    4. CUxD mit ioBroker - Send this info to developer
      DeepCore last edited by
      Man sollte nicht spät an einem System werkeln, aber ich habe gerade versucht den hm.rpc mit CUxD zu verbinden.
      Erhalte dann im Log ein paar Warn-Meldungen für die Entwickler:
      hm-rpc.1 2017-09-10 22:03:17.625 info Connected
      hm-rpc.1 2017-09-10 22:03:17.622 info new CUxD devices/channels after filter: 0
      hm-rpc.1 2017-09-10 22:03:17.615 info binrpc -> listDevices 21
      hm-rpc.1 2017-09-10 22:03:17.094 info binrpc client is trying to connect to 10.13.4.40:8701 with ['xmlrpc_bin://10.13.4.49:8701','hm-rpc.1']
      hm-rpc.1 2017-09-10 22:03:17.094 info binrpc server is trying to listen on 10.13.4.49:8701
      hm-rpc.1 2017-09-10 22:03:16.994 info starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.11.1
      hm-rpc.1 2017-09-10 22:03:13.886 info terminating
      hm-rpc.1 2017-09-10 22:03:13.878 info Disconnected
      hm-rpc.1 2017-09-10 22:03:13.872 info binrpc -> 10.13.4.40:8701 init ['xmlrpc_bin://10.13.4.49:8701','']
      hm-rpc.1 2017-09-10 22:03:13.833 warn Send this info to developer: {'type':'meta','meta':{'adapter':'hm-rpc','type':'paramsetDescription'},'common':{},'native':{'STATE':{'ID':'STATE','UNIT':'%','TAB_ORDER':0,'OPERATIONS':5,'FLAGS':1,'TYPE':'FLOAT','MIN':-99999,'MAX':99999,'DEFAULT':0},'SET_STATE':{'ID':'SET_STATE','UNIT':'','TAB_ORDER':1,'OPERATIONS':2,'FLAGS':2,'TYPE':'FLOAT','MIN':-99999,'MAX':99999,'DEFAULT':0},'RESET':{'ID':'RESET','UNIT':'','TAB_ORDER':2,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false}}}
      hm-rpc.1 2017-09-10 22:03:13.832 warn Send this info to developer: _id: 'hm-rpc.meta.VALUES.10000.WRAPPER.1'
      hm-rpc.1 2017-09-10 22:03:13.821 info binrpc -> getParamsetDescription ['CUX9000001:1','VALUES']
      hm-rpc.1 2017-09-10 22:03:13.791 info binrpc -> getParamsetDescription ['CUX9000001:0','VALUES']
      hm-rpc.1 2017-09-10 22:03:12.660 warn Send this info to developer: {'type':'meta','meta':{'adapter':'hm-rpc','type':'paramsetDescription'},'common':{},'native':{'LEVEL':{'ID':'LEVEL','UNIT':'100%','TAB_ORDER':0,'OPERATIONS':7,'FLAGS':2,'TYPE':'FLOAT','MIN':0,'MAX':1,'DEFAULT':0},'OLD_LEVEL':{'ID':'OLD_LEVEL','UNIT':'','TAB_ORDER':1,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'STOP':{'ID':'STOP','UNIT':'','TAB_ORDER':2,'OPERATIONS':6,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'STATE':{'ID':'STATE','UNIT':'','TAB_ORDER':3,'OPERATIONS':7,'FLAGS':2,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false},'PRESS_SHORT':{'ID':'PRESS_SHORT','UNIT':'','TAB_ORDER':4,'OPERATIONS':6,'FLAGS':1,'CONTROL':'BUTTON.SHORT','TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'PRESS_LONG':{'ID':'PRESS_LONG','UNIT':'','TAB_ORDER':5,'OPERATIONS':6,'FLAGS':1,'CONTROL':'BUTTON.LONG','TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'CMD_RUNS':{'ID':'CMD_RUNS','UNIT':'','TAB_ORDER':6,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'CMD_RUNL':{'ID':'CMD_RUNL','UNIT':'','TAB_ORDER':7,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'CMD_KILL':{'ID':'CMD_KILL','UNIT':'','TAB_ORDER':8,'OPERATIONS':2,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