    5. Lüftersteuerung funktioniert nicht
    • G
      gluecksmann last edited by
      var Luftreiniger_oben;
      on({ id: 'zigbee.0.00158d0008ab28bc.opened' /* Is open */, change: 'ne' }, async (obj) => {
        let value = obj.state.val;
        if (getState('zigbee.0.00158d0008ab28bc.opened').val == true) {
          Luftreiniger_oben = getState('philips-air.1.control.power').val;
          setState('philips-air.1.control.power' /* Power */, false);
        } else {
          setState('philips-air.1.control.power' /* Power */, Luftreiniger_oben);
      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
      Hallo, ich habe dieses Script schon einmal luaffähig da. Habe aber sowohl Luftriniger als auch Fensterkontakt doppelt. Also dachte ich ich ändere eben die Komponenten und es läuft. Aber nix. Jemand eine Idee?
        paul53 @gluecksmann last edited by
        @gluecksmann
        Weshalb zeigst du nicht das Blockly?
        • G
          gluecksmann @paul53 last edited by
          Weil ich bislang imme angemault wurde wenn ich das gemacht habe...
            <variables>
              <variable id="ipxhv:mW=fGe;}a1[zxs">Lufttreiniger Zustand</variable>
            </variables>
            <block type="on" id=";-Kgs.@y(q%C-?)+a}n~" x="-2012" y="-863">
              <field name="OID">zigbee.0.00158d0006d30e97.opened</field>
                <block type="controls_if" id="YS*_n/I@{iX*15G9NSv~">
                    <block type="logic_compare" id="}u[P^bFzMF8:{+[Lf:.E">
                      <field name="OP">EQ</field>
                        <block type="get_value" id="MkA7;.taf|KI3%bJM}Wp">
                        <block type="logic_boolean" id=",9U^aOXyxIPbssu@c^om">
                    <block type="variables_set" id="xw8#_#tu)i|n1KS;kV]3">
                      <field name="VAR" id="ipxhv:mW=fGe;}a1[zxs">Lufttreiniger Zustand</field>
                        <block type="get_value" id="4:pl[Xd1r8Q^r#`ArTdg">
                          <field name="OID">philips-air.0.control.power</field>
                        <block type="control" id="23hyS4nX40{u|mD@%e65">
                          <field name="OID">alexa2.0.Echo-Devices.d45170c55cb94b44aa6bbdfd2eb11f61.Commands.speak</field>
                            <block type="text" id="BBtY-gka`Qa.IUj-jmC;">
                              <field name="TEXT">Luftreiniger wurde ausgeschaltet</field>
                            <block type="control" id="PKE):[;F:93Z]wN7y=_l">
                                <block type="logic_boolean" id="]4h;6!H.D]iu(A|T=F2u">
                  <statement name="ELSE">
                    <block type="control" id="(`y*IO6Cy$VzWeMOhGgm">
                        <block type="variables_get" id="N%2AIn]8y9fAj/5)}w1u">
                        <block type="control" id="RO?{G;7kg[{qS8qdO,5/">
                            <block type="text" id="_{,sBi^WY*0%$aoE$!EN">
                              <field name="TEXT">alter Zustand wurde wiederhergestellt</field>
            @gluecksmann sagte: wenn ich das gemacht habe...
            Poste das Bild (Snipping tool).
            • G
                paul53 @gluecksmann last edited by paul53
                @gluecksmann
                "philips-air.1.control.power" ist vom Typ "boolean"? Dann sollte es funktionieren.
                Besser:
                • G
                  Sorry, falsches Script gewesen .. das läuft ja...hier das das nicht geht...
                    @gluecksmann sagte: hier das das nicht geht...
                    Das sollte es aber, wenn "philips-air.1.control.power" vom Typ "boolean" ist.
                    Setze die Variable auch bei Skriptstart, da sie sonst undefined ist, wenn das Skript bei offenem Fenster gestartet wird.
                    • G
                      In deinem Beispiel hast die Variable zweimal gesetzt. Ist das richtig?
                        @gluecksmann sagte: hast die Variable zweimal gesetzt. Ist das richtig?
                        Ja, einmal bei Skriptstart und einmal beim Öffnen.
                        357
