    4. invalid Key bei Zugriff auf iobroker
      Loco last edited by
      Hallo Leute!
      Nach mühsamer Neuinstallation von VIs und iobroker läuft meine VIS endlich wieder, jedoch komme ich nicht mehr auf iobroker. Wenn ich die Adresse 192.168.220.191:8081 oder http://192.168.220.191:8081/#tab-intro eingebe, kommt sofort die Meldung invalid key im Browser. Hätte ihr eine Idee was ich machen könnte?
      iob diag liefert folgendes:
      The state system.host.raspberrypi.versions.nodeNewestNext was not found!
      The state system.host.raspberrypi.versions.npmNewestNext was not found!
      The state system.host.raspberrypi.versions.nodeCurrent was not found!
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.20+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       12:06:59 up 16:22,  2 users,  load average: 0.53, 0.27, 0.21
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** Time and Time Zones ***
                     Local time: Fri 2024-06-14 12:06:59 CEST
                 Universal time: Fri 2024-06-14 10:06:59 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      HOME=/home/ioBroker
      GROUPS=ioBroker adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        986M        1.4G        1.2M        1.7G        3.0G
      Total:          4.1G        986M        1.5G
      Active iob-Instances:   25
               3792 M total memory
                941 M used memory
                939 M active memory
               1253 M inactive memory
               1334 M free memory
                154 M buffer memory
               1438 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 12:07:00 up 16:22,  2 users,  load average: 0.53, 0.27, 0.21
      Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 20.0 us, 20.0 sy,  0.0 ni, 40.0 id, 20.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.1 total,   1333.8 free,    941.9 used,   1593.1 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2850.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       29G  6.0G   22G  22% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   63M  448M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Thu Jun 13 19:44:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:3E:C9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d17a74ee-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Thu Jun 13 19:44:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
      [Thu Jun 13 19:44:41 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE      OPTIONS
      /                                                       /dev/mmcblk0p2 ext4        rw,noatime
      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1140
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671540k,nr_inodes=417885,mode=755
      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
      `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      636M    /var/
      325M    /var/cache
      319M    /var/cache/apt
      206M    /var/cache/apt/archives
      166M    /var/lib
      Archived and active journals take up 44.0M in the file system.
      /opt/iobroker/backups:
      89M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      762M    /opt/iobroker/iobroker-data/
      695M    /opt/iobroker/iobroker-data/files
      156M    /opt/iobroker/iobroker-data/files/vis-2
      90M     /opt/iobroker/iobroker-data/files/echarts.admin
      81M     /opt/iobroker/iobroker-data/files/vis-2/static
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      20M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.9f324f1d.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.14.0
      /usr/bin/node           v20.14.0
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.1
      nodejs:
        Installed: 20.14.0-1nodesource1
        Candidate: 20.14.0-1nodesource1
        Version table:
       *** 20.14.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
           18.13.0+dfsg1-1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.3.5
      javascript:     7.1.4
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled, compact enabled (group 1)
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.cameras.0                : cameras               : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 192.168.220.191
      + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled, compact enabled (group 1)
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, compact disabled, port: 8899
        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact enabled (group 1)
        system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled, compact enabled (group 1)
        system.adapter.hue-extended.1           : hue-extended          : raspberrypi                              -  enabled, compact enabled (group 1)
