    4. Fehlermeldungen nach javascript update - benötige Hilfe
      kaffeschluerfer last edited by
      ich habe heute im Rahmen der "allgemeinen Wartung" verschiedene Adapter aktualisiert, darunter auch javascript. Ich erhalte nun die unten stehenden Fehlermeldungen. Hat jemand eine Idee, was ich dagegen tun könnte?
      js-controller ist v5.0.19
      Iobroker läuft in einem Proxmox LCX container auf Debian 11 (bullseye)
      Ein node.js update auf v20.14 (npm 10.7) hat leider nichts geändert...
      Hier die Fehlermeldungen:
      host.iobroker-new	2024-06-07 12:45:00.562	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker-new	2024-06-07 12:45:00.562	error	Caught by controller[0]: at Object.onceWrapper (node:events:633:28)
      host.iobroker-new	2024-06-07 12:45:00.562	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
      host.iobroker-new	2024-06-07 12:45:00.562	error	Caught by controller[0]: at Request.emit (node:domain:488:12)
      host.iobroker-new	2024-06-07 12:45:00.562	error	Caught by controller[0]: at Request.emit (node:events:519:28)
      host.iobroker-new	2024-06-07 12:45:00.561	error	Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
      host.iobroker-new	2024-06-07 12:45:00.561	error	Caught by controller[0]: at Request.emit (node:domain:488:12)
      host.iobroker-new	2024-06-07 12:45:00.561	error	Caught by controller[0]: at Request.emit (node:events:519:28)
      host.iobroker-new	2024-06-07 12:45:00.561	error	Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      host.iobroker-new	2024-06-07 12:45:00.561	error	Caught by controller[0]: at Request._callback (script.js.Telegram-Edomi-messaging:116:31)
      host.iobroker-new	2024-06-07 12:45:00.560	error	Caught by controller[0]: at JSON.parse (<anonymous>)
      host.iobroker-new	2024-06-07 12:45:00.559	error	Caught by controller[0]: SyntaxError: Unexpected end of JSON input
      und
      javascript.0 	2024-06-07 12:45:00.363	error	at Object.onceWrapper (node:events:633:28)
      javascript.0	2024-06-07 12:45:00.363	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
      javascript.0	2024-06-07 12:45:00.363	error	at Request.emit (node:domain:488:12)
      javascript.0	2024-06-07 12:45:00.362	error	at Request.emit (node:events:519:28)
      javascript.0	2024-06-07 12:45:00.362	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
      javascript.0	2024-06-07 12:45:00.362	error	at Request.emit (node:domain:488:12)
      javascript.0	2024-06-07 12:45:00.362	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      javascript.0	2024-06-07 12:45:00.361	error	at Request._callback (script.js.Telegram-Edomi-messaging:116:31)
      javascript.0	2024-06-07 12:45:00.361	error	at JSON.parse (<anonymous>)
      javascript.0	2024-06-07 12:45:00.360	error	script.js.Telegram-Edomi-messaging: SyntaxError: Unexpected end of JSON input
      Vielen Dank vorab für eure Hilfe!!
      Viele Grüße,
      Domenic
      • haus-automatisierung
        haus-automatisierung Developer Most Active @kaffeschluerfer last edited by
        @kaffeschluerfer Zeig mal das Script "Telegram-Edomi-messaging"
          Puh - peinlich. Es liegt tatsächlich auf jedem fall an diesem Script- da hätte ich selbst drauf kommen können. Wenn ich es anhalte kommen die Meldungen nicht mehr.
          D.h. ich muss dieses script debuggen. Das Script ist eine "Spielerei", mit der ich per telegram den Status der Fenster abfragen kann bzw. eine Meldung bekomme wenn sich etwas im Haus tut wenn ich im Urlaub bin. Das ganze ist in blockly gebaut, ist glaube ich schwierig hier einzufügen. Ich versuche mal herauszufinden wo das Problem liegen könnte und melde mich ggf. nochmal...
          Vielen Dank und sorry fürs belästigen...!
          • DJMarc75
            DJMarc75 @kaffeschluerfer last edited by
            @kaffeschluerfer sagte in Fehlermeldungen nach javascript update - benötige Hilfe:
            als Screenshot bitte.
