    4. Zigbee Startprobleme
      toki1973 last edited by toki1973
      An was kann das liegen. Der USB Kanal ist erfolgreich durch die VM gerootet worden.
      zigbee.0
      2024-06-10 11:33:40.242	error	Error herdsman start
      zigbee.0
      2024-06-10 11:33:40.242	error	Failed to start Zigbee
      zigbee.0
      2024-06-10 11:33:40.241	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      zigbee.0
      2024-06-10 11:33:39.774	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2024-06-10 11:33:39.765	debug	Starting zigbee-herdsman...
      zigbee.0
      2024-06-10 11:33:39.760	info	Starting Zigbee npm ...
      zigbee.0
      2024-06-10 11:33:39.759	info	Try to reconnect. 1 attempts left
      zigbee.0
      2024-06-10 11:33:29.759	error	Error herdsman start
      zigbee.0
      2024-06-10 11:33:29.759	error	Failed to start Zigbee
      zigbee.0
      2024-06-10 11:33:29.758	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      Das Ti Board ist in der iob VM sichtbar
      toki@iobroker:~$ lsusb
      Bus 005 Device 002: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
      Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
      Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
      Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
      Bus 001 Device 002: ID 0627:0001 Adomax Technology Co., Ltd QEMU Tablet
      Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
      toki@iobroker:~$
      • Meister Mopper
        Meister Mopper @toki1973 last edited by
        @toki1973
        Was liefert ls -lAh /dev/serial/by-id ?
          toki1973 @Meister Mopper last edited by
          @meister-mopper
          2 devices. Im Adapter habe ich schon beide probiert
          toki@iobroker:~$ ls -lAh /dev/serial/by-id
          insgesamt 0
          lrwxrwxrwx 1 root root 13 10. Jun 11:48 usb-Texas_Instruments_XDS110__02.03.00.1        8__Embed_with_CMSIS-DAP_L1100C1R-if00 -> ../../ttyACM0
          lrwxrwxrwx 1 root root 13 10. Jun 11:48 usb-Texas_Instruments_XDS110__02.03.00.1        8__Embed_with_CMSIS-DAP_L1100C1R-if03 -> ../../ttyACM1
          toki@iobroker:~$
            Thomas Braun Most Active @toki1973 last edited by
            @toki1973 sagte in Zigbee Startprobleme:
            ttyACM0
            ls -lah /dev/ttyACM*
            sudo -H -u iobroker groups
            sagt?
              toki1973 @Thomas Braun last edited by
              @thomas-braun said in Zigbee Startprobleme:
              toki@iobroker:~$ ls -lah /dev/ttyACM*
              crw-rw---- 1 root dialout 166, 0 10. Jun 11:55 /dev/ttyACM0
              crw-rw---- 1 root dialout 166, 1 10. Jun 11:48 /dev/ttyACM1
              toki@iobroker:~$ sudo -H -u iobroker groups
              iobroker tty dialout audio video plugdev bluetooth
              toki@iobroker:~$
                @toki1973
                Gut, das passt. Irgendwas / -wer greift auf die Schnittstellen zu.
                Läuft da noch irgendwas anderes? zigbee2mqtt oder sowas?
                Ansonsten einfach mal die VM neustarten.
                  Bin 3. VM Start bzw, Herunterfahren und dann starten hat es funktioniert,
                  • Meister Mopper
                    Meister Mopper @toki1973 last edited by Meister Mopper
                    Ich habe auch schon länger das Problem beim reboot meines Raspberry (Slave) an dem mein TI-Board hängt.
                    Nach jedem Neustart kommt zunächst keine USB-Verbindung zustande, und ich muss den Adapter mehrmals neu starten, bis es endlich funktioniert.
                    Ich habe natürlich sträflich nicht dokumentiert, was ich vorher verändert hatte, vermute aber, dass das Bücherwurm-Update ursächlich ist und da eine Verzögerung für die USB-Hardware eingebaut werden sollte.
                    Als Linux-Noob bin ich da jedoch überfordert.
                    Vielleicht hilft es auch dir zukünftig:
                    Adapter mehrmals starten (immer warten, bis er gemäß debug-log nach 6 Sekunden den zweiten Versuch abgebrochen hat).
                    Nach ein paar Versuchen kommt die Verbindung zustande (zumindest hier).
                    Bestimmt haben die Entwickler/Maintainer @arteck @Asgothian noch andere Ideen.
                      arteck Developer Most Active @Meister Mopper last edited by
                      @meister-mopper welcher pi 4 oder 3 ?
                      das Problem kenn ich aber.. konnte noch nicht lokalisieren wodran es liegt..
