    5. [SOLVED] Warnmeldung bei mooncalc
      marios774 last edited by marios774
      Hallo ich habe die folgende Fehlermeldung im Log.
      javascript.0	19:09:00.021	warn	at Object.<anonymous> (script.js.common.000_System.010_x_Minuten.012_Mondstand_-_5min:36:5)
      Das Programm klappt, es es kommt immer die Meldung. Kann mir bitte hier einer helfen, Danke.
      ar  mooncalc = require('suncalc');
      //createState('0_userdata.0.Astro.Mondstand.MondAufgang', 0)
      //createState('0_userdata.0.Astro.Mondstand.MondUntergang', 0)
      //createState('0_userdata.0.Astro.Mondstand.MondSichtbar', 0, {unit: '°'})
      //createState('0_userdata.0.Astro.Mondstand.MondVerdeckt', 0, {unit: '°'})
      //createState("0_userdata.0.Astro.Mondstand.MondHoehe",0);
      //createState("0_userdata.0.Astro.Mondstand.MondAzimut",0);
      //createState("0_userdata.0.Astro.Mondstand.MondFraction",0);
      //createState("0_userdata.0.Astro.Mondstand.MondPhase",0);
      schedule("*/3 * * * *", async () => {
          var now = new Date();
          var moonpos = mooncalc.getMoonPosition(now, 50, 7);
          var hm = moonpos.altitude * 180 / Math.PI;
          var am = moonpos.azimuth * 180 / Math.PI + 180;
          var moonillu = mooncalc.getMoonIllumination(now, 50, 7);
          var f = moonillu.fraction;
          var p = moonillu.phase;
          var moontime = mooncalc.getMoonTimes(now, 50, 7);
          var tr = moontime.rise.getHours() + ':' + moontime.rise.getMinutes();
          var ts = moontime.set.getHours() + ':' + moontime.set.getMinutes();
          var state = 0;
                  if(p > 0.05) state = 1;
                  if(p > 0.2) state = 2;
                  if(p > 0.3) state = 3;
                  if(p > 0.45) state = 4;
                  if(p > 0.55) state = 5;
                  if(p > 0.7) state = 6;
                  if(p > 0.8) state = 7;
                  if(p > 0.95) state = 0;
          setState("0_userdata.0.Astro.Mondstand.MondPhasenText",state);
          setState("0_userdata.0.Astro.Mondstand.MondHoehe",hm.toFixed(1));
          setState("0_userdata.0.Astro.Mondstand.MondAzimut",am.toFixed());
          setState("0_userdata.0.Astro.Mondstand.MondFraction",f.toFixed(3));
          setState("0_userdata.0.Astro.Mondstand.MondPhase",p.toFixed(2));
          setState("0_userdata.0.Astro.Mondstand.MondAufgang",tr);
          setState("0_userdata.0.Astro.Mondstand.MondUntergang",ts);
          //console.info(ts);
          //console.info(tr);
          //console.info(state);
      Gruß Mario S.
        paul53 @marios774 last edited by paul53
        @marios774
        .toFixed(N) wandelt in einen String. Die Datenpunkte sind auch vom Typ "string"?
          Mit der Änderung kommt keine Fehlermeldung mehr.
          var state = "0";
                  if(p > 0.05) state = "1";
                  if(p > 0.2) state = "2";
                  if(p > 0.3) state = "3";
                  if(p > 0.45) state = "4";
                  if(p > 0.55) state = "5";
                  if(p > 0.7) state = "6";
                  if(p > 0.8) state = "7";
                  if(p > 0.95) state = "0";
          Danke.
