.
        • mcm1957
          mcm1957 @Gaspode last edited by
          @gaspode
          Ich hab die Meldungen auch- Ich hab sie bisher auf mein sehr zähes Windows System geschoben. Wenn sie allerdings auch nach einem sauberen Shutdown und mit viiiel Wartezeit od. Host Reboot kommen dann wär das m.E. ein issue wert. Ev. wird da beim Systemstart irgenein Status nicht sauber gesetzt. ZU diesbezüglichen Hypothesen kann aber Foxriver76 sicher mehr sagen bzw sagen ob da was gezielt (und wie) getestet werden kann - soll ja nicht jede Analyse gleich bei ihm landen.
          Gaspode 1 Reply Last reply Reply Quote 1
          • Gaspode
            Gaspode @mcm1957 last edited by
            @mcm1957 said in Alpha Test js-controller Kiera (v6.0):
            Ich hab jetzt nochmal ein wenig rum probiert. Ich hab die Meldung auch mit dem aktuellen JS-Controller, wenn ich "kurz" zuvor ioBroker gestoppt habe und "gleich" wieder starte. Ist mir noch nie aufgefallen. Node.js Prozesse gibt es zu dieser Zeit allerdings keine mehr.
            Evtl. hängt es damit zusammen, dass auch "iob status" nach dem Stoppen noch eine Zeit lang fälschlicherweise sagt, "obroker is running on this host."
            Hat also wohl wirklich nix mit dem neuen Controller zu tun. Ich behalte das mal im Hinterkopf und mache bei Gelegenheit noch ein paar Tests. ggfs. folgt dann auch ein Issue.
            • mcm1957
              @gaspode said in Alpha Test js-controller Kiera (v6.0):
              Ich tippe drauf, dass da was beim Shutdown unsauber abläuft und beim Start nicht wirklich bereinigt wird. Es betrifft (bei mir) ja nicht alle Adapter.
              Um 11:22 hab ich das System runtergefahren. Dabei wurde von 3 Adaptern (admin, backitup und notification manager) ein "unsauberer" shutdown mit nachfolgendem Restart gelogged.
              Und genau diese 3 Adapter haben beim Start ab 11:37 einen already running error gemeldet.
              @foxriver76
              Hast du da eine Idee dazu? Kann ich / wir da was testen um es weiter einzugrenzen?
              Auch wenn wahrscheinlich kein neues js-controlelr 6 issue ist könnte man es ev mit dem js-controller 6 fixen. Ist aber in jedem Fall eher cosmetic.
              Übrigends: Der js-controller logged scheinbar nicht, dass er den Befehl zum stoppen bekommen hat. Wär m.e. sinnvoll das im Log zu haben. Ich schreib dazu einen Feature Issue.
              v6.17.11
              22
              69
              Log-Größe: 26.8 KB
              Zeit
              debug
              Nachricht
              admin.0
              2024-05-24 11:42:36.689	info	==> Connected system.user.admin from ::1
              discovery.0
              2024-05-24 11:38:26.404	info	starting. Version 4.2.0 in C:/ioBroker/node_modules/iobroker.discovery, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
              host.Envy
              2024-05-24 11:38:24.894	info	instance system.adapter.discovery.0 started with pid 23076
              notification-manager.0
              2024-05-24 11:38:18.271	info	Starting notification manager ...
              2024-05-24 11:38:18.260	info	starting. Version 1.1.2 in C:/ioBroker/node_modules/iobroker.notification-manager, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
              host.Envy
              2024-05-24 11:38:16.979	info	instance system.adapter.notification-manager.0 started with pid 11636
              backitup.0
              2024-05-24 11:38:15.504	info	[iobroker] backup will be activated at 02:40 every 1 day(s)
              backitup.0
              2024-05-24 11:38:15.456	info	starting. Version 2.10.11 in C:/ioBroker/node_modules/iobroker.backitup, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
              admin.0
              2024-05-24 11:38:13.322	info	Use link "http://127.0.0.1:8081" to configure.