                      MartinP Meister Mopper 2 Replies Last reply Reply Quote 0
                      • MartinP
                        MartinP @arteck last edited by
                        In einem anderen Zusammenhang hatte ich mal Probleme mit dem "brltty" Dienst, der sollte aber auf einem Linux ohne grafischer UI nicht gestartet werden ... und eigentlich ist der lsusb nicht passend dazu, dass brltty daneben greifen könnte...
                        https://github.com/arduino/help-center-content/issues/155
                        per1234 created this issue in arduino/help-center-content
                        open Article suggestion: missing port on Linux caused by interference from BRLTTY #155
                          Thomas Braun Most Active @MartinP last edited by
                          @martinp sagte in Zigbee Startprobleme:
                          Doch gerade dort. Ist ja der Treiber für ein Braille-Gerät.
                          Insbesondere bei Ubuntus kommt der sich gerne mit dem Rest ins Gehege.
                          Muss man mal in den Boot-Vorgang schauen, insbesondere in die udev-Regeln.
                            na dann kommen wir der Sache vielleicht näher
                              toki1973 @arteck last edited by
                              Danke für eure Rückmeldungen!
                              • Meister Mopper
                                Meister Mopper @arteck last edited by
                                @arteck sagte in Zigbee Startprobleme:
                                Es ist ein RaspberryPi 4B mit 8G.
                                  robbsen last edited by
                                  Habe ebenfalls Probleme, vermute erste seit Linux-Updates heute, ich bin mir aber nicht sicher ob es der selbe Fehler ist
                                  v1.10.3
                                  VM in Proxmox
                                  2024-06-11 12:03:06.084 - info: host.iobroker-slave-proxmox "system.adapter.zigbee.0" disabled
                                  2024-06-11 12:03:07.621 - info: host.iobroker-slave-proxmox "system.adapter.zigbee.0" enabled
                                  2024-06-11 12:03:07.873 - info: host.iobroker-slave-proxmox instance system.adapter.zigbee.0 started with pid 2609
                                  2024-06-11 12:03:08.334 - error: host.iobroker-slave-proxmox Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: throw err;
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: ^
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: Error: Cannot find module 'uri-js'
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: Require stack:
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/inovelli.js
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/index.js
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/index.js
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
                                  2024-06-11 12:03:08.335 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js:35:26)
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: requireStack: [
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js',
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/inovelli.js',
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/index.js',
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js',
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js',
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js',
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: ]
                                  2024-06-11 12:03:08.336 - error: host.iobroker-slave-proxmox Caught by controller[0]: }
                                  2024-06-11 12:03:08.337 - error: host.iobroker-slave-proxmox Caught by controller[1]: Node.js v18.20.3
                                  2024-06-11 12:03:08.337 - error: host.iobroker-slave-proxmox instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2024-06-11 12:03:08.337 - info: host.iobroker-slave-proxmox Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually
                                  • Meister Mopper
                                    Meister Mopper @robbsen last edited by
                                    @robbsen sagte in Zigbee Startprobleme:
                                    Das ist ein anderer Fehler.
                                    Was sagt iob diag ?
                                      robbsen @Meister Mopper last edited by robbsen
                                      @meister-mopper bei mir scheint es was mit dem update von 5 auf 6 zusammen zu hängen. Hatte eben ein Backup eingespielt und der Adapter lief nach dem Update bleibt es rot. Ist ggf. bei mir einfach die Node.js das Thema?
                                      Ist übrigens nen Slave
                                                              v.2024-05-22
                                         Static hostname: iobroker-slave-proxmox
                                               Icon name: computer-vm
                                                 Chassis: vm
                                          Virtualization: kvm
                                        Operating System: Ubuntu 20.04.6 LTS
                                                  Kernel: Linux 5.4.0-177-generic
                                            Architecture: x86-64
                                      Installation:           kvm
                                      User-ID:                1000
                                      Display-Server:         true
                                      Pending OS-Updates:     45
                                      Pending iob updates:    0
                                      Nodejs-Installation:
                                      /usr/bin/nodejs         v18.20.0
                                      /usr/bin/node           v18.20.0
                                      /usr/bin/npm            10.5.0
                                      /usr/bin/npx            10.5.0
                                      /usr/bin/corepack       0.25.2
                                      MEMORY:
                                      Mem:           3.9G        450M        2.0G        1.0M        1.5G        3.2G
                                      Swap:          3.9G          0B        3.9G
                                      Total:         7.9G        450M        5.9G
                                      Active iob-Instances:   26
                                      Active repo(s): Beta (latest)
                                      ioBroker Core:          js-controller           6.0.1
                                                              admin                   "admin" not found
                                      At least one iobroker host is running.
