    4. "homepilot20" stürzt nach js-controller 6.0.1-Update ab
    • KlausStoertebeker
      KlausStoertebeker last edited by
      Hallo ins Forum,
      ich habe gestern meinen js-controller auf die Version 6.0.1 aktualisiert und seitdem stürzt mein "homepilot20" Adapter zur Steuerung meiner Rademacher-Jallousien ständig ab.
      Im ioBroker-Protokoll gibt es dazu folgende Einträge:
      host.Nordmanns-ioBroker-Server
      	2024-06-12 17:46:11.532	error	instance system.adapter.homepilot20.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: Node.js v18.20.3
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.homepilot20/main.js:2736:5)
      	2024-06-12 17:46:11.531	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.homepilot20/main.js:66:12)
      	2024-06-12 17:46:11.530	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
      	2024-06-12 17:46:11.530	error	Caught by controller[0]: ^
      	2024-06-12 17:46:11.530	error	Caught by controller[0]: adapter = new utils.Adapter(options);
      	2024-06-12 17:46:11.530	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.homepilot20/main.js:66
      Hat jemand das gleiche Problem und vielleicht auch eine Lösung?
      Vielen Dank im voraus und viele Grüße aus Dräschdn
      "Klaus"
      Systeminformationen
      • Adaptername: homepilot20
      • Link zu Adapterrepository: https://github.com/homecineplexx/ioBroker.homepilot20
      • Adapterversion: 0.0.51
      • js-controller Version: 6.0.1
      • Admin Version: 6.17.14
      • Hardwaresystem: Raspberry Pi 4B
      • Arbeitsspeicher: 8 GByte
      • Festplattenart: 256 GByte SSD
      • Betriebssystem: Linux
      • Nodejs-Version: v18.20.3
      • NPM-Version: 10.7
      • Installationsart: Manuell (Adapter nicht über Repositories verfügbar)
      • Image, Docker genutzt: Nein
      Output von iob diag
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: Nordmanns-ioBroker-Server
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       17:29:32 up 19:51,  2 users,  load average: 0.92, 0.85, 0.82
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-06-12 17:29:33 CEST
                 Universal time: Wed 2024-06-12 15:29:33 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mainuser
      HOME=/home/mainuser
      GROUPS=mainuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            8.2G        2.1G        3.4G        1.3M        2.8G        6.1G
      Swap:           209M          0B        209M
      Total:          8.4G        2.1G        3.6G
      Active iob-Instances: 	19
               7810 M total memory
               2036 M used memory
               3400 M active memory
                985 M inactive memory
               3259 M free memory
                113 M buffer memory
               2523 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 17:29:33 up 19:51,  2 users,  load average: 0.92, 0.85, 0.82
      Tasks: 176 total,   2 running, 174 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7810.2 total,   3258.0 free,   2038.0 used,   2637.3 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5772.3 avail Mem
      *** FAILED SERVICES ***
        UNIT                                   LOAD   ACTIVE SUB    DESCRIPTION
      * 4 netshares (powered off)              loaded failed failed <mountpoints>
      4 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                           Type      Size  Used Avail Use% Mounted on
      udev                                 devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs                                tmpfs     782M  1.2M  780M   1% /run
      /dev/sda2                            ext4      235G   11G  212G   5% /
      tmpfs                                tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                                tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/sda1                            vfat      510M   61M  450M  12% /boot/firmware
      //5 netshares (working fine and deleted for privacy reasons
      tmpfs                                tmpfs     782M     0  782M   0% /run/user/1000
      [Tue Jun 11 21:38:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:99:FE:52 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=09f188be-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Tue Jun 11 21:38:30 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Jun 11 21:38:32 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE                               FSTYPE      OPTIONS
      /                                                       /dev/sda2                            ext4        rw,noatime
      |-/sys                                                  sysfs                                sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs                           securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2                              cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore                               pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf                                  bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs                              debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs                              tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config                                  configfs                             configfs    rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections                            fusectl                              fusectl     rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc                                 proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1                            autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3940
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc                          binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev                                 devtmpfs    rw,nosuid,relatime,size=3729132k,nr_inodes=932283,mode=755
      | |-/dev/pts                                            devpts                               devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs                                tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue                               mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs                                tmpfs       rw,nosuid,nodev,noexec,relatime,size=799772k,mode=755
      | |-/run/lock                                           tmpfs                                tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs                                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs                                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc                               rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs                                tmpfs       rw,nosuid,nodev,relatime,size=799768k,nr_inodes=199942,mode=700,uid=1000,gid=1000
      |-/boot/firmware                                        /dev/sda1                            vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      | 6 netshares mounted successful, deleted because of privacy issues
      /var:
      2.9G	/var/
      2.0G	/var/log/journal/608b96614dfe4477b12b074e08cee6d6
      2.0G	/var/log
      520M	/var/cache
      Archived and active journals take up 1.9G in the file system.