              admin.0
              2024-05-24 11:38:13.322	info	http server listening on port 8081
              admin.0
              2024-05-24 11:38:13.320	info	socket.io server listening on port 8081
              host.Envy
              2024-05-24 11:38:13.302	info	instance system.adapter.backitup.0 started with pid 1460
              admin.0
              2024-05-24 11:38:13.023	info	received all objects
              admin.0
              2024-05-24 11:38:12.213	info	requesting all objects
              admin.0
              2024-05-24 11:38:12.192	info	starting. Version 6.17.11 in C:/ioBroker/node_modules/iobroker.admin, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
              host.Envy
              2024-05-24 11:38:10.024	info	instance system.adapter.admin.0 started with pid 8660
              host.Envy
              2024-05-24 11:37:56.430	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
              ical.1
              2024-05-24 11:37:55.908	info	Terminated (NO_ERROR): Without reason
              host.Envy
              2024-05-24 11:37:54.547	info	Restart adapter system.adapter.discovery.0 because enabled
              host.Envy
              2024-05-24 11:37:54.547	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              discovery.0
              2024-05-24 11:37:54.012	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              discovery.0
              2024-05-24 11:37:54.011	error	discovery.0 already running
              host.Envy
              2024-05-24 11:37:52.741	info	instance system.adapter.discovery.0 started with pid 10408
              ical.1
              2024-05-24 11:37:50.889	info	All calenders could not be processed, Do not clean up events
              ical.1
              2024-05-24 11:37:50.888	warn	Error reading "http://11111.ics": Cannot read URL: "http://11111.ics"
              ical.1
              2024-05-24 11:37:50.888	warn	Error reading from URL "http://11111.ics"
              ical.1
              2024-05-24 11:37:50.661	info	starting. Version 1.15.0 in C:/ioBroker/node_modules/iobroker.ical, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
              host.Envy
              2024-05-24 11:37:48.837	info	instance system.adapter.ical.1 started with pid 16528
              host.Envy
              2024-05-24 11:37:48.829	info	instance scheduled system.adapter.ical.1 0,4 0,30 * * * *
              host.Envy
              2024-05-24 11:37:46.671	info	Restart adapter system.adapter.notification-manager.0 because enabled
              host.Envy
              2024-05-24 11:37:46.670	error	instance system.adapter.notification-manager.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              2024-05-24 11:37:46.126	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              2024-05-24 11:37:46.124	error	notification-manager.0 already running
              host.Envy
              2024-05-24 11:37:44.776	info	instance system.adapter.notification-manager.0 started with pid 14436
              host.Envy
              2024-05-24 11:37:42.774	info	Restart adapter system.adapter.backitup.0 because enabled
              host.Envy
              2024-05-24 11:37:42.774	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              backitup.0
              2024-05-24 11:37:42.250	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              backitup.0
              2024-05-24 11:37:42.249	error	backitup.0 already running
              host.Envy
              2024-05-24 11:37:40.733	info	instance system.adapter.backitup.0 started with pid 19664
              host.Envy
              2024-05-24 11:37:39.629	info	Restart adapter system.adapter.admin.0 because enabled
              host.Envy
              2024-05-24 11:37:39.629	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              admin.0
              2024-05-24 11:37:39.056	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              admin.0
              2024-05-24 11:37:39.054	error	admin.0 already running
              host.Envy
              2024-05-24 11:37:36.798	info	Some obsolete host states deleted.
