    5. Brauche Hilfe bei Anrufer Ansage
    • WUCHTTIGER
      WUCHTTIGER last edited by Homoran
      Re: [Vorlage] Simple Anrufer-Ansage via Alexa/tr-064
      Das Script läuft an ohne Fehler. Jedoch wenn ein Anruf reinkommt werden folgende Fehler rausgeschmissen.
      Wie kann ich das reparieren? Ich wäre Euch dankbar für Eure Hilfe oder einen funktionierenden Code 😉
      31.5.2024, 13:49:05.347	[error]: javascript.0 (5076) script.js.common.ANRUFER_ANSAGE_: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      31.5.2024, 13:49:05.348	[error]: javascript.0 (5076) script.js.common.ANRUFER_ANSAGE_: Please disable that setting or use "getState" with a callback, e.g.: getState('tr-064.0.callmonitor.inbound.callee', (err, state) => { ... });
      31.5.2024, 13:49:05.359	[error]: javascript.0 (5076)     at tellMeWhoCalls (script.js.common.ANRUFER_ANSAGE_:14:63)
      31.5.2024, 13:49:05.360	[error]: javascript.0 (5076)     at Object.<anonymous> (script.js.common.ANRUFER_ANSAGE_:66:9)
      31.5.2024, 13:49:09.347	[error]: javascript.0 (5076) script.js.common.ANRUFER_ANSAGE_: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      31.5.2024, 13:49:09.348	[error]: javascript.0 (5076) script.js.common.ANRUFER_ANSAGE_: Please disable that setting or use "getState" with a callback, e.g.: getState('tr-064.0.callmonitor.inbound.callee', (err, state) => { ... });
      31.5.2024, 13:49:09.354	[error]: javascript.0 (5076)     at tellMeWhoCalls (script.js.common.ANRUFER_ANSAGE_:14:63)
      31.5.2024, 13:49:09.355	[error]: javascript.0 (5076)     at Object.<anonymous> (script.js.common.ANRUFER_ANSAGE_:61:9)
        Homoran Global Moderator Administrators @WUCHTTIGER last edited by
        @wuchttiger sagte in Brauche Hilfe bei Anrufer Ansage:
        Das Script
        und warum zeigst du es nicht?
        WUCHTTIGER 1 Reply Last reply Reply Quote 0
        • WUCHTTIGER
          WUCHTTIGER @Homoran last edited by
          @homoran Das Script war im original Thread zu sehen, deswegen habe ich es nicht erneut gepostet. Hatte nur auf Empfehlung hin einen neuen Thread eröffnet, weil der originale schon etwas älter war.
          Anbei der Code, welche ich nutze
          //* Insert own numbers with description
          const numbers = {
              '01234512345': 'privat',
              '01234522222': 'Büro'
          function tellMeWhoCalls(sayattention) {
              let curtime = new Date();
              //* not between 21pm and 7am UTC
              if(curtime.getHours() < 7 || curtime.getHours() > 21) {
                  return;
              let targ = getState('tr-064.0.callmonitor.inbound.callee').val;
              let src = getState('tr-064.0.callmonitor.inbound.caller').val;
              let srcName = getState('tr-064.0.callmonitor.inbound.callerName').val;
              let targName = numbers[targ];
              if(!targName) {
                  targName = 'unbekannt';
              let text = (sayattention ? 'Achtung! ' : '') + 'Anruf für ' + targName + ' von ';
              if(srcName) {
                  text += srcName;
              } else if(src) {
                  text += '<say-as interpret-as="digits">' + src + '</say-as>';
              } else {
                  text += 'unbekannter Nummer';
              text += '.';
              text = '<speak>' + text + '</speak>';
              //* replace XXXXX by your echo device id and add further lines for more devices
              setState('alexa2.0.Echo-Devices.XXXXXXX.Commands.ssml', text);
              if(targName === 'privat') {
                  //* replace YYYYYY by your echo device id or delete this part if you don't need it
                  setState('alexa2.0.Echo-Devices.YYYYYYYY.Commands.ssml', text);
          let ringInterval = null;
          on({id: 'tr-064.0.callmonitor.ringing', change: 'ne'}, function(obj) {
              if(obj.state.val !== true) {
                  //* no longer ringing
                  if(ringInterval) {
                      clearInterval(ringInterval);
                  return;
              if(ringInterval) {
              //* repeat caller anouncement each 10 secs
              ringInterval = setInterval(function() {
                  tellMeWhoCalls();
              }, 10000);
              //* first time add "Achtung!" in front of the text
              setTimeout(function() {
                  tellMeWhoCalls(true);
              }, 1000);
            paul53 @WUCHTTIGER last edited by
            @wuchttiger sagte: because the adapter setting "Do not subscribe to all states on start" is enabled.
            Nimm in der Instanz-Konfiguration den Haken raus!
            WUCHTTIGER 2 Replies Last reply Reply Quote 0
            • WUCHTTIGER
              WUCHTTIGER @paul53 last edited by
              @paul53 Danke für deine schnelle Antwort. Ich gehe davon aus, dass du die TR-064 Instanz meinst.
              Aber welcher Haken ist das ?
              • WUCHTTIGER
                @paul53 Habe es gefunden. Vielen Dank für den Tipp. Es war in der Java Script Instanz.
                  paul53 @WUCHTTIGER last edited by paul53
                  @wuchttiger sagte: dass du die TR-064 Instanz meinst.
                  Nein, die Javascript-Instanz.
