    4. Probleme mit verschiedenen Adaptern (HUE, Javascript, Harmony)
      Spike08122 last edited by
      Sverus Zusammen,
      wie oben schon gesagt, habe ich Probleme mit verschienden Adaptern. Ich habe (natürlich) in letzten Zeit viel ausprobiert. Das Letzte war der Harmony-Adapter. Da ich den nicht installieren konnte, habe ich eine Update vom RPI gemacht. Ich glaube seit dem habe ich Probleme, aber der Reihe nach.
      1. Javascript-Adapter
      Der Log gibt mir da einiges an Fehlermeldungen aus
      ! javascript.0 2017-09-10 12:10:01.112 error at TCP.onread (net.js:547:20)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket.Readable.push (_stream_readable.js:134:10)
      ! javascript.0 2017-09-10 12:10:01.112 error at readableAddChunk (_stream_readable.js:176:18)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket.emit (events.js:188:7)
      ! javascript.0 2017-09-10 12:10:01.112 error at emitOne (events.js:96:13)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket.realHandler (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:825:20)
      ! javascript.0 2017-09-10 12:10:01.112 error at Receiver.add (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:103:24)
      ! javascript.0 2017-09-10 12:10:01.112 error at Receiver.expectHandler (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:499:31)
      ! javascript.0 2017-09-10 12:10:01.112 error at Receiver.finish (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:541:12)
      ! javascript.0 2017-09-10 12:10:01.112 error at Receiver.flush (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:347:3)
      ! javascript.0 2017-09-10 12:10:01.112 error at /opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:508:14
      ! javascript.0 2017-09-10 12:10:01.112 error at Receiver.applyExtensions (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:371:5)
      ! javascript.0 2017-09-10 12:10:01.112 error at /opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
      ! javascript.0 2017-09-10 12:10:01.112 error at Receiver.ontext (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
      ! javascript.0 2017-09-10 12:10:01.112 error at WebSocket.emit (events.js:191:7)
      ! javascript.0 2017-09-10 12:10:01.112 error at emitTwo (events.js:106:13)
      ! javascript.0 2017-09-10 12:10:01.112 error at WebSocket.onMessage (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
      ! javascript.0 2017-09-10 12:10:01.112 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      ! javascript.0 2017-09-10 12:10:01.112 error at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
      ! javascript.0 2017-09-10 12:10:01.112 error at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
      ! javascript.0 2017-09-10 12:10:01.112 error at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      ! javascript.0 2017-09-10 12:10:01.112 error at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! javascript.0 2017-09-10 12:10:01.112 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      ! javascript.0 2017-09-10 12:10:01.112 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      ! javascript.0 2017-09-10 12:10:01.112 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      ! javascript.0 2017-09-10 12:10:01.112 error at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! javascript.0 2017-09-10 12:10:01.112 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      ! javascript.0 2017-09-10 12:10:01.112 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! javascript.0 2017-09-10 12:10:01.112 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      ! javascript.0 2017-09-10 12:10:01.112 error at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2185:38)
      ! javascript.0 2017-09-10 12:10:01.112 error TypeError: name.match is not a function
      ! javascript.0 2017-09-10 12:10:01.111 error uncaught exception: name.match is not a function
      mit denen ich nix anfangen kann.
      2. HUE-Adapter
      Der Adapter ist installiert und mit der richtigen IP eingerichtet, aber er findet die HUE-Brigde nicht. Beide befinden sich im gleichen Netzwerk. Soweit ich gelesen habe, sind sonst keine weiteren Einstellugnen nötig. In den Objekten wiird auch kein Datenpunkt angelegt.