              host.Envy
              2024-05-24 11:37:36.795	info	Delete state "system.host.Envy.versions.npmNewestNext"
              host.Envy
              2024-05-24 11:37:36.791	info	Delete state "system.host.Envy.versions.npmNewest"
              host.Envy
              2024-05-24 11:37:36.787	info	Delete state "system.host.Envy.versions.npmCurrent"
              host.Envy
              2024-05-24 11:37:36.781	info	instance system.adapter.admin.0 started with pid 12684
              host.Envy
              2024-05-24 11:37:36.774	info	Delete state "system.host.Envy.versions.nodeNewestNext"
              host.Envy
              2024-05-24 11:37:36.766	info	Delete state "system.host.Envy.versions.nodeNewest"
              host.Envy
              2024-05-24 11:37:36.728	info	Delete state "system.host.Envy.versions.nodeCurrent"
              host.Envy
              2024-05-24 11:37:36.419	info	starting 5 instances
              host.Envy
              2024-05-24 11:37:36.404	info	17 instances found
              host.Envy
              2024-05-24 11:37:35.648	info	added notifications configuration of host
              host.Envy
              2024-05-24 11:37:35.632	info	connected to Objects and States
              host.Envy
              2024-05-24 11:37:35.136	info	ip addresses: 10.17.2.100 fe80::3089:3ca1:e684:7494 10.17.2.16
              host.Envy
              2024-05-24 11:37:35.136	info	hostname: Envy, node: v20.13.1
              host.Envy
              2024-05-24 11:37:35.136	info	Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              host.Envy
              2024-05-24 11:37:35.133	info	iobroker.js-controller version 6.0.1 js-controller starting
              host.Envy
              2024-05-24 11:22:35.097	info	Restart adapter system.adapter.notification-manager.0 because enabled
              host.Envy
              2024-05-24 11:22:35.097	error	instance system.adapter.notification-manager.0 terminated with code 4294967295 ()
              host.Envy
              2024-05-24 11:22:34.914	info	Restart adapter system.adapter.backitup.0 because enabled
              host.Envy
              2024-05-24 11:22:34.914	error	instance system.adapter.backitup.0 terminated with code 4294967295 ()
              host.Envy
              2024-05-24 11:22:34.733	info	Restart adapter system.adapter.admin.0 because enabled
              host.Envy
              2024-05-24 11:22:34.732	error	instance system.adapter.admin.0 terminated with code 4294967295 ()
              sigi234 Gaspode 2 Replies Last reply Reply Quote 0
              • sigi234
                sigi234 Forum Testing Most Active @mcm1957 last edited by
                @mcm1957 sagte in Alpha Test js-controller Kiera (v6.0):
                Bei mir sind es einige mehr. War aber immer schon so. Beruhigt sich nach einiger Zeit wieder. Bis zum Neustart eben.
                host.SmartHome
                2024-05-24 11:58:49.508	error	instance system.adapter.upnp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:41.067	error	instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:37.231	error	instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:25.628	error	instance system.adapter.ecovacs-deebot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:22.100	error	instance system.adapter.vis-2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:16.992	error	instance system.adapter.parser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:13.106	error	instance system.adapter.tapo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:09.359	error	instance system.adapter.pollenflug.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:05.571	error	instance system.adapter.musiccast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:58:01.679	error	instance system.adapter.web.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:57.194	error	instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:53.440	error	instance system.adapter.jarvis.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:49.746	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:45.893	error	instance system.adapter.weather-warnings.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:42.774	error	instance system.adapter.alarm.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:32.892	error	instance system.adapter.socketio.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:29.354	error	instance system.adapter.ws.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:24.995	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:17.208	error	instance system.adapter.snmp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:12.895	error	instance system.adapter.lgtv.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:57:05.988	error	instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:57.522	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:50.507	error	instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:45.626	error	instance system.adapter.yamaha.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:42.406	error	instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:37.747	error	instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:32.874	error	instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:28.974	error	instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:24.950	error	instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:20.873	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:16.888	error	instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:13.251	error	instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:09.200	error	instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:56:05.239	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                host.SmartHome
                2024-05-24 11:55:52.252	error	instance system.adapter.vis-inventwo.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:52.143	error	instance system.adapter.sayit.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:52.042	error	instance system.adapter.ecovacs-deebot.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:51.928	error	instance system.adapter.vis-2.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:51.827	error	instance system.adapter.parser.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:51.724	error	instance system.adapter.tapo.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:51.540	error	instance system.adapter.pollenflug.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:51.400	error	instance system.adapter.musiccast.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:51.300	error	instance system.adapter.web.1 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:51.182	error	instance system.adapter.iot.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:51.081	error	instance system.adapter.jarvis.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.961	error	instance system.adapter.fb-checkpresence.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.853	error	instance system.adapter.weather-warnings.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.752	error	instance system.adapter.alarm.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.652	error	instance system.adapter.socketio.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.553	error	instance system.adapter.ws.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.447	error	instance system.adapter.web.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.347	error	instance system.adapter.snmp.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.250	error	instance system.adapter.lgtv.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.149	error	instance system.adapter.meross.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:50.050	error	instance system.adapter.cloud.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:49.944	error	instance system.adapter.alexa2.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:49.825	error	instance system.adapter.yamaha.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:49.697	error	instance system.adapter.tr-064.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:49.576	error	instance system.adapter.hm-rpc.1 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:49.471	error	instance system.adapter.hm-rega.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:49.363	error	instance system.adapter.hm-rpc.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:49.226	error	instance system.adapter.hue.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:49.091	error	instance system.adapter.backitup.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:48.983	error	instance system.adapter.email.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:48.883	error	instance system.adapter.javascript.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:48.747	error	instance system.adapter.history.0 terminated with code 4294967295 ()
                host.SmartHome
                2024-05-24 11:55:48.583	error	instance system.adapter.admin.0 terminated with code 4294967295 ()
                • sigi234
                  @sigi234
                  OK, aber auch diese haben einen "ungewöhnlichen" Existstatus beim Beenden.
