    4. Cannot download and install adapter "telegram@3.2.1"
    • jmeister79
      jmeister79 last edited by
      meine Waschmaschine ist fertig und ich wudnere mich, warum ich keine Nachricht kriege,
      der Telegram Adapter ist gestoppt und wenn ich ihn restarte gibts das hier:
      host.iobrokerpi
      2024-06-11 14:47:07.332	error	Cannot download and install adapter "telegram@3.2.1". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      host.iobrokerpi
      2024-06-11 14:47:07.214	info	iobroker npm-install: exit 1
      host.iobrokerpi
      2024-06-11 14:47:07.203	error	iobroker npm-install: node:internal/modules/cjs/loader:1143 throw err; ^Error: Cannot find module 'axios'Require stack:- /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js- /opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js- /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js- /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) at Module._load (node:internal/modules/cjs/loader:981:27) at Module.require (node:internal/modules/cjs/loader:1231:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33) at Module._compile (node:internal/modules/cjs/loader:1364:14) at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) at Module.load (node:internal/modules/cjs/loader:1203:32) at Module._load (node:internal/modules/cjs/loader:1019:12) at Module.require (node:internal/modules/cjs/loader:1231:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js', '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]}Node.js v18.20.2
      Ging jetzt ca 4 Jahre problemlos und nun das...
        Thomas Braun Most Active @jmeister79 last edited by
        @jmeister79
        System aktuell halten.
        UPDATEN:
        telegram
        github:	3.4.1
        latest:	3.4.1 for 1 days
        stable:	3.3.2 for 16 days
        Deine 3.2.1 gibt es wohl nicht mehr im Repo.
        • jmeister79
          @thomas-braun Danke für die antwort, was neueres zeigt er nicht an. ist alles so aktuell wie er sagt. Das problem hab ich seit wochen
            Homoran Global Moderator Administrators @jmeister79 last edited by
            @jmeister79 sagte in Cannot download and install adapter "telegram@3.2.1":
            was sagt iob update ?
            jmeister79 1 Reply Last reply Reply Quote 0
              @jmeister79
              Dann schau dir die Ausgabe von
              iob diag
              an.
              • jmeister79
                jmeister79 @Homoran last edited by jmeister79
                @homoran spannend, habe die eltzten monate immer über das Webinterface geupdated und nicht mehr über die konsole.
                in der konsole gibts neue versionen für admin, backitup discovery und -js-controller.
                im Webinterface ganz andere
                liegts daran?
                Wichtig: ich darf nicht alles updaten, da das letzte update für VIS auf keinem meiner panels funktioniert und VIS 2 für mich keine alternative ist.
                  liegts daran?
                  @homoran sagte in Cannot download and install adapter "telegram@3.2.1":
                    Die Konsole lügt (im Gegensatz zu GUIs) eigentlich nie.
                    • jmeister79
                      jmeister79 @Thomas Braun last edited by
                      @thomas-braun Screenshot_2024-06-11-15-05-25-65_e36872cd03453bb5e33ec96ae2d9a765.jpg
                      wie eben gesagt.
                      ich will eigentlich nicht mehr updaten, da das system für mich läuft unt hatte nur gezielt einige adapter upgedated, scheinbar war das ne doofe idee.
                      jmeister79 Thomas Braun Ro75 3 Replies Last reply Reply Quote 0
                      • jmeister79
                        jmeister79 @jmeister79 last edited by
                        dagegen das GUI
                          Ja, so handelt man sich nämlich Inkonsistenzen ein.
                          Nochmal:
                          Vollständige Ausgabe von
                          iob diag
                          wird benötigt.
                          • Ro75
                            Ro75 @jmeister79 last edited by Ro75
                            @jmeister79 der js-controller ist mit Version 4 für die meisten Adapter zu alt.
                            Ro75
                            EDIT: ggfs auch NodeJS.
                            • jmeister79
                                                      v.2024-05-22
                                 Static hostname: iobrokerpi
                                       Icon name: computer
                                          Kernel: Linux 6.1.21-v8+
                                    Architecture: arm64
                              Userland:               32 bit
                              User-ID:                1000
                              Display-Server:         false
                              Pending OS-Updates:     7
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.20.2
                              Pending iob updates:    0
                              Nodejs-Installation:
                              /usr/bin/nodejs         v18.20.2
                              /usr/bin/node           v18.20.2
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              /usr/bin/corepack       0.25.2
                              MEMORY:
                              Mem:            3.8G        2.7G        182M        0.0K        898M        948M
                              Swap:            99M         99M        0.0K
                              Total:          3.9G        2.8G        182M
                              Active iob-Instances:   0
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.20.2
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.20.2
                              ioBroker Core:          js-controller
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.20.2
                                                      admin
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.20.2
                              ioBroker Status:
                              Objects:                0
                              States:                 0
                              Size of iob-Database:
                              18M     /opt/iobroker/iobroker-data/objects.jsonl
                              4.0M    /opt/iobroker/iobroker-data/states.jsonl
                              Some problems detected, please run iob fix and try to have them fixed
                              • jmeister79
                                iob update:
                                pi@iobrokerpi:~ $ iob update
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.20.2
                                pi@iobrokerpi:~ $
                                • jmeister79
                                  jmeister79 last edited by jmeister79
                                  spannend, das putty hier die ganzen Fehler schmeisst und die ssh Console auf dem handy nicht
                                  war ja auch der andere iobroker.... IDIOT
                                  • jmeister79
                                    Tja und jetzt läuft garnix mehr, update und upgrade geht nicht und nach nem restart ist auch der iobroker wech
                                      Tja, dann kannst du ja jetzt die vernachlässigten Updates nachholen. Insbesondere des js-controllers.
                                      iob stop
                                      cd /opt/iobroker
                                      npm install iobroker.js-controller@5.0.19
                                      iob start
                                      iob update
                                      • jmeister79
                                        @thomas-braun said in Cannot download and install adapter "telegram@3.2.1":
                                        ok, wenn das so geht, kannst du mir kurz erklären wie das passiert das der iobroker sich selber so abschießt, wenn der js-controller alt sit? würde es gerne verstehen.
                                          passiert das. Weil dann Abhängigkeiten nicht bedient werden können.
                                          Deswegen funktioniert es ja auch nicht, das System einmal zu installieren und dann 'das running süstem never zu tatschen'.
                                          Die einzelnen Komponenten (Betriebssystem; Laufzeitumgebung, js-controller, iob-Adapter) müssen halt mit einander richtig zusammenspielen. Das kannst du aber nur mit jeweils aktuellen, stabilen Versionen gewährleisten.
                                          • jmeister79
                                            @thomas-braun ok danke.
                                            leider bringt
                                            nix.
                                            selber Fehler bei iob update
                                            494
