    4. Pflege des Betriebssystems
    5. Betriebssystem-Paket-Updates, Linux ist auf neustem Stand
      luder last edited by
      ich bekomme beim Start die Meldung:
      Betriebssystem-Paket-Updates verfügbar
      Einige Betriebssystempakete können aktualisiert werden.
      Darunter ist dann eine ziemlich lange Liste, siehe unten.
      Ich habe dann ein Update meines Linux System gemacht
      sudo apt update
      sudo apt dist-upgrade
      sudo reboot
      aber die Meldung kommt immer noch. Muss ich noch etwas anderes aktualisieren?
      Bin leider kein Linux Experte.
      base-files/stable 12.4+deb12u6 amd64 [upgradable from: 12.4]
      bash/stable 5.2.15-2+b7 amd64 [upgradable from: 5.2.15-2+b2]
      bind9-dnsutils/stable,stable-security 1:9.18.24-1 amd64 [upgradable from: 1:9.18.16-1~deb12u1]
      bind9-host/stable,stable-security 1:9.18.24-1 amd64 [upgradable from: 1:9.18.16-1~deb12u1]
      bind9-libs/stable,stable-security 1:9.18.24-1 amd64 [upgradable from: 1:9.18.16-1~deb12u1]
      bsdextrautils/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      bsdutils/stable,stable-security 1:2.38.1-5+deb12u1 amd64 [upgradable from: 1:2.38.1-5+b1]
      dbus-bin/stable 1.14.10-1~deb12u1 amd64 [upgradable from: 1.14.6-1]
      dbus-daemon/stable 1.14.10-1~deb12u1 amd64 [upgradable from: 1.14.6-1]
      dbus-session-bus-common/stable 1.14.10-1~deb12u1 all [upgradable from: 1.14.6-1]
      dbus-system-bus-common/stable 1.14.10-1~deb12u1 all [upgradable from: 1.14.6-1]
      dbus/stable 1.14.10-1~deb12u1 amd64 [upgradable from: 1.14.6-1]
      debian-archive-keyring/stable 2023.3+deb12u1 all [upgradable from: 2023.3]
      debianutils/stable 5.7-0.5~deb12u1 amd64 [upgradable from: 5.7-0.4]
      distro-info-data/stable 0.58+deb12u2 all [upgradable from: 0.58]
      fdisk/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      gir1.2-gdkpixbuf-2.0/stable 2.42.10+dfsg-1+deb12u1 amd64 [upgradable from: 2.42.10+dfsg-1+b1]
      gir1.2-rsvg-2.0/stable,stable-security 2.54.7+dfsg-1~deb12u1 amd64 [upgradable from: 2.54.5+dfsg-1]
      inetutils-telnet/stable 2:2.4-2+deb12u1 amd64 [upgradable from: 2:2.4-2]
      krb5-locales/stable 1.20.1-2+deb12u1 all [upgradable from: 1.20.1-2]
      less/stable,stable-security 590-2.1~deb12u2 amd64 [upgradable from: 590-2]
      libarchive13/stable,stable-security 3.6.2-1+deb12u1 amd64 [upgradable from: 3.6.2-1]
      libblkid-dev/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      libblkid1/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      libc-bin/stable,stable-security 2.36-9+deb12u7 amd64 [upgradable from: 2.36-9]
      libc-dev-bin/stable,stable-security 2.36-9+deb12u7 amd64 [upgradable from: 2.36-9]
      libc-l10n/stable,stable-security 2.36-9+deb12u7 all [upgradable from: 2.36-9]
      libc6-dev/stable,stable-security 2.36-9+deb12u7 amd64 [upgradable from: 2.36-9]
      libc6/stable,stable-security 2.36-9+deb12u7 amd64 [upgradable from: 2.36-9]
      libcryptsetup12/stable 2:2.6.1-4~deb12u2 amd64 [upgradable from: 2:2.6.1-4~deb12u1]