                  Jupp, hat wahrscheinlich nix mit js-controller Kiera zu tun, ev. sollte man das abtrennen in einen Neuen Beitrag?
                  • mcm1957
                    mcm1957 @sigi234 last edited by
                    @sigi234 said in Alpha Test js-controller Kiera (v6.0):
                    @sigi234
                    Jaein.
                    Warten wir mal ab ob / was @Foxriver76 sagt. Wenn es ein js-controller Problem ist kann es ev. auch hier bleiben. Wenn wir mehr Suchdiskussion brauchen ists ev. extra besser. Aber im Prinzip ist im Moment wahrscheinlich alles geschrieben bis wer der den betreffenden Code gut kennt sagen kann was da los ist bzw. zu suchen wäre. Ist jedenfalls kein Einzelfall.
                    • Gaspode
                      Gaspode @mcm1957 last edited by Gaspode
                      Hmm, ich denke immer noch, dass da grundsätzlich was krumm ist unter Windows.
                      Versuch(t) mal folgendes bei gestartetem ioBroker:
                      iob stop
                      iob status
                      iob status
                      iob start
                      Bei mir antwortet "iob status" Nummer 1 "iobroker is running on this host.", obwohl keinerlei Node.js-Prozess auf dem Rechner läuft. Aufruf Nummer 2 liefert "iobroker is not running on this host.", wie es sein soll. Der nächste Start erfolgt dann bei mir sauber OHNE diese ADAPTER_ALREADY_RUNNING Meldungen.
                      2024-05-24 13:05:28.210  - info: host.SmartHome5 iobroker.js-controller version 6.0.1 js-controller starting
                      2024-05-24 13:05:28.211  - info: host.SmartHome5 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2024-05-24 13:05:28.211  - info: host.SmartHome5 hostname: SmartHome5, node: v20.13.1
                      2024-05-24 13:05:28.211  - info: host.SmartHome5 ip addresses: XXXXXXXXXXXXXXXXXXXXXXX
                      2024-05-24 13:05:28.335  - info: host.SmartHome5 connected to Objects and States
                      2024-05-24 13:05:28.339  - info: host.SmartHome5 added notifications configuration of host
                      2024-05-24 13:05:28.478  - info: host.SmartHome5 4 instances found
                      2024-05-24 13:05:28.479  - info: host.SmartHome5 starting 3 instances
                      2024-05-24 13:05:28.543  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeCurrent"
                      2024-05-24 13:05:28.548  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeNewest"
                      2024-05-24 13:05:28.558  - info: host.SmartHome5 instance system.adapter.admin.0 started with pid 31324
                      2024-05-24 13:05:28.559  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeNewestNext"
                      2024-05-24 13:05:28.560  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmCurrent"
                      2024-05-24 13:05:28.561  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmNewest"
                      2024-05-24 13:05:28.562  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmNewestNext"
                      2024-05-24 13:05:28.562  - info: host.SmartHome5 Some obsolete host states deleted.
