    5. (gelöst) javascript v8.3.1 - Umbau request method DELETE
      stenmic last edited by stenmic
      Moin,
      ich nutze folgenden code den ich jetzt wegen dem request umbauen möchte.
      var requestDelete = require('request');
      var options = {
          url: 'http://192.168.xxx.xxx/server/files/gcodes/' + String(getState("0_userdata.0.3D-Drucker_Nextion.Loesche_Job").val),
          method: 'DELETE'
      requestDelete(options, function  (error, response, body) {
          log('error: ' + error);
          log('response: ' + JSON.stringify(response));
          log('body: ' + body);
      leider hab ich keine Ahnung wie 🤕
        MCU @stenmic last edited by MCU
        @stenmic
        //var requestDelete = require('request');
        var options = {
            method: 'DELETE'
        httpGet(options, function  (error, response) {
            log('body: ' + response.data);
          stenmic @MCU last edited by stenmic
          @mcu sagte in javascript v8.3.1 - request method DELETE:
          @stenmic
          var options = {
              method: 'DELETE'
          danke, aber es geht leider nicht (eventuell wegen dem "DELETE")
          javascript.0 2024-06-01 16:13:12.470	error	at process.processImmediate (node:internal/timers:476:21)
          javascript.0 2024-06-01 16:13:12.470	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
          javascript.0 2024-06-01 16:13:12.470	error	at Object.<anonymous> (script.js.3D-Drucker.Printjob:34:11)
          javascript.0 2024-06-01 16:13:12.470	error	at httpGet (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1183:20)
          javascript.0 2024-06-01 16:13:12.470	error	at getHttpRequestConfig (/opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:151:21)
          javascript.0 2024-06-01 16:13:12.469	error	at new NodeError (node:internal/errors:405:5)
          javascript.0 2024-06-01 16:13:12.470	error	at delete2 (script.js.3D-Drucker.Printjob:11:5)
          javascript.0 2024-06-01 16:13:12.470	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1399:38)
          javascript.0 2024-06-01 16:13:12.470	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8489:62)
          javascript.0 2024-06-01 16:13:12.469	error	script.js.3D-Drucker.Printjob: TypeError [ERR_INVALID_URL]: Invalid URL
          javascript.0 2024-06-01 16:13:12.469	error	at new URL (node:internal/url:676:13)
            @stenmic Und so?
            let url = 'http://192.168.xxx.xxx/server/files/gcodes/' + String(getState("0_userdata.0.3D-Drucker_Nextion.Loesche_Job").val);
            var options = {
                 method: 'DELETE'
            httpGet(url , options, function  (error, response) {
            • haus-automatisierung
              haus-automatisierung Developer Most Active @MCU last edited by
              @mcu Delete gibts aktuell nicht. Muss man per axios o.ä. selbst implementieren.
              Bitte in die Doku schauen und keine Parameter raten. Das müsste schon rot unterstrichen werden wenn man ein Objekt als ersten Parameter reingibt
              M S Homoran 3 Replies Last reply Reply Quote 0
                MCU @haus-automatisierung last edited by
                @haus-automatisierung Axios
                const axios = require('axios');
                const url = 'http://192.168.xxx.xxx/server/files/gcodes/' + String(getState("0_userdata.0.3D-Drucker_Nextion.Loesche_Job").val);
                axios.delete(url)
                    .then(response => {
                        console.log('response: ' + JSON.stringify(response.data));
                    .catch(error => {
                        console.log('error: ' + error);
                        if (error.response) {
                            console.log('response: ' + JSON.stringify(error.response.data));
                S 1 Reply Last reply Reply Quote 2
                  stenmic @haus-automatisierung last edited by stenmic
                  @haus-automatisierung sagte in javascript v8.3.1 - request method DELETE:
                  kein Problem, er versucht wenigstens mir zu helfen.
                    axios.delete(url)
                        .then(response => {
                        .catch(error => {
                    PERFEKT!!!
                    Danke, so gehts 👌
                      Homoran Global Moderator Administrators @haus-automatisierung last edited by
                      @haus-automatisierung sagte in (gelöst) javascript v8.3.1 - request method DELETE:
                      wie bereits in mehreren Threads erwähnt, hiesige User sind damit überfordert!
                        haus-automatisierung Developer Most Active @Homoran last edited by
                        @homoran Mh? @MCU hat doch direkt danach die Lösung geteilt. Bin nur am Smartphone nebenbei unterwegs und kann hier schlecht Code tippen. War nur ein Hinweis… und hat ja scheinbar geholfen?
                          klar, hätte aber dem Hilfesuchenden nicht geholfen. @mcu hat dann auf axios umgebaut, was ein c&p user auch mit Doku nicht kann.
                            @homoran sagte in (gelöst) javascript v8.3.1 - request method DELETE:
                            Ich hab doch auf seinen Beitrag geantwortet und ihn explizit angesprochen?! Verstehe die Diskussion gerade nicht. Was ist dein Ziel gerade? Dass ich nicht mehr auf die Doku verweisen soll?
                              Homoran Global Moderator Administrators @haus-automatisierung last edited by Homoran
                              ok, dann hab ich das übersehen.
                              Ich hielt es für einen allgemeinen Einwurf an den Hilfesuchenden
                              Sorry!
                              81.1k
                              823
