    5. (gelöst) benötige Hilfe beim Json in Datenpunkte umwandeln
    • 2
      2hot4you last edited by 2hot4you
      Hallo Zusammen,
      ich benötige Hilfe beim zerpflücken eines Jason um damit Datenpunkte zu erzeugen/füllen.
      Nachfolgenes Json gibt mein Wechselrichter über Growatt Inverter aus.
        "InverterStatus": 5,
        "InputPower": 3970,
        "PV1Voltage": 447.3,
        "PV1InputCurrent": 8.1,
        "PV1InputPower": 3660.1,
        "PV2Voltage": 502.2,
        "PV2InputCurrent": 0.6,
        "PV2InputPower": 316.1,
        "OutputPower": 349.5,
        "GridFrequency": 49.95,
        "L1ThreePhaseGridVoltage": 404.8,
        "L1ThreePhaseGridOutputCurrent": 0.7,
        "L1ThreePhaseGridOutputPower": 569.4,
        "L2ThreePhaseGridVoltage": 400,
        "L2ThreePhaseGridOutputCurrent": 0.8,
        "L2ThreePhaseGridOutputPower": 0,
        "L3ThreePhaseGridVoltage": 407.6,
        "L3ThreePhaseGridOutputCurrent": 0.8,
        "L3ThreePhaseGridOutputPower": 0,
        "TodayGenerateEnergy": 2.3,
        "TotalGenerateEnergy": 622.6,
        "TWorkTimeTotal": 1521098,
        "PV1EnergyToday": 3.7,
        "PV1EnergyTotal": 336.5,
        "PV2EnergyToday": 0.3,
        "PV2EnergyTotal": 342.7,
        "PVEnergyTotal": 679.2,
        "InverterTemperature": 39.8,
        "TemperatureInsideIPM": 47,
        "BoostTemperature": 50.6,
        "DischargePower": 0,
        "ChargePower": 3270,
        "BatteryVoltage": 219.2,
        "SOC": 87,
        "ACPowerToUser": 0,
        "ACPowerToUserTotal": 0,
        "ACPowerToGrid": 0,
        "ACPowerToGridTotal": 0,
        "INVPowerToLocalLoad": 700,
        "INVPowerToLocalLoadTotal": 700,
        "BatteryTemperature": 237,
        "BatteryState": 5,
        "EnergyToUserToday": 0.4,
        "EnergyToUserTotal": 97.7,
        "EnergyToGridToday": 0.1,
        "EnergyToGridTotal": 429,
        "DischargeEnergyToday": 2.8,
        "DischargeEnergyTotal": 115,
        "ChargeEnergyToday": 3.5,
        "ChargeEnergyTotal": 119.4,
        "LocalLoadEnergyToday": 4,
        "LocalLoadEnergyTotal": 348.7,
        "ACChargeEnergyToday": 0.2,
        "ACChargeEnergyTotal": 12.1,
        "Mac": "44:17:93:11:0F:C7",
        "Cnt": 8437
      habe schon diverse Beiträge im Forum gelesen, werde da aber nicht schlau raus.
      Das json wird über MQTT übermittelt
      Gruß Michael
      bahnuhr W 2 Replies Last reply Reply Quote 0
      • bahnuhr
        bahnuhr Forum Testing Most Active @2hot4you last edited by
        @2hot4you
        var J_Test = '{"InverterStatus": 5,"InputPower": 3970,"PV1Voltage": 447.3}';
        var obj = JSON.parse(J_Test);
        log (obj.PV1Voltage)
          wolfi913 @2hot4you last edited by
          @2hot4you
          oder als Blockly
          Homoran 2 3 Replies Last reply Reply Quote 1
            Homoran Global Moderator Administrators @wolfi913 last edited by
            @wolfi913 sagte in benötige Hilfe beim Json in Datenpunkte umwandeln:
            @2hot4you
            oder als Blockly
            oder einfacher ohne Variable json
            einfach die Systemvariable Wert aus dem Bereich Trigger nehmen.
            • MartinP
              MartinP @Homoran last edited by
              @homoran Mein Weg sind Alias-Datenpunkte, dann hat man auch im Object-Tree einen einfacheren Blick auf die Elemente der Struktur, und hat das sowieso ratsame "Aliasieren" gleich mit erledigt...
              {"battery":63,
              "humidity":54.65,
              "last_seen":"2024-06-07T09:37:48+02:00",
              "linkquality":188,
              "power_outage_count":78,
              "pressure":1008.1,
              "temperature":19.39,
              "voltage":2945}
              • 2
                2hot4you @wolfi913 last edited by
                @wolfi913
                Perfekt, danke läuft
                • 2
                  2hot4you @wolfi913 last edited by Homoran
                  @wolfi913
                  ich habe noch eine Frage, vielleicht hast Du dazu eine Antwort.
