    4. InfluxDB verbindet sich nicht mehr mit IOB
      michihorn last edited by
      Hallo, über Monate läuft influxdb.1 auf meinem Rasp4 ohne zu mucken
      nun verbindet sich der IOB Adapter nicht mehr. Offensichtlich läuft influx jedoch.
      Folgende Fehlermeldung:
      	Zeit
      debug
      Nachricht
      influxdb.0
      2024-05-30 15:25:20.296	error	Error: connect ECONNREFUSED 192.168.178.144:8086
      influxdb.0
      2024-05-30 15:25:20.290	info	Influx DB Version used: 1.x
      influxdb.0
      2024-05-30 15:25:20.290	info	Connecting http://192.168.178.144:8086/ ...
      influxdb.0
      2024-05-30 15:25:10.283	error	Error: connect ECONNREFUSED 192.168.178.144:8086
      influxdb.0
      2024-05-30 15:25:10.277	info	Influx DB Version used: 1.x
      influxdb.0
      2024-05-30 15:25:10.276	info	Connecting http://192.168.178.144:8086/ ...
      influxdb.0
      2024-05-30 15:25:00.275	error	Error: connect ECONNREFUSED 192.168.178.144:8086
      influxdb.0
      2024-05-30 15:25:00.270	info	Influx DB Version used: 1.x
      influxdb.0
      2024-05-30 15:25:00.269	info	Connecting http://192.168.178.144:8086/ ...
      influxdb.0
      2024-05-30 15:24:50.268	error	Error: connect ECONNREFUSED 192.168.178.144:8086
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
      Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
      Active: active (running) since Thu 2024-05-30 15:20:34 CEST; 708ms ago
      Docs: man:influxd(1)
      Main PID: 20097 (influxd)
      Tasks: 10 (limit: 8754)
      CPU: 1.121s
      CGroup: /system.slice/influxdb.service
      └─20097 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
      May 30 15:20:38 rp4 influxd[20097]: run: open server: open service: Stat(): stat /usr/share/collectd/types.db: no such file or directory
      May 30 15:20:38 rp4 systemd[1]: influxdb.service: Main process exited, code=exited, status=1/FAILURE
      May 30 15:20:38 rp4 systemd[1]: influxdb.service: Failed with result 'exit-code'.
      May 30 15:20:38 rp4 systemd[1]: influxdb.service: Consumed 6.457s CPU time.
      May 30 15:20:39 rp4 systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 1457.
      May 30 15:20:39 rp4 systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
      May 30 15:20:39 rp4 systemd[1]: influxdb.service: Consumed 6.457s CPU time.
      May 30 15:20:39 rp4 systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.127795Z lvl=info msg="InfluxDB starting" log_id=0pUQP4ql000 version=1.6.7~rc0 branch=unknown commit=unknown
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.127857Z lvl=info msg="Go runtime" log_id=0pUQP4ql000 version=go1.15.9 maxprocs=4
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.140744Z lvl=info msg="Using data dir" log_id=0pUQP4ql000 service=store path=/var/lib/influxdb/data
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.140819Z lvl=info msg="Compaction settings" log_id=0pUQP4ql000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_burst_bytes=50331648
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.140847Z lvl=info msg="Open store (start)" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open op_event=start
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.149698Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/159/000000012-000000002.tsm id=0 duration=1.545>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.151568Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/160/000000012-000000002.tsm id=0 duration=2.401>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.152475Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/157/000000012-000000002.tsm id=0 duration=5.795>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.156788Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/155/000000012-000000002.tsm id=0 duration=0.978>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.371897Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/157>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.372562Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/159>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.374130Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/158/000000012-000000002.tsm id=0 duration=1.196>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.375932Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/156/000000012-000000002.tsm id=0 duration=1.766>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.376044Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/160>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.385857Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/161/000000004-000000001.tsm id=3 duration=1.796>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.389731Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/161/000000001-000000001.tsm id=0 duration=5.663>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.390556Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/155>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.394757Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/161/000000002-000000001.tsm id=1 duration=8.695>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.397979Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/161/000000003-000000001.tsm id=2 duration=0.900>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.399120Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/152/000000012-000000002.tsm id=0 duration=1.441>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.398559Z lvl=info msg="Reading file" log_id=0pUQP4ql000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/161/_00017.wal size=10538679
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.511177Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/156>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.512951Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/45/000000008-000000002.tsm id=0 duration=0.356ms
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.523000Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/158>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.525682Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/2/000000005-000000002.tsm id=0 duration=0.418ms
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.562564Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/152>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.564864Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/27/000000008-000000002.tsm id=0 duration=0.415ms
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.650443Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/45 d>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.652121Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/36/000000008-000000002.tsm id=0 duration=0.490ms
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.705460Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/27 d>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.707294Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/18/000000007-000000002.tsm id=0 duration=0.311ms
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.774709Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/2 du>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.776953Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/72/000000008-000000002.tsm id=0 duration=0.506ms
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.892576Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/18 d>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.892681Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/36 d>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.894331Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/63/000000007-000000002.tsm id=0 duration=0.520ms
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.894331Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/54/000000007-000000002.tsm id=0 duration=0.306ms
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.928088Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/72 d>
      May 30 15:20:39 rp4 influxd[20110]: ts=2024-05-30T13:20:39.930409Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/9/000000007-000000002.tsm id=0 duration=0.683ms
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.012438Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/54 d>
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.012658Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/63 d>
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.014007Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/90/000000006-000000002.tsm id=0 duration=0.499ms
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.014008Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/81/000000008-000000002.tsm id=0 duration=0.510ms
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.028339Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/9 du>
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.031495Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/collectd/autogen/99/000000004-000000002.tsm id=0 duration=0.643ms
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.125759Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/81 d>
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.127976Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/91/000000002-000000002.tsm id=0 duration=0.384ms
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.142543Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/90 d>
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.144121Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/10/000000049-000000002.tsm id=0 duration=0.280ms
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.181592Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/collectd/autogen/99 d>
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.183025Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/100/000000002-000000002.tsm id=0 duration=0.371ms
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.269448Z lvl=info msg="Opened shard" log_id=0pUQP4ql000 service=store trace_id=0pUQP4u0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/91 d>
      May 30 15:20:40 rp4 influxd[20110]: ts=2024-05-30T13:20:40.271303Z lvl=info msg="Opened file" log_id=0pUQP4ql000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/109/000000001-000000001.tsm id=0 duration=0.338ms
      pi@rp4:~ $
      Wo kann der Fehler liegen?