      /opt/iobroker/backups:
      4.0K	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G	/opt/iobroker/iobroker-data/
      946M	/opt/iobroker/iobroker-data/files
      285M	/opt/iobroker/iobroker-data/files/javascript.admin
      250M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      249M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M	/opt/iobroker/iobroker-data/objects.jsonl
      29M	/opt/iobroker/iobroker-data/states.jsonl
      29M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ecef4f21.js.map
      26M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DB_FT2PTYKW-if00-port0
      /dev/serial/by-id/usb-0658_0200-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.20.3
      /usr/bin/node 		v18.20.3
      /usr/bin/npm 		10.7.0
      /usr/bin/npx 		10.7.0
      /usr/bin/corepack 	0.28.0
      nodejs:
        Installed: 18.20.3-1nodesource1
        Candidate: 18.20.3-1nodesource1
        Version table:
       *** 18.20.3-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	6.0.1
      admin: 		6.17.14
      javascript: 	8.5.2
      nodejs modules from github: 	2
      +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
      +-- iobroker.pioneer_sc_vsx@0.1.0 (git+ssh://git@github.com/okeck1982/ioBroker.pioneer_sc_vsx.git#b74d0f748835d2c1c4b860d43a8e6a24939039ce)
      Adapter State
      + system.adapter.adb.0                    : adb                   : Nordmanns-ioBroker-Server                -  enabled
      + system.adapter.admin.0                  : admin                 : Nordmanns-ioBroker-Server                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : Nordmanns-ioBroker-Server                - disabled
        system.adapter.backitup.0               : backitup              : Nordmanns-ioBroker-Server                - disabled
      + system.adapter.broadlink2.0             : broadlink2            : Nordmanns-ioBroker-Server                -  enabled
        system.adapter.discovery.0              : discovery             : Nordmanns-ioBroker-Server                - disabled
        system.adapter.dwd.0                    : dwd                   : Nordmanns-ioBroker-Server                -  enabled
      + system.adapter.echarts.0                : echarts               : Nordmanns-ioBroker-Server                -  enabled
      + system.adapter.ekey.0                   : ekey                  : Nordmanns-ioBroker-Server                -  enabled, port: 56000, bind: 0.0.0.0
      + system.adapter.enocean.0                : enocean               : Nordmanns-ioBroker-Server                -  enabled
      + system.adapter.ford.0                   : ford                  : Nordmanns-ioBroker-Server                -  enabled
        system.adapter.homepilot20.0            : homepilot20           : Nordmanns-ioBroker-Server                -  enabled
      + system.adapter.hue.0                    : hue                   : Nordmanns-ioBroker-Server                -  enabled, port: 443
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Nordmanns-ioBroker-Server                - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Nordmanns-ioBroker-Server                - disabled
      + system.adapter.javascript.0             : javascript            : Nordmanns-ioBroker-Server                -  enabled
        system.adapter.modbus.0                 : modbus                : Nordmanns-ioBroker-Server                - disabled
      + system.adapter.netatmo.0                : netatmo               : Nordmanns-ioBroker-Server                -  enabled
      + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : Nordmanns-ioBroker-Server                -  enabled, port: 23
        system.adapter.scenes.0                 : scenes                : Nordmanns-ioBroker-Server                - disabled
      + system.adapter.shelly.0                 : shelly                : Nordmanns-ioBroker-Server                -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.signal-cmb.0             : signal-cmb            : Nordmanns-ioBroker-Server                -  enabled
      + system.adapter.simple-api.0             : simple-api            : Nordmanns-ioBroker-Server                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sql.0                    : sql                   : Nordmanns-ioBroker-Server                -  enabled, port: 3306
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : Nordmanns-ioBroker-Server                - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : Nordmanns-ioBroker-Server                - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Nordmanns-ioBroker-Server                - disabled
      + system.adapter.vis-2.0                  : vis-2                 : Nordmanns-ioBroker-Server                -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : Nordmanns-ioBroker-Server                - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : Nordmanns-ioBroker-Server                - disabled
      + system.adapter.web.0                    : web                   : Nordmanns-ioBroker-Server                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zwave2.0                 : zwave2                : Nordmanns-ioBroker-Server                -  enabled
      + instance is alive
      ioBroker-Repositories
      latest        : http://download.iobroker.net/sources-dist-latest.json
      stable        : http://download.iobroker.net/sources-dist-stable.json