      libdbus-1-3/stable 1.14.10-1~deb12u1 amd64 [upgradable from: 1.14.6-1]
      libdbus-1-dev/stable 1.14.10-1~deb12u1 amd64 [upgradable from: 1.14.6-1]
      libfdisk1/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      libfreetype-dev/stable 2.12.1+dfsg-5+deb12u3 amd64 [upgradable from: 2.12.1+dfsg-5]
      libfreetype6/stable 2.12.1+dfsg-5+deb12u3 amd64 [upgradable from: 2.12.1+dfsg-5]
      libgdk-pixbuf-2.0-0/stable 2.42.10+dfsg-1+deb12u1 amd64 [upgradable from: 2.42.10+dfsg-1+b1]
      libgdk-pixbuf-2.0-dev/stable 2.42.10+dfsg-1+deb12u1 amd64 [upgradable from: 2.42.10+dfsg-1+b1]
      libgdk-pixbuf2.0-bin/stable 2.42.10+dfsg-1+deb12u1 amd64 [upgradable from: 2.42.10+dfsg-1+b1]
      libgdk-pixbuf2.0-common/stable 2.42.10+dfsg-1+deb12u1 all [upgradable from: 2.42.10+dfsg-1]
      libglib2.0-0/stable 2.74.6-2+deb12u3 amd64 [upgradable from: 2.74.6-2]
      libglib2.0-bin/stable 2.74.6-2+deb12u3 amd64 [upgradable from: 2.74.6-2]
      libglib2.0-data/stable 2.74.6-2+deb12u3 all [upgradable from: 2.74.6-2]
      libglib2.0-dev-bin/stable 2.74.6-2+deb12u3 amd64 [upgradable from: 2.74.6-2]
      libglib2.0-dev/stable 2.74.6-2+deb12u3 amd64 [upgradable from: 2.74.6-2]
      libgnutls30/stable 3.7.9-2+deb12u3 amd64 [upgradable from: 3.7.9-2]
      libgssapi-krb5-2/stable 1.20.1-2+deb12u1 amd64 [upgradable from: 1.20.1-2]
      libisl23/stable 0.25-1.1 amd64 [upgradable from: 0.25-1]
      libk5crypto3/stable 1.20.1-2+deb12u1 amd64 [upgradable from: 1.20.1-2]
      libkrb5-3/stable 1.20.1-2+deb12u1 amd64 [upgradable from: 1.20.1-2]
      libkrb5support0/stable 1.20.1-2+deb12u1 amd64 [upgradable from: 1.20.1-2]
      libmount-dev/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      libmount1/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      libnftables1/stable 1.0.6-2+deb12u2 amd64 [upgradable from: 1.0.6-2]
      libnghttp2-14/stable,stable-security 1.52.0-1+deb12u1 amd64 [upgradable from: 1.52.0-1]
      libnss-systemd/stable 252.26-1~deb12u2 amd64 [upgradable from: 252.6-1]
      libpam-modules-bin/stable 1.5.2-6+deb12u1 amd64 [upgradable from: 1.5.2-6]
      libpam-modules/stable 1.5.2-6+deb12u1 amd64 [upgradable from: 1.5.2-6]
      libpam-runtime/stable 1.5.2-6+deb12u1 all [upgradable from: 1.5.2-6]
      libpam-systemd/stable 252.26-1~deb12u2 amd64 [upgradable from: 252.6-1]
      libpam0g-dev/stable 1.5.2-6+deb12u1 amd64 [upgradable from: 1.5.2-6]
      libpam0g/stable 1.5.2-6+deb12u1 amd64 [upgradable from: 1.5.2-6]
      libperl5.36/stable 5.36.0-7+deb12u1 amd64 [upgradable from: 5.36.0-7]
      libpython3.11-minimal/stable 3.11.2-6+deb12u2 amd64 [upgradable from: 3.11.2-6]
      libpython3.11-stdlib/stable 3.11.2-6+deb12u2 amd64 [upgradable from: 3.11.2-6]
      librsvg2-2/stable,stable-security 2.54.7+dfsg-1~deb12u1 amd64 [upgradable from: 2.54.5+dfsg-1]
      librsvg2-common/stable,stable-security 2.54.7+dfsg-1~deb12u1 amd64 [upgradable from: 2.54.5+dfsg-1]
      librsvg2-dev/stable,stable-security 2.54.7+dfsg-1~deb12u1 amd64 [upgradable from: 2.54.5+dfsg-1]