        system.adapter.hue-extended.2           : hue-extended          : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, compact enabled (group 1), port: 443
      + system.adapter.hue.1                    : hue                   : raspberrypi                              -  enabled, compact enabled (group 1), port: 443
      + system.adapter.hue.2                    : hue                   : raspberrypi                              -  enabled, compact enabled (group 1), port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact enabled (group 1)
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
      + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled, compact enabled (group 1)
        system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.signal-cmb.0             : signal-cmb            : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled, compact disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled, compact disabled
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact enabled (group 1)
      + system.adapter.vesync.0                 : vesync                : raspberrypi                              -  enabled, compact disabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact enabled (group 1)
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact enabled (group 1), port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "accuweather"  : 1.4.0    , installed 1.2.4  [Updatable]
      Adapter    "admin"        : 6.17.14  , installed 6.3.5  [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.25.2 [Updatable]
      Adapter    "backitup"     : 3.0.3    , installed 2.8.1  [Updatable]
      Adapter    "broadlink2"   : 2.3.0    , installed 2.1.5  [Updatable]
      Adapter    "cameras"      : 2.0.8    , installed 1.2.2  [Updatable]
      Adapter    "chromecast"   : 3.4.0    , installed 2.3.1  [Updatable]
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.8  [Updatable]
      Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
      Adapter    "discovery"    : 4.5.0    , installed 3.0.3  [Updatable]
      Adapter    "echarts"      : 1.8.1    , installed 1.5.4  [Updatable]
      Adapter    "fritzdect"    : 2.5.9    , installed 2.3.1  [Updatable]
      Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
      Adapter    "hue"          : 3.11.0   , installed 3.7.1  [Updatable]
      Adapter    "ical"         : 1.15.0   , installed 1.13.2 [Updatable]
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
      Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "javascript"   : 8.5.2    , installed 7.1.4  [Updatable]
      Controller "js-controller": 6.0.4    , installed 5.0.19 [Updatable]
      Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
      Adapter    "onvif"        : 1.1.4    , installed 0.4.4  [Updatable]
      Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
      Adapter    "sonoff"       : 3.1.0    , installed 2.5.7  [Updatable]
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.16 [Updatable]
      Adapter    "trashschedule": 3.3.0    , installed 2.0.3  [Updatable]
      Adapter    "vesync"       : 0.0.7    , installed 0.0.5  [Updatable]
      Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.1  [Updatable]
      Adapter    "vis-icontwo"  : 1.5.0    , installed 0.90.0 [Updatable]
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
      Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
      Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
      Adapter    "web"          : 6.2.6    , installed 6.1.10 [Updatable]
      Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
      Adapter    "ws"           : 2.6.1    , installed 2.5.8  [Updatable]
      Objects and States
      Objects:        10754
      States:         8987
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 23
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140543     15690/io.sonoff.0
      tcp        0      0 192.168.220.191:8081    0.0.0.0:*               LISTEN      1001       140610     15746/io.cameras.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       137914     15531/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       137909     15531/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6204       698/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       139723     15586/iobroker.js-c
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6215       698/sshd: /usr/sbin
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       139660     15731/io.broadlink2
      udp        0      0 0.0.0.0:54058           0.0.0.0:*                           1001       138138     15731/io.broadlink2
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       138110     15586/iobroker.js-c
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3065       526/avahi-daemon: r
      udp        0      0 0.0.0.0:45007           0.0.0.0:*                           104        3067       526/avahi-daemon: r