      ! hue.0 2017-09-10 12:24:25.752 warn could not connect to ip
      ! hue.0 2017-09-10 12:24:20.730 warn could not connect to ip
      ! hue.0 2017-09-10 12:24:15.704 warn could not connect to ip
      ! hue.0 2017-09-10 12:24:10.683 warn could not connect to ip
      ! hue.0 2017-09-10 12:24:10.620 info starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.hue, node: v6.11.3
      ! hue.0 2017-09-10 12:24:06.535 info terminating
      3. Harmony-Adapter
      Im Prizip gleiches Probelem wie mit HUE, ioBroker findet den HUB nicht. Er sucht, aber es gibt dann auch keinen Datenpunkt bei den Objekten.
      ! harmony.0 2017-09-10 12:34:06.976 debug redis publish io.system.adapter.harmony.0.outputCount {"val":8,"ack":true,"ts":1505039646976,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:34:06.974 debug redis publish io.system.adapter.harmony.0.inputCount {"val":0,"ack":true,"ts":1505039646973,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:34:06.971 debug redis publish io.system.adapter.harmony.0.uptime {"val":78,"ack":true,"ts":1505039646970,"q":0,"from":"system.adapter.harmony.0","lc":1505039646970}
      ! harmony.0 2017-09-10 12:34:06.968 debug redis publish io.system.adapter.harmony.0.memHeapUsed {"val":11.52,"ack":true,"ts":1505039646967,"q":0,"from":"system.adapter.harmony.0","lc":1505039646967}
      ! harmony.0 2017-09-10 12:34:06.966 debug redis publish io.system.adapter.harmony.0.memHeapTotal {"val":15.98,"ack":true,"ts":1505039646965,"q":0,"from":"system.adapter.harmony.0","lc":1505039646965}
      ! harmony.0 2017-09-10 12:34:06.963 debug redis publish io.system.adapter.harmony.0.memRss {"val":32.41,"ack":true,"ts":1505039646962,"q":0,"from":"system.adapter.harmony.0","lc":1505039646962}
      ! harmony.0 2017-09-10 12:34:06.960 debug redis publish io.system.adapter.harmony.0.connected {"val":true,"ack":true,"ts":1505039646960,"q":0,"from":"system.adapter.harmony.0","lc":1505039571948}
      ! harmony.0 2017-09-10 12:34:06.959 debug redis publish io.system.adapter.harmony.0.alive {"val":true,"ack":true,"ts":1505039646958,"q":0,"from":"system.adapter.harmony.0","lc":1505039571946}
      ! harmony.0 2017-09-10 12:33:51.979 debug redis publish io.system.adapter.harmony.0.outputCount {"val":8,"ack":true,"ts":1505039631978,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:33:51.976 debug redis publish io.system.adapter.harmony.0.inputCount {"val":0,"ack":true,"ts":1505039631976,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:33:51.973 debug redis publish io.system.adapter.harmony.0.uptime {"val":63,"ack":true,"ts":1505039631973,"q":0,"from":"system.adapter.harmony.0","lc":1505039631973}
      ! harmony.0 2017-09-10 12:33:51.971 debug redis publish io.system.adapter.harmony.0.memHeapUsed {"val":11.6,"ack":true,"ts":1505039631970,"q":0,"from":"system.adapter.harmony.0","lc":1505039631970}
      ! harmony.0 2017-09-10 12:33:51.968 debug redis publish io.system.adapter.harmony.0.memHeapTotal {"val":16.98,"ack":true,"ts":1505039631967,"q":0,"from":"system.adapter.harmony.0","lc":1505039631967}
      ! harmony.0 2017-09-10 12:33:51.963 debug redis publish io.system.adapter.harmony.0.memRss {"val":32.48,"ack":true,"ts":1505039631962,"q":0,"from":"system.adapter.harmony.0","lc":1505039631962}
      ! harmony.0 2017-09-10 12:33:51.959 debug redis publish io.system.adapter.harmony.0.connected {"val":true,"ack":true,"ts":1505039631959,"q":0,"from":"system.adapter.harmony.0","lc":1505039571948}
