    4. Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion
    • G
      Gaunt last edited by
      Moin,
      ich habe in meinem ZigbeeNetzwerk neuerdings eine Steckdose im Einsatz.
      TuYa TS011F @Amazon
      Allerdings bin ich mit dieser nicht besonders zufrieden, da diese nach ca. 2 Tagen sich verabschiedet hat und seitdem nicht mehr funktioniert.
      Die letzten Logmeldungen:
      	Zeile  3769: 2024-05-26 03:32:33.221  - error: zigbee2mqtt.0 (1877) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> ZDO - extRouteDisc - {"dstAddr":58704,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)' (expected '(0x00: SUCCESS)'))'
      	Zeile  8770: 2024-05-26 08:22:12.090  - error: zigbee2mqtt.0 (1877) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> ZDO - extRouteDisc - {"dstAddr":58704,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)' (expected '(0x00: SUCCESS)'))'
      	Zeile  9512: 2024-05-26 08:56:16.882  - error: zigbee2mqtt.0 (1877) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> ZDO - extRouteDisc - {"dstAddr":58704,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)' (expected '(0x00: SUCCESS)'))'
      	Zeile 11660: 2024-05-26 10:44:07.686  - error: zigbee2mqtt.0 (1877) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> ZDO - extRouteDisc - {"dstAddr":58704,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)' (expected '(0x00: SUCCESS)'))'
      	Zeile 12896: 2024-05-26 11:41:44.820  - error: zigbee2mqtt.0 (1877) Default response to 0xa4c138ee2956659f failed
      Aktuelle Meldung:
      Zeile 24008: 2024-05-26 19:35:21.475  - error: zigbee2mqtt.0 (2100) Default response to 0xa4c138ee2956659f failed
      	Zeile 24606: 2024-05-26 20:07:58.523  - error: zigbee2mqtt.0 (2100) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
      	Zeile 24611: 2024-05-26 20:08:11.142  - error: zigbee2mqtt.0 (2100) Default response to 0xa4c138ee2956659f failed
      	Zeile 24635: 2024-05-26 20:09:39.015  - error: zigbee2mqtt.0 (2100) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
      	Zeile 24655: 2024-05-26 20:10:45.705  - error: zigbee2mqtt.0 (2100) Default response to 0xa4c138ee2956659f failed
      Ich bekomme das Gerät ins Netzwerk hinein jedoch funktioniert es nicht korrekt. Schalter können nicht geschaltet werden (nur am Gerät). Die Strom- und Leistungsmessung funktioniert irgendwie. Ich hatte bei einem Strom von 0.03A und einer Spannung von 235V eine Leistung von 635W.
      Das ist inzwischen die dritte Steckdose welche ich testweise ausprobiere. Bisher hatte ich folgende bereits ohne Erfolg im Einsatz:
      Aqara Zigbee Steckdose @Amazon
      SURFOU Zigbee Steckdose
      Die Aqara Steckdose hat sich leider selbstständig und ungewollt nach einer zufälligen Zeit ausgeschaltet (Auto Off war deaktiviert. das wurde nach dem 1 aus überprüft) und das Verbraucher eingesteckt hat leider nicht funktioniert.
      Die Steckdose von Surfou hat auch nicht getan was sie sollte, da sind mir leider die Gründe nicht mehr bekannt.
      Kennt ihr diese Probleme und/oder konntet ihr sie lösen.
      Sind meine Einstellungen vom Zigbee2mqtt ggf fehlerhaft.
      Gibt es aktuelle Fehler im Adapter vom IOB welche das Problem erzeugen?
      Welche Zigbeesteckdosen habt ihr im Einsatz (gerne mit Verlinkung) und seit ihr mit diesen Steckdosen dann zufrieden und würdet diese weiter empfehlen?
      D crunchip 2 Replies Last reply Reply Quote 0
        Dragon @Gaunt last edited by
        @gaunt Gut, günstig und einfach zu beziehen, wären die Lidl Steckdosen, allerdings ohne Leistungsmessung. Falls du die benötigst müssten wir noch mal schauen...