                  Bei der Ausführung vom Skript bekomme Fehlermeldung:
                  7.6.2024, 23:51:42.878	[warn ]: javascript.0 (3511)     at Object.<anonymous> (script.js.Home.Growatt:9:3)
                  7.6.2024, 23:51:47.927	[warn ]: javascript.0 (3511)     at Object.<anonymous> (script.js.Home.Growatt:9:3)
                  7.6.2024, 23:51:52.920	[warn ]: javascript.0 (3511)     at Object.<anonymous> (script.js.Home.Growatt:9:3)
                  7.6.2024, 23:51:57.917	[warn ]: javascript.0 (3511)     at Object.<anonymous> (script.js.Home.Growatt:9:3)
                  7.6.2024, 23:52:02.888	[warn ]: javascript.0 (3511)     at Object.<anonymous> (script.js.Home.Growatt:9:3)
                  7.6.2024, 23:52:07.920	[warn ]: javascript.0 (3511)     at Object.<anonymous> (script.js.Home.Growatt:9:3)
                  7.6.2024, 23:52:12.894	[warn ]: javascript.0 (3511)     at Object.<anonymous> (script.js.Home.Growatt:9:3)
                  Was bedeutet das ?
                  W Homoran 2 Replies Last reply Reply Quote 0
                    @2hot4you sagte in benötige Hilfe beim Json in Datenpunkte umwandeln:
                    Was bedeutet das ?
                    Nur eine Vermutung da ich Dein Script nicht kenne.
                    Evtl. steht im Datenpunkt den Du auswerten willst nichts drin.
                      Homoran Global Moderator Administrators @2hot4you last edited by Homoran
                      Was bedeutet das ?
                      zeig doch mal dein Blockly und den erzeugten JS-Code
                      2 1 Reply Last reply Reply Quote 0
                      • 2
                        2hot4you @Homoran last edited by
                        anbei der Code vom Blockly. Ich habe alle Datenpunkte geprüft, alle mit Werten.
                        on({ id: [].concat(['mqtt.0.OpenInverterGateway']), change: 'ne' }, async (obj) => {
                          let value = obj.state.val;
                          json = getState('mqtt.0.OpenInverterGateway').val;
                          setState('0_userdata.0.Growatt.InverterStatus' /* InverterStatus */, getAttr(json, 'InverterStatus'), true);
                          setState('0_userdata.0.Growatt.InputPower' /* InputPower */, getAttr(json, 'InputPower'), true);
                          setState('0_userdata.0.Growatt.PV1InputPower' /* PV1InputPower */, getAttr(json, 'PV1InputPower'), true);
                          setState('0_userdata.0.Growatt.PV2InputPower' /* PV2InputPower */, getAttr(json, 'PV2InputPower'), true);
                          setState('0_userdata.0.Growatt.PV1EnergyToday' /* PV1EnergyToday */, getAttr(json, 'PV1EnergyToday'), true);
                          setState('0_userdata.0.Growatt.PV2EnergyToday' /* PV2EnergyToday */, getAttr(json, 'PV2EnergyToday'), true);
                          setState('0_userdata.0.Growatt.PVEnergyTotal' /* PVEnergyTotal */, getAttr(json, 'PVEnergyTotal'), true);
                          setState('0_userdata.0.Growatt.DischargePower' /* DischargePower */, getAttr(json, 'DischargePower'), true);
                          setState('0_userdata.0.Growatt.ChargePower' /* ChargePower */, getAttr(json, 'ChargePower'), true);
                          setState('0_userdata.0.Growatt.BatteryVoltage' /* BatteryVoltage */, getAttr(json, 'BatteryVoltage'), true);
                          setState('0_userdata.0.Growatt.BatteryTemperature' /* BatteryTemperature */, getAttr(json, 'BatteryTemperature'), true);
                          setState('0_userdata.0.Growatt.BatteryState' /* BatteryState */, getAttr(json, 'BatteryState'), true);
                          setState('0_userdata.0.Growatt.SOC' /* SOC */, getAttr(json, 'SOC'), true);
                          setState('0_userdata.0.Growatt.ChargeEnergyToday' /* ChargeEnergyToday */, getAttr(json, 'ChargeEnergyToday'), true);
                          setState('0_userdata.0.Growatt.OutputPower' /* OutputPower */, getAttr(json, 'OutputPower'), true);
                          setState('0_userdata.0.Growatt.InverterTemperature' /* InverterTemperature */, getAttr(json, 'InverterTemperature'), true);
                          wenn das Zeile 9 ist, wird der DP angemeckert.
