    4. iobroker startet nicht mehr
      manrum1 @Glasfaser last edited by manrum1
      Hallo, mein 2tes iobroker-system startet nicht mehr, benötige bitte Hilfe. FOlgendes ist der Output von iob diag:
                              v.2024-05-22
         Static hostname: iob2
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      User-ID:                1001
      Display-Server:         false
      Pending OS-Updates:     0
      node:internal/modules/cjs/loader:1143
        throw err;
      Error: Cannot find module '../path-exists'
      Require stack:
      - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js
      - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js
      - /opt/iobroker/node_modules/fs-extra/lib/index.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
          at Module._load (node:internal/modules/cjs/loader:981:27)
          at Module.require (node:internal/modules/cjs/loader:1231:19)
          at require (node:internal/modules/helpers:177:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24)
          at Module._compile (node:internal/modules/cjs/loader:1364:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          at Module.load (node:internal/modules/cjs/loader:1203:32)
          at Module._load (node:internal/modules/cjs/loader:1019:12)
          at Module.require (node:internal/modules/cjs/loader:1231:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js',
          '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js',
          '/opt/iobroker/node_modules/fs-extra/lib/index.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      Node.js v18.20.3
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v18.20.3
      /usr/bin/node           v18.20.3
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      MEMORY:
      Mem:            1.8G        318M        865M        1.0M        665M        1.5G
      Swap:            99M          0B         99M
      Total:          1.9G        318M        965M
      Active iob-Instances:   0
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.20.3
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.20.3
      ioBroker Core:          js-controller
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.20.3
                              admin
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.20.3
      ioBroker Status:
      Objects:                0
      States:                 0
      Size of iob-Database:
      7.8M    /opt/iobroker/iobroker-data/objects.jsonl
      1.3M    /opt/iobroker/iobroker-data/states.jsonl
      MOD-EDIT: Code-tags gefixt, Neuen Thread eröffnet
        Homoran Global Moderator Administrators @manrum1 last edited by Homoran
        @manrum1 bitte provisorischen Threadtitel anpassen und die Langfassung von iob diag posten
          manrum1 @Homoran last edited by manrum1
          @homoran äh, wie (Titel anpassen meine ich)?
            @manrum1 sagte in mein 2tes iobroker-system startet nicht mehr, benötige Hilfe:
            äh, wie
            ääähhh was? 😉
            EDIT: Der Herr haben editiert ohne Kennzeichnung!
            ersten Post editieren und Titel ändern
              @homoran Danke!
              Und hier noch die Langfassung:
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               12:14:58 up 17 min,  1 user,  load average: 0.34, 0.21, 0.18
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Sun 2024-06-23 12:14:58 CEST
                         Universal time: Sun 2024-06-23 10:14:58 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth gpio i2c
              js-controller is not running
              *** Display-Server-Setup ***
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            1.8G        332M        837M        1.0M        678M        1.4G
              Swap:            99M          0B         99M
              Total:          1.9G        332M        937M
                       1849 M total memory
                        332 M used memory
                        565 M active memory
                        315 M inactive memory
                        837 M free memory
                         48 M buffer memory
                        629 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              top - 12:14:59 up 17 min,  1 user,  load average: 0.34, 0.21, 0.18
              Tasks: 157 total,   1 running, 156 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 94.2 id,  1.4 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   1849.2 total,    837.5 free,    333.2 used,    678.5 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1439.1 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       29G  7.2G   20G  27% /
              devtmpfs       devtmpfs  667M     0  667M   0% /dev
              tmpfs          tmpfs     925M     0  925M   0% /dev/shm
              tmpfs          tmpfs     370M  1.1M  369M   1% /run
              /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
              tmpfs          tmpfs     185M     0  185M   0% /run/user/1001
              [Sun Jun 23 11:57:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:13:59:70 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=20988741-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sun Jun 23 11:57:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sun Jun 23 11:57:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sun Jun 23 11:57:30 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              Show mounted filesystems:
              TARGET                       SOURCE         FSTYPE     OPTIONS
              /                            /dev/mmcblk0p2 ext4       rw,noatime
              |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=682572k,nr_inodes=170643,mode=755
              | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
              | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
              | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
              |-/proc                      proc           proc       rw,relatime
              | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
              |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
              | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
              | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
              | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
              |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=378720k,nr_inodes=819200,mode=755
              | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
              | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
              | `-/run/user/1001           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=189356k,nr_inodes=47339,mode=700,uid=1001,gid=1001
              `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              4.4G    /var/
              3.6G    /var/log
              2.9G    /var/log/journal/879f6c73ec204cb2920b3b859423412b
              454M    /var/cache
              Archived and active journals take up 2.0G in the file system.