      udp6       0      0 :::42182                :::*                                104        3068       526/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        3066       526/avahi-daemon: r
      udp6       0      0 fe80::b8c3:506d:cd3:546 :::*                                0          1780       634/NetworkManager
      2024-06-14 12:07:27.172  - error: hue.1 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
      2024-06-14 12:07:27.798  - error: hue.2 (COMPACT) connect ECONNREFUSED 192.168.220.144:443
      2024-06-14 12:07:27.799  - warn: hue.2 (COMPACT) Could not get configuration from HUE bridge (192.168.220.144:443)
      2024-06-14 12:07:28.318  - error: hue.1 (COMPACT) connect ECONNREFUSED 192.168.220.133:443
      2024-06-14 12:07:28.318  - warn: hue.1 (COMPACT) Could not get configuration from HUE bridge (192.168.220.133:443)
      2024-06-14 12:07:28.863  - error: hue.2 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
      2024-06-14 12:07:32.816  - error: hue.2 (COMPACT) connect ECONNREFUSED 192.168.220.144:443
      2024-06-14 12:07:32.816  - warn: hue.2 (COMPACT) Could not get configuration from HUE bridge (192.168.220.144:443)
      2024-06-14 12:07:32.966  - error: hue.0 (COMPACT) connect EHOSTUNREACH 192.168.220.115:443
      2024-06-14 12:07:32.966  - warn: hue.0 (COMPACT) Could not get configuration from HUE bridge (192.168.220.115:443)
      2024-06-14 12:07:33.328  - error: hue.1 (COMPACT) connect ECONNREFUSED 192.168.220.133:443
      2024-06-14 12:07:33.328  - warn: hue.1 (COMPACT) Could not get configuration from HUE bridge (192.168.220.133:443)
      2024-06-14 12:07:37.177  - error: hue.0 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
      2024-06-14 12:07:37.178  - error: hue.1 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
      2024-06-14 12:07:37.835  - error: hue.2 (COMPACT) connect ECONNREFUSED 192.168.220.144:443
      2024-06-14 12:07:37.835  - warn: hue.2 (COMPACT) Could not get configuration from HUE bridge (192.168.220.144:443)
      2024-06-14 12:07:38.351  - error: hue.1 (COMPACT) connect ECONNREFUSED 192.168.220.133:443
      2024-06-14 12:07:38.351  - warn: hue.1 (COMPACT) Could not get configuration from HUE bridge (192.168.220.133:443)
      2024-06-14 12:07:38.867  - error: hue.2 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
      2024-06-14 12:07:41.026  - error: hue.0 (COMPACT) connect EHOSTUNREACH 192.168.220.115:443
      2024-06-14 12:07:41.026  - warn: hue.0 (COMPACT) Could not get configuration from HUE bridge (192.168.220.115:443)
      2024-06-14 12:07:42.958  - error: hue.2 (COMPACT) connect ECONNREFUSED 192.168.220.144:443
      2024-06-14 12:07:42.959  - warn: hue.2 (COMPACT) Could not get configuration from HUE bridge (192.168.220.144:443)
      2024-06-14 12:07:43.362  - error: hue.1 (COMPACT) connect ECONNREFUSED 192.168.220.133:443
      2024-06-14 12:07:43.362  - warn: hue.1 (COMPACT) Could not get configuration from HUE bridge (192.168.220.133:443)
      iob diag has finished.
      paul53 Thomas Braun 2 Replies Last reply Reply Quote 0
        paul53 @Loco last edited by
        @loco sagte: Idee was ich machen könnte?
        iob start admin.0
          Loco @paul53 last edited by
          @paul53 leider kein Erfolg....
            @loco sagte: leider kein Erfolg....
            Läuft die Admin-Instanz jetzt oder kamen Fehlermeldungen beim Start?
            iob list instances
            L Homoran 2 Replies Last reply Reply Quote 0
              Loco @paul53 last edited by Homoran
              ioBroker@raspberrypi:~ $ iob list instances
              + instance is alive
                Thomas Braun Most Active @Loco last edited by
                @loco sagte in invalid Key bei Zugriff auf iobroker:
                Pending Updates: 23
                Updaten...
                iob stop
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                Den ioBroker auch updaten, besser aber auf das Stable-Repo zurückgehen.
                  Homoran Global Moderator Administrators @paul53 last edited by Homoran
                  @paul53 sagte in invalid Key bei Zugriff auf iobroker:
                  nöö
                  • system.adapter.accuweather.0 : accuweather : raspberrypi - enabled, compact enabled (group 1)
                    Loco @Homoran last edited by
                    ich hab mal iob upgrade ausgeführt. Alle Adapter aktualisiert. Jetz geht es wieder.
                    Hab keine Ahnung warum! Wie auch immer, Chat kann geschloßen werden....
                    Danke für eure Hilfe!
                    Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                    • Ro75
                      Ro75 @Loco last edited by
                      @loco und an das Netzteil denken.
                      Ro75.
