    4. npm error code ENOTEMPTY
      Tschirpke36 last edited by Homoran
      Ich kann keine Updates machen oder neue Adapter installieren, habe jetzt auch schon alles ausprobiert.
      Wenn ich eine Adapter installiere oder updaten will bekomme ich folgende Meldung:
      $ iobroker add yahka auto --host 3f8906b1dbca --debug
      NPM version: 10.8.0
      Installing iobroker.yahka@1.0.3... (System call)
      npm error syscall renamenpm error path /opt/iobroker/node_modules/iobroker.js-controllernpm error dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsbanpm error errno -39npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'
      npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-07-10T12_41_26_233Z-debug-0.log
      Try to solve ENOTEMPTY error automatically
      Could not handle ENOTEMPTY, because no deletable files were foundnpm error code ENOTEMPTYnpm error syscall renamenpm error path /opt/iobroker/node_modules/iobroker.js-controllernpm error dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsbanpm error errno -39npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-07-10T12_41_26_233Z-debug-0.loghost.3f8906b1dbca Cannot install iobroker.yahka@1.0.3: 217
      ERROR: Process exited with code 25
      3f8906b1dbca
      Plattform: docker (official image - v9.1.2)
      RAM: 46.9 GB
      Node.js: v18.20.3(18.20.4)
      NPM: 10.8.0
      Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
      • Codierknecht
        Codierknecht Developer Most Active @Tschirpke36 last edited by
        @Tschirpke36
        1. Ausgaben aus der Konsole bitte immer in Code-Tags </> packen. Sonst ist das fast unlesbar
        2. Da steht doch schon, was Du machen sollst:
          Thomas Braun Most Active @Tschirpke36 last edited by Thomas Braun
          @tschirpke36
          iob stop
          iob fix
          iob nodejs-update 20
          sudo reboot
          Sollte danach laufen.
          Oh, gerade erst gesehen... Docker...
          Da funktioniert das wohl anders.
            @codierknecht
            wenn ich das ausführe kommt:
            <rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'>
            -bash: rename: Kommando nicht gefunden.
            scheint wollt irgendwie nicht zu gehen mit dem Code kenne mich da kaum aus
              Tschirpke36 @Thomas Braun last edited by
              Hier kann ich alles befehler ausführen nur nicht das das update 20 da sagt der ich soll einen standart User nehmen nicht user
                @tschirpke36
                Jag den
                iob fix
                über das System. Der hat die notwendigen Befehle an Bord.
                  hat leider nichts gebracht
                    Tschirpke36 @Tschirpke36 last edited by
                    bekomme auch jedesmal diese Update Meldung wo kann oder wie kann ich das ausführen?
                      @tschirpke36
                      Aktuellen Docker ausrollen.
                      Das sind halt die Nachteile, wenn das kein vollständiges System ist sondern nur die Tupperdose 'Dockercontainer' drübergestülpt wird.
                        also werde ich den IoBroker neu aufsetzten müssen ?
                        Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                          @tschirpke36
                          Zu Dockern will ich nix sagen oder raten.
                          • Codierknecht
                            @tschirpke36 sagte in npm error code ENOTEMPTY:
                            Ist ja keine Rocket-Science.
                            Du hast ein externes Verzeichnis nach /opt/iobroker gemountet?
                            Dann sind ja alle Daten vorhanden und das Ganze beschränkt sich auf:
                            • Container stoppen und löschen
                            • Aktuelles Image ziehen
                            • Neuen Container mit identischen Einstellungen erzeugen und starten
                            • warten, warten, voilá
                              Tschirpke36 @Codierknecht last edited by
                              Werde neu komplett machen IOBroker bekommt seinen eigen Pi5 auf M.2 NVMe
                              Hardware ist bestellt und dann die Tage alles neu einrichten.
                              Vielen dank allen nochmal für die Hilfe,.
                              858