              /opt/iobroker/backups:
              18M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              136M    /opt/iobroker/iobroker-data/
              87M     /opt/iobroker/iobroker-data/files
              67M     /opt/iobroker/iobroker-data/files/javascript.admin
              48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
              7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              5.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/484.5f7d9187.chunk.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              nodejs:
                Installed: 18.20.3-1nodesource1
                Candidate: 18.20.3-1nodesource1
                Version table:
               *** 18.20.3-1nodesource1 600
                      100 /var/lib/dpkg/status
                   18.20.2-1nodesource1 600
                   18.20.1-1nodesource1 600
                   18.20.0-1nodesource1 600
                   18.19.1-1nodesource1 600
                   18.19.0-1nodesource1 600
                   18.18.2-1nodesource1 600
                   18.18.1-1nodesource1 600
                   18.18.0-1nodesource1 600
                   18.17.1-1nodesource1 600
                   18.17.0-1nodesource1 600
                   18.16.1-1nodesource1 600
                   18.16.0-1nodesource1 600
                   18.15.0-1nodesource1 600
                   18.14.2-1nodesource1 600
                   18.14.1-1nodesource1 600
                   18.14.0-1nodesource1 600
                   18.13.0-1nodesource1 600
                   18.12.0-1nodesource1 600
                   18.11.0-1nodesource1 600
                   18.10.0-1nodesource1 600
                   18.9.1-1nodesource1 600
                   18.9.0-1nodesource1 600
                   18.8.0-1nodesource1 600
                   18.7.0-1nodesource1 600
                   18.6.0-1nodesource1 600
                   18.5.0-1nodesource1 600
                   18.4.0-1nodesource1 600
                   18.3.0-1nodesource1 600
                   18.2.0-1nodesource1 600
                   18.1.0-1nodesource1 600
                   18.0.0-1nodesource1 600
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.20.3
              Core adapters versions
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.20.3
              js-controller:
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.20.3
              admin:
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.20.3
              javascript:
              Adapter State
              ioBroker-Repositories
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.20.3
              Installed ioBroker-Instances
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.20.3
              Objects and States
              Objects:        0
              States:         0
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://repos.influxdata.com/debian bullseye InRelease
              Hit:6 https://apt.grafana.com stable InRelease
              Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1864       506/sshd: /usr/sbin
              tcp6       0      0 :::22                   :::*                    LISTEN      0          1866       506/sshd: /usr/sbin
              tcp6       0      0 :::3000                 :::*                    LISTEN      110        13792      695/grafana
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        13742      635/influxd
              udp        0      0 0.0.0.0:44677           0.0.0.0:*                           108        14890      356/avahi-daemon: r
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1880       631/dhcpcd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14888      356/avahi-daemon: r
              udp6       0      0 :::36594                :::*                                108        14891      356/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        14889      356/avahi-daemon: r
              2024-06-14 22:33:00.038  - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated
              2024-06-14 22:33:00.056  - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated
              2024-06-14 22:33:00.057  - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus
              2024-06-14 22:33:00.073  - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated
              2024-06-14 22:34:00.007  - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated
              2024-06-14 22:34:00.018  - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated
              2024-06-14 22:34:00.018  - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus
              2024-06-14 22:34:00.030  - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated
              2024-06-14 22:34:00.044  - info: javascript.0 (931) script.js.hichi.hichi-run: Strom HichiMB Werte geschrieben
              2024-06-14 22:35:00.020  - info: javascript.0 (931) script.js.hichi.hichi-run: Strom HichiMB Werte geschrieben
              2024-06-14 22:35:00.041  - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated
              2024-06-14 22:35:00.066  - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated
              2024-06-14 22:35:00.067  - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus
              2024-06-14 22:35:00.079  - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated
              2024-06-14 22:36:00.007  - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated
              2024-06-14 22:36:00.018  - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated
              2024-06-14 22:36:00.018  - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus
              2024-06-14 22:36:00.031  - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated
              2024-06-14 22:36:00.045  - info: javascript.0 (931) script.js.hichi.hichi-run: Strom HichiMB Werte geschrieben
              2024-06-14 22:37:00.008  - info: javascript.0 (931) script.js.hichi.hichi-run: Strom HichiMB Werte geschrieben
              2024-06-14 22:37:00.018  - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated
              2024-06-14 22:37:00.030  - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated
              2024-06-14 22:37:00.031  - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus
              2024-06-14 22:37:00.043  - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated
                Thomas Braun Most Active @manrum1 last edited by Thomas Braun
                @manrum1
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                Und verwende den user mit der uid=1000, nicht den user iobroker mit der uid=1001.