                          und wo ist
                          @homoran sagte in benötige Hilfe beim Json in Datenpunkte umwandeln:
                          • 2
                            hier ist mein Blockly. Datenpunkt ist da
                              Datenpunkt ist da
                              und wie sieht das json aus?
                              ist da auch der Wert da?
                              es geht auch nicht um den markierten Block!
                              • 2
                                so sieht das json aus
                                  "InputPower": 0,
                                  "PV1Voltage": 110,
                                  "PV1InputCurrent": 0,
                                  "PV1InputPower": 0,
                                  "PV2Voltage": 165.6,
                                  "PV2InputCurrent": 0,
                                  "PV2InputPower": 0,
                                  "OutputPower": 0,
                                  "GridFrequency": 49.98,
                                  "L1ThreePhaseGridVoltage": 409.4,
                                  "L1ThreePhaseGridOutputCurrent": 0.3,
                                  "L1ThreePhaseGridOutputPower": 314.1,
                                  "L2ThreePhaseGridVoltage": 404.3,
                                  "L2ThreePhaseGridOutputCurrent": 0.3,
                                  "L3ThreePhaseGridVoltage": 412.1,
                                  "L3ThreePhaseGridOutputCurrent": 0.3,
                                  "TodayGenerateEnergy": 49.6,
                                  "TotalGenerateEnergy": 912,
                                  "TWorkTimeTotal": 1918900,
                                  "PV1EnergyToday": 21.6,
                                  "PV1EnergyTotal": 477.8,
                                  "PV2EnergyToday": 32.3,
                                  "PV2EnergyTotal": 509.2,
                                  "PVEnergyTotal": 987,
                                  "InverterTemperature": 31,
                                  "TemperatureInsideIPM": 28.3,
                                  "BoostTemperature": 27.4,
                                  "ChargePower": 0.1,
                                  "BatteryVoltage": 212.8,
                                  "SOC": 85,
                                  "ACPowerToUser": 550,
                                  "ACPowerToUserTotal": 550,
                                  "ACPowerToGrid": 0,
                                  "INVPowerToLocalLoad": 550,
                                  "INVPowerToLocalLoadTotal": 550,
                                  "BatteryTemperature": 211,
                                  "BatteryState": 5,
                                  "EnergyToUserToday": 0.6,
                                  "EnergyToUserTotal": 102.6,
                                  "EnergyToGridToday": 40.7,
                                  "EnergyToGridTotal": 619.7,
                                  "DischargeEnergyToday": 4.3,
                                  "DischargeEnergyTotal": 147.1,
                                  "ChargeEnergyToday": 5.5,
                                  "ChargeEnergyTotal": 151.1,
                                  "LocalLoadEnergyToday": 12.9,
                                  "LocalLoadEnergyTotal": 472.3,
                                  "ACChargeEnergyToday": 0.1,
                                  "ACChargeEnergyTotal": 15.2,
                                  "Mac": "D4:D4:DA:CC:8F:98",
                                  "Cnt": 1914
                                • Codierknecht
                                  Codierknecht Developer Most Active @2hot4you last edited by
                                  @2hot4you
                                  Also ich würde das wie von @MartinP vorgeschlagen mit Aliasen lösen - komplett ohne Script.
                                  • 2
                                    2hot4you @Codierknecht last edited by
                                    @codierknecht
                                    ich habe umgestellt auf Alias 😉
                                    • I
                                      iobroker2001 @2hot4you last edited by
                                      Eine Frage hierzu in die Runde:
                                      Ich lese ebenfalls per Alias die MQTT-Daten des Growatt aus.
                                      Abends, wenn der Inverter seinen Betrieb einstellt, fällt der JSON-Datenpunkt aber fast komplett aus.
                                      In der JSON-Struktur ist dann nur noch der Inverterstatus zu sehen.
                                      Dadurch werden die Aliaswerte alle auf NaN gesetzt.
                                      Ist das bei Euch auch so?
                                      Dann müsste ich doch mit einem Blockly die Werte erst zwischenspeichern.
                                      Danke!
                                      • I
                                        iobroker2001 @iobroker2001 last edited by
                                        Ich habe das erst einmal so gelöst:
                                        2 Datenpunkte manuell angelegt (Leistung und EnergieHeute), die dann beschrieben werden, wenn der Inverter läuft:
                                        909