      ! harmony.0 2017-09-10 12:33:51.956 debug redis publish io.system.adapter.harmony.0.alive {"val":true,"ack":true,"ts":1505039631955,"q":0,"from":"system.adapter.harmony.0","lc":1505039571946}
      ! harmony.0 2017-09-10 12:33:36.990 debug redis publish io.system.adapter.harmony.0.outputCount {"val":8,"ack":true,"ts":1505039616990,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:33:36.987 debug redis publish io.system.adapter.harmony.0.inputCount {"val":0,"ack":true,"ts":1505039616985,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:33:36.984 debug redis publish io.system.adapter.harmony.0.uptime {"val":48,"ack":true,"ts":1505039616983,"q":0,"from":"system.adapter.harmony.0","lc":1505039616983}
      ! harmony.0 2017-09-10 12:33:36.982 debug redis publish io.system.adapter.harmony.0.memHeapUsed {"val":11.4,"ack":true,"ts":1505039616982,"q":0,"from":"system.adapter.harmony.0","lc":1505039616982}
      ! harmony.0 2017-09-10 12:33:36.973 debug redis publish io.system.adapter.harmony.0.memHeapTotal {"val":15.98,"ack":true,"ts":1505039616972,"q":0,"from":"system.adapter.harmony.0","lc":1505039616972}
      ! harmony.0 2017-09-10 12:33:36.970 debug redis publish io.system.adapter.harmony.0.memRss {"val":32.44,"ack":true,"ts":1505039616969,"q":0,"from":"system.adapter.harmony.0","lc":1505039616969}
      ! harmony.0 2017-09-10 12:33:36.968 debug redis publish io.system.adapter.harmony.0.connected {"val":true,"ack":true,"ts":1505039616967,"q":0,"from":"system.adapter.harmony.0","lc":1505039571948}
      ! harmony.0 2017-09-10 12:33:36.965 debug redis publish io.system.adapter.harmony.0.alive {"val":true,"ack":true,"ts":1505039616949,"q":0,"from":"system.adapter.harmony.0","lc":1505039571946}
      ! harmony.0 2017-09-10 12:33:21.939 debug redis publish io.system.adapter.harmony.0.outputCount {"val":8,"ack":true,"ts":1505039601938,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:33:21.934 debug redis publish io.system.adapter.harmony.0.inputCount {"val":0,"ack":true,"ts":1505039601934,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:33:21.921 debug redis publish io.system.adapter.harmony.0.uptime {"val":33,"ack":true,"ts":1505039601920,"q":0,"from":"system.adapter.harmony.0","lc":1505039601920}
      ! harmony.0 2017-09-10 12:33:21.918 debug redis publish io.system.adapter.harmony.0.memHeapUsed {"val":12.65,"ack":true,"ts":1505039601917,"q":0,"from":"system.adapter.harmony.0","lc":1505039601917}
      ! harmony.0 2017-09-10 12:33:21.915 debug redis publish io.system.adapter.harmony.0.memHeapTotal {"val":16.98,"ack":true,"ts":1505039601915,"q":0,"from":"system.adapter.harmony.0","lc":1505039601915}
      ! harmony.0 2017-09-10 12:33:21.913 debug redis publish io.system.adapter.harmony.0.memRss {"val":33.39,"ack":true,"ts":1505039601913,"q":0,"from":"system.adapter.harmony.0","lc":1505039601913}
      ! harmony.0 2017-09-10 12:33:21.911 debug redis publish io.system.adapter.harmony.0.connected {"val":true,"ack":true,"ts":1505039601911,"q":0,"from":"system.adapter.harmony.0","lc":1505039571948}
      ! harmony.0 2017-09-10 12:33:21.908 debug redis publish io.system.adapter.harmony.0.alive {"val":true,"ack":true,"ts":1505039601907,"q":0,"from":"system.adapter.harmony.0","lc":1505039571946}