      libseccomp2/stable 2.5.4-1+deb12u1 amd64 [upgradable from: 2.5.4-1+b3]
      libsmartcols1/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      libssl3/stable 3.0.13-1~deb12u1 amd64 [upgradable from: 3.0.9-1]
      libsystemd-shared/stable 252.26-1~deb12u2 amd64 [upgradable from: 252.6-1]
      libsystemd0/stable 252.26-1~deb12u2 amd64 [upgradable from: 252.6-1]
      libtiff-dev/stable,stable-security 4.5.0-6+deb12u1 amd64 [upgradable from: 4.5.0-6]
      libtiff6/stable,stable-security 4.5.0-6+deb12u1 amd64 [upgradable from: 4.5.0-6]
      libtiffxx6/stable,stable-security 4.5.0-6+deb12u1 amd64 [upgradable from: 4.5.0-6]
      libudev-dev/stable 252.26-1~deb12u2 amd64 [upgradable from: 252.6-1]
      libudev1/stable 252.26-1~deb12u2 amd64 [upgradable from: 252.6-1]
      libuuid1/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      libuv1/stable,stable-security 1.44.2-1+deb12u1 amd64 [upgradable from: 1.44.2-1]
      libwbclient0/stable,stable-security 2:4.17.12+dfsg-0+deb12u1 amd64 [upgradable from: 2:4.17.8+dfsg-2]
      libwebp-dev/stable,stable-security 1.2.4-0.2+deb12u1 amd64 [upgradable from: 1.2.4-0.2]
      libwebp7/stable,stable-security 1.2.4-0.2+deb12u1 amd64 [upgradable from: 1.2.4-0.2]
      libwebpdemux2/stable,stable-security 1.2.4-0.2+deb12u1 amd64 [upgradable from: 1.2.4-0.2]
      libwebpmux3/stable,stable-security 1.2.4-0.2+deb12u1 amd64 [upgradable from: 1.2.4-0.2]
      libx11-6/stable,stable-security 2:1.8.4-2+deb12u2 amd64 [upgradable from: 2:1.8.4-2+deb12u1]
      libx11-data/stable,stable-security 2:1.8.4-2+deb12u2 all [upgradable from: 2:1.8.4-2+deb12u1]
      libx11-dev/stable,stable-security 2:1.8.4-2+deb12u2 amd64 [upgradable from: 2:1.8.4-2+deb12u1]
      libxml2/stable 2.9.14+dfsg-1.3~deb12u1 amd64 [upgradable from: 2.9.14+dfsg-1.2]
      linux-libc-dev/stable 6.1.94-1 amd64 [upgradable from: 6.1.37-1]
      locales/stable,stable-security 2.36-9+deb12u7 all [upgradable from: 2.36-9]
      mount/stable,stable-security 2.38.1-5+deb12u1 amd64 [upgradable from: 2.38.1-5+b1]
      nano/stable 7.2-1+deb12u1 amd64 [upgradable from: 7.2-1]
      nftables/stable 1.0.6-2+deb12u2 amd64 [upgradable from: 1.0.6-2]
      openssh-client/stable-security 1:9.2p1-2+deb12u3 amd64 [upgradable from: 1:9.2p1-2]
      openssh-server/stable-security 1:9.2p1-2+deb12u3 amd64 [upgradable from: 1:9.2p1-2]
      openssh-sftp-server/stable-security 1:9.2p1-2+deb12u3 amd64 [upgradable from: 1:9.2p1-2]
      openssl/stable 3.0.13-1~deb12u1 amd64 [upgradable from: 3.0.9-1]
      perl-base/stable 5.36.0-7+deb12u1 amd64 [upgradable from: 5.36.0-7]
      perl-modules-5.36/stable 5.36.0-7+deb12u1 all [upgradable from: 5.36.0-7]
      perl/stable 5.36.0-7+deb12u1 amd64 [upgradable from: 5.36.0-7]
      Homoran Codierknecht F 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @luder last edited by
        @luder sagte in Betriebssystem-Paket-Updates, Linux ist auf neustem Stand:
        sudo apt update
        was kommt jetzt bei
        sudo apt update?