                  manrum1 @Thomas Braun last edited by
                  @thomas-braun Danke für deine schnelle Antwort. Das ist de rOutput:
                  iobroker@iob2:~ $ cd /opt/iobroker
                  iobroker@iob2:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                  npm error code 1
                  npm error path /opt/iobroker/node_modules/iobroker.js-controller
                  npm error command failed
                  npm error command sh -c node iobroker.js setup first
                  npm error node:internal/modules/cjs/loader:1143
                  npm error   throw err;
                  npm error   ^
                  npm error
                  npm error Error: Cannot find module '../path-exists'
                  npm error Require stack:
                  npm error - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js
                  npm error - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js
                  npm error - /opt/iobroker/node_modules/fs-extra/lib/index.js
                  npm error - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
                  npm error - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
                  npm error - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                  npm error     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                  npm error     at Module._load (node:internal/modules/cjs/loader:981:27)
                  npm error     at Module.require (node:internal/modules/cjs/loader:1231:19)
                  npm error     at require (node:internal/modules/helpers:177:18)
                  npm error     at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24)
                  npm error     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                  npm error     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                  npm error     at Module.load (node:internal/modules/cjs/loader:1203:32)
                  npm error     at Module._load (node:internal/modules/cjs/loader:1019:12)
                  npm error     at Module.require (node:internal/modules/cjs/loader:1231:19) {
                  npm error   code: 'MODULE_NOT_FOUND',
                  npm error   requireStack: [
                  npm error     '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js',
                  npm error     '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js',
                  npm error     '/opt/iobroker/node_modules/fs-extra/lib/index.js',
                  npm error     '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
                  npm error     '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
                  npm error     '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  npm error   ]
                  npm error }
                  npm error
                  npm error Node.js v18.20.3
                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-06-23T10_25_13_196Z-debug-0.log
                    @manrum1
                    Versuch mal den fixer.
                    iob stop
                    iob fix
                    iob start
                      @thomas-braun Habe ich vor her schon mal versucht. Jetzt noch mal ohne Erfolg.
                       iob fix
                      library: loaded
                      Library version=2024-05-24
                          Welcome to the ioBroker installation fixer!
                          Script version: 2024-01-04
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/5)
                      OK:1 http://deb.debian.org/debian bullseye InRelease
                      OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                      OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                      OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:5 https://repos.influxdata.com/debian bullseye InRelease
                      OK:6 https://apt.grafana.com stable InRelease
                      OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Checking ioBroker user and directory permissions (2/5)
                      [sudo] Passwort f▒r iobroker:
                          Check and cleanup npm temporary directories (3/5)
                      Done.
                          Database maintenance (4/5)
                      Checking for uncompressed JSONL databases... This might take a while!
                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                      Compressed 2 JSONL files. Done
                          Checking autostart (5/5)
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                        @manrum1 sagte in iobroker startet nicht mehr:
                        ohne Erfolg.
                        woran siehst du das?
                          @manrum1
                          [sudo] Passwort für iobroker:
                          Du bist da noch mit dem falschen user bzw. einem falschen Setup unterwegs.
                          An der Stelle dürfte eigentlich das Passwort nicht für den iobroker angefragt werden.
                            @thomas-braun sagte in iobroker startet nicht mehr:
                            hab immer noch nicht erkennen können, wer da gerade wo jnterwegs ist 1000 oder 1001?
                            iobroker oder iobroker 😡
                              @homoran Sorry, war unterwegs. Der User heißt iobroker und hat die UID 1001:
                              iobroker❌1001:1001::/home/iobroker:/bin/bash
                                @homoran Woran sehe ich das?
                                1. ich komme nicht per WEB drauf.
                                2. ich habe immer noch die npm errors
                                • DJMarc75
                                  DJMarc75 @manrum1 last edited by
                                  dann mach halt nen anderen User ... z.B. Dein Vorname damit der User sich von dem Systemuser auch unterscheidet 😉
                                    manrum1 @DJMarc75 last edited by
                                    @djmarc75 Mir war nicht bewusst, dass der user nicht iobroker heißen darf. Lief bisher und die directory permissions stehen alle ebenfalls auf iobroker. Aber sicher, wenn es Sinn macht ändere ich das. Nur wie?
                                      Nur wie?
                                      Es muss aber auch bereits einen User mit der uid 1000 geben.
                                      grep 1000 /etc/passwd
                                      sagt?
                                        @thomas-braun Ja, gibt es. Was soll ich tun?
                                          @manrum1
                                          Dich mit diesem user einloggen und NICHT mit dem 'iobroker' Der ist dafür nicht gedacht.
                                            @thomas-braun Ja, habe ich genacht. Deshalb läuft aber mein iobroker immer noch nicht.
                                            934