      ! harmony.0 2017-09-10 12:33:06.942 debug redis publish io.system.adapter.harmony.0.outputCount {"val":8,"ack":true,"ts":1505039586942,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:33:06.939 debug redis publish io.system.adapter.harmony.0.inputCount {"val":0,"ack":true,"ts":1505039586939,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:33:06.937 debug redis publish io.system.adapter.harmony.0.uptime {"val":18,"ack":true,"ts":1505039586937,"q":0,"from":"system.adapter.harmony.0","lc":1505039586937}
      ! harmony.0 2017-09-10 12:33:06.935 debug redis publish io.system.adapter.harmony.0.memHeapUsed {"val":14.11,"ack":true,"ts":1505039586933,"q":0,"from":"system.adapter.harmony.0","lc":1505039586933}
      ! harmony.0 2017-09-10 12:33:06.932 debug redis publish io.system.adapter.harmony.0.memHeapTotal {"val":31.98,"ack":true,"ts":1505039586910,"q":0,"from":"system.adapter.harmony.0","lc":1505039586910}
      ! harmony.0 2017-09-10 12:33:06.909 debug redis publish io.system.adapter.harmony.0.memRss {"val":40.35,"ack":true,"ts":1505039586906,"q":0,"from":"system.adapter.harmony.0","lc":1505039586906}
      ! harmony.0 2017-09-10 12:33:06.905 debug redis publish io.system.adapter.harmony.0.connected {"val":true,"ack":true,"ts":1505039586905,"q":0,"from":"system.adapter.harmony.0","lc":1505039571948}
      ! harmony.0 2017-09-10 12:33:06.904 debug redis publish io.system.adapter.harmony.0.alive {"val":true,"ack":true,"ts":1505039586903,"q":0,"from":"system.adapter.harmony.0","lc":1505039571946}
      ! harmony.0 2017-09-10 12:32:51.969 debug redis mget 1 1
      ! harmony.0 2017-09-10 12:32:51.961 debug redis publish io.system.adapter.harmony.0.outputCount {"val":8,"ack":true,"ts":1505039571961,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:32:51.959 debug redis publish io.system.adapter.harmony.0.inputCount {"val":0,"ack":true,"ts":1505039571959,"q":0,"from":"system.adapter.harmony.0","lc":1504806216428}
      ! harmony.0 2017-09-10 12:32:51.958 debug redis publish io.system.adapter.harmony.0.uptime {"val":3,"ack":true,"ts":1505039571957,"q":0,"from":"system.adapter.harmony.0","lc":1505039571957}
      ! harmony.0 2017-09-10 12:32:51.956 debug redis publish io.system.adapter.harmony.0.memHeapUsed {"val":13.73,"ack":true,"ts":1505039571956,"q":0,"from":"system.adapter.harmony.0","lc":1505039571956}
      ! harmony.0 2017-09-10 12:32:51.953 debug redis publish io.system.adapter.harmony.0.memHeapTotal {"val":30.98,"ack":true,"ts":1505039571953,"q":0,"from":"system.adapter.harmony.0","lc":1505039571953}
      ! harmony.0 2017-09-10 12:32:51.952 debug redis publish io.system.adapter.harmony.0.memRss {"val":40.04,"ack":true,"ts":1505039571951,"q":0,"from":"system.adapter.harmony.0","lc":1505039571951}
      ! harmony.0 2017-09-10 12:32:51.949 debug redis publish io.system.adapter.harmony.0.connected {"val":true,"ack":true,"ts":1505039571948,"q":0,"from":"system.adapter.harmony.0","lc":1505039571948}
      ! harmony.0 2017-09-10 12:32:51.946 debug redis publish io.system.adapter.harmony.0.alive {"val":true,"ack":true,"ts":1505039571946,"q":0,"from":"system.adapter.harmony.0","lc":1505039571946}
      ! harmony.0 2017-09-10 12:32:51.942 debug redis keys 1 .logging
      ! harmony.0 2017-09-10 12:32:51.939 info searching for Harmony Hubs…
      ! harmony.0 2017-09-10 12:32:51.925 debug redis psubscribe io.harmony.0.checkLogging
      ! harmony.0 2017-09-10 12:32:51.905 debug redis psubscribe io.harmony.0.
