    4. [gelöst ] Hilfe bei SourceAnalytix
      Kuddel last edited by Kuddel
      Bitte ausfüllen:
      • Adaptername: SourceAnalytix
      • Link zu Adapterrepository: https://github.com/DrozmotiX/ioBroker.sourceanalytix
      • Adapterversion: 0.4.14
      • js-controller Version: 5.0.19
      • Admin Version: 6.13.16
      • Hardwaresystem: NUC (ESX) mit Ubuntu VM
      • Arbeitsspeicher: 6GB
      • Festplattenart: SSD
      • Betriebssystem: Ubuntu 22.04.4 LTS
      • Nodejs-Version: 18.20.3
      • NPM-Version: 10.7.0
      • Installationsart: Manuell
      • Image, Docker genutzt: Nein
      iobdiag:
                             v.2024-05-22
      Static hostname: ioBroker-PROD
            Icon name: computer-vm
              Chassis: vm
       Virtualization: vmware
      Operating System: Ubuntu 22.04.4 LTS
               Kernel: Linux 5.15.0-113-generic
         Architecture: x86-64
      Hardware Vendor: VMware, Inc.
       Hardware Model: VMware Virtual Platform
      Installation:           vmware
      User-ID:                0
      Display-Server:         false
      Pending OS-Updates:     0
      Pending iob updates:    8
      Nodejs-Installation:
      /usr/bin/nodejs         v18.20.3
      /usr/bin/node           v18.20.3
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      Recommended versions are nodejs 18.20.3 and npm 10.7.0
      MEMORY:
      Mem:            5.9G        4.2G        592M        1.0M        1.1G        1.4G
      Swap:           2.0G        1.3G        742M
      Total:          7.9G        5.5G        1.3G
      Active iob-Instances:   45
                             admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBroker-PROD                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : ioBroker-PROD                            -  enabled, port: 8082, bind: 192.168.4.161, run as: admin
      Objects:                35718
      States:                 31898
      Size of iob-Database:
      53M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/states.jsonl
      Seit heute bekomme ich folgende Meldung vom Adapter:
      sourceanalytix.0 2024-07-03 12:48:01.549	error	Initialization of alias.0.Garten.SD_GA_Whirlpool.POWER_SUM failed, check warn messages !
      sourceanalytix.0 2024-07-03 12:48:01.549	error	Cannot handle calculations for alias.0.Garten.SD_GA_Whirlpool.POWER_SUM, check log messages and adjust settings!
      sourceanalytix.0 2024-07-03 12:48:01.549	error	Troubleshoot Data alias.0.Garten.SD_GA_Whirlpool.POWER_SUM custom Data : {"type":"state","common":{"name":"SD_GA_Whirlpool.POWER_SUM","type":"number","role":"value.power.consumption","read":true,"write":false,"def":0,"unit":"Wh","alias":{"id":"shelly.0.SHSW-PM#349454767634#1.Relay0.Energy"},"desc":"per Script erstellt","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":1,"start_day":377.66441000000003,"start_week":367.97456000000005,"start_month":367.97456000000005,"start_quarter":367.97456000000005,"start_year":336.37404000000004,"alias":"SD_GA_Whirlppol_Stromverbrauch","selectedPrice":"ElectricityDay","costs":true,"consumption":true,"valueAtDeviceReset":378.03337000000005,"valueAtDeviceInit":0,"cumulativeValue":377.66441000000003}}},"native":{},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1719996785347,"_id":"alias.0.Garten.SD_GA_Whirlpool.POWER_SUM","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      sourceanalytix.0 2024-07-03 12:48:01.548	error	Check settings for alias.0.Garten.SD_GA_Whirlpool.POWER_SUM ! Known valueAtDeviceReset : (378.03337000000005) > known cumulative value (336.37404000000004) cannot proceed
      Der Adapter soll den Verbauch von einem Shelly 1 PM (über einen Alias DP) aufzeichnen.
      • crunchip
        crunchip Forum Testing Most Active @Kuddel last edited by
        @kuddel woher kommen die vielen Nachkommastellen?