        • Codierknecht
          Codierknecht Developer Most Active @luder last edited by Codierknecht
          @luder
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
            luder @Homoran last edited by Homoran
            @homoran sagte in Betriebssystem-Paket-Updates, Linux ist auf neustem Stand:
            sudo apt update
            root@cloneV01:~# sudo apt update
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
            Reading package lists... Done
            Building dependency tree... Done
            All packages are up to date.
            Homoran Codierknecht 2 Replies Last reply Reply Quote 0
              @luder ja, da ist nichts mehr.
              Mal den admin refresht und Browsercache geleert?
                luder @Codierknecht last edited by Homoran
                @codierknecht sagte in Betriebssystem-Paket-Updates, Linux ist auf neustem Stand:
                @luder
                sudo apt update
                sudo reboot
                dann kommt dieses, der Fehler bleibt aber bestehen nach reboot
                root@cloneV01:~# sudo apt full-upgrade
                Calculating upgrade... Done
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  @luder warum als root?
                  • MartinP
                    MartinP @Homoran last edited by
                    @homoran und warum dann zusätzlich mit sudo...
                      Browser cache habe ich gelöscht und einen anderen Browser probiert, leider ohne Erfolg.
                      Was meinst du mit admin refresht?
                        @martinp sagte in Betriebssystem-Paket-Updates, Linux ist auf neustem Stand:
                        weil ich immer davon ausgehe dass niemand als root durchs System pflügt
                        • Codierknecht
                          @luder
                          Man fummelt grundsätzlich nicht als "root" im System rum!
                          • MartinP
                            @codierknecht Hast Du Dir auch für die PVE Shell einen normalen User eingerichtet?
                            In den Proxmox Foren wird das kontrovers diskutiert....
                            • Codierknecht
                              Codierknecht Developer Most Active @MartinP last edited by
                              Jepp. Kontrovers hin oder her. Im LXC für ioB arbeite ich nur mit dem normalen User - ohne irgendwelche Probleme.
                              Anders sieht das bei Docker aus. Aber davon ist ja hier keine Rede.
                              • MartinP
                                MartinP @Codierknecht last edited by
                                @codierknecht Nein es geht mir um die Shell von Proxmox selber. In dem LXC von Iobroker und auch den meisten anderen Containern und VMs bin ich als normaler User mit sudo für die Updates unterwegs
                                Codierknecht T 2 Replies Last reply Reply Quote 0
                                • Codierknecht
                                  @martinp
                                  Na, dann machen wir das dann doch so ziemlich gleich 😉
                                  In die Shell von Proxmox muss ich ja fast nie ... außer für die Updates.
                                    TT-Tom @MartinP last edited by
                                    @martinp
                                    In der normalen Shell habe ich auch ein Normalo. Aber an der Oberfläche meldet man sich doch eh als Root an und schiebt die Updates auch darüber an. Habe den Normalo bzw. Die Shell habe ich so noch nicht gebraucht.
                                    • Codierknecht
                                      Codierknecht Developer Most Active @TT-Tom last edited by
                                      @tt-tom sagte in Betriebssystem-Paket-Updates, Linux ist auf neustem Stand:
                                      An welcher "Oberfläche"?
                                        TT-Tom @Codierknecht last edited by
                                        @codierknecht von proxmox
                                          Frawu @luder last edited by
                                          @luder Hi,
                                          konntest Du das Problem lösen? Bei mir sieht es genauso aus.
                                          • Meister Mopper
                                            Meister Mopper @Frawu last edited by
                                            @frawu sagte in Betriebssystem-Paket-Updates, Linux ist auf neustem Stand:
                                            @luder Hi,
                                            Wie sieht dein System aus? Was sagt das logging?
                                            RaspiUser 1 Reply Last reply Reply Quote 0
                                            61
                                            12624