              Hi zusammen!
              kleines update nach etwas rumprobieren, auskommentieren, scripte anhalten und immer wieder diesen Protokolleinträgen für verscheidene scripte (nicht nur das o.g.):
              • Es lag definitiv nicht am script, den selbst nachdem ich ALLES auskommentiert bzw. deaktiviert hatte, kamen diese Fehler
              • Bei einem neuen "jungfräulichen" script mit EXAKT demselben Inhalt (also "nachgebaut") entsteht das Problem nicht
              • bei einem neu angelegtem script, in dem ich die blockly blöcke über export/import hineinkopiert habe, kommen dieselben Fehler
              Woran auch immer es liegt, der workaround (script neu machen) für diesen Fall funktioniert. Vielleicht hilft diese Info ja jemandem der vllt. ähmliche Probleme hat...
              Viele Grüße!
              haus-automatisierung 2 Replies Last reply Reply Quote 0
                Du hast nicht zufällig Scripts in "Global" liegen?
                  Dann zeig doch bitte endlich mal das XML 🙂 Sonst kann doch niemand helfen
                    Hi Matthias,
                    eigentlich wollte ich gerade mit "nicht nötig" und "Problem ist doch gelöst" antworten, doch da hab ich mich getäuscht... 😞
                    Ich habe es soweit runter gedampft, dass ich immer wenn ich dieses Script aktiviere, die o.g. Fehlermeldungen im Protokoll bekomme. Nur die Zeile mit dem Verweis auf das Script ist beliebig irgendein anderes laufendes:
                    Caught by controller[0]: at Request._callback (script.js.common.<<<beliebiger-scriptname>>>:116:31)
                    Das Problem existiert nur, wenn ich dieses hier starte (...auch wenn es jungfräulich neu gebaut ist).
                    Hier auch als xml
                      <block type="on_ext" id="[_^HmXcZr`)r-4uQ%xhI" x="63" y="-1162">
                        <value name="OID0">
                          <shadow type="field_oid" id=")7txGL3IY1g~QmXC4[Dk">
                          <block type="field_oid" id="lqz(x$Cx%%r!{+-#s4#o">
                            <field name="oid">0_userdata.0.telegram.Edomi_message</field>
                          <block type="telegram" id="m+C7(~Rdr}}mKH%m$AvM">
                            <field name="INSTANCE">.0</field>
                            <field name="LOG"></field>
                            <field name="ESCAPING">FALSE</field>
                            <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                            <value name="MESSAGE">
                              <shadow type="text" id="vc#ayA!HR7hL?xJdLKuc">
                              <block type="text_join" id="`gM534ankvY9}ZK7j}bL">
                                <value name="ADD0">
                                  <block type="text" id="Z}O*G*;r+nXC;OTRwvCu">
                                    <field name="TEXT">Edomi</field>
                                <value name="ADD1">
                                  <block type="get_value" id="IbKu]q.*AU?SiM)efemj">
                                    <field name="OID">0_userdata.0.telegram.Edomi_message</field>
                    Das script sendet einen Nachrichtentext (text objekt) per telegram, sobald dieser geändert wurde. Wenn dieses script nicht läuft, ist alles supi.
                    Alle scripte sind in "common". Hat jemand eine Idee?
                    Viele Grüße,
                    Domenic
                      @haus-automatisierung said in Fehlermeldungen nach javascript update - benötige Hilfe:
                      ...ähm doch - gerade erst entdeckt weil der global ordner ausgeblendet war.
                      Da liegt altes script mit dem ich vor Jahren mal den Wechselrichter ausgelesen hatte - mittlerweile gibts aber nen adapter dafür...
                      kanne s daran liegen?
                      paul53 haus-automatisierung 2 Replies Last reply Reply Quote 0
                        paul53 @kaffeschluerfer last edited by paul53
                        @kaffeschluerfer sagte: Alle scripte sind in "common".
                        Sicher nichts unter "global"? Ist der Expertenmodus aktiviert?
                          @kaffeschluerfer sagte: Da liegt altes script
                          Skript löschen!
                            @paul53 said in Fehlermeldungen nach javascript update - benötige Hilfe:
                            Okay, das wars echt... Ohne das läufts bisher ohne Probleme. Woran kann es gelegen haben? Das Problem ist jetzt erst irgendwann mal mit einem der updates hinzu gekommen...