        • crunchip
          crunchip Forum Testing Most Active @Gaunt last edited by
          @gaunt sagte in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
          Dazu könnte man erst etwas sagen, wenn die benötigten Informationen vorhanden wären.
          • Wintermute
            Wintermute last edited by
            Ich benutze neben den Tradfri-Dingern von Ikea noch die Nous A1Z (ZB https://www.amazon.de/NOUS-A1Z-Stromverbrauch-Verbrauchsmessung-Zigbee2MQTT/dp/B0054PSH0G), wenn ich Leistungsmessung brauche. Laufen bis jetzt ohne Probleme bei mir.
            arteck G 2 Replies Last reply Reply Quote 0
              arteck Developer Most Active @Wintermute last edited by
              @wintermute welcher koordiantor und welche Firmwareversion ?
              G Wintermute 2 Replies Last reply Reply Quote 0
              • G
                Gaunt @arteck last edited by
                @arteck
                Das ist mein Daten aus dem Zigbee2MQTT
                Zigbee2MQTT-Version: 1.37.1 commit: cda867a3
                Coordinator-Typ: zStack3x0
                Coordinator-Version: 20210708
                Frontend-Version: 0.6.167
                Zigbee Herdsman Konverter Version: 19.37.2
                Zigbee Herdsman Version: 0.46.6
                Zigbee2MQTT Adapter IOB: 2.13.6
                Ich verwende den Sonoff Zigbee 3.0 USB Dongle Plus Basierend auf dem CC2652P und CP2102(N).
                Mit meinen Ledvance Leuchten, Sonoff und Aqara Temperatur/Motion Sensoren funktioniert das prima. Nur die Steckdosen wollen scheinbar nicht so richtig 🤣
                crunchip arteck 2 Replies Last reply Reply Quote 0
                • Wintermute
                  Wintermute @arteck last edited by
                  @arteck sagte in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
                  Ein Conbee II mit dem dconz-Adapter.
                  • G
                    Gaunt @crunchip last edited by
                    @crunchip said in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
                    Hier ist einmal der Auszug aus der configuration.yaml den networkkey, panid, ext Pan id und die Geräte am ende habe ich mal rausgenommen um es übersichtlicher zu machen.
                    Gibt es noch weitere Einstellungen die relevant sind?
                    homeassistant: false
                    frontend: true
                    mqtt:
                      base_topic: zigbee2mqtt
                      server: mqtt://127.0.0.1:1884
                    serial:
                      port: >-
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_521bfe7ad08bed1194da7b7937e930e3-if00-port0
                    advanced:
                      homeassistant_legacy_entity_attributes: false
                      legacy_api: false
                      legacy_availability_payload: false
                      cache_state: false
                      output: json
                      log_syslog:
                        app_name: Zigbee2MQTT
                        eol: /n
                        host: localhost
                        localhost: localhost
                        path: /dev/log
                        pid: process.pid
                        port: 514
                        protocol: udp4
                        type: '5424'
                      last_seen: ISO_8601_local
                    device_options:
                      legacy: false
                      availability: true
                    devices:
                    Die Darstellung der Anwesenheit der Geräte (egal ob Batterie oder Stromversorgt) funktioniert auch nicht immer korrekt. aber da wollte ich mich bei anderer Gelegenheit mal mit beschäftigen 🙂
                    • G
                      Gaunt @Dragon last edited by
                      @dragon said in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
                      Das klingt interessant. ich habe die mal bei Lidl online gerade angesehen. Laut Webseite gibt es diese im 3er Packet mit Leistungsmessung. Als einzelpacket nur ohne Leistungmessung. Die mit Messung sind sogar im Stückpreis geringer.
                      Hier der Link zu diesen:
                      3er SmartPlug Silvercrest
                      • G
                        Gaunt @Wintermute last edited by
                        @wintermute said in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
                        Die Ikea Tradfri sind mir von der Bauform zu groß da würde ich mir zu viel Platz um die Steckdosen . Aber die Tretakt haben eine gute Größe. die werde ich auch mal in meine weiteren Test mit einbeziehen.
