    4. Homeconnect Fehlermeldung
      TimoWald last edited by
      Meine hOmeconnect Geräte lassen sich nicht mehr steueren.
      Adapter ist grün.
      Hier ein Auszug aus dem LOG.
      2024-07-04 16:06:35.450 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/0
      2024-07-04 16:06:36.151 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/0
      2024-07-04 16:06:36.868 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/1
      2024-07-04 16:06:37.569 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/1
      2024-07-04 16:06:37.731 - error: homeconnect.0 (98957) AxiosError: Request failed with status code 429
      2024-07-04 16:06:37.731 - error: homeconnect.0 (98957) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 10950 seconds.","key":"429"}}
      2024-07-04 16:06:38.271 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/1
      2024-07-04 16:06:39.042 - error: homeconnect.0 (98957) AxiosError: Request failed with status code 429
      2024-07-04 16:06:39.042 - error: homeconnect.0 (98957) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 10949 seconds.","key":"429"}}
      2024-07-04 16:06:40.222 - error: homeconnect.0 (98957) AxiosError: Request failed with status code 429
      2024-07-04 16:06:40.223 - error: homeconnect.0 (98957) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 10948 seconds.","key":"429"}}
      Was läuft da verkehrt?
        Thomas Braun Most Active @TimoWald last edited by
        @timowald sagte in Homeconnect Fehlermeldung:
        The rate limit "1000 calls in 1 day" was reached. Requests are blocked during the remaining period of 10948 seconds."
        Du fragst zu häufig was an und für den Rest des Tages hast du nun Pause.
          TimoWald @Thomas Braun last edited by
          @thomas-braun Wie bekomme ich raus was angefragt wird und von wo aus die anfrage kommt?
            TT-Tom @TimoWald last edited by
            @timowald
            Setzte mal den Adapter in den Debug Modus. Dann sieht man vielleicht im log etwas.
            T 2 Replies Last reply Reply Quote 0
              TimoWald @TT-Tom last edited by
              @tt-tom Habe ich jetzt mal gemacht. Warte jetzt mal etwas und setze den LOG hier rein.
                @tt-tom Hier mal der LOG nach 3 Minuten.
                Jede Minute passiert etwas.
                2024-07-04 16:52:01.914 - info: host.iobroker "system.adapter.homeconnect.0" enabled
                2024-07-04 16:52:02.309 - info: host.iobroker instance system.adapter.homeconnect.0 started with pid 101249
                2024-07-04 16:52:03.207 - debug: homeconnect.0 (101249) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2024-07-04 16:52:03.275 - debug: homeconnect.0 (101249) Objects client ready ... initialize now
                2024-07-04 16:52:03.277 - debug: homeconnect.0 (101249) Objects create System PubSub Client
                2024-07-04 16:52:03.277 - debug: homeconnect.0 (101249) Objects create User PubSub Client
                2024-07-04 16:52:03.441 - debug: homeconnect.0 (101249) Objects client initialize lua scripts
                2024-07-04 16:52:03.446 - debug: homeconnect.0 (101249) Objects connected to redis: 127.0.0.1:9001
                2024-07-04 16:52:03.535 - debug: homeconnect.0 (101249) Redis States: Use Redis connection: 127.0.0.1:9000
                2024-07-04 16:52:03.638 - debug: homeconnect.0 (101249) States create System PubSub Client
                2024-07-04 16:52:03.639 - debug: homeconnect.0 (101249) States create User PubSub Client
                2024-07-04 16:52:03.768 - debug: homeconnect.0 (101249) States connected to redis: 127.0.0.1:9000
                2024-07-04 16:52:03.837 - debug: homeconnect.0 (101249) Plugin sentry Initialize Plugin (enabled=true)
                2024-07-04 16:52:04.158 - info: homeconnect.0 (101249) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v18.17.1, js-controller: 5.0.19