                            Das hier war das besagte für das es mittlerw. (schon seit einer ganzen weile) einen adapter gibt:
                            // Ausleseskript Wechselrichter Kostal Piko ab Firmware v05.31 (12.10.2015)
                            //Variaben
                             //Leistungswerte
                                ID_DCEingangGesamt = 33556736;         // in W
                                ID_Ausgangsleistung = 67109120;        // in W
                                ID_Eigenverbrauch = 83888128;          // in W
                                //Status
                                ID_Status = 16780032;                  // 0:Off
                                //Statistik - Tag
                                ID_Ertrag_d = 251658754;               // in Wh
                                ID_Hausverbrauch_d = 251659010;        // in Wh
                                ID_Eigenverbrauch_d = 251659266;       // in Wh
                                ID_Eigenverbrauchsquote_d = 251659278; // in %
                                ID_Autarkiegrad_d = 251659279;         // in %
                                //Statistik - Gesamt
                                ID_Ertrag_G = 251658753;               // in kWh
                                ID_Hausverbrauch_G = 251659009;        // in kWh
                                ID_Eigenverbrauch_G = 251659265;       // in kWh
                                ID_Eigenverbrauchsquote_G = 251659280; // in %
                                ID_Autarkiegrad_G = 251659281;         // in %
                                ID_Betriebszeit = 251658496;           // in h
                                //Momentanwerte - PV Genertor
                                ID_DC1Spannung = 33555202;             // in V
                                ID_DC1Strom = 33555201;                // in A
                                ID_DC1Leistung = 33555203;             // in W
                                ID_DC2Spannung = 33555458;             // in V
                                ID_DC2Strom = 33555457;                // in A
                                ID_DC2Leistung = 33555459;             // in W
                                //Momentanwerte Haus
                                ID_HausverbrauchSolar = 83886336;      // in W
                                ID_HausverbrauchBatterie = 83886592;   // in W
                                ID_HausverbrauchNetz = 83886848;       // in W
                                ID_HausverbrauchPhase1 = 83887106;     // in W
                                ID_HausverbrauchPhase2 = 83887362;     // in W
                                ID_HausverbrauchPhase3 = 83887618;     // in W
                                //Netz Netzparameter
                                ID_NetzAusgangLeistung = 67109120;     // in W
                                ID_NetzFrequenz = 67110400;            // in Hz
                                ID_NetzCosPhi = 67110656;
                                //Netz Phase 1
                                ID_P1Spannung = 67109378;              // in V
                                ID_P1Strom = 67109377;                 // in A
                                ID_P1Leistung = 67109379;              // in W
                                //Netz Phase 2
                                ID_P2Spannung = 67109634;              // in V
                                ID_P2Strom = 67109633;                 // in A
                                ID_P2Leistung = 67109635;              // in W
                                //Netz Phase 3
                                ID_P3Spannung = 67109890;              // in V
                                ID_P3Strom = 67109889;                 // in A
                                ID_P3Leistung = 67109891;              // in W
                            var IPAnlage = '192.168.0.122/api/dxs.json';   // IP der Photovoltaik-Anlage
                            createState('Piko.Ausgangsleistung', 0);
                            createState('Piko.Autarkiegrad_d',0);
                            createState('Piko.Autarkiegrad_G',0);
                            createState('Piko.Betriebszeit',0);
                            createState('Piko.DCEingangGesamt',0);
                            createState('Piko.Eigenverbrauch',0);
                            createState('Piko.Eigenverbrauch_d');
                            createState('Piko.Eigenverbrauch_G', 0);
                            createState('Piko.Eigenverbrauchsquote_d', 0);
                            createState('Piko.Eigenverbrauchsquote_G', 0);
                            createState('Piko.Ertrag_d', 0);
                            createState('Piko.Ertrag_G', 0);
                            createState('Piko.Hausverbrauch_d', 0);
                            createState('Piko.Hausverbrauch_G', 0);
                            createState('Piko.P1Spannung');
                            createState('Piko.P2Spannung');
                            createState('Piko.P1Strom');
                            createState('Piko.P2Strom');
                            createState('Piko.P1Leistung');
                            createState('Piko.P2Leistung');
                            createState('Piko.HausverbrauchSolar');
                            createState('Piko.HausverbrauchNetz');
                            var logging = true;
                            function Piko() {