      ! harmony.0 2017-09-10 12:32:51.897 info starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.harmony, node: v6.11.3
      ! harmony.0 2017-09-10 12:32:51.866 debug redis get system.adapter.harmony.0.alive ok: {"val":false,"ack":true,"ts":1505039566433,"q":0,"from":"system.host.ioBroker-RasPi","lc":1505039566385}
      ! harmony.0 2017-09-10 12:32:51.848 info States connected to redis: 127.0.0.1:6379
      Ich hoffe, es ist kein Problem, dass ich das hier in einem Beitrag geschieben habe.
      Vielen Dank schon im Voraus :?:
      Spike
      • eric2905
        eric2905 last edited by
        eine Frage vorab.
        Hast Du Redis aktiviert?
        Und auch Multihost?
        Bei mir findet der Harmonie-Adapter die Bridge selber und ließt auch alles ein.
        Gruß,
        Eric
        Von unterwegs getippert
        • apollon77
          apollon77 last edited by
          das nächste mal am besten ein Thread pro Adapter der Probleme macht sonst wird es schnell unübersichtlich.
          JavaScript:
          Welche Adapter-version läuft?
          Hast DU ein Script was "createState" nutzt? Wenn ja, ist da alles korrekt. Der Fehler kann an sich nur passieren wenn ein Skriptname kein String ist oder bei "createState" der Name kein STring ist. Also bitte Code checken bzw zeigen.
          Hue:
          Du kannst von dem Rechner aus wo ioBroker läuft ein "ping" an die Hue-Bridge IP absetzen? Das geht?
          Harmony:
          Siehe Hue
          Wenn zwei Adapter die woanders hin verbinden wollen das nicht können sieht da irgendwie das Netzwerk für mich als Verursacher aus.
            @eric
            ich habe nichts weiter eingestellt, weder Redis noch Multihost (sag mir nichts, sorry)
            Ich habe beide Geräte gepingt, die HUE hat geantwortet die HUB nicht, obwohl er laut FB im Netz ist. Per App kann ich den HUB auch nicht erreichen. Wenn ich ihn per USB am PC habe, ist das Netzwerk aber eingerichtet.
            Ich nutze auch noch Yonomi um alles per Alexa zu steuern, was Problemlos funktioniert.
            Ich habe ich ein Script mit createState zum Testen, weil ich mich da n bisschen reinarbeiten will
            schedule("*/10 * * * *",  function () { // alle 30 Minuten - für Tests ggf auskommentieren
            createState("Anwesenheit.LG_G3", 0);   // State für Anwesenheit erstellen
            if ("radar.0.Holger_G3.here" === true) {setState("javascript.0.Anwesenheit.LG_G3",1);}
            else {setState("javascript.0.Anwesenheit.LG_G3",0);}
            }); // für Tests ggf aus kommentieren
            Fehlermeldungen kommen da nicht.
              @Spike08122:
              ich habe nichts weiter eingestellt, weder Redis noch Multihost (sag mir nichts, sorry) `
              Lt. Log läuft bei dir Redis.
              Hast du a) selbst installiert oder b) ein Image genommen?
              bei a) nach welcher Anleitung)
              wenn b) welches Image genau?
              hast du git für harmony installiert?
              • eric2905
                @Spike08122:
                Ich habe beide Geräte gepingt, ….. die HUB nicht, obwohl er laut FB im Netz ist. Per App kann ich den HUB auch nicht erreichen. `
                solange Du den Hub vom ioBroker aus nicht erreichst, ist das Deine vorrangige Baustelle.