                        Weil die Kisten halt am besten laufen, wenn die vollständig auf einem aktuellen Stand sind, deswegen.
                          Loco @Ro75 last edited by
                          @ro75
                          Hab ich schon! Hab jetzt ein 3A Netzteil dran. Keine weiteren Meldungen bzgl. Undervoltage bisher gesehen...
                            Loco @Thomas Braun last edited by
                            Macht Sinn !!!! Sind aber immer diese Meldungen mit denen ein "etwas" Unwissender dann nicht so klarkommt und sich dann da durchbeißen muß (oder will). Finde es aber super das es dieses Forum gibt wo man (Mann) dann da auch mal nachfragen kann...
                            Schönes Wochenende euch allen und genießt die Fußball-EM
                              Loco @Loco last edited by
                              Gibt doch ein Problem, nach Update aller Adapter öffnet das Widget eCharts keine Diagramm mehr:
                              Die Diagramm sind da bei Zugriff auf eCharts über iobroker werden die Diagramm dargestellt. In der VIS jedoch nicht. Hätte jemand eine Idee warum?
                              Ach ja, die neuste Version von eCharts funzzt überhaupt nicht. Die Instanz wird unter iobroker nichtmal geöffnet. Bin auf Version 1.5.3 zurück, diese Instanz läßt sich öffnen und es werden Diagramme angezeigt (aber im Widget nicht).
                              BananaJoe amg_666 2 Replies Last reply Reply Quote 0
                              • BananaJoe
                                BananaJoe Most Active @Loco last edited by
                                @loco wie sind die Einstellungen im Web-Adapter? Screenshot. Könnte an der Web-Socket-Einstellung liegen
                                • amg_666
                                  amg_666 @Loco last edited by
                                  @loco Dann wirf mal einen Blick ins Github. Die Version 1.8.1 von eCharts hat da ein Problem, das ist bereits gemeldet.
                                  Ich bin da gestern auch drauf reingefallen 🙂
                                  https://github.com/ioBroker/ioBroker.echarts/issues/630
                                  sigi2345 created this issue in ioBroker/ioBroker.echarts
                                  closed Update Fehler 1.8.1 #630
                                  • BananaJoe
                                    BananaJoe Most Active @amg_666 last edited by
                                    @amg_666 Ich hatte verstanden er ist auf die 1.5.3 zurück und es geht immer noch nicht
                                    @Loco schon mal das System neu gestartet?
                                      Loco @BananaJoe last edited by
                                      @bananajoe: ich mußte wegen einem anderen Fehler ein Backup zurückspielen. Interesanterweise läuft eCharts jetzt in Version 1.8.1. Die Diagramme werden sauber angezeigt - keine Fehler mehr.
                                      Kann euch nicht sagen warum es jetzt geht,...
                                      amg_666 1 Reply Last reply Reply Quote 0
                                      • amg_666
                                        Bei der 1.8.1 werden bei mir die Diagramme in meiner VIS korrekt angezeigt, aber wenn ich auf dem iobroker admin links im Menu auf ECharts klicke, dann habe ich einen leeren Bildschirm
                                        Homoran BananaJoe 2 Replies Last reply Reply Quote 0
                                          Homoran Global Moderator Administrators @amg_666 last edited by
                                          @amg_666 wenn ich das noch richtig in Erinnerung habe führt der Link in der admin-Sidebar über den Adminport :8081.
                                          in der vis über web :8082
                                          • BananaJoe
                                            @amg_666 sagte in invalid Key bei Zugriff auf iobroker:
                                            Bei funktioniert 1.8.1 - außer auf einem Fire-Tablet. Schon älter, ungepatcht, mit Fully Kiosk. Da kommt dann einfach nichts.
                                            Eigentlich wollte ich das Tablet gar nicht anfassen, habe ich in 3 Jahren vielleicht 3 mal neu gestartet, das läuft einfach ...
                                            2019