                2024-07-04 16:52:04.231 - debug: homeconnect.0 (101249) Found current session
                2024-07-04 16:52:04.232 - debug: homeconnect.0 (101249) Refresh Token
                2024-07-04 16:52:04.554 - debug: homeconnect.0 (101249) {"access_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.h05vzbNvOhLkpk6CTBVW8QUDpCTpPUzI9tHoDJGyPFqpNtX-oifpS7gRj_5KGQAb7ifxkzM_etF_wuvUVIHPVSSkSO0UWHaxQRHw8DLgyUKLTVDM4T7FAJ8cHAz6YM-e4_cd1Fbg8bq_O3-OYyMuWIQ1_w7Gp3X3tkUYiT5F1YEhQxHANgGGAtjrUUuw1AEnhIAmzmmJiX_6tYLFunAJ69zXrdc-ilE-BdVuLN6Yo6bonvayzI265D4bmLwIww_4x7enGUsUoLlkNx3ZDf4dEV1SWrZn2M6lwoMqxwzgdLQgGKCUdO7bIwD1mxLRoJzgV3kE6gEpLOKSPSs4XlDQOA","expires_in":86400,"id_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.eyJmZ3JwIjpbXSwiY2x0eSI6InByaXZhdGUiLCJzdWIiOiIxYzQwMzQyZS1kMGNlLTQzYzktODcwOS05MmY5NDZmNGIxYjAiLCJhdWQiOiIwODI1MTJCREVCOEFGNDUyNjBBRUQ5Q0U1QjBDRjNCRTVDM0IxRUI4RkRGRDI2Q0FBNTRDNzZFN0UyRDhDNTJGIiwic3RhZ2UiOiJQUkQiLCJhenAiOiIwODI1MTJCREVCOEFGNDUyNjBBRUQ5Q0U1QjBDRjNCRTVDM0IxRUI4RkRGRDI2Q0FBNTRDNzZFN0UyRDhDNTJGIiwic2NvcGUiOlsiSWRlbnRpZnlBcHBsaWFuY2UiLCJNb25pdG9yIiwiU2V0dGluZ3MiLCJDb250cm9sIl0sImlzcyI6IkVVOlBSRDowIiwiZXhwIjoxNzIwMTkxMTI0LCJyZWdpb24iOiJFVSIsImlhdCI6MTcyMDEwNDcyNCwianRpIjoiNWEyMmMwZTAtOTE5Ni00MDNlLThiYjAtN2FmZTAxNDQ3NDBlIn0.h05vzbNvOhLkpk6CTBVW8QUDpCTpPUzI9tHoDJGyPFqpNtX-oifpS7gRj_5KGQAb7ifxkzM_etF_wuvUVIHPVSSkSO0UWHaxQRHw8DLgyUKLTVDM4T7FAJ8cHAz6YM-e4_cd1Fbg8bq_O3-OYyMuWIQ1_w7Gp3X3tkUYiT5F1YEhQxHANgGGAtjrUUuw1AEnhIAmzmmJiX_6tYLFunAJ69zXrdc-ilE-BdVuLN6Yo6bonvayzI265D4bmLwIww_4x7enGUsUoLlkNx3ZDf4dEV1SWrZn2M6lwoMqxwzgdLQgGKCUdO7bIwD1mxLRoJzgV3kE6gEpLOKSPSs4XlDQOA","refresh_token":"eyJyZWdpb24iOiJFVSIsInN0YWdlIjoiUFJEIiwiY3JlZiI6IjA4MjUxMkJEIiwidG9rZW4iOiJiZThjOTA5OC1hYmZlLTQ3N2ItODAwMi1kMzQwYjJhYjVjZmQiLCJjbHR5IjoicHJpdmF0ZSIsIngtcmVnIjoiRVUiLCJ4LWVudiI6IlBSRCJ9","scope":"IdentifyAppliance Monitor Settings Control","token_type":"Bearer"}
                2024-07-04 16:52:04.555 - debug: homeconnect.0 (101249) Get device list
                2024-07-04 16:52:04.735 - error: homeconnect.0 (101249) AxiosError: Request failed with status code 429
                2024-07-04 16:52:04.736 - error: homeconnect.0 (101249) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 85880 seconds.","key":"429"}}
                2024-07-04 16:52:04.737 - debug: homeconnect.0 (101249) Start EventStream
                2024-07-04 16:52:04.838 - error: homeconnect.0 (101249) 429 Too Many Requests
                2024-07-04 16:52:04.838 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
                2024-07-04 16:52:04.838 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
                2024-07-04 16:52:14.813 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
                2024-07-04 16:52:14.814 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
                2024-07-04 16:52:40.625 - info: solax.0 (21770) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                2024-07-04 16:53:14.742 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
                2024-07-04 16:53:14.743 - debug: homeconnect.0 (101249) Start EventStream
                2024-07-04 16:53:14.817 - error: homeconnect.0 (101249) 429 Too Many Requests
                2024-07-04 16:53:14.818 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
                2024-07-04 16:53:14.818 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
                2024-07-04 16:53:16.253 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
                2024-07-04 16:53:16.254 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
                2024-07-04 16:54:13.597 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
                2024-07-04 16:54:13.598 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