                Welche IP, Subnetzmaske und Gateway-Adresse haben denn der Raspi und der Hub?
                Gruß,
                Eric
                  Pman last edited by
                  Dass man bei HUE nur die IP einrichten muss stimmt so nicht, man muss einen USER auf der Bridge erstellen. Das sollte einfach in der Adapter-Konfig funktionieren.
                  • eric2905
                    Solange er die Bridge nicht per Ping erreicht, hat er erst mal irgendwas in der Konfig unschön, oder ein Netzwerkproblem.
                    Gruß,
                    Eric
                      Pman last edited by
                      Er schrieb doch, dass die Bridge antwortet?
                      • eric2905
                        Die Hue-Bridge soll wohl antworten, der Harmony-Hub wohl nicht - zumindest habe ich es so verstanden.
                        @Spike08122:
                        Ich habe beide Geräte gepingt, die HUE hat geantwortet die HUB nicht, obwohl er laut FB im Netz ist. `
                        Gruß,
                        Eric
                          Danke für Eure Bemühungen erstmal einem Blinden beim Sehen zu helfen.
                          Ich werde mal versuchen alles Fragen zu beantworten. Falls ich alles verstanden habe :x
                          -Installierte Vesion von ioBroker ist iobroker_RPi_2_3_20170514 (das kleine Image)
                          • HUE ist per ping erreichbar, HUB <u>nicht</u> (Hab ich gerade nochmal getestet). Der HUB ist aber an der FB online. Das Problem mit dem HUB, kann ich aber im Moment nicht weiter verfolgen. Hab gerade Urlaub und meine Frau wäre nicht begeistert, wenn ich mich da mit solchen Problemen beschäftige. Wir wissen ja alle, das da schnell mal n paar Stunden vergehen.
                          Zur Konfiguration: Alles was mit IOT zu tun hat hängt an einer FB, mit jeweils über die FB fest zugeordneten IP´s.
                          Javascript stand heute auf rot, musste ich neu Starten, damit der Adapter wieder läuft.
                          Sollte ich vielleicht ne komplette Neuistallation in Betracht ziehen?
                          Spike
                          • eric2905
                            nur zur Sicherheit … mit HUB meinst Du den Harmony Hub, oder?
                            Poste mal bitte die Netzwerkkonfiguration (IP, Subnetzmaske und Gateway) von ioBroker, Fritzbox und dem HUB.
                            Gruß,
                            Eric
                              @eric: ja sorry, HUB ist der Harmony HUB
                              Netzwerkkonfiguration ist "kompliziert" 😄 , wenn ich jetzt darüber nachdenke, könnte das vielleicht tatsächlich eine Fehlerquelle sein :idea:
                              Internetzugang über einen Gigacube (IP: 192.168.2.1)
                              daran hängt eine FB1 mit eigenem WLAN und IP-Bereich über LAN
                              IP von FB1: 192.162.188.1
                              über LAN die HUE 192.168.188.20 und der Raspimatic IP: 192.168.188.27
                              daran habe ich auch meine WLAN-Garäte angemeldet, also
                              Harmony HUB 192.168.188.61, jeweils mit fester IP über die FB,
                              Weiter hängt über LAN eine weitere FB2 dran, da hängt n Telefon und der ioBroker über LAN dran
                              IP ioBroker: 192.168.188.24
                              Also kurz zusammengefaßt, zwischen dem ioBroker und dem Rest hängt noch die FB2, daraus könnte sich ein Zugriffsproblem ioBroker>FB2>FB1 ergeben. Aber bin da Netzwerkmäßig nicht so fit.
                              Könnte das ein Problem sein?
                              Aber ich erreiche den (Harmony) HUB auch von meinem Tab aus nicht, da aber auch im den Netzwerk von FB1 über WLAN drin ist.
                              Ich hoffe das war verständlich.
                              Spike
                              1113