                                if (logging) log("Piko 5.5 auslesen");
                                request('http://' + IPAnlage +
                                '?dxsEntries=' + ID_DCEingangGesamt +
                                '&dxsEntries=' + ID_Ausgangsleistung +
                                '&dxsEntries=' + ID_Eigenverbrauch +
                                '&dxsEntries=' + ID_Eigenverbrauch_d +
                                '&dxsEntries=' + ID_Eigenverbrauch_G +
                                '&dxsEntries=' + ID_Eigenverbrauchsquote_d +
                                '&dxsEntries=' + ID_Eigenverbrauchsquote_G +
                                '&dxsEntries=' + ID_Ertrag_d +
                                '&dxsEntries=' + ID_Ertrag_G +
                                '&dxsEntries=' + ID_Hausverbrauch_d +
                                '&dxsEntries=' + ID_Hausverbrauch_G +
                                '&dxsEntries=' + ID_Autarkiegrad_G +
                                '&dxsEntries=' + ID_Autarkiegrad_d +
                                '&dxsEntries=' + ID_Betriebszeit +
                                '&dxsEntries=' + ID_P1Spannung +
                                '&dxsEntries=' + ID_P2Spannung +
                                '&dxsEntries=' + ID_P1Strom +
                                '&dxsEntries=' + ID_P2Strom +
                                '&dxsEntries=' + ID_P1Leistung +
                                '&dxsEntries=' + ID_P2Leistung +
                                '&dxsEntries=' + ID_HausverbrauchSolar +
                                '&dxsEntries=' + ID_HausverbrauchNetz,
                                function (error, response, body) {
                                    if(!error && response.statusCode ==200) {
                                        if(logging) log(body);
                                        var result = JSON.parse(body).dxsEntries;
                                        setState('Piko.DCEingangGesamt', result[0].value);
                                        setState('Piko.Ausgangsleistung', result[1].value);
                                        setState('Piko.Eigenverbrauch', result[2].value);
                                        setState('Piko.Eigenverbrauch_d', result[3].value);
                                        setState('Piko.Eigenverbrauch_G', result[4].value);
                                        setState('Piko.Eigenverbrauchsquote_d', result[5].value);
                                        setState('Piko.Eigenverbrauchsquote_G', result[6].value);
                                        setState('Piko.Ertrag_d', result[7].value);
                                        setState('Piko.Ertrag_G', result[8].value);
                                        setState('Piko.Hausverbrauch_d', result[9].value);
                                        setState('Piko.Hausverbrauch_G', result[10].value);
                                        setState('Piko.Autarkiegrad_G', result[11].value);
                                        setState('Piko.Autarkiegrad_d', result[12].value);
                                        setState('Piko.Betriebszeit', result[13].value);
                                        setState('Piko.P1Spannung', result[14].value);
                                        setState('Piko.P2Spannung', result[15].value);
                                        setState('Piko.P1Strom', result[16].value);
                                        setState('Piko.P2Strom', result[17].value);
                                        setState('Piko.P1Leistung', result[18].value);
                                        setState('Piko.P2Leistung', result[19].value);
                                        setState('Piko.HausverbrauchSolar', result[20].value);
                                        setState('Piko.HausverbrauchNetz', result[21].value);
                                    } else {
                                        log("Fehler: " + error + " bei Abfrage von: " + url, "warn");
                            schedule("* * * * *", function () {
                              //  if(isAstroDay ()) {
                                    log ("Auslöser: Schedule");
                                    Piko();
                              @kaffeschluerfer sagte: Das hier war das besagte
                              Ein solches Skript ist völlig ungeeignet für "global"!
                                Das gehört da aber absolut nicht hin. Der Inhalt aus Global-Scripts wird vor jedes andere Script kopiert! Das heißt, die Logik wird von allen deinen Scripts ausgeführt. Parallel. Ist total unnötig und belastet das System.
                                Jedes deiner Scripts führt also dann jede Minute die Logik aus.
                                  kaffeschluerfer @haus-automatisierung last edited by
                                  @haus-automatisierung, @paul53
                                  Vielen Dank für die Erklärung und die Hilfe!
                                  Ich hatte es echt nicht mehr auf dem Schirm, dass es das Script überhaupt noch gibt. Es ist einige Jahre her. Vielleicht gabs damals irgendeinen Grund, aber da fehlt mir jetzt die Phantasie und die Erinnerung sowieso.
                                  Wie dem auch sei - Problem gelöst - vielen Dank nochmal an euch!!! 👍 👍 👍
                                  641