      Active repo(s): latest
      Installed ioBroker-Instances
      Used repository: latest
      Adapter    "adb"          : 0.0.7    , installed 0.0.7
      Adapter    "admin"        : 6.17.14  , installed 6.17.14
      Adapter    "backitup"     : 3.0.3    , installed 3.0.3
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "ekey"         : 1.2.3    , installed 1.2.3
      Adapter    "enocean"      : 0.9.3    , installed 0.9.3
      Adapter    "ford"         : 1.0.2    , installed 1.0.2
      Adapter    "hue"          : 3.11.0   , installed 3.11.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "javascript"   : 8.5.2    , installed 8.5.2
      Controller "js-controller": 6.0.2    , installed 6.0.1  [Updatable]
      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "scenes"       : 3.0.4    , installed 3.0.4
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
      Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
      Adapter    "vis-2-widgets-material": 1.3.33, installed 1.3.33
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "web"          : 6.2.6    , installed 6.2.6
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
      Objects and States
      Objects: 	13334
      States: 	8317
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13800      734/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18633      734/iobroker.js-con
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17843      1061/io.shelly.0
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       18987      1309/adb
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12225      758/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14190      1132/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13843      962/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18935      1173/io.simple-api.
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12227      758/sshd: /usr/sbin
      udp        0      0 0.0.0.0:58091           0.0.0.0:*                           104        13151      603/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13149      603/avahi-daemon: r
      udp        0      0 0.0.0.0:55610           0.0.0.0:*                           1001       80679      1018/io.broadlink2.
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       13898      1018/io.broadlink2.
      udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1001       18909      1118/io.ekey.0
      udp        0      0 0.0.0.0:57738           0.0.0.0:*                           1001       18782      1018/io.broadlink2.
      udp6       0      0 :::5353                 :::*                                104        13150      603/avahi-daemon: r
      udp6       0      0 :::53284                :::*                                104        13152      603/avahi-daemon: r
      2024-06-12 17:30:35.915  - debug: zwave2.0 (1197) Node 9: metadata updated: value_001_electric_kwh_consumed
      2024-06-12 17:30:35.916  - debug: zwave2.0 (1197) Node 9: value updated: value_001_electric_kwh_consumed => 7.54
      2024-06-12 17:30:35.963  - info: pioneer_sc_vsx.0 (1146) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
      2024-06-12 17:30:36.006  - debug: zwave2.0 (1197) Node 23: metadata updated: power
      2024-06-12 17:30:36.007  - debug: zwave2.0 (1197) Node 23: value updated: power => 33.5
      2024-06-12 17:30:36.201  - debug: zwave2.0 (1197) Node 25: metadata updated: value_electric_kwh_consumed
      2024-06-12 17:30:36.202  - debug: zwave2.0 (1197) Node 25: value updated: value_electric_kwh_consumed => 91.9
      2024-06-12 17:30:36.376  - debug: zwave2.0 (1197) Node 4: metadata updated: value_002_electric_w_consumed
      2024-06-12 17:30:36.377  - debug: zwave2.0 (1197) Node 4: value updated: value_002_electric_w_consumed => 0
      2024-06-12 17:30:36.585  - debug: zwave2.0 (1197) Node 11: metadata updated: power
      2024-06-12 17:30:36.587  - debug: zwave2.0 (1197) Node 11: value updated: power => 0
      2024-06-12 17:30:36.912  - debug: zwave2.0 (1197) Node 23: metadata updated: power
      2024-06-12 17:30:36.915  - debug: zwave2.0 (1197) Node 23: value updated: power => 14.7
      2024-06-12 17:30:36.947  - debug: zwave2.0 (1197) Node 45: metadata updated: power
      2024-06-12 17:30:36.949  - debug: zwave2.0 (1197) Node 45: value updated: power => 0.5
      2024-06-12 17:30:36.960  - debug: zwave2.0 (1197) Node 23: metadata updated: power
      2024-06-12 17:30:36.962  - debug: zwave2.0 (1197) Node 23: value updated: power => 14.7
      2024-06-12 17:30:37.038  - debug: zwave2.0 (1197) Node 45: metadata updated: power
      2024-06-12 17:30:37.039  - debug: zwave2.0 (1197) Node 45: value updated: power => 0.5
      2024-06-12 17:30:37.912  - debug: zwave2.0 (1197) Node 23: metadata updated: power
      2024-06-12 17:30:37.913  - debug: zwave2.0 (1197) Node 23: value updated: power => 24
      2024-06-12 17:30:38.460  - debug: zwave2.0 (1197) Node 36: metadata updated: power
      2024-06-12 17:30:38.462  - debug: zwave2.0 (1197) Node 36: value updated: power => 0.5
      2024-06-12 17:30:38.997  - debug: zwave2.0 (1197) Node 25: metadata updated: power
      2024-06-12 17:30:38.998  - debug: zwave2.0 (1197) Node 25: value updated: power => 122.6
      • Ro75
        Ro75 last edited by Ro75
        @klausstoertebeker bist du viel in BETA unterwegs? Der Controller ist "Beta". Wenn du nicht testen willst und das nicht deine Absicht ist, dann bleibe auf "stable".