                        Die Nous Geräte habe ich auch schon gesehen. Von diesen habe ich die Wifi Version im Einsatz und bin mit diesen nicht so wirklich zufrieden. Die Funktionieren technisch jedoch summen die Steckdosen im 50Hz takt und das in einer Lautstärke, das man es im Schlafzimmer nicht störend ist, jedoch wahrnehmbar.
                        Summen deine Steckdosen in der Zigbee version von Nous auch?
                        Sonst würde ich diese auch mal testen
                        • crunchip
                          crunchip Forum Testing Most Active @Gaunt last edited by crunchip
                          @gaunt bis auf den Adapter nicht auf aktuellem/neusten Stand, vor allem die Firmware
                          • G
                            @crunchip
                            Alles klar, das ist natürlich doof und durchaus eine Mögliche Ursache der Probleme. Dann werde ich mich mal dran machen und die Firmware aktualisieren. Wenn du eine gute Verlinkung hast wie ich die Firmware der Geräte hochziehen kann wäre ich dir dankbar. Ich mache mich sonst selber mal auf die Suche wie das funktioniert.
                            • G
                              @crunchip ok das habe ich geschafft . Jetzt ist die Version auf 20230507. Das ist die neuste die ich gefunden habe.
                              Mal gucken wie sich die Geräte jetzt verhalten.
                                Die A1Z habe ich auch. Passen die zusätzlich gelieferten Werte nicht so ganz. Bin mir grad nicht sicher, aber entweder Leistung oder Strom lieferte völlig konfuse Werte. Ich meine es war die Stromstärke die nicht passte.
                                  arteck Developer Most Active @Gaunt last edited by
                                  20210708
                                  der ist zu alt.. flash den mal auf was aktuelles
                                  • crunchip
                                    crunchip Forum Testing Most Active @arteck last edited by
                                    @arteck hat er doch schon, siehe 2 Post davor
                                    • Duffy
                                      Duffy @Gaunt last edited by
                                      @gaunt
                                      Funktioniert die Steckdose jetzt?
                                      • G
                                        Gaunt @Duffy last edited by
                                        @duffy
                                        Moin,
                                        ich habe jetzt die aktuelleste Version auf dem Stick installiert.
                                        Im Einsatz habei ch bisher die Steckdose von Nous, welche bisher ausreichend gut funktioniert.
                                        Die Leistungsmessung funktioniert und Messdaten für Strom und Spannung und Leistung passen zusammen. Das ist schonmal gut, und besser als mit den alten Steckdosen.
                                        etwas verwirrt bin ich noch über die Häufigkeit der Übertragung der Messdaten bei Stromverbrauch:
                                        Da wundert mich der Zeitverlauf z.B. das um 18:38 bis bei 103 W gewesen ist und erst um 18:55 auf der gleichen Schwellwert gewesen hin.
                                        Ich werde mit einem anderen Gerät mal überprüfen ob das realistische ist. Aber im groben und ganzen ist mit dieser Steckdose (und dem Update) die Funktion schon deutlich besser.
                                        Ich habe jetzt zusätzlich noch die SURFOU Zigbee Steckdose hier liegen und werde diese nochmal prüfen. Ggf ist da ja jetzt ein besseres Ergebnis. Ikea konnte ich leider noch nicht testen. Und gegen die Steckdose von Silvercrest habe ich mich doch gegen entschieden da diese etwas schlechtere Reichweite haben sollen.
                                        • Duffy
                                          Duffy @Gaunt last edited by Duffy
                                          @gaunt
                                          Werde dann wohl auch mal ei n Update auf den Stick spielen.
                                          Ich habe 3 Aqara Steckdosen aber die Spannungsanzeige schwankt, je nach Dose zwischen 224 und 229 Volt.
                                          Gibt es einen Weg das zu kalibrieren wie es auch bei Tasmota möglich ist?
                                          VG
                                          • G
                                            @duffy
                                            Ja in den geräten unter Einstellungen gibt es was zum kalibrieren.
                                            Kann später mal nen Screenshot reinstellen.
                                            3077