        Du hast einen device reset und die unit würde ich nicht auf automatik stehen lassen
          Kuddel @crunchip last edited by
          @crunchip keine Ahnung wo die Nachkommastellen kommen.
          Der Einheit habe ich jetzt auf Wh festgelegt.
          Hat sich der Shelly resettet oder was genau meinst du?
          Wie bekomme ich denn jetzt den Fehler weg?
          • crunchip
            @kuddel sagte in Hilfe bei SourceAnalytix:
            zeig mal das Raw vom alias
              @crunchip
              RAW von alias.0.Garten.SD_GA_Whirlpool.POWER_SUM
               "type": "state",
               "common": {
                 "name": "SD_GA_Whirlpool.POWER_SUM",
                 "type": "number",
                 "role": "value.power.consumption",
                 "read": true,
                 "write": false,
                 "def": 0,
                 "unit": "Wh",
                 "alias": {
                   "id": "shelly.0.SHSW-PM#349454767634#1.Relay0.Energy"
                 "desc": "per Script erstellt",
                 "custom": {
                   "sourceanalytix.0": {
                     "enabled": true,
                     "selectedUnit": "Wh",
                     "deviceResetLogicEnabled": true,
                     "threshold": 1,
                     "start_day": 377.66441000000003,
                     "start_week": 367.97456000000005,
                     "start_month": 367.97456000000005,
                     "start_quarter": 367.97456000000005,
                     "start_year": 336.37404000000004,
                     "alias": "SD_GA_Whirlppol_Stromverbrauch",
                     "selectedPrice": "ElectricityDay",
                     "costs": true,
                     "consumption": true,
                     "valueAtDeviceReset": 378.03337000000005,
                     "valueAtDeviceInit": 0,
                     "cumulativeValue": 377.66441000000003
               "native": {},
               "_id": "alias.0.Garten.SD_GA_Whirlpool.POWER_SUM",
               "acl": {
                 "object": 1636,
                 "state": 1636,
                 "owner": "system.user.admin",
               "user": "system.user.admin",
               "ts": 1720122580653
              • crunchip
                crunchip Forum Testing Most Active @Kuddel last edited by crunchip
                @kuddel dein Zähler war schon auf 378.0333 und aktuell hast du einen Stand von 377.66441, dementsprechend ein device reset.
                Du musst SA stoppen, anschließend die Zeilen löschen.
                Danach SA wieder starten
                Edit
                Kannst du nicht im alias angeben, das auf 3 Stellen gerundet werden soll?
                  @crunchip
                  Habe die Zeilen gelöscht und die SA Instanz gestartet. DIe Fehlermeldung ist schon einmal weg.
                  SA sagt mir jetzt aber folgendes:
                  • crunchip
                    @kuddel was für einen Zählerstand hat der shelly denn tatsächlich?
                      @crunchip
                      • crunchip
                        @kuddel woher kommen denn deine Startwert in SA? Die stimmen ja gar nicht mit deinem shelly überein. Da müssen ebenfalls wh stehen und dem Stand deines shelly entsprechen
                          @crunchip
                          Als ich den Shelly in Betrieb genommen habe, habe ich auch SA installiert.
                          Somit können die Werte nicht von einem anderen Gerät stammen.
                          • crunchip
                            @kuddel und wielange läuft das schon?
                            Hat sich dein shelly zurückgesetzt?
                            Stromlos bzw Firmware Update gemacht?
                            Da wäre es sinnvoller bei shelly den Datenpunkt Watt zu nehmen, anstatt den Zähler in wh, da sich Shelly's zurücksetzen bei Stromausfall bzw update
                              Kuddel @crunchip last edited by Kuddel
                              @crunchip
                              der Shelly läuft seit letztem Sommer und war über den Winter eingelagert.
                              Ich meine ich habe letzte Woche zudem ein Update installiert.
                              Also sollte SA eher den aktuellen Verbrauch in W messen?
                              EDIT: 84729645-e981-4d6f-9843-fa7ef8547343-grafik.png
                              • crunchip
                                Ja
                                  @crunchip
                                  Alles klar. Vielen Dank für die Hilfe
                                  1.0k
                                  678