      Michael
        Thomas Braun Most Active @michihorn last edited by Thomas Braun
        @michihorn
        Schau dir das 'große Ganze' an
        iob diag
        Und zu influxdb auch noch
        sudo apt update
        apt policy influx*
          michihorn @Thomas Braun last edited by michihorn
          iob diag
          v.2024-05-22
          Static hostname: rp4
          Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
          Kernel: Linux 6.1.21-v8+
          Architecture: arm64
          Installation: native
          Kernel: aarch64
          Userland: 64 bit
          Timezone: Europe/Berlin (CEST, +0200)
          User-ID: 1000
          Display-Server: false
          Boot Target: multi-user.target
          Pending OS-Updates: 0
          Pending iob updates: 3
          Nodejs-Installation:
          /usr/bin/nodejs v18.20.3
          /usr/bin/node v18.20.3
          /usr/bin/npm 10.7.0
          /usr/bin/npx 10.7.0
          /usr/bin/corepack 0.28.0
          Recommended versions are nodejs 18.20.3 and npm 10.7.0
          MEMORY:
          total used free shared buff/cache available
          Mem: 7.8G 1.2G 5.4G 1.0M 1.2G 6.4G
          Swap: 99M 0B 99M
          Total: 7.9G 1.2G 5.5G
          Active iob-Instances: 14
          Active repo(s): beta
          ioBroker Core: js-controller 5.0.19
          admin 6.17.6
          ioBroker Status: iobroker is running on this host.
          Objects type: jsonl
          States type: jsonl
          • system.adapter.admin.0 : admin : rp4 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          Objects: 4082
          States: 3388
          Size of iob-Database:
          14M /opt/iobroker/iobroker-data/objects.jsonl
          2.3M /opt/iobroker/iobroker-data/states.jsonl
          apt policy influx*:
          pi@rp4:~ $ apt policy influx*
          influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1+b5
          Version table:
          1.6.7~rc0-1+b5 500
          500 http://deb.debian.org/debian bullseye/main arm64 Packages
          influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
          influxdb:
          Installed: 1.6.7~rc0-1+b5
          Version table:
          *** 1.6.7~rc0-1+b5 500
          100 /var/lib/dpkg/status
          pi@rp4:~ $ ~
          Update:
          pi@rp4:~ $ sudo apt update
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 https://packages.grafana.com/oss/deb stable InRelease
          Get:7 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
          Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
          Fetched 17.1 kB in 3s (6,353 B/s)
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          List Instances:
          pi@rp4:~ $ iob list instances
          • system.adapter.backitup.0 : backitup : rp4 - enabled
          • system.adapter.history.0 : history : rp4 - enabled
          • system.adapter.hm-rega.0 : hm-rega : rp4 - enabled
          • system.adapter.hm-rpc.0 : hm-rpc : rp4 - enabled, port: 0
          • system.adapter.hm-rpc.2 : hm-rpc : rp4 - enabled, port: 0
          • system.adapter.influxdb.0 : influxdb : rp4 - enabled, port: 8086
          • system.adapter.javascript.0 : javascript : rp4 - enabled
          • system.adapter.mqtt-client.0 : mqtt-client : rp4 - enabled, port: 3002
          • system.adapter.mqtt.0 : mqtt : rp4 - enabled, port: 3003, bind: 0.0.0.0
          • system.adapter.smartmeter.0 : smartmeter : rp4 - enabled
          • system.adapter.smartmeter.1 : smartmeter : rp4 - enabled
          • system.adapter.tuya.0 : tuya : rp4 - enabled
          • instance is alive
            @michihorn
            Mit influxdb 1.6.7~rc0-1+b5 hast du da was recht altes aus dem debian-Repo laufen.
            Ich bin eigentlich ein Freund davon die distributions-eigenen Repos zu verwenden, es könnte hier aber vielleicht die Version von influx direkt ( 1.8.10-1) helfen.
              @thomas-braun kann man sudo apt upgrade rückgängig machen?
              Offenbar scheint beim Upgrade was daneben gelaufen zu sein. Ein Backup-Speicher läuft einwandfrei
                @michihorn sagte in InfluxDB verbindet sich nicht mehr mit IOB:
                Kommt ganz darauf an. Was haste denn jetzt genau wie gemacht?
                  @thomas-braun sudo apt update und dann sudo apt upgrade, seit dem klappt der influx-adapter nicht mehr
                    @michihorn
                    influxdb neugestartet?
                    Und welche Versionen haste jetzt drin?
                    apt policy influx*
                      Meldungen?
                        @thomas-braun alles noch wie im ersten post.
                        Aktuell läuft das Backup.
                        Kümmere mich nach meinem urlaub wieder drum.
                          Das kann ja nicht sein.
                          influxdb-adapter
                          173