_EXEC':{'ID':'CMD_EXEC','UNIT':'','TAB_ORDER':9,'OPERATIONS':2,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'LOGIT':{'ID':'LOGIT','UNIT':'','TAB_ORDER':10,'OPERATIONS':2,'FLAGS':2,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'SYSLOG':{'ID':'SYSLOG','UNIT':'','TAB_ORDER':11,'OPERATIONS':2,'FLAGS':2,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_SETS':{'ID':'CMD_SETS','UNIT':'','TAB_ORDER':12,'OPERATIONS':7,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_SETL':{'ID':'CMD_SETL','UNIT':'','TAB_ORDER':13,'OPERATIONS':7,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_RETS':{'ID':'CMD_RETS','UNIT':'','TAB_ORDER':14,'OPERATIONS':5,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_RETL':{'ID':'CMD_RETL','UNIT':'','TAB_ORDER':15,'OPERATIONS':5,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_QUERY_RET':{'ID':'CMD_QUERY_RET','UNIT':'','TAB_ORDER':16,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'WORKING':{'ID':'WORKING','UNIT':'','TAB_ORDER':17,'OPERATIONS':5,'FLAGS':1,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false},'CONTROL':{'ID':'CONTROL','UNIT':'','TAB_ORDER':18,'OPERATIONS':1,'FLAGS':2,'TYPE':'INTEGER','MIN':0,'MAX':1,'DEFAULT':0},'SET_STATE':{'ID':'SET_STATE','UNIT':'','TAB_ORDER':19,'OPERATIONS':2,'FLAGS':2,'TYPE':'FLOAT','MIN':0,'MAX':1,'DEFAULT':0},'RAND':{'ID':'RAND','UNIT':'','TAB_ORDER':20,'OPERATIONS':3,'FLAGS':2,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'INHIBIT':{'ID':'INHIBIT','UNIT':'','TAB_ORDER':21,'OPERATIONS':3,'FLAGS':1,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false}}}
      hm-rpc.1 2017-09-10 22:03:12.652 warn Send this info to developer: _id: 'hm-rpc.meta.VALUES.HM-RC-19.KEY.1'
      hm-rpc.1 2017-09-10 22:03:12.627 info binrpc -> getParamsetDescription ['CUX2801001:1','VALUES']
      hm-rpc.1 2017-09-10 22:03:12.604 warn Send this info to developer: {'type':'meta','meta':{'adapter':'hm-rpc','type':'paramsetDescription'},'common':{},'native':{'LOWBAT':{'ID':'LOWBAT','UNIT':'','TAB_ORDER':0,'OPERATIONS':5,'FLAGS':9,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false},'UNREACH':{'ID':'UNREACH','UNIT':'','TAB_ORDER':1,'OPERATIONS':5,'FLAGS':9,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false},'STICKY_UNREACH':{'ID':'STICKY_UNREACH','UNIT':'','TAB_ORDER':2,'OPERATIONS':7,'FLAGS':25,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false}}}
      hm-rpc.1 2017-09-10 22:03:12.603 warn Send this info to developer: _id: 'hm-rpc.meta.VALUES.HM-RC-19.MAINTENANCE.1'
      hm-rpc.1 2017-09-10 22:03:12.589 info binrpc -> getParamsetDescription ['CUX2801001:0','VALUES']
      hm-rpc.1 2017-09-10 22:03:12.585 info Connected
      hm-rpc.1 2017-09-10 22:03:12.453 warn No image for '10000' found.
      hm-rpc.1 2017-09-10 22:03:12.451 info binrpc -> listDevices 21
      hm-rpc.1 2017-09-10 22:03:11.931 info binrpc client is trying to connect to 10.13.4.40:8701 with ['xmlrpc_bin://10.13.4.49:8701','hm-rpc.1']
      hm-rpc.1 2017-09-10 22:03:11.926 info binrpc server is trying to listen on 10.13.4.49:8701
      hm-rpc.1 2017-09-10 22:03:11.831 info starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.11.1
      81.0k