                      2024-05-24 13:05:29.331  - info: admin.0 (31324) starting. Version 6.13.16 in C:/ioBroker/SmartHome5/node_modules/iobroker.admin, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
                      2024-05-24 13:05:29.343  - info: admin.0 (31324) requesting all objects
                      2024-05-24 13:05:29.479  - info: admin.0 (31324) received all objects
                      2024-05-24 13:05:29.523  - info: admin.0 (31324) socket.io server listening on port 8191
                      2024-05-24 13:05:29.523  - info: admin.0 (31324) http server listening on port 8191
                      2024-05-24 13:05:29.523  - info: admin.0 (31324) Use link "http://127.0.0.1:8191" to configure.
                      2024-05-24 13:05:32.566  - info: host.SmartHome5 instance system.adapter.backitup.0 started with pid 36456
                      2024-05-24 13:05:33.240  - info: backitup.0 (36456) starting. Version 2.11.0 in C:/ioBroker/SmartHome5/node_modules/iobroker.backitup, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
                      2024-05-24 13:05:33.261  - info: backitup.0 (36456) [iobroker] backup will be activated at 02:48 every 1 day(s)
                      2024-05-24 13:05:36.571  - info: host.SmartHome5 instance system.adapter.discovery.0 started with pid 32412
                      2024-05-24 13:05:37.209  - info: discovery.0 (32412) starting. Version 4.4.0 in C:/ioBroker/SmartHome5/node_modules/iobroker.discovery, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
                      Das verhält sich bei mir gleich mit Controller 5 und 6. also evtl. doch abtrennen, um das hier übersichtlicher zu halten?
                        Homoran Global Moderator Administrators @Gaspode last edited by
                        wenn gewünscht, bitte Link zum ersten abzutrennenden Post.
                        Gaspode 1 Reply Last reply Reply Quote 0
                        • Gaspode
                          Gaspode @Homoran last edited by
                          @homoran said in Alpha Test js-controller Kiera (v6.0):
                          Lass uns mal warten, ob und was @foxriver76 dazu meint.
                          Betroffen sind diese Beiträge:
                          https://forum.iobroker.net/post/1162260
                          https://forum.iobroker.net/post/1162264
                          https://forum.iobroker.net/post/1162266
                          https://forum.iobroker.net/post/1162267
                          https://forum.iobroker.net/post/1162311
                          https://forum.iobroker.net/post/1162316
                          https://forum.iobroker.net/post/1162317
                          https://forum.iobroker.net/post/1162327
                          https://forum.iobroker.net/post/1162329
                          https://forum.iobroker.net/post/1162355
                          foxriver76 Homoran 2 Replies Last reply Reply Quote 1
                          • foxriver76
                            foxriver76 Developer @Gaspode last edited by
                            @gaspode @Homoran gerne abtrennen, das ist alles Controller Shutdown unter Windows, was schon immer abrupt passiert ist, da bräuchte man mal Infos wie das überhaupt gestoppt wird von Usern normalerweise. Und ich habe da auch aktuell eher keinen Fokus drauf.
                              @gaspode Danke fpr die Liste, hat aber leider beim selektieren nicht geholfen, wenn ich im Auswahlmenü bin.
                              ich hoffe ich habe alles und nicht zu viel.
                              wie immer
                              ggf. provisorischen Threadtitel anpassen
                              • Gaspode
                                @homoran said in iobroker Shutdown unter Windowe:
                                Sieht gut aus, Danke.
                                • foxriver76
                                  foxriver76 Developer last edited by foxriver76
                                  Falscher Thread 😉
                                  • mcm1957
                                    mcm1957 @foxriver76 last edited by mcm1957
                                    -- obsoleter Text ---
                                    • Gaspode
                                      Hier geht es weiter:
                                      https://forum.iobroker.net/topic/75829
                                      @Homoran
                                      Ich denke, dieser Thread hier kann geschlossen werden. Wärst du so nett? Danke. 🙂
                                        @gaspode erledigt!
                                        1.0k
                                        1127
