    4. Fehler in meinem Javascript
      Mico last edited by Homoran
      Hallo alle zusammen,
      Ich bekomme immer wieder im Protokoll diese Fehlermeldung angezeigt.:
      2024-06-04 20:00:00.024 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Büro.Buero_Computer_kWh_Berechnung" has to be type "string" but received type "number"
      2024-06-04 20:00:00.065 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Büro.Buero_Computer_kWh/h" has to be type "string" but received type "number"
      2024-06-04 20:00:00.065 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Büro.Buero_Computer_kWh_Verbrauswert" has to be type "string" but received type "number"
      2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Raumentlüfter.Raumlüfter_kWh/Berechnung" has to be type "string" but received type "number"
      2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Raumentlüfter.Raumentlüfter_kWh/h" has to be type "string" but received type "number"
      2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Raumentlüfter.Raumentlüfter_kWh/Verbrauchswert" has to be type "string" but received type "number"
      2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Stube.Stuben_Fernseher_kWh/Berechnung" has to be type "string" but received type "number"
      2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Stube.Stuben_Fernseher_kWh/h" has to be type "string" but received type "number"
      2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Stube.Stuben_Fernseher_kWh/Verbrauchswert" has to be type "string" but received type "number"
      2024-06-04 20:00:00.899 - info: ical.0 (12260) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
      Was hat das für mich zu bedeuten. Die DP sind alle String das heißt doch das sie sowohl Zahlen wie Buchstaben verarbeiten oder ?
      mico
        Homoran Global Moderator Administrators @Mico last edited by
        @mico sagte in Fehler in meinem Javascript:
        Oder!
        Deswegen ja die Fehlermeldung.
        String ist String und Number ist Number.
          Mico @Homoran last edited by
          Das heißt ich müsste nur String in Nummer ändern und alles ist gut
            Homoran Global Moderator Administrators @Mico last edited by Homoran
            wo?
            den Typ des Datenpunktes!
            mit String lässt sich nämlich auch schlecht rechnen.
            "1" + "1" = "11"
              Mico @Homoran last edited by Mico
              in der o Usherdata die DP die ich angelegt hatte.
              Ich dachte immer wenn ich Zahlen sende muss die Gegenstelle auch Zahlen annehmen. und nicht aus einer 1 einfach "1" machen. Meine Logik trifft Computer HiHi
              • OliverIO
                OliverIO @Mico last edited by
                @mico
                darauf versucht dich die Meldung hinzuweisen.
                1 ist number
                "1" ist string
                dein skript (welches wir nicht kennen) schreibt werte vom typ number
                in einen datenpunkt vom typ string.
                wenn du den wert dennoch als string schreiben möchtest, dann kannst du bspw folgendes machen
                setState("0_userdata.0.Stromwerteberechnung.Stube.Stuben_Fernseher_kWh/Berechnung",value.toString());
