    4. Installation
    5. iob diag - Fehlermeldung
      hotspot_2 last edited by
      ich habe im iob diag diese Fehlermeldung entdeckt. Könnt ihr mir helfen was hier zu tun ist?
      Nodejs-Installation:
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      corepack:       N/A
      Recommended versions are nodejs 18.20.3 and npm 10.7.0
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed
      Vielen Dank schon mal.
        Thomas Braun Most Active @hotspot_2 last edited by
        @hotspot_2 sagte in iob diag - Fehlermeldung:
        Ja, eine aktuelle Version von nodejs installieren.
        iob nodejs-update 20
          hotspot_2 @Thomas Braun last edited by
          @thomas-braun sagte in iob diag - Fehlermeldung:
          Danke! Ist ein Testsystem das nicht so oft läuft, aber jetzt passt es.
            hotspot_2 @hotspot_2 last edited by
            @hotspot_2 Das sieht glaub nicht so gut aus, oder?
            ou are running nodejs v18.19.0. Do you want to install latest version from nodejs v.20 tree?
            Press <y> to continue or any other key to quit
            Trying to fix your installation now. Please be patient.
            Virtualization: lxc
            Waiting for ioBroker to shut down - Give me a minute...
            *** These repos are active on your system:
            Hit:1 http://ftp.debian.org/debian bookworm InRelease
            Hit:2 http://ftp.debian.org/debian bookworm-updates InRelease
            Hit:3 http://security.debian.org bookworm-security InRelease
            Reading package lists... Done
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://ftp.debian.org/debian bookworm InRelease
            Hit:3 http://ftp.debian.org/debian bookworm-updates InRelease
            Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
            Get:5 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [7936 B]
            Fetched 20.1 kB in 0s (50.1 kB/s)
            Installing nodejs now!
            E: Broken packages
            E: Broken packages
            *** You need to manually restart your container/virtual machine now! ***
            We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
            marcus@iobroker-test:/opt/iobroker$
              Thomas Braun Most Active @hotspot_2 last edited by Thomas Braun
              E: Broken packages
              Das ist aber eher nicht direkt von nodejs.
              sudo apt update
              sudo apt full-upgrade
              sagt?
              Ist das zufällig ein Docker?
                @thomas-braun Das ist ein proxmox container.
                Da war aber noch ein wenig was zu tun. NodeJS kam jetzt eine Meldung "Setting up nodejs20....".
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.15.0
                /usr/bin/node           v20.15.0
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                /usr/bin/corepack       0.28.1
                nodejs:
                  Installed: 20.15.0-1nodesource1
                  Candidate: 20.15.0-1nodesource1
                Jetzt schaut es besser aus.
                  Das kann das Skript halt nicht alles abfangen. Da muss der Systemadministrator auch mal reinschauen...
                    @thomas-braun Kurze Frage noch:
                    npm notice
                    npm notice New minor version of npm available! 10.7.0 -> 10.8.1
                    npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.8.1
                    npm notice To update run: npm install -g npm@10.8.1
                    npm notice
                    Sollte man das hier machen? Oder stellt das ein Problem dar? Ich habe mal abgespeichert das man nur nodejs updaten sollte und npm nicht einzeln.
                      @hotspot_2
                      Finger weg von npm. Das wird nie von Hand angepackt.
                        @thomas-braun Dann habe ich das doch korrekt abgespeichert! Sehr gut 😉 und vielen Dank.
                        354