        Ro75.
        KlausStoertebeker 1 Reply Last reply Reply Quote 0
        • KlausStoertebeker
          KlausStoertebeker @Ro75 last edited by
          @Ro75
          Nein, ich wollte nicht testen. Aber mir wurde halt über eine Benachrichtigung unter "Hosts" mitgeteilt, dass für den js-controller eine neue Version vorliegt - von "Beta" war da nicht die Rede...
          Aber wenn Version 6.0.1 keine "stable"-Version ist, werde ic hwieder auf die letzte stabile Version downgraden (5.0.19).
          Danke für den Hinweis 🙂
          Ro75 Samson71 2 Replies Last reply Reply Quote 0
          • Ro75
            Ro75 @KlausStoertebeker last edited by
            @klausstoertebeker dann stelle mal zurück auf "stable" wenn du nicht aktiv testen willst.
            Aber ich befürchte, dass da schon jede Menge an Adapter in "Testversion / nicht stable" installiert wurde.
            Ro75.
            • Samson71
              Samson71 Global Moderator @KlausStoertebeker last edited by
              @klausstoertebeker sagte in "homepilot20" stürzt nach js-controller 6.0.1-Update ab:
              Dann steht aber in den Einstellungen Dein Standard-Repo nicht auf stable sondern auf beta. Änder das ggf. ab
              • mcm1957
                mcm1957 @Ro75 last edited by
                Homepilot20 ist nicht in einem Repository gelistet und nicht mit js-controller 6 kompatibel.
                Bitte wende dich an den dev des Adapters.
                Von der Installation von Adaptern dirjet von Github wird exolizut abgeraten ausser für Testzwecke in Abstimmung mit dem dev.
                • mcm1957
                  mcm1957 @mcm1957 last edited by mcm1957
                  @mcm1957
                  @mcm1957 said in "homepilot20" stürzt nach js-controller 6.0.1-Update ab:
                  Von der Installation von Adaptern direkt von Github wird explizit abgeraten ausser für Testzwecke in Abstimmung mit dem dev.
                  @homecineplexx hat den Adapter dankenswerterweise angepasst. Bitte teste mit Version 0.0.53. Diese sollte nun auch mit js-controller funktionieren. - DANKE (Installation von Github und npm möglich, derzeit aber nicht in den Repos)
                  Sollte der Adapter nun auch mit js-ontroller 6 in gewohnter guter Qualität funktionieren rege ggF beim dev an diesen in den Repositories zu veröffentlichen. Die offizielle Empfehlung außer auf Anregung des Devs und zu Testzwecken keine Adapter direkt von Github auf produktiven Systemen zu installieren gilt unverändert.
                  • KlausStoertebeker
                    KlausStoertebeker @Samson71 last edited by
                    @samson71
                    Hallo Samson,
                    mein Repo steht auf "latest"...
                    Und weiter unten hat mcm1957 gesagt, dass der homepilot20-Adapter angepasst wurde. Dann werde ich das bei meiner geplanten Neuinstallation mal ausprobieren 🙂
                    • mcm1957
                      mcm1957 @KlausStoertebeker last edited by mcm1957
                      @samson71 said in "homepilot20" stürzt nach js-controller 6.0.1-Update ab:
                      @klausstoertebeker said in "homepilot20" stürzt nach js-controller 6.0.1-Update ab:
                      LATEST === BETA = Testversionen von Adaptern
                      STABLE = Versionen die bereits einige Zeit ohne (gröbere) Probleme im Latest getestet wurden.
                      Wenn du also nicht nagelneue Versionen zum Tests installieren willst, stell dein Repo auf STABLE. Zusätzlich solltest du solange du latest / beta eingestelltz hast am oberen Rand des Admin Adapter Tabs eine Warnmeldung sehen dass du auf latest / beta bist ...