                                      Objects type: jsonl
                                      States  type: redis
                                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 7777, bind: 0.0.0.0 (SSL), run as: admin
                                      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      Objects:                10591
                                      States:                 10135
                                      Size of iob-Database:
                                      284K    /opt/iobroker/iobroker-data/objects.jsonl
                                      280K    /opt/iobroker/iobroker-data/objects.json.migrated
                                      264K    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                      204K    /opt/iobroker/iobroker-data/states.json.bak
                                        Thomas Braun Most Active @robbsen last edited by Thomas Braun
                                        Ist zumindest nicht die aktuellste und empfohlene Version.
                                        Installier da auf Master wie Slave die Version 20.
                                        Und schalt den Desktop aus:
                                        Geht mit
                                        sudo systemctl set-default multi-user.target
                                        Bring die Kiste auf Stand:
                                        Sind 45 zuviel.
                                          Hab noch mal das Backup eingespielt, dieses mal erst das Update auf die aktuelle Node.js dann Linux Updates, hier gab es abhängigkeitsfehler also noch mal updates mit sudo apt dist-upgrade
                                          Final dann das update vom js controller auf js-controller 6.0.1
                                          2024-06-11 15:23:32.925  - error: host.iobroker-slave-proxmox Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                          2024-06-11 15:23:32.925  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                                          2024-06-11 15:23:32.925  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-06-11 15:23:32.925  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-06-11 15:23:32.925  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                                          2024-06-11 15:23:32.925  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js:35:26)
                                          2024-06-11 15:23:32.925  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-06-11 15:23:32.925  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19) {
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:   requireStack: [
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js',
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/inovelli.js',
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/index.js',
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     '/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js',
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js',
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js',
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]:   ]
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[0]: }
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox Caught by controller[1]: Node.js v20.14.0
                                          2024-06-11 15:23:32.926  - error: host.iobroker-slave-proxmox instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2024-06-11 15:23:32.926  - info: host.iobroker-slave-proxmox Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                          und das summary
        v.2024-05-22
                                                     Chassis: vm
                                              Virtualization: kvm
                                                      Kernel: Linux 5.4.0-182-generic
                                          Installation:           kvm
                                          User-ID:                1000
                                          Pending OS-Updates:     0
                                          /usr/bin/nodejs         v20.14.0
                                          /usr/bin/node           v20.14.0
                                          /usr/bin/npm            10.7.0
                                          /usr/bin/npx            10.7.0
                                          /usr/bin/corepack       0.28.1
                                          MEMORY:
                                          Mem:           3.9G        422M        2.5G        1.0M        958M        3.3G
                                          Swap:          3.9G          0B        3.9G
                                          Total:         7.9G        422M        6.5G
                                          Active iob-Instances:   29
                                          Objects type: jsonl
                                          States  type: redis
                                          Objects:                11234
                                          States:                 10725
                                            robbsen last edited by robbsen
                                            konnte es umständlich selber lösen
                                            Nach dem Update auf Version 6.0.1 erhielt ich im Log die Fehlermeldung, dass das Modul 'uri-js' fehlte. Also habe ich es installiert, und dann wurde mir angezeigt, dass auch das Modul 'request' fehlte. Also habe ich beide Module erneut im Verzeichnis /opt/iobroker installiert.
                                            Hier ist mein vollständiger Ablauf:
                                            • sudo apt-get dist-upgrade ausgeführt.
                                              ioBroker mit iob stop angehalten.
                                              Dann Node.js mit iob nodejs-update aktualisiert.
                                              Das System habe ich neu gestartet (reboot).
                                              Wieder ioBroker gestoppt mit iob stop.
                                              Dann ioBroker mit iob fix repariert.
                                              Die Datei 'iobroker.bat' mit del iobroker.bat gelöscht.
                                              Erneut iob fix ausgeführt.
                                              Mit cd /opt/iobroker in das Verzeichnis gewechselt.
                                              Dort das Selbst-Upgrade mit iob upgrade self durchgeführt.
                                              Das Modul 'uri-js' mit npm install uri-js installiert.
                                              Und zuletzt das Modul 'request' mit npm install request installiert.
                                            950