                2024-07-04 16:54:24.749 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
                2024-07-04 16:54:24.750 - debug: homeconnect.0 (101249) Start EventStream
                2024-07-04 16:54:24.826 - error: homeconnect.0 (101249) 429 Too Many Requests
                2024-07-04 16:54:24.826 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
                2024-07-04 16:54:24.826 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
                2024-07-04 16:55:15.037 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
                2024-07-04 16:55:15.038 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
                2024-07-04 16:55:34.756 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
                2024-07-04 16:55:34.756 - debug: homeconnect.0 (101249) Start EventStream
                2024-07-04 16:55:34.862 - error: homeconnect.0 (101249) 429 Too Many Requests
                2024-07-04 16:55:34.862 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
                2024-07-04 16:55:34.862 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
                Thomas Braun T haselchen 3 Replies Last reply Reply Quote 0
                  node: v18.17.1
                  Bring das auf eine aktuelle Version.
                  iob nodejs-update 20
                    @thomas-braun Den Befehl in der Console?
                      @timowald
                      Ja. Deine Installation steht auf dem falschen Gleis.
                        @thomas-braun Da kommt diese Meldung:
                        Zur Info: IoBroker läuft auf Proxmox.
                          @timowald
                          Du sollst ja auch NICHT als root herumhampeln. Auch nicht im Proxmox-Container.
                          Als USER:
                          iob stop
                          iob fix
                            TT-Tom @TimoWald last edited by TT-Tom
                            @timowald schalte mal den Adapter ab bis morgen. Heute kommen da eh keine sinnvolle Meldungen zurück, weil du kein Connect mehr bekommst.
                              Thomas Braun Most Active @TT-Tom last edited by
                              @tt-tom sagte in Homeconnect Fehlermeldung:
                              Das stimmt.
                              Die Zeit kann man dann für ein vollständiges und richtiges Setup des Containers verwenden.
                                @thomas-braun said in Homeconnect Fehlermeldung:
                                Wie kann ich nachträglich noch einen Standard benutzer hinzufügen?
                                  @timowald
                                  Steht in der Doku drin:
                                  https://www.iobroker.net/#de/documentation/install/proxmox.md
                                    @thomas-braun Also geht das im nachhinein gar nicht mehr?
                                      @timowald
                                      Klar geht das. Einfache User können natürlich jederzeit angelegt und auch wieder gelöscht werden.
                                        TimoWald @Thomas Braun last edited by TimoWald
                                        @thomas-braun ich mus ihn doch anlegen über die konsole in proxmox oder über Putty oder liege ich da falsch?
                                        Mus ich einen Benutzer für den IObroker oder für Proxmox anlegen?
                                          @timowald
                                          Mit einem Terminal. Ich würde da aber immer was 'gescheites' verwenden.
                                          puTTY halte ich nicht für gescheit...
                                          Das Terminal aus proxmos kenne ich nicht. Keine Ahnung was die da verwenden.
                                            Das steht doch in der Anleitung drin, oder nicht?
                                            2325
